[GRASS-SVN] r49660 - grass/trunk/lib/rst/interp_float
svn_grass at osgeo.org
Sun Dec 11 23:51:29 EST 2011
Author: hamish
Date: 2011-12-11 20:51:29 -0800 (Sun, 11 Dec 2011)
New Revision: 49660
grass/trunk/lib/rst/interp_float/segmen2d.c
add note about the best place to parallelize v.surf.rst, partial-doxygenize, fix typo
Modified: grass/trunk/lib/rst/interp_float/segmen2d.c
--- grass/trunk/lib/rst/interp_float/segmen2d.c 2011-12-12 04:42:31 UTC (rev 49659)
+++ grass/trunk/lib/rst/interp_float/segmen2d.c 2011-12-12 04:51:29 UTC (rev 49660)
@@ -13,6 +13,24 @@
static double smallest_segment(struct multtree *, int);
+ * Recursively processes each segment in a tree by:
+ * a) finding points from neighbouring segments so that the total number of
+ * points is between KMIN and KMAX2 by calling tree function MT_get_region().
+ * b) creating and solving the system of linear equations using these points
+ * and interp() by calling matrix_create() and G_ludcmp().
+ * c) checking the interpolating function values at points by calling
+ * check_points().
+ * d) computing grid for this segment using points and interp() by calling
+ * grid_calc().
int IL_interp_segments_2d(struct interp_params *params, struct tree_info *info, /* info for the quad tree */
struct multtree *tree, /* current leaf of the quad tree */
struct BM *bitmask, /* bitmask */
@@ -24,17 +42,6 @@
int totsegm, /* total number of segments */
off_t offset1, /* offset for temp file writing */
double dnorm)
- Recursively processes each segment in a tree by
- a) finding points from neighbouring segments so that the total number of
- points is between KMIN and KMAX2 by calling tree function MT_get_region().
- b) creating and solving the system of linear equations using these points
- and interp() by calling matrix_create() and G_ludcmp().
- c) checking the interpolating function values at points by calling
- check_points().
- d) computing grid for this segment using points and interp() by calling
- grid_calc().
double xmn, xmx, ymn, ymx, distx, disty, distxp, distyp, temp1, temp2;
int i, npt, nptprev, MAXENC;
@@ -230,6 +237,8 @@
skip_point.y = 0.;
skip_point.z = 0.;
+ /*** TODO: parallelize this loop instead of the LU solver! ***/
for (skip_index = 0; skip_index < m_skip; skip_index++) {
if (params->cv) {
segtest = 0;
@@ -274,7 +283,7 @@
b[i + 1] = data->points[i].z;
b[0] = 0.;
G_lubksb(matrix, data->n_points + 1, indx, b);
- /* put here condition to skip ertot if not needed */
+ /* put here condition to skip error if not needed */
params->check_points(params, data, b, ertot, zmin, dnorm,
skip_point);
