[GRASS-SVN] r49513 - grass/trunk/lib/gis
Sun Dec 4 01:05:22 EST 2011
Author: hamish
Date: 2011-12-03 22:05:22 -0800 (Sat, 03 Dec 2011)
New Revision: 49513
   grass/trunk/lib/gis/parser_standard_options.c
try to make these option descriptions make more sense
Modified: grass/trunk/lib/gis/parser_standard_options.c
--- grass/trunk/lib/gis/parser_standard_options.c	2011-12-04 06:01:53 UTC (rev 49512)
+++ grass/trunk/lib/gis/parser_standard_options.c	2011-12-04 06:05:22 UTC (rev 49513)
@@ -428,7 +428,7 @@
 	Opt->description =
 	    _("A single vector map can be connected to multiple database "
 	      "tables. This number determines which table to use. "
-/* huh? */    "Layer name for direct OGR access.");
+	      "When used with direct OGR access this is the layer name.");
 	Opt->gisprompt = "old,layer,layer";
 	break;
     case G_OPT_V_FIELD_ALL:
@@ -440,7 +440,7 @@
 	Opt->description =
 	Opt->gisprompt = "old,layer,layer_all";
 	break;
     case G_OPT_V_CAT:
