[GRASS-SVN] r49475 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Thu Dec 1 18:19:11 EST 2011
Author: martinl
Date: 2011-12-01 15:19:10 -0800 (Thu, 01 Dec 2011)
New Revision: 49475
grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
wxGUI: simplify PropertiesDialog()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2011-12-01 23:11:36 UTC (rev 49474)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py 2011-12-01 23:19:10 UTC (rev 49475)
@@ -544,8 +544,7 @@
def OnUnivariateStats(self, event):
"""!Univariate raster statistics"""
name = self.GetPyData(self.layer_selected)[0]['maplayer'].GetName()
- menuform.GUI(parent = self).ParseCommand(['r.univar',
- 'map=%s' % name])
+ self.lmgr.goutput.RunCmd(['r.univar', 'map=%s' % name], switchPage = True)
def OnStartEditing(self, event):
"""!Start editing vector map layer requested by the user
@@ -881,7 +880,7 @@
return layer
- def PropertiesDialog (self, layer, show = True):
+ def PropertiesDialog(self, layer, show = True):
"""!Launch the properties dialog"""
if 'propwin' in self.GetPyData(layer)[0] and \
self.GetPyData(layer)[0]['propwin'] is not None:
@@ -902,7 +901,8 @@
Debug.msg (3, "LayerTree.PropertiesDialog(): ltype=%s" % \
ltype)
+ cmd = None
if self.GetPyData(layer)[0]['cmd']:
module = menuform.GUI(parent = self, show = show, centreOnParent = False)
module.ParseCommand(self.GetPyData(layer)[0]['cmd'],
@@ -911,37 +911,28 @@
self.GetPyData(layer)[0]['cmd'] = module.GetCmd()
elif ltype == 'raster':
cmd = ['d.rast']
if UserSettings.Get(group='cmd', key='rasterOverlay', subkey='enabled'):
cmd.append('-o')
- menuform.GUI(parent = self, centreOnParent = False).ParseCommand(cmd,
- completed = (self.GetOptData,layer,params))
elif ltype == '3d-raster':
cmd = ['d.rast3d']
elif ltype == 'rgb':
- menuform.GUI(parent = self, centreOnParent = False).ParseCommand(['d.rgb'],
+ cmd = ['d.rgb']
+ if UserSettings.Get(group='cmd', key='rasterOverlay', subkey='enabled'):
+ cmd.append('-o')
elif ltype == 'his':
- menuform.GUI(parent = self, centreOnParent = False).ParseCommand(['d.his'],
+ cmd = ['d.his']
elif ltype == 'shaded':
- menuform.GUI(parent = self, centreOnParent = False).ParseCommand(['d.shadedmap'],
+ cmd = ['d.shadedmap']
elif ltype == 'rastarrow':
- menuform.GUI(parent = self, centreOnParent = False).ParseCommand(['d.rast.arrow'],
+ cmd = ['d.rast.arrow']
elif ltype == 'rastnum':
- menuform.GUI(parent = self, centreOnParent = False).ParseCommand(['d.rast.num'],
+ cmd = ['d.rast.num']
elif ltype == 'vector':
types = list()
@@ -949,39 +940,31 @@
if UserSettings.Get(group = 'cmd', key = 'showType', subkey = [ftype, 'enabled']):
types.append(ftype)
- menuform.GUI(parent = self, centreOnParent = False).ParseCommand(['d.vect', 'type=%s' % ','.join(types)],
+ cmd = ['d.vect', 'type=%s' % ','.join(types)]
elif ltype == 'thememap':
# -s flag requested, otherwise only first thematic category is displayed
# should be fixed by C-based d.thematic.* modules
- menuform.GUI(parent = self, centreOnParent = False).ParseCommand(['d.vect.thematic', '-s'],
+ cmd = ['d.vect.thematic', '-s']
elif ltype == 'themechart':
- menuform.GUI(parent = self, centreOnParent = False).ParseCommand(['d.vect.chart'],
+ cmd = ['d.vect.chart']
elif ltype == 'grid':
- menuform.GUI(parent = self, centreOnParent = False).ParseCommand(['d.grid'],
+ cmd = ['d.grid']
elif ltype == 'geodesic':
- menuform.GUI(parent = self, centreOnParent = False).ParseCommand(['d.geodesic'],
+ cmd = ['d.geodesic']
elif ltype == 'rhumb':
- menuform.GUI(parent = self, centreOnParent = False).ParseCommand(['d.rhumbline'],
+ cmd = ['d.rhumbline']
elif ltype == 'labels':
- menuform.GUI(parent = self, centreOnParent = False).ParseCommand(['d.labels'],
+ cmd = ['d.labels']
+ if cmd:
+ menuform.GUI(parent = self, centreOnParent = False).ParseCommand(cmd,
- elif ltype == 'cmdlayer':
- pass
- elif ltype == 'group':
- pass
def OnActivateLayer(self, event):
"""!Double click on the layer item.
