[GRASS-SVN] r49490 - grass/trunk/mswindows
svn_grass at osgeo.org
Fri Dec 2 11:20:47 EST 2011
Author: martinl
Date: 2011-12-02 08:20:46 -0800 (Fri, 02 Dec 2011)
New Revision: 49490
grass/trunk/mswindows/GRASS-Installer.nsi
winGRASS standalone installer: don't overwrite GISRC if exists
Modified: grass/trunk/mswindows/GRASS-Installer.nsi
--- grass/trunk/mswindows/GRASS-Installer.nsi 2011-12-02 12:41:21 UTC (rev 49489)
+++ grass/trunk/mswindows/GRASS-Installer.nsi 2011-12-02 16:20:46 UTC (rev 49490)
@@ -868,19 +868,23 @@
;replace \ with / in $GIS_DATABASE
${StrReplace} "$UNIX_LIKE_GIS_DATABASE_PATH" "\" "/" "$GIS_DATABASE"
- ;create $APPDATA\GRASS7\rc
- SetShellVarContext current
- ClearErrors
- CreateDirectory $APPDATA\GRASS7
- FileOpen $0 $APPDATA\GRASS7\rc w
- IfErrors done_create_grass7\rc
- FileWrite $0 'GISDBASE: $UNIX_LIKE_GIS_DATABASE_PATH$\r$\n'
- FileWrite $0 'LOCATION_NAME: demolocation$\r$\n'
- FileWrite $0 'MAPSET: PERMANENT$\r$\n'
- FileClose $0
- done_create_grass7\rc:
+ SetShellVarContext current
+ ${If} ${FileExists} "$APPDATA\GRASS7\rc"
+ DetailPrint "File $APPDATA\GRASS7\rc already exists. Skipping."
+ ${Else}
+ ;create $APPDATA\GRASS7\rc
+ ClearErrors
+ CreateDirectory $APPDATA\GRASS7
+ FileOpen $0 $APPDATA\GRASS7\rc w
+ IfErrors done_create_grass7_rc
+ FileWrite $0 'GISDBASE: $UNIX_LIKE_GIS_DATABASE_PATH$\r$\n'
+ FileWrite $0 'LOCATION_NAME: demolocation$\r$\n'
+ FileWrite $0 'MAPSET: PERMANENT$\r$\n'
+ FileClose $0
+ done_create_grass7_rc:
+ ${EndIf}
;replace gisbase = "/c/OSGeo4W/apps/grass/grass-7.0.svn" in grass70.py with $INSTDIR
Push "$INSTDIR\etc\grass70.py" ; file to modify
Push 'gisbase = "/c/OSGeo4W/apps/grass/grass-7.0.svn"' ; string that a line must begin with *WS Sensitive*
@@ -1001,9 +1005,12 @@
;remove the $APPDATA\GRASS7 folder
;disabled, don't remove user settings
- ;SetShellVarContext current
- ;RMDir /r "$APPDATA\GRASS7"
+ ;RMDir /r "$APPDATA\GRASS7"
+ ${If} ${FileExists} "$APPDATA\GRASS7\addons\*.*"
+ RMDir /r "$APPDATA\GRASS7\addons"
+ ${EndIf}
;remove the Registry Entries
DeleteRegKey HKLM "Software\${GRASS_BASE}"
DeleteRegKey HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"
