[GRASS-SVN] r49655 - grass/trunk/lib/init
svn_grass at osgeo.org
Sun Dec 11 21:09:53 EST 2011
Author: hamish
Date: 2011-12-11 18:09:53 -0800 (Sun, 11 Dec 2011)
New Revision: 49655
grass/trunk/lib/init/variables.html
document OMP_NUM_THREADS enviro variable
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html 2011-12-12 02:02:08 UTC (rev 49654)
+++ grass/trunk/lib/init/variables.html 2011-12-12 02:09:53 UTC (rev 49655)
@@ -267,6 +267,12 @@
<dt>GRASS_NO_GLX_PIXMAPS</dt>
<dd>[nviz]<br>
Set to any value to disable the use of GLX Pixmaps.</dd>
+ <dt>OMP_NUM_THREADS</dt>
+ <dd>[OpenMP]<br>
+ If OpenMP support is enabled this limits the number of threads.
+ The default is set to the number of CPUs on the system.
+ Setting to '1' effectively disables parallel processing.</dd>
</dl>
<a name="rendering"></a>
