[GRASS-SVN] r49588 - grass-addons/grass6/vector/v.surf.icw
svn_grass at osgeo.org
Tue Dec 6 22:40:31 EST 2011
Author: hamish
Date: 2011-12-06 19:40:31 -0800 (Tue, 06 Dec 2011)
New Revision: 49588
grass-addons/grass6/vector/v.surf.icw/v.surf.icw
adjustments needed to allow it to also run in grass7
Modified: grass-addons/grass6/vector/v.surf.icw/v.surf.icw
--- grass-addons/grass6/vector/v.surf.icw/v.surf.icw 2011-12-07 02:54:17 UTC (rev 49587)
+++ grass-addons/grass6/vector/v.surf.icw/v.surf.icw 2011-12-07 03:40:31 UTC (rev 49588)
@@ -12,7 +12,7 @@
# PURPOSE: Like IDW interpolation, but distance is cost to get to any
# other site.
-# COPYRIGHT: (c) 2003-2008 Hamish Bowman
+# COPYRIGHT: (c) 2003-2011 Hamish Bowman
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
@@ -177,7 +177,8 @@
fi
### cleanse cost area mask to a flat =1 for my porpoises
-r.mapcalc "tmp_icw_area_$$=if("$GIS_OPT_COST_MAP",1,null())"
+GRASS_OVERWRITE=1 \
+ r.mapcalc "tmp_icw_area_$$ = if(\"$GIS_OPT_COST_MAP\", 1, null())"
@@ -227,7 +228,7 @@
EASTING=`echo "$POS" | cut -f1 -d"|"`
NORTHING=`echo "$POS" | cut -f2 -d"|"`
CAT=`echo "$POS" | cut -f"$CATCOL" -d"|"`
- DATA_VALUE="`db.select -c tmp_icw_points_$$ sql="select $COL_NAME from tmp_icw_points_$$ where cat=${CAT}"`"
+ DATA_VALUE="`v.db.select -c tmp_icw_points_$$ column="$COL_NAME" where="cat=${CAT}"`"
echo "Site $NUM of $N e=$EASTING n=$NORTHING data=$DATA_VALUE"
@@ -251,22 +252,23 @@
# so the divisor exists and the weighting is huge at the exact sample spots
# more efficient to reclass to 1?
- r.mapcalc "cost_site.$NUM = if(cost_site.$NUM == 0, 0.1, cost_site.$NUM)"
+ GRASS_OVERWRITE=1 \
+ r.mapcalc "cost_site.$NUM = if(cost_site.$NUM == 0, 0.1, cost_site.$NUM)"
# r.to.vect then r.patch output
# v.to.rast in=tmp_idw_cost_site_29978 out=tmp_idw_cost_val_$$ use=val val=10
if [ "$GIS_FLAG_R" -eq 0 ] ; then
# exp(3,2) is 3^2 etc. as is pow(3,2)
- # r.mapcalc 1by_cost_site_sqrd.$NUM=" 1.0 / exp(cost_site.$NUM , $FRICTION)"
+ # r.mapcalc "1by_cost_site_sqrd.$NUM = 1.0 / exp(cost_site.$NUM , $FRICTION)"
EXPRESSION="1.0 / pow(cost_site.$NUM $DIVISOR, $FRICTION )"
else
# use log10() or ln() ?
EXPRESSION="1.0 / ( pow(cost_site.$NUM, $FRICTION) * log (cost_site.$NUM) )"
fi
# echo "r.mapcalc expression is: [$EXPRESSION]"
+ r.mapcalc "1by_cost_site_sqrd.$NUM = $EXPRESSION"
- r.mapcalc "1by_cost_site_sqrd.$NUM = $EXPRESSION"
# r.patch in=1by_cost_site_sqrd.${NUM},tmp_idw_cost_val_$$ out=1by_cost_site_sqrd.${NUM} --o
# g.remove rast=cost_site.$NUM
@@ -285,7 +287,8 @@
if [ -n "$GIS_OPT_POST_MASK" ] ; then
echo "Setting post_mask [$GIS_OPT_POST_MASK]" 1>&2
- r.mapcalc MASK="$GIS_OPT_POST_MASK"
+ r.mapcalc "MASK = \"$GIS_OPT_POST_MASK\""
fi
echo "Summation of cost weights.." 1>&2
@@ -305,7 +308,7 @@
echo "Site $NUM of $N data value = $DATA_VALUE" 1>&2
@@ -319,8 +322,9 @@
continue
fi
- r.mapcalc partial_icw.$NUM=\
- "( $DATA_VALUE * 1by_cost_site_sqrd.$NUM ) / sum_of_1by_cost_sqs"
+ r.mapcalc "partial_icw.$NUM = \
+ ( $DATA_VALUE * 1by_cost_site_sqrd.$NUM ) / sum_of_1by_cost_sqs"
#"( $DATA_VALUE / $N ) * (1.0 - ( cost_sq_site.$NUM / sum_of_cost_sqs ))"
#"( cost_sq_site.$NUM / sum_of_cost_sqs ) * ( $DATA_VALUE / $N )"
@@ -367,16 +371,21 @@
# 5) rm cost and cost_sq maps, tmp_icw_points, etc
cleanup()
- echo "Cleanup .." 1>&2
- g.mremove -f rast=cost_site.* | grep REMOVE
- g.mremove -f rast=1by_cost_site_sqrd.* | grep REMOVE
- g.mremove -f rast=partial_icw.* | grep REMOVE
+ echo "Cleanup.." 1>&2
+ g.mremove -f rast=cost_site.*
+ g.mremove -f rast=1by_cost_site_sqrd.*
+ g.mremove -f rast=partial_icw.*
#g.mremove -f rast=tmp_icw_*_$$
#g.mremove -f vect=tmp_icw_*_$$
- g.remove rast=sum_of_1by_cost_sqs | grep REMOVE
+ g.remove rast=sum_of_1by_cost_sqs
#g.remove vect=tmp_idw_cost_site_$$
- g.remove rast=tmp_icw_area_$$ | grep REMOVE
- g.remove vect=tmp_icw_region_$$,tmp_icw_points_$$,tmp_icw_points_sel_$$
+ g.remove rast=tmp_icw_area_$$
+ g.remove vect=tmp_icw_region_$$,tmp_icw_points_$$
+ # check if it exists
+ eval `g.findfile element=vector file="tmp_icw_points_sel_$$"`
+ if [ -e "$file" ] ; then
+ g.remove vect=tmp_icw_points_sel_$$
+ fi
rm -f "$TMP_POINTS"
@@ -394,5 +403,5 @@
cleanup
# 6) done!
-echo "Done! Wrote results to <${GIS_OPT_OUTPUT}>." 1>&2
+echo "Done! Results written to <${GIS_OPT_OUTPUT}>." 1>&2
exit 0
