[GRASS-SVN] r49533 - grass/branches/develbranch_6/gui/scripts
svn_grass at osgeo.org
Sun Dec 4 19:05:50 EST 2011
Author: hamish
Date: 2011-12-04 16:05:50 -0800 (Sun, 04 Dec 2011)
New Revision: 49533
grass/branches/develbranch_6/gui/scripts/g.extension.py
avoid unnecessary build clutter in private installs (see #1501, sync with r49527);
only create build dirs for option=add
Modified: grass/branches/develbranch_6/gui/scripts/g.extension.py
--- grass/branches/develbranch_6/gui/scripts/g.extension.py 2011-12-04 23:32:53 UTC (rev 49532)
+++ grass/branches/develbranch_6/gui/scripts/g.extension.py 2011-12-05 00:05:50 UTC (rev 49533)
@@ -430,6 +430,7 @@
'GRASS_ADDON_PATH environment variable (see "g.manual variables")'))
def install_extension_other():
+ # todo: rip all this out and replace it with a call to the g.extension shell script.
gisbase = os.getenv('GISBASE')
gui_list = list_wxgui_extensions(print_module = False)
@@ -513,7 +514,41 @@
else:
grass.message(_("Installation of '%s' successfully finished.") % options['extension'])
+ # cleanup build cruft
+ if not flags['s']:
+ # move script/ and bin/ to main dir
+ if os.path.exists(os.path.join(options['prefix'], 'bin', options['extension'])):
+ shutil.move(os.path.join(options['prefix'], 'bin', options['extension']),
+ os.path.join(options['prefix'], options['extension']))
+ if os.path.exists(os.path.join(options['prefix'], 'scripts', options['extension'])):
+ shutil.move(os.path.join(options['prefix'], 'scripts', options['extension']),
+ # if empty, rmdir scripts/ and bin/
+ if os.path.exists(os.path.join(options['prefix'], 'bin')):
+ if os.listdir(os.path.join(options['prefix'], 'bin')) == []:
+ os.removedirs(os.path.join(options['prefix'], 'bin'))
+ if os.path.exists(os.path.join(options['prefix'], 'scripts')):
+ if os.listdir(os.path.join(options['prefix'], 'scripts')) == []:
+ os.removedirs(os.path.join(options['prefix'], 'scripts'))
+ # move man/ into docs/
+ if os.path.exists(os.path.join(options['prefix'], 'man', 'man1', options['extension'] + '.1')):
+ shutil.move(os.path.join(options['prefix'], 'man', 'man1', options['extension'] + '.1'),
+ os.path.join(options['prefix'], 'docs', 'man', 'man1', options['extension'] + '.1'))
+ # if empty, rmdir man/man1
+ if os.path.exists(os.path.join(options['prefix'], 'man', 'man1')):
+ if os.listdir(os.path.join(options['prefix'], 'man', 'man1')) == []:
+ os.removedirs(os.path.join(options['prefix'], 'man', 'man1'))
+ if os.path.exists(os.path.join(options['prefix'], 'man')):
+ if os.listdir(os.path.join(options['prefix'], 'man')) == []:
+ os.removedirs(os.path.join(options['prefix'], 'man'))
def remove_extension():
+ # the following relies on an online file manifest for each module; remove_extension_std() does not.
# try to download XML metadata file first
url = "http://grass.osgeo.org/addons/grass%s.xml" % grass.version()['version'].split('.')[0]
name = options['extension']
@@ -562,16 +597,19 @@
grass.message(_("Extension <%s> successfully uninstalled.") % options['extension'])
def remove_extension_std():
- # is module available?
- if not os.path.exists(os.path.join(options['prefix'], 'bin', options['extension'])):
- grass.fatal(_("Extension <%s> not found") % options['extension'])
- for file in [os.path.join(options['prefix'], 'bin', options['extension']),
+ # is module available? what if the user has leftover cruft to uninstall?
+ #if not os.path.exists(os.path.join(options['prefix'], options['extension'])):
+ # grass.fatal(_("Extension <%s> not found") % options['extension'])
+ for file in [os.path.join(options['prefix'], options['extension']),
+ os.path.join(options['prefix'], 'bin', options['extension']),
- os.path.join(options['prefix'], 'docs', 'html', options['extension'] + '.html')]:
+ os.path.join(options['prefix'], 'docs', 'html', options['extension'] + '.html'),
+ os.path.join(options['prefix'], 'docs', 'man', 'man1', options['extension'] + '.1'),
+ os.path.join(options['prefix'], 'man', 'man1', options['extension'] + '.1')]:
if os.path.isfile(file):
+ #grass.message(_("Removing <%s> ..." % file))
os.remove(file)
def create_dir(path):
if os.path.isdir(path):
return
@@ -585,8 +623,8 @@
def check_style_files(fil):
#check the links to grassdocs.css/grass_logo.png to a correct manual page of addons
- dist_file = os.path.join(os.getenv('GISBASE'),'docs','html',fil)
- addons_file = os.path.join(options['prefix'],'docs','html',fil)
+ dist_file = os.path.join(os.getenv('GISBASE'), 'docs', 'html', fil)
+ addons_file = os.path.join(options['prefix'], 'docs', 'html', fil)
#check if file already exists in the grass addons docs html path
if os.path.isfile(addons_file):
return
@@ -600,11 +638,12 @@
def check_dirs():
create_dir(os.path.join(options['prefix'], 'bin'))
+ create_dir(os.path.join(options['prefix'], 'scripts'))
+ create_dir(os.path.join(options['prefix'], 'man', 'man1'))
+ create_dir(os.path.join(options['prefix'], 'docs', 'man', 'man1'))
create_dir(os.path.join(options['prefix'], 'docs', 'html'))
check_style_files('grass_logo.png')
check_style_files('grassdocs.css')
- create_dir(os.path.join(options['prefix'], 'man', 'man1'))
- create_dir(os.path.join(options['prefix'], 'scripts'))
def main():
# check dependecies
@@ -638,7 +677,8 @@
options['prefix'] = path_list[0]
# check dirs
- check_dirs()
+ if options['operation'] == 'add':
+ check_dirs()
if flags['d']:
if options['operation'] != 'add':
