[GRASS-SVN] r49488 - grass/trunk/gui/wxpython/modules
svn_grass at osgeo.org
Fri Dec 2 07:33:57 EST 2011
Author: martinl
Date: 2011-12-02 04:33:57 -0800 (Fri, 02 Dec 2011)
New Revision: 49488
grass/trunk/gui/wxpython/modules/vclean.py
wxGUI/v.clean: check input parameters, define OnDone handler
Modified: grass/trunk/gui/wxpython/modules/vclean.py
--- grass/trunk/gui/wxpython/modules/vclean.py 2011-12-02 12:05:18 UTC (rev 49487)
+++ grass/trunk/gui/wxpython/modules/vclean.py 2011-12-02 12:33:57 UTC (rev 49488)
@@ -21,7 +21,7 @@
from grass.script import core as grass
-from core.gcmd import RunCommand
+from core.gcmd import RunCommand, GError
from core import globalvar
from gui_core.gselect import Select
from core.debug import Debug
@@ -444,13 +444,31 @@
else:
self.selected = -1
+ def OnDone(self, cmd, returncode):
+ """!Command done"""
+ self.SetStatusText('')
def OnCleaningRun(self, event):
"""!Builds options and runs v.clean
+ self.GetCmdStrings()
+ err = list()
+ for p, name in ((self.inmap, _('Name of input vector map')),
+ (self.outmap, _('Name for output vector map')),
+ (self.tools_string, _('Tools')),
+ (self.thresh_string, _('Threshold'))):
+ if not p:
+ err.append(_("'%s' not defined") % name)
+ if err:
+ GError(_("Some parameters not defined. Operation "
+ "cancelled.\n\n%s") % '\n'.join(err),
+ parent = self)
+ return
self.SetStatusText(_("Executing selected cleaning operations..."))
snum = len(self.toolslines.keys())
- self.GetCmdStrings()
if self.log:
cmd = [ self.cmd,
'input=%s' % self.inmap,
@@ -462,7 +480,7 @@
if self.overwrite.IsChecked():
cmd.append('--overwrite')
- self.log.RunCmd(cmd)
+ self.log.RunCmd(cmd, onDone = self.OnDone)
self.parent.Raise()
else:
