[GRASS-SVN] r49658 - grass/trunk/lib/rst/interp_float
svn_grass at osgeo.org
Sun Dec 11 23:33:11 EST 2011
Author: hamish
Date: 2011-12-11 20:33:11 -0800 (Sun, 11 Dec 2011)
New Revision: 49658
grass/trunk/lib/rst/interp_float/matrix.c
whitespace cleanup, doxygenize, use M_PI, add debug msg when calling G_ludcmp()
Modified: grass/trunk/lib/rst/interp_float/matrix.c
--- grass/trunk/lib/rst/interp_float/matrix.c 2011-12-12 04:15:37 UTC (rev 49657)
+++ grass/trunk/lib/rst/interp_float/matrix.c 2011-12-12 04:33:11 UTC (rev 49658)
@@ -1,5 +1,4 @@
* Original program and various modifications:
* Lubos Mitas
@@ -17,7 +16,6 @@
* modified by McCauley in August 1995
* modified by Mitasova in August 1995, Nov. 1996
#include <stdio.h>
@@ -27,7 +25,21 @@
#include <grass/interpf.h>
#include <grass/gmath.h>
-int IL_matrix_create(struct interp_params *params, struct triple *points, /* points for interpolation */
+ * \brief Creates system of linear equations from interpolated points
+ * Creates system of linear equations represented by matrix using given
+ * points and interpolating function interp()
+ * \param params struct interp_params *
+ * \param points struct triple * : points for interpolation
+ * \param n_points int : number of points
+ * \param matrix double **
+ * \return -1 on failure, 1 on success
+int IL_matrix_create(struct interp_params *params,
+ struct triple *points, /* points for interpolation */
int n_points, /* number of points */
double **matrix, /* matrix */
int *indx)
@@ -47,7 +59,7 @@
double xxr, yyr;
if (params->theta) {
- teta = params->theta / 57.295779; /* deg to rad */
+ teta = params->theta * (M_PI / 180); /* deg to rad */
rsin = sin(teta);
rcos = cos(teta);
@@ -67,11 +79,8 @@
- C
C GENERATION OF MATRIX
- C
C FIRST COLUMN
- C
A[1] = 0.;
for (k = 1; k <= n_points; k++) {
@@ -79,26 +88,24 @@
A[i1] = 1.;
- C
C OTHER COLUMNS
- C
RO = -params->rsm;
- /* fprintf (stderr,"sm[%d]=%f,ro=%f\n",1,points[1].smooth,RO); */
+ /* fprintf (stderr, "sm[%d] = %f, ro=%f\n", 1, points[1].smooth, RO); */
k1 = k * n1 + 1;
k2 = k + 1;
i1 = k1 + k;
if (params->rsm < 0.) { /*indicates variable smoothing */
A[i1] = -points[k - 1].sm; /* added by Mitasova nov. 96 */
- /* fprintf (stderr,"sm[%d]=%f,a=%f\n",k,points[k-1].sm,A[i1]); */
+ /* G_debug(5, "sm[%d]=%f, a=%f", k, points[k-1].sm, A[i1]); */
else {
A[i1] = RO; /* constant smoothing */
- /* if (i1 == 100) fprintf (stderr,"A[%d]=%f\n",i1,A[i1]); */
+ /* if (i1 == 100) fprintf (stderr,i "A[%d] = %f\n", i1, A[i1]); */
- /* A[i1] = RO; */
+ /* A[i1] = RO; */
for (l = k2; l <= n_points; l++) {
xx = points[k - 1].x - points[l - 1].x;
yy = points[k - 1].y - points[l - 1].y;
@@ -118,8 +125,8 @@
if (rfsta2 == 0.) {
- fprintf(stderr, "ident. points in segm. \n");
- fprintf(stderr, "x[%d]=%f,x[%d]=%f,y[%d]=%f,y[%d]=%f\n",
+ fprintf(stderr, "ident. points in segm.\n");
+ fprintf(stderr, "x[%d]=%f, x[%d]=%f, y[%d]=%f, y[%d]=%f\n",
k - 1, points[k - 1].x, l - 1, points[l - 1].x, k - 1,
points[k - 1].y, l - 1, points[l - 1].y);
return -1;
@@ -128,11 +135,8 @@
A[i1] = params->interp(r, params->fi);
- C
- C SYMMETRISATION
- C
+ /* C SYMMETRISATION */
amaxa = 1.;
for (k = 1; k <= n1; k++) {
k1 = (k - 1) * n1;
@@ -151,13 +155,13 @@
- if (G_ludcmp(matrix, n_points + 1, indx, &d) <= 0) { /* find the inverse of the mat
- rix */
- fprintf(stderr, "G_ludcmp() failed! n=%d\n", n_points);
+ G_debug(3, "calling G_ludcmp() n=%d indx=%d", n_points, *indx);
+ if (G_ludcmp(matrix, n_points + 1, indx, &d) <= 0) {
+ /* find the inverse of the matrix */
+ fprintf(stderr, "G_ludcmp() failed! n=%d d=%.2f\n", n_points, d);
return -1;
- G_free_vector(A);
+ /* G_free_vector(A); */
return 1;
