[GRASS-SVN] r49524 - grass-addons/grass6/vector/v.strahler
svn_grass at osgeo.org
Sun Dec 4 16:16:25 EST 2011
Author: hamish
Date: 2011-12-04 13:16:25 -0800 (Sun, 04 Dec 2011)
New Revision: 49524
grass-addons/grass6/vector/v.strahler/main.c
grass-addons/grass6/vector/v.strahler/strahler.c
minor whitespace
Modified: grass-addons/grass6/vector/v.strahler/main.c
--- grass-addons/grass6/vector/v.strahler/main.c 2011-12-04 21:05:20 UTC (rev 49523)
+++ grass-addons/grass6/vector/v.strahler/main.c 2011-12-04 21:16:25 UTC (rev 49524)
@@ -109,9 +109,7 @@
txout_opt->description =
_("Path to ASCII file where results will be written");
/* option sloppy for bad topology */
sloppy_opt = G_define_option();
sloppy_opt->key = "sloppy";
sloppy_opt->type = TYPE_DOUBLE;
@@ -121,13 +119,13 @@
sloppy_opt->description =
_("Threshold for distance within different nodes are considered the same node - may not work");
field_opt = G_define_standard_option(G_OPT_V_FIELD);
field = atoi(field_opt->answer);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
Vect_check_input_output_name(input->answer, output->answer,
GV_FATAL_EXIT);
Modified: grass-addons/grass6/vector/v.strahler/strahler.c
--- grass-addons/grass6/vector/v.strahler/strahler.c 2011-12-04 21:05:20 UTC (rev 49523)
+++ grass-addons/grass6/vector/v.strahler/strahler.c 2011-12-04 21:16:25 UTC (rev 49524)
@@ -29,7 +29,7 @@
G_debug(1, "Reached StrahFindLeaves with %d trees", ntrees);
G_get_window(&window);
- G_debug(2, "window: N %f S %f W %f E %f\n", window.north, window.south,
+ G_debug(2, "window: N %f S %f W %f E %f", window.north, window.south,
window.west, window.east);
G_debug(2, "%d nodes in map", nnodes);
@@ -66,7 +66,7 @@
0, method);
- G_debug(5, "fdrast=%d node=%d y=%f x=%f z=%f\n", fdrast, node, y,
+ G_debug(5, "fdrast=%d node=%d y=%f x=%f z=%f", fdrast, node, y,
x, z);
tree = dbbuf[aline].bsnid;
@@ -189,8 +189,7 @@
if (norder > 1 || norder == 0) { /* if (norder > 1: node indeterminate OR norder == 0 : subtree finished) */
G_debug(3, "Finished run at line %d because norder=%d",
cline, norder);
- G_debug(4, "visiting unode %d for line %d\n", unode,
- cline);
+ G_debug(4, "visiting unode %d for line %d", unode, cline);
nodev[unode].visited += 1; /* visit unode, for the sake of completeness */
rfinish = 1; /* finish this run */
