[GRASS-SVN] r49608 - grass/branches/develbranch_6/gui/scripts
svn_grass at osgeo.org
Wed Dec 7 07:55:54 EST 2011
Author: martinl
Date: 2011-12-07 04:55:54 -0800 (Wed, 07 Dec 2011)
New Revision: 49608
grass/branches/develbranch_6/gui/scripts/g.extension.py
g.extension.py: sync with trunk (keep G6-specific code)
Modified: grass/branches/develbranch_6/gui/scripts/g.extension.py
--- grass/branches/develbranch_6/gui/scripts/g.extension.py 2011-12-07 12:30:25 UTC (rev 49607)
+++ grass/branches/develbranch_6/gui/scripts/g.extension.py 2011-12-07 12:55:54 UTC (rev 49608)
@@ -81,6 +81,10 @@
#% key: i
#% description: Don't install new extension, just compile it
#%end
+#%flag
+#% key: f
+#% description: Force removal when uninstalling extension (operation=remove)
+#%end
import os
import sys
@@ -104,11 +108,13 @@
# temp dir
remove_tmpdir = True
+# check requirements
def check():
for prog in ('svn', 'make', 'gcc'):
if not grass.find_program(prog, ['--help']):
grass.fatal(_("'%s' required. Please install '%s' first.") % (prog, prog))
+# expand prefix to class name
def expand_module_class_name(c):
name = { 'd' : 'display',
'db' : 'database',
@@ -128,6 +134,7 @@
return c
+# list modules (read XML file from grass.osgeo.org/addons)
def list_available_modules():
mlist = list()
@@ -159,19 +166,21 @@
return mlist
+# list modules (scan SVN repo)
def list_available_modules_svn():
mlist = list()
grass.message(_('Fetching list of modules from GRASS-Addons SVN (be patient)...'))
pattern = re.compile(r'(<li><a href=".+">)(.+)(</a></li>)', re.IGNORECASE)
- i = 0
+ if flags['c']:
+ grass.warning(_("Flag 'c' ignored, metadata file not available"))
+ if flags['g']:
+ grass.warning(_("Flag 'g' ignored, metadata file not available"))
prefix = ['d', 'db', 'g', 'i', 'm', 'ps',
'p', 'r', 'r3', 's', 'v']
nprefix = len(prefix)
for d in prefix:
- if flags['g']:
- grass.percent(i, nprefix, 1)
- i += 1
modclass = expand_module_class_name(d)
grass.verbose(_("Checking for '%s' modules...") % modclass)
@@ -190,16 +199,14 @@
continue
name = sline.group(2).rstrip('/')
if name.split('.', 1)[0] == d:
- print_module_desc(name, url)
+ print name
mlist.append(name)
mlist += list_wxgui_extensions()
- if flags['g']:
- grass.percent(1, 1, 1)
return mlist
+# list wxGUI extensions
def list_wxgui_extensions(print_module = True):
mlist = list()
grass.debug('Fetching list of wxGUI extensions from GRASS-Addons SVN (be patient)...')
@@ -208,11 +215,10 @@
url = '%s/%s' % (options['svnurl'], 'gui/wxpython')
grass.debug("url = %s" % url, debug = 2)
- try:
- f = urlopen(url)
- except HTTPError:
- grass.debug("Unable to fetch '%s'" % url, debug = 1)
- return mlist
+ f = urlopen(url)
+ if not f:
+ grass.warning(_("Unable to fetch '%s'") % url)
+ return
for line in f.readlines():
# list modules
@@ -222,116 +228,19 @@
if name not in ('..', 'Makefile'):
if print_module:
+ print name
mlist.append(name)
return mlist
-def print_module_desc(name, url):
- if not flags['c'] and not flags['g']:
- print name
- return
- if flags['g']:
- print 'name=' + name
- # check main.c first
- desc = get_module_desc(url + '/' + name + '/' + name)
- if not desc:
- desc = get_module_desc(url + '/' + name + '/main.c', script = False)
- if not desc:
- if not flags['g']:
- print name + ' - '
- return
- if flags['g']:
- print 'description=' + desc.get('description', '')
- print 'keywords=' + ','.join(desc.get('keywords', list()))
- else:
- print name + ' - ' + desc.get('description', '')
-def get_module_desc(url, script = True):
- grass.debug('url=%s' % url)
- try:
- f = urlopen(url)
- except HTTPError:
- return {}
- if script:
- ret = get_module_script(f)
- else:
- ret = get_module_main(f)
- return ret
-def get_module_main(f):
- if not f:
- return dict()
- ret = { 'keyword' : list() }
- pattern = re.compile(r'(module.*->)(.+)(=)(.*)', re.IGNORECASE)
- keyword = re.compile(r'(G_add_keyword\()(.+)(\);)', re.IGNORECASE)
- key = ''
- value = ''
- for line in f.readlines():
- line = line.strip()
- find = pattern.search(line)
- if find:
- key = find.group(2).strip()
- line = find.group(4).strip()
- else:
- find = keyword.search(line)
- if find:
- ret['keyword'].append(find.group(2).replace('"', '').replace('_(', '').replace(')', ''))
- if key:
- value += line
- if line[-2:] == ');':
- value = value.replace('"', '').replace('_(', '').replace(');', '')
- if key == 'keywords':
- ret[key] = map(lambda x: x.strip(), value.split(','))
- else:
- ret[key] = value
- key = value = ''
- return ret
-def get_module_script(f):
- ret = dict()
- if not f:
- return ret
- begin = re.compile(r'#%.*module', re.IGNORECASE)
- end = re.compile(r'#%.*end', re.IGNORECASE)
- mline = None
- if not mline:
- mline = begin.search(line)
- if mline:
- if end.search(line):
- break
- try:
- key, value = line.split(':', 1)
- key = key.replace('#%', '').strip()
- value = value.strip()
- else:
- ret[key] = value
- except ValueError:
- pass
- return ret
def cleanup():
if remove_tmpdir:
grass.try_rmdir(tmpdir)
else:
grass.message(_("Path to the source code:"))
sys.stderr.write('%s\n' % os.path.join(tmpdir, options['extension']))
+# install extension on MS Windows
def install_extension_win():
### TODO: do not use hardcoded url
version = grass.version()['version'].split('.')
@@ -362,6 +271,7 @@
except HTTPError:
grass.fatal(_("GRASS Addons <%s> not found") % options['extension'])
def install_extension():
gisbase = os.getenv('GISBASE')
if not gisbase:
@@ -432,8 +342,8 @@
grass.warning(_('This add-on module will not function until you set the '
'GRASS_ADDON_PATH environment variable (see "g.manual variables")'))
+# install extension on other plaforms
def install_extension_other():
- # todo: rip all this out and replace it with a call to the g.extension shell script.
gui_list = list_wxgui_extensions(print_module = False)
@@ -446,7 +356,7 @@
if not flags['s']:
grass.fatal(_("Installation of wxGUI extension requires -%s flag.") % 's')
- grass.message(_("Fetching '%s' from GRASS-Addons SVN (be patient)...") % options['extension'])
+ grass.message(_("Fetching <%s> from GRASS-Addons SVN (be patient)...") % options['extension'])
os.chdir(tmpdir)
if grass.verbosity() == 0:
@@ -492,7 +402,7 @@
os.chdir(os.path.join(tmpdir, options['extension']))
- grass.message(_("Compiling '%s'...") % options['extension'])
+ grass.message(_("Compiling <%s>...") % options['extension'])
if options['extension'] not in gui_list:
ret = grass.call(makeCmd,
stdout = outdev)
@@ -507,7 +417,7 @@
if flags['i'] or options['extension'] in gui_list:
return
- grass.message(_("Installing '%s'...") % options['extension'])
+ grass.message(_("Installing <%s>...") % options['extension'])
ret = grass.call(installCmd,
stdout = outdev)
@@ -515,7 +425,7 @@
if ret != 0:
grass.warning(_('Installation failed, sorry. Please check above error messages.'))
else:
- grass.message(_("Installation of '%s' successfully finished.") % options['extension'])
+ grass.message(_("Installation of <%s> successfully finished.") % options['extension'])
# cleanup build cruft
if not flags['s']:
@@ -526,35 +436,46 @@
if os.path.exists(os.path.join(options['prefix'], 'scripts', options['extension'])):
shutil.move(os.path.join(options['prefix'], 'scripts', options['extension']),
os.path.join(options['prefix'], options['extension']))
# if empty, rmdir scripts/ and bin/
if os.path.exists(os.path.join(options['prefix'], 'bin')):
if os.listdir(os.path.join(options['prefix'], 'bin')) == []:
os.removedirs(os.path.join(options['prefix'], 'bin'))
if os.path.exists(os.path.join(options['prefix'], 'scripts')):
if os.listdir(os.path.join(options['prefix'], 'scripts')) == []:
os.removedirs(os.path.join(options['prefix'], 'scripts'))
# move man/ into docs/
if os.path.exists(os.path.join(options['prefix'], 'man', 'man1', options['extension'] + '.1')):
shutil.move(os.path.join(options['prefix'], 'man', 'man1', options['extension'] + '.1'),
os.path.join(options['prefix'], 'docs', 'man', 'man1', options['extension'] + '.1'))
# if empty, rmdir man/man1
if os.path.exists(os.path.join(options['prefix'], 'man', 'man1')):
if os.listdir(os.path.join(options['prefix'], 'man', 'man1')) == []:
os.removedirs(os.path.join(options['prefix'], 'man', 'man1'))
if os.path.exists(os.path.join(options['prefix'], 'man')):
if os.listdir(os.path.join(options['prefix'], 'man')) == []:
os.removedirs(os.path.join(options['prefix'], 'man'))
+ if not os.environ.has_key('GRASS_ADDON_PATH') or \
+ not os.environ['GRASS_ADDON_PATH']:
+ grass.warning(_('This add-on module will not function until you set the '
+ 'GRASS_ADDON_PATH environment variable (see "g.manual variables")'))
-def remove_extension():
- # the following relies on an online file manifest for each module; remove_extension_std() does not.
+# remove existing extension (reading XML file)
+def remove_extension(force = False):
# try to download XML metadata file first
url = "http://grass.osgeo.org/addons/grass%s.xml" % grass.version()['version'].split('.')[0]
name = options['extension']
+ if force:
+ grass.verbose(_("List of removed files:"))
+ else:
+ grass.info(_("Files to be removed (use flag 'f' to force removal):"))
try:
f = urlopen(url)
tree = etree.fromstring(f.read())
@@ -573,66 +494,65 @@
fpath[-1] += '.py'
flist.append(fpath)
if flist:
removed = False
err = list()
for f in flist:
fpath = os.path.join(options['prefix'], os.path.sep.join(f))
try:
- os.remove(fpath)
- removed = True
+ if force:
+ grass.verbose(fpath)
+ os.remove(fpath)
+ removed = True
+ else:
+ print fpath
except OSError:
err.append((_("Unable to remove file '%s'") % fpath))
- if not removed:
+ if force and not removed:
grass.fatal(_("Extension <%s> not found") % options['extension'])
if err:
for e in err:
grass.error(e)
else:
- remove_extension_std()
+ remove_extension_std(force)
except HTTPError:
- # symlink for binaries needed, see http://trac.osgeo.org/grass/changeset/49124
- grass.try_remove(os.path.join(options['prefix'], options['extension']))
+ if force:
+ grass.message(_("Extension <%s> successfully uninstalled.") % options['extension'])
+ else:
+ grass.warning(_("Extension <%s> not removed. "
+ "Re-run '%s' with 'f' flag to force removal") % (options['extension'], 'g.extension'))
- grass.message(_("Extension <%s> successfully uninstalled.") % options['extension'])
+# remove exising extension (using standard files layout)
+def remove_extension_std(force = False):
+ # is module available?
+ if not os.path.exists(os.path.join(options['prefix'], 'bin', options['extension'])):
+ grass.fatal(_("Extension <%s> not found") % options['extension'])
-def remove_extension_std():
- # is module available? what if the user has leftover cruft to uninstall?
- #if not os.path.exists(os.path.join(options['prefix'], options['extension'])):
- # grass.fatal(_("Extension <%s> not found") % options['extension'])
- for file in [os.path.join(options['prefix'], options['extension']),
- os.path.join(options['prefix'], 'bin', options['extension']),
- os.path.join(options['prefix'], 'scripts', options['extension']),
- os.path.join(options['prefix'], 'docs', 'html', options['extension'] + '.html'),
- os.path.join(options['prefix'], 'docs', 'man', 'man1', options['extension'] + '.1'),
- os.path.join(options['prefix'], 'man', 'man1', options['extension'] + '.1')]:
- if os.path.isfile(file):
- #grass.message(_("Removing <%s> ..." % file))
- os.remove(file)
-def create_dir(path):
- if os.path.isdir(path):
- return
+ for fpath in [os.path.join(options['prefix'], 'bin', options['extension']),
+ os.path.join(options['prefix'], 'scripts', options['extension']),
+ os.path.join(options['prefix'], 'docs', 'html', options['extension'] + '.html'),
+ os.path.join(options['prefix'], 'man', 'man1', options['extension'] + '.1')]:
+ if os.path.isfile(fpath):
+ if force:
+ os.remove(fpath)
+ else:
+ print fpath
- try:
- os.makedirs(path)
- except OSError, e:
- grass.fatal(_("Unable to create '%s': %s") % (path, e))
- grass.debug("'%s' created" % path)
+# check links in CSS
def check_style_files(fil):
- #check the links to grassdocs.css/grass_logo.png to a correct manual page of addons
+ # check the links to grassdocs.css/grass_logo.png to a correct manual page of addons
dist_file = os.path.join(os.getenv('GISBASE'), 'docs', 'html', fil)
addons_file = os.path.join(options['prefix'], 'docs', 'html', fil)
- #check if file already exists in the grass addons docs html path
+ # check if file already exists in the grass addons docs html path
if os.path.isfile(addons_file):
return
- #otherwise copy the file from $GISBASE/docs/html, it doesn't use link
- #because os.symlink it work only in Linux
+ # otherwise copy the file from $GISBASE/docs/html, it doesn't use link
+ # because os.symlink it work only in Linux
else:
try:
shutil.copyfile(dist_file,addons_file)
@@ -640,11 +560,6 @@
grass.fatal(_("Unable to create '%s': %s") % (addons_file, e))
def check_dirs():
- create_dir(os.path.join(options['prefix'], 'bin'))
- create_dir(os.path.join(options['prefix'], 'scripts'))
- create_dir(os.path.join(options['prefix'], 'man', 'man1'))
- create_dir(os.path.join(options['prefix'], 'docs', 'man', 'man1'))
- create_dir(os.path.join(options['prefix'], 'docs', 'html'))
check_style_files('grass_logo.png')
check_style_files('grassdocs.css')
@@ -693,7 +608,7 @@
if options['operation'] == 'add':
install_extension()
else: # remove
- remove_extension()
+ remove_extension(flags['f'])
return 0
