[GRASS-SVN] r49628 - in grass/trunk/gui/wxpython: . gui_core lmgr
location_wizard mapdisp modules nviz psmap
svn_grass at osgeo.org
Thu Dec 8 15:11:28 EST 2011
Author: martinl
Date: 2011-12-08 12:11:28 -0800 (Thu, 08 Dec 2011)
New Revision: 49628
grass/trunk/gui/wxpython/gis_set.py
grass/trunk/gui/wxpython/gui_core/dialogs.py
grass/trunk/gui/wxpython/gui_core/forms.py
grass/trunk/gui/wxpython/gui_core/ghelp.py
grass/trunk/gui/wxpython/gui_core/goutput.py
grass/trunk/gui/wxpython/gui_core/gselect.py
grass/trunk/gui/wxpython/gui_core/preferences.py
grass/trunk/gui/wxpython/gui_core/widgets.py
grass/trunk/gui/wxpython/lmgr/pyshell.py
grass/trunk/gui/wxpython/location_wizard/wizard.py
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/gui/wxpython/modules/mcalc_builder.py
grass/trunk/gui/wxpython/nviz/animation.py
grass/trunk/gui/wxpython/nviz/mapwindow.py
grass/trunk/gui/wxpython/nviz/workspace.py
grass/trunk/gui/wxpython/psmap/frame.py
grass/trunk/gui/wxpython/wxgui.py
wxGUI: various mirror fixes
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2011-12-08 20:10:09 UTC (rev 49627)
+++ grass/trunk/gui/wxpython/gis_set.py 2011-12-08 20:11:28 UTC (rev 49628)
@@ -31,13 +31,16 @@
import gettext
gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
+if __name__ == "__main__":
+ sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython'))
from core import globalvar
import wx
import wx.lib.mixins.listctrl as listmix
import wx.lib.scrolledpanel as scrolled
from gui_core.ghelp import HelpFrame
-from core.gcmd import GMessage, GError
+from core.gcmd import GMessage, GError, DecodeString, RunCommand
+from core.utils import GetListOfLocations, GetListOfMapsets
sys.stderr = codecs.getwriter('utf8')(sys.stderr)
@@ -873,15 +876,11 @@
return 1
if os.getenv("GISBASE") is None:
- print >> sys.stderr, "Failed to start GUI, GRASS GIS is not running."
- else:
- import gettext
- gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
- from core.gcmd import RunCommand, DecodeString
- from core.utils import GetListOfMapsets, GetListOfLocations
- GRASSStartUp = StartUp(0)
- GRASSStartUp.MainLoop()
+ sys.exit("Failed to start GUI, GRASS GIS is not running.")
+ import gettext
+ gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
+ GRASSStartUp = StartUp(0)
+ GRASSStartUp.MainLoop()
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py 2011-12-08 20:10:09 UTC (rev 49627)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py 2011-12-08 20:11:28 UTC (rev 49628)
@@ -19,7 +19,6 @@
- dialogs::DxfImportDialog
- dialogs::LayersList (used by MultiImport)
- dialogs::SetOpacityDialog
- - dialogs::StaticWrapText
- dialogs::ImageSizeDialog
- dialogs::SqlQueryFrame
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py 2011-12-08 20:10:09 UTC (rev 49627)
+++ grass/trunk/gui/wxpython/gui_core/forms.py 2011-12-08 20:11:28 UTC (rev 49628)
@@ -5,8 +5,11 @@
description.
Classes:
+ - forms::UpdateThread
+ - forms::UpdateQThread
- forms::TaskFrame
- forms::CmdPanel
+ - forms::GUI
- forms::GrassGUIApp
This program is just a coarse approach to automatically build a GUI
Modified: grass/trunk/gui/wxpython/gui_core/ghelp.py
--- grass/trunk/gui/wxpython/gui_core/ghelp.py 2011-12-08 20:10:09 UTC (rev 49627)
+++ grass/trunk/gui/wxpython/gui_core/ghelp.py 2011-12-08 20:11:28 UTC (rev 49628)
@@ -42,23 +42,6 @@
from core.gcmd import GError, DecodeString
from gui_core.widgets import GNotebook, StaticWrapText, ItemTree
-class HelpFrame(wx.Frame):
- """!GRASS Quickstart help window"""
- def __init__(self, parent, id, title, size, file):
- wx.Frame.__init__(self, parent = parent, id = id, title = title, size = size)
- sizer = wx.BoxSizer(wx.VERTICAL)
- # text
- content = HelpPanel(parent = self)
- content.LoadPage(file)
- sizer.Add(item = content, proportion = 1, flag = wx.EXPAND)
- self.SetAutoLayout(True)
- self.SetSizer(sizer)
- self.Layout()
class SearchModuleWindow(wx.Panel):
"""!Search module window (used in MenuTreeWindow)"""
def __init__(self, parent, id = wx.ID_ANY, cmdPrompt = None,
@@ -710,6 +693,23 @@
"""!Close window"""
self.Close()
+class HelpFrame(wx.Frame):
+ """!GRASS Quickstart help window"""
+ def __init__(self, parent, id, title, size, file):
+ wx.Frame.__init__(self, parent = parent, id = id, title = title, size = size)
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ # text
+ content = HelpPanel(parent = self)
+ content.LoadPage(file)
+ sizer.Add(item = content, proportion = 1, flag = wx.EXPAND)
+ self.SetAutoLayout(True)
+ self.SetSizer(sizer)
+ self.Layout()
class HelpWindow(HtmlWindow):
"""!This panel holds the text from GRASS docs.
Modified: grass/trunk/gui/wxpython/gui_core/goutput.py
--- grass/trunk/gui/wxpython/gui_core/goutput.py 2011-12-08 20:10:09 UTC (rev 49627)
+++ grass/trunk/gui/wxpython/gui_core/goutput.py 2011-12-08 20:11:28 UTC (rev 49628)
@@ -6,9 +6,9 @@
Classes:
- goutput::CmdThread
- goutput::GMConsole
- - goutput::GMStc
- goutput::GMStdout
- goutput::GMStderr
+ - goutput::GMStc
(C) 2007-2011 by the GRASS Development Team
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py 2011-12-08 20:10:09 UTC (rev 49627)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py 2011-12-08 20:11:28 UTC (rev 49628)
@@ -11,6 +11,7 @@
- gselect::LayerSelect
- gselect::DriverSelect
- gselect::DatabaseSelect
+ - gselect::TableSelect
- gselect::ColumnSelect
- gselect::DbaseSelect
- gselect::LocationSelect
Modified: grass/trunk/gui/wxpython/gui_core/preferences.py
--- grass/trunk/gui/wxpython/gui_core/preferences.py 2011-12-08 20:10:09 UTC (rev 49627)
+++ grass/trunk/gui/wxpython/gui_core/preferences.py 2011-12-08 20:11:28 UTC (rev 49628)
@@ -13,6 +13,7 @@
- preferences::PreferencesDialog
- preferences::DefaultFontDialog
- preferences::MapsetAccess
+ - preferences::CheckListMapset
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py 2011-12-08 20:10:09 UTC (rev 49627)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py 2011-12-08 20:11:28 UTC (rev 49628)
@@ -41,8 +41,8 @@
except ImportError:
import wx.lib.customtreectrl as CT
-from core import globalvar
-from core.debug import Debug
+from core import globalvar
+from core.debug import Debug
class GNotebook(FN.FlatNotebook):
"""!Generic notebook widget
Modified: grass/trunk/gui/wxpython/lmgr/pyshell.py
--- grass/trunk/gui/wxpython/lmgr/pyshell.py 2011-12-08 20:10:09 UTC (rev 49627)
+++ grass/trunk/gui/wxpython/lmgr/pyshell.py 2011-12-08 20:11:28 UTC (rev 49628)
@@ -6,8 +6,8 @@
Classes:
- pyshell::PyShellWindow
- at todo run pyshell and evaluate code in a separate instance of python
-& design the widget communicate back and forth with it
+ at todo Run pyshell and evaluate code in a separate instance of python &
+design the widget communicate back and forth with it
(C) 2011 by the GRASS Development Team
Modified: grass/trunk/gui/wxpython/location_wizard/wizard.py
--- grass/trunk/gui/wxpython/location_wizard/wizard.py 2011-12-08 20:10:09 UTC (rev 49627)
+++ grass/trunk/gui/wxpython/location_wizard/wizard.py 2011-12-08 20:11:28 UTC (rev 49628)
@@ -14,6 +14,7 @@
- wizard::DatumPage
- wizard::EllipsePage
- wizard::GeoreferencedFilePage
+ - wizard::WKTPage
- wizard::EPSGPage
- wizard::CustomPage
- wizard::SummaryPage
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2011-12-08 20:10:09 UTC (rev 49627)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2011-12-08 20:11:28 UTC (rev 49628)
@@ -34,7 +34,7 @@
sys.path.append(os.path.join(globalvar.ETCDIR, "python"))
-from core.render import EVT_UPDATE_PRGBAR, Map
+from core.render import EVT_UPDATE_PRGBAR
from vdigit.toolbars import VDigitToolbar
from mapdisp.toolbars import MapToolbar
from mapdisp.gprint import PrintOptions
Modified: grass/trunk/gui/wxpython/modules/mcalc_builder.py
--- grass/trunk/gui/wxpython/modules/mcalc_builder.py 2011-12-08 20:10:09 UTC (rev 49627)
+++ grass/trunk/gui/wxpython/modules/mcalc_builder.py 2011-12-08 20:11:28 UTC (rev 49628)
@@ -1,5 +1,5 @@
- at package modules mcalc_builder
+ at package modules::mcalc_builder
@brief Map calculator, GUI wrapper for r.mapcalc
Modified: grass/trunk/gui/wxpython/nviz/animation.py
--- grass/trunk/gui/wxpython/nviz/animation.py 2011-12-08 20:10:09 UTC (rev 49627)
+++ grass/trunk/gui/wxpython/nviz/animation.py 2011-12-08 20:11:28 UTC (rev 49628)
@@ -6,7 +6,7 @@
Classes:
- animation::Animation
-(C) 2008-2011 by the GRASS Development Team
+(C) 2011 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
Modified: grass/trunk/gui/wxpython/nviz/mapwindow.py
--- grass/trunk/gui/wxpython/nviz/mapwindow.py 2011-12-08 20:10:09 UTC (rev 49627)
+++ grass/trunk/gui/wxpython/nviz/mapwindow.py 2011-12-08 20:11:28 UTC (rev 49628)
@@ -36,7 +36,6 @@
from core.gcmd import GMessage, GException, GError
from gui_core.mapwindow import MapWindow
-from gui_core.goutput import wxCmdOutput
from core.settings import UserSettings
from nviz.workspace import NvizSettings
from nviz.animation import Animation
Modified: grass/trunk/gui/wxpython/nviz/workspace.py
--- grass/trunk/gui/wxpython/nviz/workspace.py 2011-12-08 20:10:09 UTC (rev 49627)
+++ grass/trunk/gui/wxpython/nviz/workspace.py 2011-12-08 20:11:28 UTC (rev 49628)
@@ -19,7 +19,7 @@
try:
- import nviz.wxnviz as wxnviz
+ from nviz import wxnviz
except ImportError:
wxnviz = None
Modified: grass/trunk/gui/wxpython/psmap/frame.py
--- grass/trunk/gui/wxpython/psmap/frame.py 2011-12-08 20:10:09 UTC (rev 49627)
+++ grass/trunk/gui/wxpython/psmap/frame.py 2011-12-08 20:11:28 UTC (rev 49628)
@@ -41,7 +41,7 @@
from gui_core.menu import Menu
from gui_core.goutput import CmdThread, EVT_CMD_DONE
from psmap.toolbars import PsMapToolbar
-from icon import Icons, MetaIcon, iconSet
+from icon import Icons
from core.gcmd import RunCommand, GError, GMessage
from gui_core.forms import GUI
from psmap.menudata import PsMapData
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py 2011-12-08 20:10:09 UTC (rev 49627)
+++ grass/trunk/gui/wxpython/wxgui.py 2011-12-08 20:11:28 UTC (rev 49628)
@@ -75,6 +75,7 @@
from lmgr.toolbars import LMMiscToolbar, LMVectorToolbar, LMNvizToolbar
from lmgr.pyshell import PyShellWindow
+from gcp.manager import GCPWizard
class GMFrame(wx.Frame):
"""!Layer Manager frame with notebook widget for controlling GRASS
@@ -347,7 +348,6 @@
def OnGCPManager(self, event):
"""!Launch georectifier module
- from gcp.manager import GCPWizard
GCPWizard(self)
def OnGModeler(self, event):
