[GRASS-SVN] r49498 - grass/trunk/raster/r.viewshed
svn_grass at osgeo.org
Fri Dec 2 14:32:02 EST 2011
Author: martinl
Date: 2011-12-02 11:32:02 -0800 (Fri, 02 Dec 2011)
New Revision: 49498
grass/trunk/raster/r.viewshed/main.cpp
r.viewshed: more gui section, cosmetics in description
Modified: grass/trunk/raster/r.viewshed/main.cpp
--- grass/trunk/raster/r.viewshed/main.cpp 2011-12-02 19:10:39 UTC (rev 49497)
+++ grass/trunk/raster/r.viewshed/main.cpp 2011-12-02 19:32:02 UTC (rev 49498)
@@ -115,7 +115,8 @@
G_add_keyword(_("raster"));
G_add_keyword(_("viewshed"));
G_add_keyword(_("line of sight"));
- module->description = _("IO-efficient viewshed algorithm");
+ module->label = _("Computes the viewshed of a point on a raster terrain.");
+ module->description = _("Default format: NULL (invisible), vertical angle wrt viewpoint (visible).");
struct Cell_head region;
@@ -437,17 +438,12 @@
inputOpt = G_define_standard_option(G_OPT_R_ELEV);
inputOpt->key = "input";
- inputOpt->guisection = _("Input_options");
/* the output */
struct Option *outputOpt;
outputOpt = G_define_standard_option(G_OPT_R_OUTPUT);
- outputOpt->label = _("Name of output viewshed raster map");
- outputOpt->description =
- _("default format: {NULL (invisible), vertical angle wrt viewpoint (visible)}");
- outputOpt->guisection = _("Output_options");
/* curvature flag */
struct Flag *curvature;
@@ -463,6 +459,7 @@
refractionFlag->key = 'r';
refractionFlag->description =
_("Consider the effect of atmospheric refraction");
+ refractionFlag->guisection = _("Refraction");
/* boolean output flag */
struct Flag *booleanOutput;
@@ -471,6 +468,7 @@
booleanOutput->key = 'b';
booleanOutput->description =
_("Output format is {0 (invisible) 1 (visible)}");
+ booleanOutput->guisection = _("Output format");
/* output mode = elevation flag */
struct Flag *elevationFlag;
@@ -479,18 +477,16 @@
elevationFlag->key = 'e';
elevationFlag->description =
_("Output format is invisible = NULL, else current elev - viewpoint_elev");
+ elevationFlag->guisection = _("Output format");
/* viewpoint coordinates */
struct Option *viewLocOpt;
- viewLocOpt = G_define_option();
+ viewLocOpt = G_define_standard_option(G_OPT_M_EN);
viewLocOpt->key = "coordinate";
- viewLocOpt->type = TYPE_STRING;
viewLocOpt->required = YES;
- viewLocOpt->key_desc = "east,north";
+ viewLocOpt->multiple = NO;
viewLocOpt->description = _("Coordinates of viewing position");
- viewLocOpt->guisection = _("Input_options");
/* observer elevation */
struct Option *obsElevOpt;
@@ -502,7 +498,7 @@
obsElevOpt->key_desc = "value";
obsElevOpt->description = _("Viewing elevation above the ground");
obsElevOpt->answer = "1.75";
- obsElevOpt->guisection = _("Input_options");
+ obsElevOpt->guisection = _("Settings");
/* target elevation offset */
struct Option *tgtElevOpt;
@@ -514,7 +510,7 @@
tgtElevOpt->key_desc = "value";
tgtElevOpt->description = _("Offset for target elevation above the ground");
tgtElevOpt->answer = "0.0";
- tgtElevOpt->guisection = _("Input_options");
+ tgtElevOpt->guisection = _("Settings");
/* max distance */
struct Option *maxDistOpt;
@@ -530,7 +526,7 @@
sprintf(infdist, "%d", INFINITY_DISTANCE);
maxDistOpt->answer = infdist;
- maxDistOpt->guisection = _("Input_options");
+ maxDistOpt->guisection = _("Settings");
/* atmospheric refraction coeff. 1/7 for visual, 0.325 for radio waves, ... */
/* in future we might calculate this based on the physics, for now we
@@ -558,7 +554,8 @@
refrCoeffOpt->required = NO;
refrCoeffOpt->answer = "0.14286";
refrCoeffOpt->options = "0.0-1.0";
+ refrCoeffOpt->guisection = _("Refraction");
/* memory size */
struct Option *memAmountOpt;
