[GRASS-SVN] r49463 - in grass/trunk/gui/wxpython: . gmodeler
svn_grass at osgeo.org
Thu Dec 1 14:05:52 EST 2011
Author: martinl
Date: 2011-12-01 11:05:52 -0800 (Thu, 01 Dec 2011)
New Revision: 49463
Removed:
grass/trunk/gui/wxpython/gmodeler/model_file.py
grass/trunk/gui/wxpython/gmodeler/model.py
grass/trunk/gui/wxpython/wxpythonlib.dox
wxGUI:gmodeler: merge `model_file` and `model` modules
Modified: grass/trunk/gui/wxpython/gmodeler/model.py
--- grass/trunk/gui/wxpython/gmodeler/model.py 2011-12-01 18:31:11 UTC (rev 49462)
+++ grass/trunk/gui/wxpython/gmodeler/model.py 2011-12-01 19:05:52 UTC (rev 49463)
@@ -1,7 +1,7 @@
@package gmodeler.model
- at brief wxGUI Graphical Modeler (base classes)
+ at brief wxGUI Graphical Modeler (base classes & read/write)
Classes:
- model::Model
@@ -12,6 +12,9 @@
- model::ModelItem
- model::ModelLoop
- model::ModelCondition
+ - model::ProcessModelFile
+ - model::WriteModelFile
+ - model::WritePythonFile
(C) 2010-2011 by the GRASS Development Team
@@ -26,6 +29,7 @@
import copy
import re
import mimetypes
+import time
try:
import xml.etree.ElementTree as etree
except ImportError:
@@ -35,9 +39,8 @@
from wx.lib import ogl
from core.globalvar import ETCWXDIR
-from core.gcmd import GMessage, GException, GError, RunCommand
+from core.gcmd import GMessage, GException, GError, RunCommand, EncodeString, GWarning
from gmodeler.dialogs import ModelParamDialog
-from gmodeler.model_file import ProcessModelFile
from core.utils import CmdToTuple
from core.settings import UserSettings
from gui_core.forms import GUI
@@ -1459,3 +1462,675 @@
if branch in ['if', 'else']:
self.items[branch] = items
+class ProcessModelFile:
+ """!Process GRASS model file (gxm)"""
+ def __init__(self, tree):
+ """!A ElementTree handler for the GXM XML file, as defined in
+ grass-gxm.dtd.
+ self.tree = tree
+ self.root = self.tree.getroot()
+ # list of actions, data
+ self.properties = dict()
+ self.variables = dict()
+ self.actions = list()
+ self.data = list()
+ self.loops = list()
+ self.conditions = list()
+ self._processWindow()
+ self._processProperties()
+ self._processVariables()
+ self._processItems()
+ self._processData()
+ def _filterValue(self, value):
+ """!Filter value
+ @param value
+ value = value.replace('<', '<')
+ value = value.replace('>', '>')
+ return value
+ def _getNodeText(self, node, tag, default = ''):
+ """!Get node text"""
+ p = node.find(tag)
+ if p is not None:
+ if p.text:
+ return utils.normalize_whitespace(p.text)
+ else:
+ return ''
+ return default
+ def _processWindow(self):
+ """!Process window properties"""
+ node = self.root.find('window')
+ if node is None:
+ self.pos = self.size = None
+ return
+ self.pos, self.size = self._getDim(node)
+ def _processProperties(self):
+ """!Process model properties"""
+ node = self.root.find('properties')
+ if node is None:
+ return
+ for key in ('name', 'description', 'author'):
+ self._processProperty(node, key)
+ for f in node.findall('flag'):
+ name = f.get('name', '')
+ if name == 'overwrite':
+ self.properties['overwrite'] = True
+ def _processProperty(self, pnode, name):
+ """!Process given property"""
+ node = pnode.find(name)
+ if node is not None:
+ self.properties[name] = node.text
+ else:
+ self.properties[name] = ''
+ def _processVariables(self):
+ """!Process model variables"""
+ vnode = self.root.find('variables')
+ if vnode is None:
+ return
+ for node in vnode.findall('variable'):
+ name = node.get('name', '')
+ if not name:
+ continue # should not happen
+ self.variables[name] = { 'type' : node.get('type', 'string') }
+ for key in ('description', 'value'):
+ self._processVariable(node, name, key)
+ def _processVariable(self, pnode, name, key):
+ """!Process given variable"""
+ node = pnode.find(key)
+ if node.text:
+ self.variables[name][key] = node.text
+ def _processItems(self):
+ """!Process model items (actions, loops, conditions)"""
+ self._processActions()
+ self._processLoops()
+ self._processConditions()
+ def _processActions(self):
+ """!Process model file"""
+ for action in self.root.findall('action'):
+ pos, size = self._getDim(action)
+ disabled = False
+ task = action.find('task')
+ if task is not None:
+ if task.find('disabled') is not None:
+ disabled = True
+ task = self._processTask(task)
+ else:
+ task = None
+ aId = int(action.get('id', -1))
+ self.actions.append({ 'pos' : pos,
+ 'size' : size,
+ 'task' : task,
+ 'id' : aId,
+ 'disabled' : disabled })
+ def _getDim(self, node):
+ """!Get position and size of shape"""
+ pos = size = None
+ posAttr = node.get('pos', None)
+ if posAttr:
+ posVal = map(int, posAttr.split(','))
+ try:
+ pos = (posVal[0], posVal[1])
+ except:
+ pos = None
+ sizeAttr = node.get('size', None)
+ if sizeAttr:
+ sizeVal = map(int, sizeAttr.split(','))
+ try:
+ size = (sizeVal[0], sizeVal[1])
+ except:
+ size = None
+ return pos, size
+ def _processData(self):
+ for data in self.root.findall('data'):
+ pos, size = self._getDim(data)
+ param = data.find('data-parameter')
+ prompt = value = None
+ if param is not None:
+ prompt = param.get('prompt', None)
+ value = self._filterValue(self._getNodeText(param, 'value'))
+ if data.find('intermediate') is None:
+ intermediate = False
+ else:
+ intermediate = True
+ rels = list()
+ for rel in data.findall('relation'):
+ defrel = { 'id' : int(rel.get('id', -1)),
+ 'dir' : rel.get('dir', 'to'),
+ 'name' : rel.get('name', '') }
+ points = list()
+ for point in rel.findall('point'):
+ x = self._filterValue(self._getNodeText(point, 'x'))
+ y = self._filterValue(self._getNodeText(point, 'y'))
+ points.append((float(x), float(y)))
+ defrel['points'] = points
+ rels.append(defrel)
+ self.data.append({ 'pos' : pos,
+ 'size': size,
+ 'prompt' : prompt,
+ 'value' : value,
+ 'intermediate' : intermediate,
+ 'rels' : rels })
+ def _processTask(self, node):
+ """!Process task
+ @return grassTask instance
+ @return None on error
+ cmd = list()
+ parameterized = list()
+ name = node.get('name', None)
+ if not name:
+ return None
+ cmd.append(name)
+ # flags
+ flag = f.get('name', '')
+ if f.get('parameterized', '0') == '1':
+ parameterized.append(('flag', flag))
+ if f.get('value', '1') == '0':
+ continue
+ if len(flag) > 1:
+ cmd.append('--' + flag)
+ else:
+ cmd.append('-' + flag)
+ # parameters
+ for p in node.findall('parameter'):
+ name = p.get('name', '')
+ if p.find('parameterized') is not None:
+ parameterized.append(('param', name))
+ cmd.append('%s=%s' % (name,
+ self._filterValue(self._getNodeText(p, 'value'))))
+ task, err = GUI(show = None, checkError = True).ParseCommand(cmd = cmd)
+ if err:
+ GWarning(os.linesep.join(err))
+ for opt, name in parameterized:
+ if opt == 'flag':
+ task.set_flag(name, True, element = 'parameterized')
+ else:
+ task.set_param(name, True, element = 'parameterized')
+ return task
+ def _processLoops(self):
+ """!Process model loops"""
+ for node in self.root.findall('loop'):
+ pos, size = self._getDim(node)
+ text = self._filterValue(self._getNodeText(node, 'condition')).strip()
+ aid = list()
+ for anode in node.findall('item'):
+ try:
+ aid.append(int(anode.text))
+ except ValueError:
+ pass
+ self.loops.append({ 'pos' : pos,
+ 'size' : size,
+ 'text' : text,
+ 'id' : int(node.get('id', -1)),
+ 'items' : aid })
+ def _processConditions(self):
+ """!Process model conditions"""
+ for node in self.root.findall('if-else'):
+ aid = { 'if' : list(),
+ 'else' : list() }
+ for b in aid.keys():
+ bnode = node.find(b)
+ if bnode is None:
+ continue
+ for anode in bnode.findall('item'):
+ try:
+ aid[b].append(int(anode.text))
+ pass
+ self.conditions.append({ 'pos' : pos,
+ 'size' : size,
+ 'text' : text,
+ 'items' : aid })
+class WriteModelFile:
+ """!Generic class for writing model file"""
+ def __init__(self, fd, model):
+ self.fd = fd
+ self.model = model
+ self.properties = model.GetProperties()
+ self.variables = model.GetVariables()
+ self.items = model.GetItems()
+ self.indent = 0
+ self._header()
+ self._window()
+ self._properties()
+ self._variables()
+ self._items()
+ dataList = list()
+ for action in model.GetItems(objType = ModelAction):
+ for rel in action.GetRelations():
+ dataItem = rel.GetData()
+ if dataItem not in dataList:
+ dataList.append(dataItem)
+ self._data(dataList)
+ self._footer()
+ """!Make value XML-valid"""
+ return value
+ def _header(self):
+ """!Write header"""
+ self.fd.write('<?xml version="1.0" encoding="UTF-8"?>\n')
+ self.fd.write('<!DOCTYPE gxm SYSTEM "grass-gxm.dtd">\n')
+ self.fd.write('%s<gxm>\n' % (' ' * self.indent))
+ self.indent += 4
+ def _footer(self):
+ """!Write footer"""
+ self.indent -= 4
+ self.fd.write('%s</gxm>\n' % (' ' * self.indent))
+ def _window(self):
+ """!Write window properties"""
+ canvas = self.model.GetCanvas()
+ if canvas is None:
+ return
+ win = canvas.parent
+ pos = win.GetPosition()
+ size = win.GetSize()
+ self.fd.write('%s<window pos="%d,%d" size="%d,%d" />\n' % \
+ (' ' * self.indent, pos[0], pos[1], size[0], size[1]))
+ def _properties(self):
+ """!Write model properties"""
+ self.fd.write('%s<properties>\n' % (' ' * self.indent))
+ self.indent += 4
+ if self.properties['name']:
+ self.fd.write('%s<name>%s</name>\n' % (' ' * self.indent, self.properties['name']))
+ if self.properties['description']:
+ self.fd.write('%s<description>%s</description>\n' % (' ' * self.indent,
+ EncodeString(self.properties['description'])))
+ if self.properties['author']:
+ self.fd.write('%s<author>%s</author>\n' % (' ' * self.indent,
+ EncodeString(self.properties['author'])))
+ if 'overwrite' in self.properties and \
+ self.properties['overwrite']:
+ self.fd.write('%s<flag name="overwrite" />\n' % (' ' * self.indent))
+ self.indent -= 4
+ self.fd.write('%s</properties>\n' % (' ' * self.indent))
+ def _variables(self):
+ """!Write model variables"""
+ if not self.variables:
+ return
+ self.fd.write('%s<variables>\n' % (' ' * self.indent))
+ self.indent += 4
+ for name, values in self.variables.iteritems():
+ self.fd.write('%s<variable name="%s" type="%s">\n' % \
+ (' ' * self.indent, name, values['type']))
+ self.indent += 4
+ if 'value' in values:
+ self.fd.write('%s<value>%s</value>\n' % \
+ (' ' * self.indent, values['value']))
+ if 'description' in values:
+ self.fd.write('%s<description>%s</description>\n' % \
+ (' ' * self.indent, values['description']))
+ self.indent -= 4
+ self.fd.write('%s</variable>\n' % (' ' * self.indent))
+ self.indent -= 4
+ self.fd.write('%s</variables>\n' % (' ' * self.indent))
+ def _items(self):
+ """!Write actions/loops/conditions"""
+ for item in self.items:
+ if isinstance(item, ModelAction):
+ self._action(item)
+ elif isinstance(item, ModelLoop):
+ self._loop(item)
+ elif isinstance(item, ModelCondition):
+ self._condition(item)
+ def _action(self, action):
+ """!Write actions"""
+ self.fd.write('%s<action id="%d" name="%s" pos="%d,%d" size="%d,%d">\n' % \
+ (' ' * self.indent, action.GetId(), action.GetName(), action.GetX(), action.GetY(),
+ action.GetWidth(), action.GetHeight()))
+ self.indent += 4
+ self.fd.write('%s<task name="%s">\n' % (' ' * self.indent, action.GetLog(string = False)[0]))
+ self.indent += 4
+ if not action.IsEnabled():
+ self.fd.write('%s<disabled />\n' % (' ' * self.indent))
+ for key, val in action.GetParams().iteritems():
+ if key == 'flags':
+ for f in val:
+ if f.get('value', False) or f.get('parameterized', False):
+ if f.get('parameterized', False):
+ if f.get('value', False) == False:
+ self.fd.write('%s<flag name="%s" value="0" parameterized="1" />\n' %
+ (' ' * self.indent, f.get('name', '')))
+ else:
+ self.fd.write('%s<flag name="%s" parameterized="1" />\n' %
+ else:
+ self.fd.write('%s<flag name="%s" />\n' %
+ else: # parameter
+ for p in val:
+ if not p.get('value', '') and not p.get('parameterized', False):
+ continue
+ self.fd.write('%s<parameter name="%s">\n' %
+ (' ' * self.indent, p.get('name', '')))
+ self.indent += 4
+ if p.get('parameterized', False):
+ self.fd.write('%s<parameterized />\n' % (' ' * self.indent))
+ (' ' * self.indent, self._filterValue(p.get('value', ''))))
+ self.indent -= 4
+ self.fd.write('%s</parameter>\n' % (' ' * self.indent))
+ self.indent -= 4
+ self.fd.write('%s</task>\n' % (' ' * self.indent))
+ self.indent -= 4
+ self.fd.write('%s</action>\n' % (' ' * self.indent))
+ def _data(self, dataList):
+ """!Write data"""
+ for data in dataList:
+ self.fd.write('%s<data pos="%d,%d" size="%d,%d">\n' % \
+ (' ' * self.indent, data.GetX(), data.GetY(),
+ data.GetWidth(), data.GetHeight()))
+ self.indent += 4
+ self.fd.write('%s<data-parameter prompt="%s">\n' % \
+ (' ' * self.indent, data.GetPrompt()))
+ self.indent += 4
+ (' ' * self.indent, self._filterValue(data.GetValue())))
+ self.indent -= 4
+ self.fd.write('%s</data-parameter>\n' % (' ' * self.indent))
+ if data.IsIntermediate():
+ self.fd.write('%s<intermediate />\n' % (' ' * self.indent))
+ # relations
+ for ft in ('from', 'to'):
+ for rel in data.GetRelations(ft):
+ if ft == 'from':
+ aid = rel.GetTo().GetId()
+ else:
+ aid = rel.GetFrom().GetId()
+ self.fd.write('%s<relation dir="%s" id="%d" name="%s">\n' % \
+ (' ' * self.indent, ft, aid, rel.GetName()))
+ self.indent += 4
+ for point in rel.GetLineControlPoints()[1:-1]:
+ self.fd.write('%s<point>\n' % (' ' * self.indent))
+ self.indent += 4
+ x, y = point.Get()
+ self.fd.write('%s<x>%d</x>\n' % (' ' * self.indent, int(x)))
+ self.fd.write('%s<y>%d</y>\n' % (' ' * self.indent, int(y)))
+ self.indent -= 4
+ self.fd.write('%s</point>\n' % (' ' * self.indent))
+ self.indent -= 4
+ self.fd.write('%s</relation>\n' % (' ' * self.indent))
+ self.indent -= 4
+ self.fd.write('%s</data>\n' % (' ' * self.indent))
+ def _loop(self, loop):
+ """!Write loops"""
+ self.fd.write('%s<loop id="%d" pos="%d,%d" size="%d,%d">\n' % \
+ (' ' * self.indent, loop.GetId(), loop.GetX(), loop.GetY(),
+ loop.GetWidth(), loop.GetHeight()))
+ text = loop.GetText()
+ self.indent += 4
+ if text:
+ self.fd.write('%s<condition>%s</condition>\n' %
+ (' ' * self.indent, self._filterValue(text)))
+ for item in loop.GetItems():
+ self.fd.write('%s<item>%d</item>\n' %
+ (' ' * self.indent, item.GetId()))
+ self.indent -= 4
+ self.fd.write('%s</loop>\n' % (' ' * self.indent))
+ def _condition(self, condition):
+ """!Write conditions"""
+ bbox = condition.GetBoundingBoxMin()
+ self.fd.write('%s<if-else id="%d" pos="%d,%d" size="%d,%d">\n' % \
+ (' ' * self.indent, condition.GetId(), condition.GetX(), condition.GetY(),
+ bbox[0], bbox[1]))
+ text = condition.GetText()
+ self.indent += 4
+ if text:
+ items = condition.GetItems()
+ for b in items.keys():
+ if len(items[b]) < 1:
+ continue
+ self.fd.write('%s<%s>\n' % (' ' * self.indent, b))
+ self.indent += 4
+ for item in items[b]:
+ self.indent -= 4
+ self.fd.write('%s</%s>\n' % (' ' * self.indent, b))
+ self.indent -= 4
+ self.fd.write('%s</if-else>\n' % (' ' * self.indent))
+class WritePythonFile:
+ """!Class for exporting model to Python script
+ @param fd file desciptor
+ self.fd = fd
+ self.indent = 4
+ self._writePython()
+ def _writePython(self):
+ """!Write model to file"""
+ properties = self.model.GetProperties()
+ self.fd.write(
+r"""#!/usr/bin/env python
+# MODULE: %s
+# AUTHOR(S): %s
+# PURPOSE: %s
+# DATE: %s
+""" % (properties['name'],
+ properties['author'],
+ properties['description'],
+ time.asctime()))
+ self.fd.write(
+r"""
+import sys
+import os
+import atexit
+import grass.script as grass
+ # cleanup()
+ rast, vect, rast3d, msg = self.model.GetIntermediateData()
+ self.fd.write(
+r"""
+def cleanup():
+ if rast:
+ self.fd.write(
+r""" grass.run_command('g.remove',
+ rast=%s)
+""" % ','.join(map(lambda x: "'" + x + "'", rast)))
+ if vect:
+ self.fd.write(
+ vect = %s)
+""" % ','.join(map(lambda x: "'" + x + "'", vect)))
+ if rast3d:
+ self.fd.write(
+ rast3d = %s)
+""" % ','.join(map(lambda x: "'" + x + "'", rast3d)))
+ if not rast and not vect and not rast3d:
+ self.fd.write(' pass\n')
+ self.fd.write("\ndef main():\n")
+ for item in self.model.GetItems():
+ self._writePythonItem(item)
+ self.fd.write("\n return 0\n")
+ self.fd.write(
+r"""
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ sys.exit(main())
+ def _writePythonItem(self, item, ignoreBlock = True, variables = []):
+ """!Write model object to Python file"""
+ if ignoreBlock and item.GetBlockId(): # ignore items in loops of conditions
+ return
+ self._writePythonAction(item, variables = variables)
+ elif isinstance(item, ModelLoop) or isinstance(item, ModelCondition):
+ # substitute condition
+ variables = self.model.GetVariables()
+ cond = item.GetText()
+ for variable in variables:
+ pattern = re.compile('%' + variable)
+ if pattern.search(cond):
+ value = variables[variable].get('value', '')
+ if variables[variable].get('type', 'string') == 'string':
+ value = '"' + value + '"'
+ cond = pattern.sub(value, cond)
+ if isinstance(item, ModelLoop):
+ condVar, condText = map(lambda x: x.strip(), re.split('\s*in\s*', cond))
+ cond = "%sfor %s in " % (' ' * self.indent, condVar)
+ if condText[0] == '`' and condText[-1] == '`':
+ task = GUI(show = None).ParseCommand(cmd = utils.split(condText[1:-1]))
+ cond += "grass.read_command("
+ cond += self._getPythonActionCmd(task, len(cond), variables = [condVar]) + ".splitlines()"
+ else:
+ cond += condText
+ self.fd.write('%s:\n' % cond)
+ self.indent += 4
+ for action in item.GetItems():
+ self._writePythonItem(action, ignoreBlock = False, variables = [condVar])
+ self.indent -= 4
+ else: # ModelCondition
+ self.fd.write('%sif %s:\n' % (' ' * self.indent, cond))
+ self.indent += 4
+ condItems = item.GetItems()
+ for action in condItems['if']:
+ self._writePythonItem(action, ignoreBlock = False)
+ if condItems['else']:
+ self.indent -= 4
+ self.fd.write('%selse:\n' % (' ' * self.indent))
+ self.indent += 4
+ for action in condItems['else']:
+ self.indent += 4
+ def _writePythonAction(self, item, variables = []):
+ """!Write model action to Python file"""
+ task = GUI(show = None).ParseCommand(cmd = item.GetLog(string = False))
+ strcmd = "%sgrass.run_command(" % (' ' * self.indent)
+ self.fd.write(strcmd + self._getPythonActionCmd(task, len(strcmd), variables) + '\n')
+ def _getPythonActionCmd(self, task, cmdIndent, variables = []):
+ opts = task.get_options()
+ ret = ''
+ flags = ''
+ params = list()
+ for f in opts['flags']:
+ if f.get('value', False):
+ if len(name) > 1:
+ params.append('%s = True' % name)
+ else:
+ flags += name
+ for p in opts['params']:
+ name = p.get('name', None)
+ value = p.get('value', None)
+ if name and value:
+ ptype = p.get('type', 'string')
+ if value[0] == '%':
+ params.append("%s = %s" % (name, value[1:]))
+ elif ptype == 'string':
+ params.append('%s = "%s"' % (name, value))
+ else:
+ params.append("%s = %s" % (name, value))
+ ret += '"%s"' % task.get_name()
+ if flags:
+ ret += ",\n%sflags = '%s'" % (' ' * cmdIndent, flags)
+ if len(params) > 0:
+ ret += ",\n"
+ for opt in params[:-1]:
+ ret += "%s%s,\n" % (' ' * cmdIndent, opt)
+ ret += "%s%s)" % (' ' * cmdIndent, params[-1])
+ else:
+ ret += ")"
+ return ret
Deleted: grass/trunk/gui/wxpython/gmodeler/model_file.py
--- grass/trunk/gui/wxpython/gmodeler/model_file.py 2011-12-01 18:31:11 UTC (rev 49462)
+++ grass/trunk/gui/wxpython/gmodeler/model_file.py 2011-12-01 19:05:52 UTC (rev 49463)
@@ -1,697 +0,0 @@
- at package gmodeler.model_file
- at brief wxGUI Graphical Modeler - model definition file
-Classes:
- - model_file::ProcessModelFile
- - model_file::WriteModelFile
- - model_file::WritePythonFile
-(C) 2010-2011 by the GRASS Development Team
-This program is free software under the GNU General Public License
-(>=v2). Read the file COPYING that comes with GRASS for details.
- at author Martin Landa <landa.martin gmail.com>
-import os
-import time
-import re
-from core import utils
-from gui_core.forms import GUI
-from core.gcmd import GWarning, EncodeString
-class ProcessModelFile:
- """!Process GRASS model file (gxm)"""
- def __init__(self, tree):
- """!A ElementTree handler for the GXM XML file, as defined in
- grass-gxm.dtd.
- self.tree = tree
- self.root = self.tree.getroot()
- # list of actions, data
- self.properties = dict()
- self.variables = dict()
- self.actions = list()
- self.data = list()
- self.loops = list()
- self.conditions = list()
- self._processWindow()
- self._processProperties()
- self._processVariables()
- self._processItems()
- self._processData()
- def _filterValue(self, value):
- """!Filter value
- @param value
- value = value.replace('<', '<')
- value = value.replace('>', '>')
- return value
- def _getNodeText(self, node, tag, default = ''):
- """!Get node text"""
- p = node.find(tag)
- if p is not None:
- if p.text:
- return utils.normalize_whitespace(p.text)
- else:
- return ''
- return default
- def _processWindow(self):
- """!Process window properties"""
- node = self.root.find('window')
- if node is None:
- self.pos = self.size = None
- return
- self.pos, self.size = self._getDim(node)
- def _processProperties(self):
- """!Process model properties"""
- node = self.root.find('properties')
- if node is None:
- return
- for key in ('name', 'description', 'author'):
- self._processProperty(node, key)
- for f in node.findall('flag'):
- name = f.get('name', '')
- if name == 'overwrite':
- self.properties['overwrite'] = True
- def _processProperty(self, pnode, name):
- """!Process given property"""
- node = pnode.find(name)
- if node is not None:
- self.properties[name] = node.text
- else:
- self.properties[name] = ''
- def _processVariables(self):
- """!Process model variables"""
- vnode = self.root.find('variables')
- if vnode is None:
- return
- for node in vnode.findall('variable'):
- name = node.get('name', '')
- if not name:
- continue # should not happen
- self.variables[name] = { 'type' : node.get('type', 'string') }
- for key in ('description', 'value'):
- self._processVariable(node, name, key)
- def _processVariable(self, pnode, name, key):
- """!Process given variable"""
- node = pnode.find(key)
- if node.text:
- self.variables[name][key] = node.text
- def _processItems(self):
- """!Process model items (actions, loops, conditions)"""
- self._processActions()
- self._processLoops()
- self._processConditions()
- def _processActions(self):
- """!Process model file"""
- for action in self.root.findall('action'):
- pos, size = self._getDim(action)
- disabled = False
- task = action.find('task')
- if task is not None:
- if task.find('disabled') is not None:
- disabled = True
- task = self._processTask(task)
- else:
- task = None
- aId = int(action.get('id', -1))
- self.actions.append({ 'pos' : pos,
- 'size' : size,
- 'task' : task,
- 'id' : aId,
- 'disabled' : disabled })
- def _getDim(self, node):
- """!Get position and size of shape"""
- pos = size = None
- posAttr = node.get('pos', None)
- if posAttr:
- posVal = map(int, posAttr.split(','))
- try:
- pos = (posVal[0], posVal[1])
- except:
- pos = None
- sizeAttr = node.get('size', None)
- if sizeAttr:
- sizeVal = map(int, sizeAttr.split(','))
- try:
- size = (sizeVal[0], sizeVal[1])
- except:
- size = None
- return pos, size
- def _processData(self):
- for data in self.root.findall('data'):
- pos, size = self._getDim(data)
- param = data.find('data-parameter')
- prompt = value = None
- if param is not None:
- prompt = param.get('prompt', None)
- value = self._filterValue(self._getNodeText(param, 'value'))
- if data.find('intermediate') is None:
- intermediate = False
- else:
- intermediate = True
- rels = list()
- for rel in data.findall('relation'):
- defrel = { 'id' : int(rel.get('id', -1)),
- 'dir' : rel.get('dir', 'to'),
- 'name' : rel.get('name', '') }
- points = list()
- for point in rel.findall('point'):
- x = self._filterValue(self._getNodeText(point, 'x'))
- y = self._filterValue(self._getNodeText(point, 'y'))
- points.append((float(x), float(y)))
- defrel['points'] = points
- rels.append(defrel)
- self.data.append({ 'pos' : pos,
- 'size': size,
- 'prompt' : prompt,
- 'value' : value,
- 'intermediate' : intermediate,
- 'rels' : rels })
- def _processTask(self, node):
- """!Process task
- @return grassTask instance
- @return None on error
- cmd = list()
- parameterized = list()
- name = node.get('name', None)
- if not name:
- return None
- cmd.append(name)
- # flags
- flag = f.get('name', '')
- if f.get('parameterized', '0') == '1':
- parameterized.append(('flag', flag))
- if f.get('value', '1') == '0':
- continue
- if len(flag) > 1:
- cmd.append('--' + flag)
- else:
- cmd.append('-' + flag)
- # parameters
- for p in node.findall('parameter'):
- name = p.get('name', '')
- if p.find('parameterized') is not None:
- parameterized.append(('param', name))
- cmd.append('%s=%s' % (name,
- self._filterValue(self._getNodeText(p, 'value'))))
- task, err = GUI(show = None, checkError = True).ParseCommand(cmd = cmd)
- if err:
- GWarning(os.linesep.join(err))
- for opt, name in parameterized:
- if opt == 'flag':
- task.set_flag(name, True, element = 'parameterized')
- else:
- task.set_param(name, True, element = 'parameterized')
- return task
- def _processLoops(self):
- """!Process model loops"""
- for node in self.root.findall('loop'):
- pos, size = self._getDim(node)
- text = self._filterValue(self._getNodeText(node, 'condition')).strip()
- aid = list()
- for anode in node.findall('item'):
- try:
- aid.append(int(anode.text))
- except ValueError:
- pass
- self.loops.append({ 'pos' : pos,
- 'size' : size,
- 'text' : text,
- 'id' : int(node.get('id', -1)),
- 'items' : aid })
- def _processConditions(self):
- """!Process model conditions"""
- for node in self.root.findall('if-else'):
- aid = { 'if' : list(),
- 'else' : list() }
- for b in aid.keys():
- bnode = node.find(b)
- if bnode is None:
- continue
- for anode in bnode.findall('item'):
- try:
- aid[b].append(int(anode.text))
- pass
- self.conditions.append({ 'pos' : pos,
- 'size' : size,
- 'text' : text,
- 'items' : aid })
-class WriteModelFile:
- """!Generic class for writing model file"""
- def __init__(self, fd, model):
- self.fd = fd
- self.model = model
- self.properties = model.GetProperties()
- self.variables = model.GetVariables()
- self.items = model.GetItems()
- self.indent = 0
- self._header()
- self._window()
- self._properties()
- self._variables()
- self._items()
- dataList = list()
- for action in model.GetItems(objType = ModelAction):
- for rel in action.GetRelations():
- dataItem = rel.GetData()
- if dataItem not in dataList:
- dataList.append(dataItem)
- self._data(dataList)
- self._footer()
- """!Make value XML-valid"""
- return value
- def _header(self):
- """!Write header"""
- self.fd.write('<?xml version="1.0" encoding="UTF-8"?>\n')
- self.fd.write('<!DOCTYPE gxm SYSTEM "grass-gxm.dtd">\n')
- self.fd.write('%s<gxm>\n' % (' ' * self.indent))
- self.indent += 4
- def _footer(self):
- """!Write footer"""
- self.indent -= 4
- self.fd.write('%s</gxm>\n' % (' ' * self.indent))
- def _window(self):
- """!Write window properties"""
- canvas = self.model.GetCanvas()
- if canvas is None:
- return
- win = canvas.parent
- pos = win.GetPosition()
- size = win.GetSize()
- self.fd.write('%s<window pos="%d,%d" size="%d,%d" />\n' % \
- (' ' * self.indent, pos[0], pos[1], size[0], size[1]))
- def _properties(self):
- """!Write model properties"""
- self.fd.write('%s<properties>\n' % (' ' * self.indent))
- self.indent += 4
- if self.properties['name']:
- self.fd.write('%s<name>%s</name>\n' % (' ' * self.indent, self.properties['name']))
- if self.properties['description']:
- self.fd.write('%s<description>%s</description>\n' % (' ' * self.indent,
- EncodeString(self.properties['description'])))
- if self.properties['author']:
- self.fd.write('%s<author>%s</author>\n' % (' ' * self.indent,
- EncodeString(self.properties['author'])))
- if 'overwrite' in self.properties and \
- self.properties['overwrite']:
- self.fd.write('%s<flag name="overwrite" />\n' % (' ' * self.indent))
- self.indent -= 4
- self.fd.write('%s</properties>\n' % (' ' * self.indent))
- def _variables(self):
- """!Write model variables"""
- if not self.variables:
- return
- self.fd.write('%s<variables>\n' % (' ' * self.indent))
- self.indent += 4
- for name, values in self.variables.iteritems():
- self.fd.write('%s<variable name="%s" type="%s">\n' % \
- (' ' * self.indent, name, values['type']))
- self.indent += 4
- if 'value' in values:
- self.fd.write('%s<value>%s</value>\n' % \
- (' ' * self.indent, values['value']))
- if 'description' in values:
- self.fd.write('%s<description>%s</description>\n' % \
- (' ' * self.indent, values['description']))
- self.indent -= 4
- self.fd.write('%s</variable>\n' % (' ' * self.indent))
- self.indent -= 4
- self.fd.write('%s</variables>\n' % (' ' * self.indent))
- def _items(self):
- """!Write actions/loops/conditions"""
- for item in self.items:
- if isinstance(item, ModelAction):
- self._action(item)
- elif isinstance(item, ModelLoop):
- self._loop(item)
- elif isinstance(item, ModelCondition):
- self._condition(item)
- def _action(self, action):
- """!Write actions"""
- self.fd.write('%s<action id="%d" name="%s" pos="%d,%d" size="%d,%d">\n' % \
- (' ' * self.indent, action.GetId(), action.GetName(), action.GetX(), action.GetY(),
- action.GetWidth(), action.GetHeight()))
- self.indent += 4
- self.fd.write('%s<task name="%s">\n' % (' ' * self.indent, action.GetLog(string = False)[0]))
- self.indent += 4
- if not action.IsEnabled():
- self.fd.write('%s<disabled />\n' % (' ' * self.indent))
- for key, val in action.GetParams().iteritems():
- if key == 'flags':
- for f in val:
- if f.get('value', False) or f.get('parameterized', False):
- if f.get('parameterized', False):
- if f.get('value', False) == False:
- self.fd.write('%s<flag name="%s" value="0" parameterized="1" />\n' %
- (' ' * self.indent, f.get('name', '')))
- else:
- self.fd.write('%s<flag name="%s" parameterized="1" />\n' %
- else:
- self.fd.write('%s<flag name="%s" />\n' %
- else: # parameter
- for p in val:
- if not p.get('value', '') and not p.get('parameterized', False):
- continue
- self.fd.write('%s<parameter name="%s">\n' %
- (' ' * self.indent, p.get('name', '')))
- self.indent += 4
- if p.get('parameterized', False):
- self.fd.write('%s<parameterized />\n' % (' ' * self.indent))
- (' ' * self.indent, self._filterValue(p.get('value', ''))))
- self.indent -= 4
- self.fd.write('%s</parameter>\n' % (' ' * self.indent))
- self.indent -= 4
- self.fd.write('%s</task>\n' % (' ' * self.indent))
- self.indent -= 4
- self.fd.write('%s</action>\n' % (' ' * self.indent))
- def _data(self, dataList):
- """!Write data"""
- for data in dataList:
- self.fd.write('%s<data pos="%d,%d" size="%d,%d">\n' % \
- (' ' * self.indent, data.GetX(), data.GetY(),
- data.GetWidth(), data.GetHeight()))
- self.indent += 4
- self.fd.write('%s<data-parameter prompt="%s">\n' % \
- (' ' * self.indent, data.GetPrompt()))
- self.indent += 4
- (' ' * self.indent, self._filterValue(data.GetValue())))
- self.indent -= 4
- self.fd.write('%s</data-parameter>\n' % (' ' * self.indent))
- if data.IsIntermediate():
- self.fd.write('%s<intermediate />\n' % (' ' * self.indent))
- # relations
- for ft in ('from', 'to'):
- for rel in data.GetRelations(ft):
- if ft == 'from':
- aid = rel.GetTo().GetId()
- else:
- aid = rel.GetFrom().GetId()
- self.fd.write('%s<relation dir="%s" id="%d" name="%s">\n' % \
- (' ' * self.indent, ft, aid, rel.GetName()))
- self.indent += 4
- for point in rel.GetLineControlPoints()[1:-1]:
- self.fd.write('%s<point>\n' % (' ' * self.indent))
- self.indent += 4
- x, y = point.Get()
- self.fd.write('%s<x>%d</x>\n' % (' ' * self.indent, int(x)))
- self.fd.write('%s<y>%d</y>\n' % (' ' * self.indent, int(y)))
- self.indent -= 4
- self.fd.write('%s</point>\n' % (' ' * self.indent))
- self.indent -= 4
- self.fd.write('%s</relation>\n' % (' ' * self.indent))
- self.indent -= 4
- self.fd.write('%s</data>\n' % (' ' * self.indent))
- def _loop(self, loop):
- """!Write loops"""
- self.fd.write('%s<loop id="%d" pos="%d,%d" size="%d,%d">\n' % \
- (' ' * self.indent, loop.GetId(), loop.GetX(), loop.GetY(),
- loop.GetWidth(), loop.GetHeight()))
- text = loop.GetText()
- self.indent += 4
- if text:
- self.fd.write('%s<condition>%s</condition>\n' %
- (' ' * self.indent, self._filterValue(text)))
- for item in loop.GetItems():
- self.fd.write('%s<item>%d</item>\n' %
- (' ' * self.indent, item.GetId()))
- self.indent -= 4
- self.fd.write('%s</loop>\n' % (' ' * self.indent))
- def _condition(self, condition):
- """!Write conditions"""
- bbox = condition.GetBoundingBoxMin()
- self.fd.write('%s<if-else id="%d" pos="%d,%d" size="%d,%d">\n' % \
- (' ' * self.indent, condition.GetId(), condition.GetX(), condition.GetY(),
- bbox[0], bbox[1]))
- text = condition.GetText()
- self.indent += 4
- if text:
- items = condition.GetItems()
- for b in items.keys():
- if len(items[b]) < 1:
- continue
- self.fd.write('%s<%s>\n' % (' ' * self.indent, b))
- self.indent += 4
- for item in items[b]:
- self.indent -= 4
- self.fd.write('%s</%s>\n' % (' ' * self.indent, b))
- self.indent -= 4
- self.fd.write('%s</if-else>\n' % (' ' * self.indent))
-class WritePythonFile:
- """!Class for exporting model to Python script
- @param fd file desciptor
- self.fd = fd
- self.indent = 4
- self._writePython()
- def _writePython(self):
- """!Write model to file"""
- properties = self.model.GetProperties()
- self.fd.write(
-r"""#!/usr/bin/env python
-# MODULE: %s
-# AUTHOR(S): %s
-# PURPOSE: %s
-# DATE: %s
-""" % (properties['name'],
- properties['author'],
- properties['description'],
- time.asctime()))
- self.fd.write(
-r"""
-import sys
-import os
-import atexit
-import grass.script as grass
- # cleanup()
- rast, vect, rast3d, msg = self.model.GetIntermediateData()
- self.fd.write(
-r"""
-def cleanup():
- if rast:
- self.fd.write(
-r""" grass.run_command('g.remove',
- rast=%s)
-""" % ','.join(map(lambda x: "'" + x + "'", rast)))
- if vect:
- self.fd.write(
- vect = %s)
-""" % ','.join(map(lambda x: "'" + x + "'", vect)))
- if rast3d:
- self.fd.write(
- rast3d = %s)
-""" % ','.join(map(lambda x: "'" + x + "'", rast3d)))
- if not rast and not vect and not rast3d:
- self.fd.write(' pass\n')
- self.fd.write("\ndef main():\n")
- for item in self.model.GetItems():
- self._writePythonItem(item)
- self.fd.write("\n return 0\n")
- self.fd.write(
-r"""
-if __name__ == "__main__":
- options, flags = grass.parser()
- atexit.register(cleanup)
- sys.exit(main())
- def _writePythonItem(self, item, ignoreBlock = True, variables = []):
- """!Write model object to Python file"""
- if ignoreBlock and item.GetBlockId(): # ignore items in loops of conditions
- return
- self._writePythonAction(item, variables = variables)
- elif isinstance(item, ModelLoop) or isinstance(item, ModelCondition):
- # substitute condition
- variables = self.model.GetVariables()
- cond = item.GetText()
- for variable in variables:
- pattern = re.compile('%' + variable)
- if pattern.search(cond):
- value = variables[variable].get('value', '')
- if variables[variable].get('type', 'string') == 'string':
- value = '"' + value + '"'
- cond = pattern.sub(value, cond)
- if isinstance(item, ModelLoop):
- condVar, condText = map(lambda x: x.strip(), re.split('\s*in\s*', cond))
- cond = "%sfor %s in " % (' ' * self.indent, condVar)
- if condText[0] == '`' and condText[-1] == '`':
- task = GUI(show = None).ParseCommand(cmd = utils.split(condText[1:-1]))
- cond += "grass.read_command("
- cond += self._getPythonActionCmd(task, len(cond), variables = [condVar]) + ".splitlines()"
- else:
- cond += condText
- self.fd.write('%s:\n' % cond)
- self.indent += 4
- for action in item.GetItems():
- self._writePythonItem(action, ignoreBlock = False, variables = [condVar])
- self.indent -= 4
- else: # ModelCondition
- self.fd.write('%sif %s:\n' % (' ' * self.indent, cond))
- self.indent += 4
- condItems = item.GetItems()
- for action in condItems['if']:
- self._writePythonItem(action, ignoreBlock = False)
- if condItems['else']:
- self.indent -= 4
- self.fd.write('%selse:\n' % (' ' * self.indent))
- self.indent += 4
- for action in condItems['else']:
- self.indent += 4
- def _writePythonAction(self, item, variables = []):
- """!Write model action to Python file"""
- task = GUI(show = None).ParseCommand(cmd = item.GetLog(string = False))
- strcmd = "%sgrass.run_command(" % (' ' * self.indent)
- self.fd.write(strcmd + self._getPythonActionCmd(task, len(strcmd), variables) + '\n')
- def _getPythonActionCmd(self, task, cmdIndent, variables = []):
- opts = task.get_options()
- ret = ''
- flags = ''
- params = list()
- for f in opts['flags']:
- if f.get('value', False):
- if len(name) > 1:
- params.append('%s = True' % name)
- else:
- flags += name
- for p in opts['params']:
- name = p.get('name', None)
- value = p.get('value', None)
- if name and value:
- ptype = p.get('type', 'string')
- if value[0] == '%':
- params.append("%s = %s" % (name, value[1:]))
- elif ptype == 'string':
- params.append('%s = "%s"' % (name, value))
- else:
- params.append("%s = %s" % (name, value))
- ret += '"%s"' % task.get_name()
- if flags:
- ret += ",\n%sflags = '%s'" % (' ' * cmdIndent, flags)
- if len(params) > 0:
- ret += ",\n"
- for opt in params[:-1]:
- ret += "%s%s,\n" % (' ' * cmdIndent, opt)
- ret += "%s%s)" % (' ' * cmdIndent, params[-1])
- else:
- ret += ")"
- return ret
Modified: grass/trunk/gui/wxpython/wxpythonlib.dox
--- grass/trunk/gui/wxpython/wxpythonlib.dox 2011-12-01 18:31:11 UTC (rev 49462)
+++ grass/trunk/gui/wxpython/wxpythonlib.dox 2011-12-01 19:05:52 UTC (rev 49463)
@@ -286,10 +286,6 @@
- frame::ItemCheckListCtrl
- gmodeler::menudata
- menudata::ModelerData
-- gmodeler::model_file
- gmodeler::model
- model::Model
- model::ModelObject
@@ -299,6 +295,9 @@
- model::ModelItem
- model::ModelLoop
- gmodeler::preferences
- preferences::PreferencesDialog
- preferences::PropertiesDialog
