[GRASS-SVN] r48011 - grass/trunk/vector/v.out.ogr
svn_grass at osgeo.org
Wed Aug 31 18:41:31 EDT 2011
Author: martinl
Date: 2011-08-31 15:41:31 -0700 (Wed, 31 Aug 2011)
New Revision: 48011
grass/trunk/vector/v.out.ogr/args.c
v.out.ogr: rename guisection - Input -> Selection
Modified: grass/trunk/vector/v.out.ogr/args.c
--- grass/trunk/vector/v.out.ogr/args.c 2011-08-31 19:43:33 UTC (rev 48010)
+++ grass/trunk/vector/v.out.ogr/args.c 2011-08-31 22:41:31 UTC (rev 48011)
@@ -16,10 +16,10 @@
options->type->description =
_("Combination of types is not supported "
"by all output formats. Default is to use first type found in input vector map.");
- options->type->guisection = _("Input");
+ options->type->guisection = _("Selection");
options->field = G_define_standard_option(G_OPT_V_FIELD);
- options->field->guisection = _("Input");
+ options->field->guisection = _("Selection");
options->dsn = G_define_option();
options->dsn->key = "dsn";
@@ -86,7 +86,7 @@
flags->cat->description =
_("Also export features without category (not labeled). "
"Otherwise only features with category are exported.");
- flags->cat->guisection = _("Input");
+ flags->cat->guisection = _("Selection");
flags->esristyle = G_define_flag();
flags->esristyle->key = 'e';
