[GRASS-SVN] r49560 -
grass/branches/develbranch_6/scripts/i.image.mosaic
svn_grass at osgeo.org
Tue Dec 6 07:13:58 EST 2011
Author: hamish
Date: 2011-12-06 04:13:58 -0800 (Tue, 06 Dec 2011)
New Revision: 49560
grass/branches/develbranch_6/scripts/i.image.mosaic/i.image.mosaic
support for @other mapsets; quote filename; rather extensive cleanup
Modified: grass/branches/develbranch_6/scripts/i.image.mosaic/i.image.mosaic
--- grass/branches/develbranch_6/scripts/i.image.mosaic/i.image.mosaic 2011-12-05 19:31:26 UTC (rev 49559)
+++ grass/branches/develbranch_6/scripts/i.image.mosaic/i.image.mosaic 2011-12-06 12:13:58 UTC (rev 49560)
@@ -3,15 +3,16 @@
# neteler geog.uni-hannover.de
# mosaic code from Felix Gershunov (Felix spsl.nsc.ru)
# updated for GRASS 5.7 by Michael Barton 2004/04/05
+# further cleanup by H.Bowman, December 2011
-# COPYRIGHT: (C) 1999,2007 by the GRASS Development Team
+# COPYRIGHT: (C) 1999,2007,2011 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
-# TODO: - implement g.findfile for 3 and 4 maps (currently only current mapset supported)
-# [done for 2 maps]
+# TODO:
+# - test if g.findfile for colr file succeeds
# - fix isnull() in r.mapcalc for 3 and 4 maps composites
# [done for 2 maps]
# - fix color table length (currently only 256 cols supported, make
@@ -21,42 +22,46 @@
#% Module
-#% description: Mosaics up to 4 images and extends colormap; creates map *.mosaic
+#% label: Mosaics up to four images, extending the color table.
+#% description: creates map *.mosaic
#% keywords: raster, imagery, mosaicking
#% End
#% option
-#% key: image1
-#% type: string
-#% gisprompt: old,cell,raster
-#% description: 1st map for mosaic (top of image stack).
-#% required : yes
+#% key: image1
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: 1st map for mosaic (top of image stack)
+#% required : yes
+#% key_desc: name
#% end
#% option
-#% key: image2
-#% type: string
-#% description: 2nd map for mosaic.
-#% required : yes
+#% key: image2
+#% type: string
+#% description: 2nd map for mosaic
+#% required : yes
+#% key_desc: name
#% end
-#% option
-#% key: image3
-#% type: string
-#% description: 3rd map for mosaic.
-#% required : no
+#% option
+#% key: image3
+#% type: string
+#% description: 3rd map for mosaic
+#% required : no
+#% key_desc: name
#% end
#% option
-#% key: image4
-#% type: string
-#% description: 4th map for mosaic.
-#% required : no
+#% key: image4
+#% type: string
+#% description: 4th map for mosaic
+#% required : no
+#% key_desc: name
#% end
-if [ -z "$GISBASE" ]
-then
- echo "You must be in GRASS GIS to run this program" >&2
- exit 1
+if [ -z "$GISBASE" ] ; then
+ echo "You must be in GRASS GIS to run this program" >&2
+ exit 1
fi
# save command line
@@ -87,68 +92,103 @@
CURRLOCATION="$GISDBASE/$LOCATION_NAME/$MAPSET"
g.message -w message='Do not forget to set region properly to cover all images!'
+#g.region rast=map1,map2,map3,map4
+IMAGE1=`echo "$GIS_OPT_IMAGE1" | cut -f1 -d'@'`
+IMAGE2=`echo "$GIS_OPT_IMAGE2" | cut -f1 -d'@'`
+IMAGE3=`echo "$GIS_OPT_IMAGE3" | cut -f1 -d'@'`
+IMAGE4=`echo "$GIS_OPT_IMAGE4" | cut -f1 -d'@'`
# two images to patch
if [ -z "$GIS_OPT_IMAGE3" -a -z "$GIS_OPT_IMAGE4" ]; then
- g.message "Mosaicing two images..."
- r.mapcalc "$GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.mosaic = if(isnull($GIS_OPT_IMAGE1),\
- $GIS_OPT_IMAGE2+256,\
- $GIS_OPT_IMAGE1)"
+ g.message "Mosaicking two images..."
+ OUTNAME="$IMAGE1.$IMAGE2.mosaic"
+ r.mapcalc "$OUTNAME = if(isnull(\"$GIS_OPT_IMAGE1\"), \
+ \"$GIS_OPT_IMAGE2\" + 256, \
+ \"$GIS_OPT_IMAGE1\")"
#modify the color table:
- echo '% 0 1024' > "$CURRLOCATION/colr/$GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.mosaic"
+ echo '% 0 1024' > "$CURRLOCATION/colr/$OUTNAME"
- eval `g.findfile element=cell file=$GIS_OPT_IMAGE1`
- mapset1="${mapset}"
+ eval `g.findfile element=cell file="$GIS_OPT_IMAGE1"`
+ mapset1="$mapset"
cat "$GISDBASE/$LOCATION_NAME/$mapset1/colr/$GIS_OPT_IMAGE1" | \
- grep -v '%' | tr -s ' ' '\012' >> "$CURRLOCATION/colr/$GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.mosaic"
+ grep -v '%' | tr -s ' ' '\012' >> "$CURRLOCATION/colr/$OUTNAME"
eval `g.findfile element=cell file="$GIS_OPT_IMAGE2"`
- mapset2="${mapset}"
+ mapset2="$mapset"
cat "$GISDBASE/$LOCATION_NAME/$mapset2/colr/$GIS_OPT_IMAGE2" | \
- grep -v '%' | tr -s ' ' '\012' | awk -F':' '{print $1+256":"$2":"$3":"$4}'\
- >> "$CURRLOCATION/colr/$GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.mosaic"
- g.message message="Ready. File $GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.mosaic created."
+ grep -v '%' | tr -s ' ' '\012' | \
+ awk -F':' '{print $1+256":"$2":"$3":"$4}' \
+ >> "$CURRLOCATION/colr/$OUTNAME"
+ g.message message="Done. New raster map <$OUTNAME> created."
# write cmd history:
- r.support "$GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.mosaic" history="${CMDLINE}"
+ r.support "$OUTNAME" history="$CMDLINE"
exit 0
fi
# three images to patch
-if [ -z "$GIS_OPT_IMAGE3" -o -z "$GIS_OPT_IMAGE4" ]; then
- g.message "Mosaicing three images..."
- r.mapcalc "$GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.$GIS_OPT_IMAGE3.mosaic = eval(t1=if($GIS_OPT_IMAGE1,$GIS_OPT_IMAGE1,$GIS_OPT_IMAGE2+256), t2=if(t1 % 256,t1,$GIS_OPT_IMAGE3+512), t2)"
+if [ -z "$GIS_OPT_IMAGE3" -o -z "$GIS_OPT_IMAGE4" ] ; then
+ g.message "Mosaicking three images..."
+ OUTNAME="$IMAGE1.$IMAGE2.$IMAGE3.mosaic"
+ r.mapcalc "$OUTNAME = eval(t1=if(\"$GIS_OPT_IMAGE1\", \
+ \"$GIS_OPT_IMAGE1\", \"$GIS_OPT_IMAGE2\" + 256), \
+ t2=if(t1 % 256, t1, \"$GIS_OPT_IMAGE3\" + 512), t2)"
- echo '% 0 1024' > "$CURRLOCATION/colr/$GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.$GIS_OPT_IMAGE3.mosaic"
- tail -256 $CURRLOCATION/colr/$GIS_OPT_IMAGE1 >> "$CURRLOCATION/colr/$GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.$GIS_OPT_IMAGE3.mosaic"
- tail -256 $CURRLOCATION/colr/$GIS_OPT_IMAGE2 |awk -F':' '{print $1+256":"$2":"$3":"$4}' \
- >> "$CURRLOCATION/colr/$GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.$GIS_OPT_IMAGE3.mosaic"
- tail -256 $CURRLOCATION/colr/$GIS_OPT_IMAGE3 |awk -F':' '{print $1+512":"$2":"$3":"$4}' \
- g.message message="Ready. File $GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.$GIS_OPT_IMAGE3.mosaic created."
+ eval `g.findfile element=colr file="$GIS_OPT_IMAGE1"`
+ tail -256 "$file" >> "$CURRLOCATION/colr/$OUTNAME"
+ eval `g.findfile element=colr file="$GIS_OPT_IMAGE2"`
+ tail -256 "$file" | awk -F':' '{print $1+256":"$2":"$3":"$4}' \
+ eval `g.findfile element=colr file="$GIS_OPT_IMAGE3"`
+ tail -256 "$file" | awk -F':' '{print $1+512":"$2":"$3":"$4}' \
- r.support $GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.$GIS_OPT_IMAGE3.mosaic history="${CMDLINE}"
exit 0
fi
# four images to patch
-if [ $GIS_OPT_IMAGE3 != "" -a $GIS_OPT_IMAGE4 != "" ]; then
- g.message "Mosaicing four images..."
- r.mapcalc "$GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.$GIS_OPT_IMAGE3.$GIS_OPT_IMAGE4.mosaic = eval(t1=if($GIS_OPT_IMAGE1,$GIS_OPT_IMAGE1,$GIS_OPT_IMAGE2+256), t2=if(t1 % 256,t1,$GIS_OPT_IMAGE3+512), t3=if(t2 % 256,t2,$GIS_OPT_IMAGE4+768),t3)"
+if [ -n "$GIS_OPT_IMAGE3" -a -n "$GIS_OPT_IMAGE4" ] ; then
+ g.message "Mosaicking four images..."
+ OUTNAME="$IMAGE1.$IMAGE2.$IMAGE3.$IMAGE4.mosaic"
+ r.mapcalc "$OUTNAME = eval(t1=if(\"$GIS_OPT_IMAGE1\", \"$GIS_OPT_IMAGE1\", \
+ \"$GIS_OPT_IMAGE2\" + 256), \
+ t2=if(t1 % 256, t1, \"$GIS_OPT_IMAGE3\" + 512), \
+ t3=if(t2 % 256, t2, \"$GIS_OPT_IMAGE4\" + 768), t3)"
- echo '% 0 1024' > $CURRLOCATION/colr/$GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.$GIS_OPT_IMAGE3.$GIS_OPT_IMAGE4.mosaic
- tail -256 $CURRLOCATION/colr/$GIS_OPT_IMAGE1 >> $CURRLOCATION/colr/$GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.$GIS_OPT_IMAGE3.$GIS_OPT_IMAGE4.mosaic
- >> "$CURRLOCATION/colr/$GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.$GIS_OPT_IMAGE3.$GIS_OPT_IMAGE4.mosaic"
- tail -256 $CURRLOCATION/colr/$GIS_OPT_IMAGE4 |awk -F':' '{print $1+768":"$2":"$3":"$4}' \
- g.message message="Ready. File $GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.$GIS_OPT_IMAGE3.$GIS_OPT_IMAGE4.mosaic created."
+ eval `g.findfile element=colr file="$GIS_OPT_IMAGE4"`
+ tail -256 "$file" | awk -F':' '{print $1+768":"$2":"$3":"$4}' \
- r.support "$GIS_OPT_IMAGE1.$GIS_OPT_IMAGE2.$GIS_OPT_IMAGE3.$GIS_OPT_IMAGE4.mosaic" history="${CMDLINE}"
exit 0
fi
