[GRASS-SVN] r49578 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Tue Dec 6 17:32:10 EST 2011
Author: martinl
Date: 2011-12-06 14:32:10 -0800 (Tue, 06 Dec 2011)
New Revision: 49578
grass/trunk/scripts/g.extension/g.extension.py
g.extension: force removal flag added
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2011-12-06 21:53:34 UTC (rev 49577)
+++ grass/trunk/scripts/g.extension/g.extension.py 2011-12-06 22:32:10 UTC (rev 49578)
@@ -87,6 +87,10 @@
#% key: i
#% description: Don't install new extension, just compile it
#%end
+#%flag
+#% key: f
+#% description: Force removal when uninstalling extension (operation=remove)
+#%end
import os
import sys
@@ -454,10 +458,15 @@
'GRASS_ADDON_PATH environment variable (see "g.manual variables")'))
# remove existing extension (reading XML file)
-def remove_extension():
+def remove_extension(force = False):
# try to download XML metadata file first
url = "http://grass.osgeo.org/addons/grass%s.xml" % grass.version()['version'].split('.')[0]
name = options['extension']
+ if force:
+ grass.verbose(_("List of removed files:"))
+ else:
+ grass.info(_("Files to be removed (use flag 'f' to force removal):"))
try:
f = urlopen(url)
tree = etree.fromstring(f.read())
@@ -476,40 +485,54 @@
fpath[-1] += '.py'
flist.append(fpath)
if flist:
removed = False
err = list()
for f in flist:
fpath = os.path.join(options['prefix'], os.path.sep.join(f))
try:
- os.remove(fpath)
- removed = True
+ if force:
+ grass.verbose(fpath)
+ os.remove(fpath)
+ removed = True
+ else:
+ print fpath
except OSError:
err.append((_("Unable to remove file '%s'") % fpath))
- if not removed:
+ if force and not removed:
grass.fatal(_("Extension <%s> not found") % options['extension'])
if err:
for e in err:
grass.error(e)
else:
- remove_extension_std()
+ remove_extension_std(force)
except HTTPError:
- grass.message(_("Extension <%s> successfully uninstalled.") % options['extension'])
+ if force:
+ grass.message(_("Extension <%s> successfully uninstalled.") % options['extension'])
+ else:
+ grass.warning(_("Extension <%s> not removed. "
+ "Re-run '%s' with 'f' flag to force removal") % (options['extension'], 'g.extension'))
# remove exising extension (using standard files layout)
-def remove_extension_std():
+def remove_extension_std(force = False):
# is module available?
if not os.path.exists(os.path.join(options['prefix'], 'bin', options['extension'])):
- for file in [os.path.join(options['prefix'], 'bin', options['extension']),
- os.path.join(options['prefix'], 'scripts', options['extension']),
- os.path.join(options['prefix'], 'docs', 'html', options['extension'] + '.html')]:
- if os.path.isfile(file):
- os.remove(file)
+ for fpath in [os.path.join(options['prefix'], 'bin', options['extension']),
+ os.path.join(options['prefix'], 'scripts', options['extension']),
+ os.path.join(options['prefix'], 'docs', 'html', options['extension'] + '.html'),
+ os.path.join(options['prefix'], 'man', 'man1', options['extension'] + '.1')]:
+ if os.path.isfile(fpath):
+ if force:
+ os.remove(fpath)
+ else:
+ print fpath
# check links in CSS
def check_style_files(fil):
@@ -575,7 +598,7 @@
if options['operation'] == 'add':
install_extension()
else: # remove
- remove_extension()
+ remove_extension(flags['f'])
return 0
