[GRASS-SVN] r49610 - grass/trunk/scripts/g.extension
Wed Dec 7 09:38:31 EST 2011
Author: martinl
Date: 2011-12-07 06:38:31 -0800 (Wed, 07 Dec 2011)
New Revision: 49610
   grass/trunk/scripts/g.extension/g.extension.py
g.extension: no symlink for executable (only G6 related)
	     create target dirs if not exists (make install should do this job)
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py	2011-12-07 13:32:31 UTC (rev 49609)
+++ grass/trunk/scripts/g.extension/g.extension.py	2011-12-07 14:38:31 UTC (rev 49610)
@@ -115,7 +115,7 @@
 remove_tmpdir = True
 # check requirements
-def check():
+def check_progs():
     for prog in ('svn', 'make', 'gcc'):
         if not grass.find_program(prog, ['--help']):
             grass.fatal(_("'%s' required. Please install '%s' first.") % (prog, prog))
@@ -314,30 +314,7 @@
             fd = open(html_man, "w")
             fd.write(html_str)
             fd.close()
-    # symlink for binaries needed, see http://trac.osgeo.org/grass/changeset/49124
-    src = None
-    if sys.platform == 'win32':
-        bin_ext = '.exe'
-        sct_ext  = '.py'
-    else:
-        bin_ext = sct_ext = ''
-    if os.path.exists(os.path.join(options['prefix'], 'bin',
-                                   options['extension'] + bin_ext)):
-        src = os.path.join(options['prefix'], 'bin', options['extension']) + bin_ext
-        dst = os.path.join(options['prefix'], options['extension']) + bin_ext
-    elif os.path.exists(os.path.join(options['prefix'], 'scripts',
-                                     options['extension'] + sct_ext)):
-        src = os.path.join(options['prefix'], 'scripts', options['extension']) + sct_ext
-        dst = os.path.join(options['prefix'], options['extension']) + sct_ext
-    if src and not os.path.exists(dst):
-            shutil.copyfile(src, dst)
-        else:
-            os.symlink(src, dst)
     if not os.environ.has_key('GRASS_ADDON_PATH') or \
             not os.environ['GRASS_ADDON_PATH']:
         grass.warning(_('This add-on module will not function until you set the '
@@ -550,14 +527,30 @@
 	except OSError, e:
 	    grass.fatal(_("Unable to create '%s': %s") % (addons_file, e))
+def create_dir(path):
+    if os.path.isdir(path):
+        return
+    try:
+        os.makedirs(path)
+    except OSError, e:
+        grass.fatal(_("Unable to create '%s': %s") % (path, e))
+    grass.debug("'%s' created" % path)
 def check_dirs():
+    create_dir(os.path.join(options['prefix'], 'bin'))
+    create_dir(os.path.join(options['prefix'], 'docs', 'html'))
     check_style_files('grass_logo.png')
-    check_style_files('grassdocs.css')
+    check_style_files('grassdocs.css')
+    create_dir(os.path.join(options['prefix'], 'etc'))
+    create_dir(os.path.join(options['prefix'], 'man', 'man1'))
+    create_dir(os.path.join(options['prefix'], 'scripts'))
 def main():
     # check dependecies
     if sys.platform != "win32":
-        check()
+        check_progs()
     # list available modules
     if flags['l'] or flags['c'] or flags['g']:
@@ -585,10 +578,6 @@
                 grass.warning(_("GRASS_ADDON_PATH has more items, using first defined - '%s'") % path_list[0])
             options['prefix'] = path_list[0]
-    # check dirs
-    if options['operation'] == 'add':
-        check_dirs()
     if flags['d']:
         if options['operation'] != 'add':
             grass.warning(_("Flag 'd' is relevant only to 'operation=add'. Ignoring this flag."))
@@ -597,7 +586,8 @@
             remove_tmpdir = False
-            install_extension()
+        check_dirs()
+        install_extension()
     else: # remove
         remove_extension(flags['f'])
