[GRASS-SVN] r49543 - grass/trunk/vector/v.to.rast
Mon Dec 5 05:06:28 EST 2011
Author: martinl
Date: 2011-12-05 02:06:28 -0800 (Mon, 05 Dec 2011)
New Revision: 49543
   grass/trunk/vector/v.to.rast/support.c
   grass/trunk/vector/v.to.rast/vect2rast.c
v.to.rast: allow `use=cat rgbcolumn=column`
         enable warning when rasterization is done
         (merge r49541 from devbr6)
Modified: grass/trunk/vector/v.to.rast/support.c
--- grass/trunk/vector/v.to.rast/support.c	2011-12-05 10:01:45 UTC (rev 49542)
+++ grass/trunk/vector/v.to.rast/support.c	2011-12-05 10:06:28 UTC (rev 49543)
@@ -132,6 +132,9 @@
 	G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
 		      Fi->database, Fi->driver);
+    if (!attr_column)
+	attr_column = Fi->key;
     /* get number of records in attr_column */
     if ((nrec =
 	 db_select_CatValArray(Driver, Fi->table, Fi->key, attr_column, NULL,
Modified: grass/trunk/vector/v.to.rast/vect2rast.c
--- grass/trunk/vector/v.to.rast/vect2rast.c	2011-12-05 10:01:45 UTC (rev 49542)
+++ grass/trunk/vector/v.to.rast/vect2rast.c	2011-12-05 10:06:28 UTC (rev 49543)
@@ -177,6 +177,7 @@
 	stat = output_raster(fd);
     } while (stat == 0);
+    G_suppress_warnings(0);
     /* stat: 0 == repeat; 1 == done; -1 == error; */
     Vect_destroy_line_struct(Points);
@@ -195,13 +196,14 @@
     /* colors */
     if (rgbcolumn) {
-	if (use != USE_ATTR) {
+	if (use != USE_ATTR && use != USE_CAT) {
 	    G_warning(_("Color can be updated from database only if use=attr"));
 	    update_colors(raster_map);
-	update_dbcolors(raster_map, vector_map, field, rgbcolumn, is_fp,
-			column);
+	else {
+	  update_dbcolors(raster_map, vector_map, field, rgbcolumn, is_fp,
+			  column);
     else if (use == USE_D)
 	update_fcolors(raster_map);
