[GRASS-SVN] r49551 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Mon Dec 5 10:51:57 EST 2011
Author: mmetz
Date: 2011-12-05 07:51:57 -0800 (Mon, 05 Dec 2011)
New Revision: 49551
grass/trunk/lib/vector/Vlib/break_lines.c
grass/trunk/lib/vector/Vlib/build.c
add new fns for topology check
Modified: grass/trunk/lib/vector/Vlib/break_lines.c
--- grass/trunk/lib/vector/Vlib/break_lines.c 2011-12-05 15:51:09 UTC (rev 49550)
+++ grass/trunk/lib/vector/Vlib/break_lines.c 2011-12-05 15:51:57 UTC (rev 49551)
@@ -17,6 +17,10 @@
#include <grass/vector.h>
#include <grass/glocale.h>
+static int break_lines(struct Map_info *, struct ilist *, struct ilist *,
+ int, struct Map_info *, int);
\brief Break lines in vector map at each intersection.
@@ -32,7 +36,7 @@
void
Vect_break_lines(struct Map_info *Map, int type, struct Map_info *Err)
- Vect_break_lines_list(Map, NULL, NULL, type, Err);
+ break_lines(Map, NULL, NULL, type, Err, 0);
return;
@@ -61,8 +65,61 @@
int
Vect_break_lines_list(struct Map_info *Map, struct ilist *List_break,
- struct ilist *List_ref, int type, struct Map_info *Err)
+ struct ilist *List_ref, int type,
+ struct Map_info *Err)
+ return break_lines(Map, List_break, List_ref, type, Err, 0);
+ \brief Check for and count intersecting lines, do not break.
+ For details see Vect_break_lines_list().
+ \param Map input vector map
+ \param type feature type
+ \param[out] Err vector map where points at intersections will be written or NULL
+ \return
+int
+Vect_check_line_breaks(struct Map_info *Map, int type, struct Map_info *Err)
+ return break_lines(Map, NULL, NULL, type, Err, 1);
+ If <i>List_break</i> is given, only lines in the list are checked for
+ intersections.
+ If reference lines are given (<i>List_ref</i>) break only lines
+ which intersect reference lines.
+ \param List_break list of lines (NULL for all lines in vector map)
+ \param List_ref list of reference lines or NULL
+ \return number of intersections
+int
+Vect_check_line_breaks_list(struct Map_info *Map, struct ilist *List_break,
+ return break_lines(Map, List_break, List_ref, type, Err, 1);
+int
+break_lines(struct Map_info *Map, struct ilist *List_break,
+ struct Map_info *Err, int check)
struct line_pnts *APoints, *BPoints, *Points;
struct line_pnts **AXLines, **BXLines;
struct line_cats *ACats, *BCats, *Cats;
@@ -177,7 +234,7 @@
btype = Vect_read_line(Map, BPoints, BCats, bline);
- /* Check if thouch by end node only */
+ /* Check if touch by end node only */
if (!is3d) {
Vect_get_line_nodes(Map, aline, &anode1, &anode2);
Vect_get_line_nodes(Map, bline, &bnode1, &bnode2);
@@ -267,13 +324,16 @@
nx = 0; /* number of intersections to be written to Err */
if (naxlines > 0) { /* intersection -> write out */
- Vect_delete_line(Map, aline);
+ if (!check)
+ Vect_delete_line(Map, aline);
for (k = 0; k < naxlines; k++) {
/* Write new line segments */
/* line may collapse, don't write zero length lines */
Vect_line_prune(AXLines[k]);
if ((atype & GV_POINTS) || AXLines[k]->n_points > 1) {
- ret = Vect_write_line(Map, atype, AXLines[k], ACats);
+ if (!check)
+ ret = Vect_write_line(Map, atype, AXLines[k],
+ ACats);
if (List_ref) {
Vect_list_append(List_ref, ret);
@@ -302,15 +362,17 @@
if (nbxlines > 0) {
if (aline != bline) { /* Self intersection, do not write twice, TODO: is it OK? */
- Vect_delete_line(Map, bline);
+ if (!check)
+ Vect_delete_line(Map, bline);
for (k = 0; k < nbxlines; k++) {
Vect_line_prune(BXLines[k]);
if ((btype & GV_POINTS) || BXLines[k]->n_points > 1) {
- ret =
- Vect_write_line(Map, btype, BXLines[k],
- BCats);
+ if (!check)
+ ret =
+ Vect_write_line(Map, btype, BXLines[k],
+ BCats);
G_debug(5, "Line %d written", ret);
if (List_break) {
Vect_list_append(List_break, ret);
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c 2011-12-05 15:51:09 UTC (rev 49550)
+++ grass/trunk/lib/vector/Vlib/build.c 2011-12-05 15:51:57 UTC (rev 49551)
@@ -487,6 +487,158 @@
+ \brief Extensive tests for correct topology
+ \param Map vector map
+ \param[out] Err vector map where errors will be written
+ \return 1 on success
+ \return 0 on error
+int Vect_topo_check(struct Map_info *Map, struct Map_info *Err)
+ int line, nlines;
+ int nerrors, n_zero_lines, n_zero_boundaries;
+ struct line_pnts *Points;
+ struct line_cats *Cats;
+ if (Vect_get_built(Map) != GV_BUILD_ALL) {
+ Vect_build_partial(Map, GV_BUILD_NONE);
+ Vect_build(Map);
+ G_message(_("Checking for topological errors..."));
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
+ /* boundaries of zero length */
+ n_zero_lines = n_zero_boundaries = 0;
+ nlines = Vect_get_num_lines(Map);
+ for (line = 1; line <= nlines; line++) {
+ int type;
+ if (!Vect_line_alive(Map, line))
+ continue;
+ type = Vect_get_line_type(Map, line);
+ if (type & GV_LINES) {
+ double len;
+ Vect_read_line(Map, Points, Cats, line);
+ len = Vect_line_length(Points);
+ if (len == 0) {
+ if (type & GV_LINE)
+ n_zero_lines++;
+ else if (type & GV_BOUNDARY)
+ n_zero_boundaries++;
+ if (Err)
+ Vect_write_line(Err, type, Points, Cats);
+ if (n_zero_lines)
+ G_warning(_("Number of lines of length zero: %d"), n_zero_lines);
+ if (n_zero_boundaries)
+ G_warning(_("Number of boundaries of length zero: %d"), n_zero_boundaries);
+ /* remaining checks are for areas only */
+ if (Vect_get_num_primitives(Map, GV_BOUNDARY) == 0)
+ return 1;
+ /* intersecting boundaries -> overlapping areas */
+ nerrors = Vect_check_line_breaks(Map, GV_BOUNDARY, Err);
+ if (nerrors)
+ G_warning(_("Number of boundary intersections: %d"), nerrors);
+ /* areas without centroids that are not holes
+ * only makes sense if all boundaries are correct */
+ nerrors = 0;
+ int type;
+ continue;
+ if (type == GV_BOUNDARY) {
+ struct P_topo_b *topo = (struct P_topo_b *)Map->plus.Line[line]->topo;
+ if (topo->left == 0 || topo->right == 0) {
+ G_debug(3, "line = %d left = %d right = %d", line,
+ topo->left, topo->right);
+ nerrors++;
+ if (nerrors)
+ G_warning(_("Skipping further checks because of incorrect boundaries"));
+ else {
+ int i, area, left, right, neighbour;
+ int nareas = Vect_get_num_areas(Map);
+ struct ilist *List = Vect_new_list();
+ nerrors = 0;
+ for (area = 1; area <= nareas; area++) {
+ if (!Vect_area_alive(Map, area))
+ continue;
+ line = Vect_get_area_centroid(Map, area);
+ if (line != 0)
+ continue; /* has centroid */
+ Vect_get_area_boundaries(Map, area, List);
+ for (i = 0; i < List->n_values; i++) {
+ line = List->value[i];
+ Vect_get_line_areas(Map, abs(line), &left, &right);
+ if (line > 0)
+ neighbour = left;
+ else
+ neighbour = right;
+ if (neighbour < 0) {
+ neighbour = Vect_get_isle_area(Map, abs(neighbour));
+ if (!neighbour) {
+ /* borders outer void */
+ nerrors++;
+ if (Err) {
+ Vect_read_line(Map, Points, Cats, abs(line));
+ Vect_write_line(Err, GV_BOUNDARY, Points, Cats);
+ /* else neighbour is > 0, check below */
+ if (neighbour > 0) {
+ if (Vect_get_area_centroid(Map, neighbour) == 0) {
+ /* neighbouring area does not have a centroid either */
+ nerrors++;
+ if (Err) {
+ Vect_destroy_list(List);
+ if (nerrors)
+ G_warning(_("Number of redundant holes: %d"),
+ nerrors);
+ /* what else ? */
+ Vect_destroy_line_struct(Points);
+ Vect_destroy_cats_struct(Cats);
+ return 1;
\brief Return current highest built level (part)
@@ -642,20 +794,28 @@
G_message(_("Number of areas: %d"), plus->n_areas);
G_message(_("Number of isles: %d"), plus->n_isles);
+#if 0
+ /* not an error, message disabled to avoid confusion */
+ if (err_nocentr)
+ G_message(_("Number of areas without centroid: %d"),
+ err_nocentr);
+#endif
+ if (plus->n_clines > plus->n_areas)
+ G_warning(_("Number of centroids exceeds number of areas: %d > %d"),
+ plus->n_clines, plus->n_areas);
if (err_boundaries)
- G_message(_("Number of incorrect boundaries: %d"),
+ G_warning(_("Number of incorrect boundaries: %d"),
err_boundaries);
if (err_centr_out)
- G_message(_("Number of centroids outside area: %d"),
+ G_warning(_("Number of centroids outside area: %d"),
err_centr_out);
if (err_centr_dupl)
- G_message(_("Number of duplicate centroids: %d"), err_centr_dupl);
+ G_warning(_("Number of duplicate centroids: %d"), err_centr_dupl);
- if (err_nocentr)
- G_message(_("Number of areas without centroid: %d"), err_nocentr);
else if (build > GV_BUILD_NONE) {
G_message(_("Number of areas: -"));
