[GRASS-SVN] r49671 - in grass/branches/develbranch_6/gui:
icons/grass2 wxpython/icons wxpython/mapdisp wxpython/psmap
wxpython/xml
svn_grass at osgeo.org
Mon Dec 12 04:40:29 EST 2011
Author: annakrat
Date: 2011-12-12 01:40:28 -0800 (Mon, 12 Dec 2011)
New Revision: 49671
Added:
grass/branches/develbranch_6/gui/icons/grass2/image-add.png
grass/branches/develbranch_6/gui/icons/grass2/north-arrow-add.png
grass/branches/develbranch_6/gui/wxpython/icons/icon.py
grass/branches/develbranch_6/gui/wxpython/mapdisp/frame.py
grass/branches/develbranch_6/gui/wxpython/psmap/dialogs.py
grass/branches/develbranch_6/gui/wxpython/psmap/frame.py
grass/branches/develbranch_6/gui/wxpython/xml/menudata_psmap.xml
wxGUI: map composer: merge recent changes from trunk
Added: grass/branches/develbranch_6/gui/icons/grass2/image-add.png
(Binary files differ)
Property changes on: grass/branches/develbranch_6/gui/icons/grass2/image-add.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: grass/branches/develbranch_6/gui/icons/grass2/north-arrow-add.png
Property changes on: grass/branches/develbranch_6/gui/icons/grass2/north-arrow-add.png
Modified: grass/branches/develbranch_6/gui/wxpython/icons/icon.py
--- grass/branches/develbranch_6/gui/wxpython/icons/icon.py 2011-12-12 09:12:29 UTC (rev 49670)
+++ grass/branches/develbranch_6/gui/wxpython/icons/icon.py 2011-12-12 09:40:28 UTC (rev 49671)
@@ -179,6 +179,8 @@
label = _('Add scalebar and north arrow')),
'addLegend' : MetaIcon(img = iconSet.get('legend-add', wx.ART_ERROR),
label = _('Add legend')),
+ 'addNorthArrow': MetaIcon(img = iconSet.get('north-arrow-add', wx.ART_ERROR),
+ label = _('North Arrow')),
'saveFile' : MetaIcon(img = iconSet.get('map-export', wx.ART_ERROR),
label = _('Save display to graphic file')),
'print' : MetaIcon(img = iconSet.get('print', wx.ART_ERROR),
@@ -461,13 +463,17 @@
'quit' : MetaIcon(img = iconSet.get('quit', wx.ART_ERROR),
label = _('Quit Cartographic Composer')),
'addText' : MetaIcon(img = iconSet.get('text-add', wx.ART_ERROR),
- label = _('Add text')),
+ label = _('Text')),
'addMapinfo' : MetaIcon(img = iconSet.get('map-info', wx.ART_ERROR),
- label = _('Add map info')),
+ label = _('Map info')),
- label = _('Add legend')),
+ label = _('Legend')),
'addScalebar' : MetaIcon(img = iconSet.get('scalebar-add', wx.ART_ERROR),
- label = _('Add scale bar')),
+ label = _('Scale bar')),
+ 'addImage' : MetaIcon(img = iconSet.get('image-add', wx.ART_ERROR),
+ label = _('Image')),
Modified: grass/branches/develbranch_6/gui/wxpython/mapdisp/frame.py
--- grass/branches/develbranch_6/gui/wxpython/mapdisp/frame.py 2011-12-12 09:12:29 UTC (rev 49670)
+++ grass/branches/develbranch_6/gui/wxpython/mapdisp/frame.py 2011-12-12 09:40:28 UTC (rev 49671)
@@ -1097,8 +1097,8 @@
# temporary
if self.IsPaneShown('3d'):
AddScale.Enable(False)
- AddArrow = wx.MenuItem(decmenu, wx.ID_ANY, _("Add north arrow"))
- AddArrow.SetBitmap(icons["addBarscale"].GetBitmap(self.iconsize))
+ AddArrow = wx.MenuItem(decmenu, wx.ID_ANY, icons['addNorthArrow'].GetLabel())
+ AddArrow.SetBitmap(icons['addNorthArrow'].GetBitmap(self.iconsize))
decmenu.AppendItem(AddArrow)
self.Bind(wx.EVT_MENU, self.OnAddArrow, AddArrow)
Modified: grass/branches/develbranch_6/gui/wxpython/psmap/dialogs.py
--- grass/branches/develbranch_6/gui/wxpython/psmap/dialogs.py 2011-12-12 09:12:29 UTC (rev 49670)
+++ grass/branches/develbranch_6/gui/wxpython/psmap/dialogs.py 2011-12-12 09:40:28 UTC (rev 49671)
@@ -379,7 +379,7 @@
kwargs = {}
if instruction == 'scalebar':
kwargs['scale'] = map['scale']
- elif instruction == 'text':
+ elif instruction in ('text', 'eps'):
kwargs['mapInstruction'] = map
elif instruction in ('vpoints', 'vlines', 'vareas'):
kwargs['id'] = wx.NewId()
@@ -408,6 +408,8 @@
buffer.append(line)
elif line.startswith('scale '):
+ if isBuffer:
+ continue
ok = self.SendToRead('scale', line, isRegionComment = isRegionComment)
if not ok: return False
@@ -433,6 +435,11 @@
elif line.startswith('text'):
instruction = 'text'
isBuffer = True
+ buffer.append(line)
+ elif line.startswith('eps'):
+ instruction = 'eps'
+ isBuffer = True
buffer.append(line)
elif line.startswith('colortable'):
@@ -543,6 +550,7 @@
mapinfo = ['mapinfo'],
scalebar = ['scalebar'],
text = ['text'],
+ eps = ['image', 'northArrow'],
vpoints = ['vector', 'vProperties'],
vlines = ['vector', 'vProperties'],
vareas = ['vector', 'vProperties'],
@@ -556,6 +564,8 @@
mapinfo = Mapinfo,
scalebar = Scalebar,
text = Text,
+ image = Image,
+ northArrow = NorthArrow,
rasterLegend = RasterLegend,
vectorLegend = VectorLegend,
vector = Vector,
@@ -566,12 +576,21 @@
for i in myInstruction:
instr = self.FindInstructionByType(i)
- if i in ('text', 'vProperties') or not instr:
+ if i in ('text', 'vProperties', 'image', 'northArrow') or not instr:
id = wx.NewId() #!vProperties expect subtype
if i == 'vProperties':
id = kwargs['id']
newInstr = myInstrDict[i](id, subType = instruction[1:])
+ elif i in ('image', 'northArrow'):
+ commentFound = False
+ for line in text:
+ if line.find("# north arrow") >= 0:
+ commentFound = True
+ if i == 'image' and commentFound or \
+ i == 'northArrow' and not commentFound:
+ continue
+ newInstr = myInstrDict[i](id, settings = self)
else:
newInstr = myInstrDict[i](id)
ok = newInstr.Read(instruction, text, **kwargs)
@@ -932,11 +951,30 @@
def __str__(self):
text = self.instruction['text'].replace('\n','\\n')
- instr = "text %s %s" % (self.instruction['east'], self.instruction['north'])
+ instr = u"text %s %s" % (self.instruction['east'], self.instruction['north'])
+ instr += " %s\n" % text
+ instr += (string.Template(" font $font\n fontsize $fontsize\n color $color\n").
+ substitute(self.instruction))
+ instr += string.Template(" hcolor $hcolor\n").substitute(self.instruction)
+ if self.instruction['hcolor'] != 'none':
+ instr += string.Template(" hwidth $hwidth\n").substitute(self.instruction)
+ instr += string.Template(" border $border\n").substitute(self.instruction)
+ if self.instruction['border'] != 'none':
+ instr += string.Template(" width $width\n").substitute(self.instruction)
+ instr += string.Template(" background $background\n").substitute(self.instruction)
+ if self.instruction["ref"] != '0':
+ instr += string.Template(" ref $ref\n").substitute(self.instruction)
+ if self.instruction["rotate"]:
+ instr += string.Template(" rotate $rotate\n").substitute(self.instruction)
+ if float(self.instruction["xoffset"]) or float(self.instruction["yoffset"]):
+ instr += (string.Template(" xoffset $xoffset\n yoffset $yoffset\n").
+ instr += " end"
try:
- instr += " %s\n" % text.encode('latin_1')
+ instr = instr.encode('latin1')
except UnicodeEncodeError, err:
try:
+ print err
pos = str(err).split('position')[1].split(':')[0].strip()
except IndexError:
pos = ''
@@ -950,24 +988,7 @@
"which is required by module ps.map.")
GMessage(message = message)
return ''
- instr += (string.Template(" font $font\n fontsize $fontsize\n color $color\n").
- substitute(self.instruction).
- encode('latin_1'))
- instr += string.Template(" hcolor $hcolor\n").substitute(self.instruction).encode('latin_1')
- if self.instruction['hcolor'] != 'none':
- instr += string.Template(" hwidth $hwidth\n").substitute(self.instruction).encode('latin_1')
- instr += string.Template(" border $border\n").substitute(self.instruction).encode('latin_1')
- if self.instruction['border'] != 'none':
- instr += string.Template(" width $width\n").substitute(self.instruction).encode('latin_1')
- instr += string.Template(" background $background\n").substitute(self.instruction).encode('latin_1')
- if self.instruction["ref"] != '0':
- instr += string.Template(" ref $ref\n").substitute(self.instruction).encode('latin_1')
- if self.instruction["rotate"]:
- instr += string.Template(" rotate $rotate\n").substitute(self.instruction).encode('latin_1')
- if float(self.instruction["xoffset"]) or float(self.instruction["yoffset"]):
- instr += (string.Template(" xoffset $xoffset\n yoffset $yoffset\n").
- substitute(self.instruction).encode('latin_1'))
- instr += " end"
return instr
def Read(self, instruction, text, **kwargs):
@@ -986,7 +1007,7 @@
instr['XY'] = False
instr['east'], instr['north'] = float(e), float(n)
- instr['text'] = line.split(None, 3)[3]
+ instr['text'] = line.split(None, 3)[3].decode('latin_1')
elif sub == 'font':
instr['font'] = line.split(None, 1)[1]
@@ -1031,7 +1052,149 @@
N = region['s'] + (region['n'] - region['s']) / 100 * n
E = region['w'] + (region['e'] - region['w']) / 100 * e
return E, N
+class Image(InstructionObject):
+ """!Class representing eps instruction - image"""
+ def __init__(self, id, settings):
+ InstructionObject.__init__(self, id = id)
+ self.settings = settings
+ self.type = 'image'
+ # default values
+ self.defaultInstruction = dict(epsfile = "", XY = True, where = (0,0), unit = 'inch',
+ east = None, north = None,
+ rotate = None, scale = 1)
+ # current values
+ self.instruction = dict(self.defaultInstruction)
+ def __str__(self):
+ self.ChangeRefPoint(toCenter = True)
+ instr = "eps %s %s\n" % (self.instruction['east'], self.instruction['north'])
+ instr += string.Template(" epsfile $epsfile\n").substitute(self.instruction)
+ if self.instruction["scale"]:
+ instr += string.Template(" scale $scale\n").substitute(self.instruction)
+ instr += " end"
+ return instr
+ def Read(self, instruction, text, **kwargs):
+ """!Read instruction and save information"""
+ mapInstr = kwargs['mapInstruction']
+ instr = {}
+ for line in text:
+ try:
+ sub = line.split(None, 1)[0]
+ if sub == 'eps':
+ e, n = line.split(None, 3)[1:3]
+ if '%' in e and '%' in n:
+ instr['XY'] = True
+ instr['east'], instr['north'] = self.PercentToReal(e, n)
+ else:
+ instr['XY'] = False
+ instr['east'], instr['north'] = float(e), float(n)
+ elif sub == 'epsfile':
+ instr['epsfile'] = line.split(None, 1)[1]
+ elif sub == 'rotate':
+ instr['rotate'] = float(line.split(None, 1)[1])
+ elif sub == 'scale':
+ instr['scale'] = float(line.split(None, 1)[1])
+ except(IndexError, ValueError):
+ GError(_("Failed to read instruction %s") % instruction)
+ return False
+ if not os.path.exists(instr['epsfile']):
+ GError(_("Failed to read instruction %s: file %s not found.") % instruction, instr['epsfile'])
+ return False
+ instr['epsfile'] = os.path.abspath(instr['epsfile'])
+ instr['size'] = self.GetImageOrigSize(instr['epsfile'])
+ if 'rotate' in instr:
+ instr['size'] = BBoxAfterRotation(instr['size'][0], instr['size'][1], instr['rotate'])
+ self.instruction.update(instr)
+ self.ChangeRefPoint(toCenter = False)
+ instr['where'] = PaperMapCoordinates(map = mapInstr, x = self.instruction['east'],
+ y = self.instruction['north'], paperToMap = False)
+ w = self.unitConv.convert(value = instr['size'][0], fromUnit = 'point', toUnit = 'inch')
+ h = self.unitConv.convert(value = instr['size'][1], fromUnit = 'point', toUnit = 'inch')
+ instr['rect'] = wx.Rect2D(x = float(instr['where'][0]), y = float(instr['where'][1]),
+ w = w * self.instruction['scale'], h = h * self.instruction['scale'])
+ return True
+ def PercentToReal(self, e, n):
+ """!Converts eps coordinates from percent of region to map coordinates"""
+ e, n = float(e.strip('%')), float(n.strip('%'))
+ region = grass.region()
+ N = region['s'] + (region['n'] - region['s']) / 100 * n
+ E = region['w'] + (region['e'] - region['w']) / 100 * e
+ return E, N
+ def ChangeRefPoint(self, toCenter):
+ """!Change reference point (left top x center)"""
+ mapInstr = self.settings.FindInstructionByType('map')
+ if not mapInstr:
+ mapInstr = self.settings.FindInstructionByType('initMap')
+ mapId = mapInstr.id
+ if toCenter:
+ center = self.instruction['rect'].GetCentre()
+ ENCenter = PaperMapCoordinates(map = self.settings[mapId],
+ x = center[0], y = center[1], paperToMap = True)
+ self.instruction['east'], self.instruction['north'] = ENCenter
+ else:
+ x, y = PaperMapCoordinates(map = self.settings[mapId], x = self.instruction['east'],
+ w = self.unitConv.convert(value = self.instruction['size'][0], fromUnit = 'point', toUnit = 'inch')
+ h = self.unitConv.convert(value = self.instruction['size'][1], fromUnit = 'point', toUnit = 'inch')
+ x -= w * self.instruction['scale'] / 2
+ y -= h * self.instruction['scale'] / 2
+ e, n = PaperMapCoordinates(map = self.settings[mapId], x = x, y = y, paperToMap = True)
+ self.instruction['east'], self.instruction['north'] = e, n
+ def GetImageOrigSize(self, imagePath):
+ """!Get image size.
+ If eps, size is read from image header.
+ fileName = os.path.split(imagePath)[1]
+ # if eps, read info from header
+ if os.path.splitext(fileName)[1].lower() == '.eps':
+ bbInfo = "%%BoundingBox"
+ file = open(imagePath,"r")
+ w = h = 0
+ while file:
+ line = file.readline()
+ if line.find(bbInfo) == 0:
+ w, h = line.split()[3:5]
+ break
+ file.close()
+ return float(w), float(h)
+ else: # we can use wx.Image
+ img = wx.Image(fileName, type=wx.BITMAP_TYPE_ANY)
+ return img.GetWidth(), img.GetHeight()
+class NorthArrow(Image):
+ """!Class representing eps instruction -- North Arrow"""
+ Image.__init__(self, id = id, settings = settings)
+ self.type = 'northArrow'
+ instr += "# north arrow\n"
+ instr += " end"
+ return instr
class Scalebar(InstructionObject):
"""!Class representing scalebar instruction"""
def __init__(self, id):
@@ -1520,6 +1683,24 @@
vInstruction += string.Template(" label $label\n lpos $lpos\n").substitute(dic)
vInstruction += " end"
+ try:
+ vInstruction = vInstruction.encode('Latin_1')
+ except UnicodeEncodeError, err:
+ try:
+ print err
+ pos = str(err).split('position')[1].split(':')[0].strip()
+ except IndexError:
+ pos = ''
+ if pos:
+ message = _("Characters on position %s are not supported "
+ "by ISO-8859-1 (Latin 1) encoding "
+ "which is required by module ps.map.") % pos
+ else:
+ message = _("Not all characters are supported "
+ GMessage(message = message)
+ return ''
return vInstruction
@@ -1533,7 +1714,7 @@
instr['name'] = info['fullname']
#connection
instr['connection'] = True
- self.mapDBInfo = dbm_base.VectorDBInfo(instr['name'])
+ self.mapDBInfo = VectorDBInfo(instr['name'])
self.layers = self.mapDBInfo.layers.keys()
if not self.layers:
instr['connection'] = False
@@ -1612,7 +1793,7 @@
if line.startswith('lpos'):
instr['lpos'] = int(line.split()[1])
elif line.startswith('label'):
- instr['label'] = line.split(None, 1)[1]
+ instr['label'] = line.split(None, 1)[1].decode('latin_1')
elif line.startswith('layer'):
instr['layer'] = line.split()[1]
elif line.startswith('masked'):
@@ -1646,7 +1827,7 @@
self.instruction = settings
self.objectType = None
self.unitConv = UnitConversion(self)
- self.spinCtrlSize = (50, -1)
+ self.spinCtrlSize = (65, -1)
self.Bind(wx.EVT_CLOSE, self.OnClose)
@@ -1660,7 +1841,8 @@
parent.units['unitsCtrl'].SetStringSelection(self.unitConv.findName(dialogDict['unit']))
def AddPosition(self, parent, dialogDict):
- parent.position = dict()
+ if not hasattr(parent, "position"):
+ parent.position = dict()
parent.position['comment'] = wx.StaticText(parent, id = wx.ID_ANY,\
label = _("Position of the top left corner\nfrom the top left edge of the paper"))
parent.position['xLabel'] = wx.StaticText(parent, id = wx.ID_ANY, label = _("X:"))
@@ -1673,6 +1855,63 @@
parent.position['xCtrl'].SetValue("%5.3f" % x)
parent.position['yCtrl'].SetValue("%5.3f" % y)
+ def AddExtendedPosition(self, panel, gridBagSizer, dialogDict):
+ """!Add widgets for setting position relative to paper and to map"""
+ panel.position = dict()
+ positionLabel = wx.StaticText(panel, id = wx.ID_ANY, label = _("Position is given:"))
+ panel.position['toPaper'] = wx.RadioButton(panel, id = wx.ID_ANY, label = _("relatively to paper"), style = wx.RB_GROUP)
+ panel.position['toMap'] = wx.RadioButton(panel, id = wx.ID_ANY, label = _("by map coordinates"))
+ panel.position['toPaper'].SetValue(dialogDict['XY'])
+ panel.position['toMap'].SetValue(not dialogDict['XY'])
+ gridBagSizer.Add(positionLabel, pos = (0,0), span = (1,3), flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_LEFT, border = 0)
+ gridBagSizer.Add(panel.position['toPaper'], pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_LEFT, border = 0)
+ gridBagSizer.Add(panel.position['toMap'], pos = (1,1),flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_LEFT, border = 0)
+ # first box - paper coordinates
+ box1 = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = "")
+ sizerP = wx.StaticBoxSizer(box1, wx.VERTICAL)
+ self.gridBagSizerP = wx.GridBagSizer (hgap = 5, vgap = 5)
+ self.gridBagSizerP.AddGrowableCol(1)
+ self.gridBagSizerP.AddGrowableRow(3)
+ self.AddPosition(parent = panel, dialogDict = dialogDict)
+ panel.position['comment'].SetLabel(_("Position from the top left\nedge of the paper"))
+ self.AddUnits(parent = panel, dialogDict = dialogDict)
+ self.gridBagSizerP.Add(panel.units['unitsLabel'], pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ self.gridBagSizerP.Add(panel.units['unitsCtrl'], pos = (0,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ self.gridBagSizerP.Add(panel.position['xLabel'], pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ self.gridBagSizerP.Add(panel.position['xCtrl'], pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ self.gridBagSizerP.Add(panel.position['yLabel'], pos = (2,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ self.gridBagSizerP.Add(panel.position['yCtrl'], pos = (2,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ self.gridBagSizerP.Add(panel.position['comment'], pos = (3,0), span = (1,2), flag = wx.ALIGN_BOTTOM, border = 0)
+ sizerP.Add(self.gridBagSizerP, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
+ gridBagSizer.Add(sizerP, pos = (2,0),span = (1,1), flag = wx.ALIGN_CENTER_HORIZONTAL|wx.EXPAND, border = 0)
+ # second box - map coordinates
+ box2 = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = "")
+ sizerM = wx.StaticBoxSizer(box2, wx.VERTICAL)
+ self.gridBagSizerM = wx.GridBagSizer (hgap = 5, vgap = 5)
+ self.gridBagSizerM.AddGrowableCol(0)
+ self.gridBagSizerM.AddGrowableCol(1)
+ eastingLabel = wx.StaticText(panel, id = wx.ID_ANY, label = "E:")
+ northingLabel = wx.StaticText(panel, id = wx.ID_ANY, label = "N:")
+ panel.position['eCtrl'] = wx.TextCtrl(panel, id = wx.ID_ANY, value = "")
+ panel.position['nCtrl'] = wx.TextCtrl(panel, id = wx.ID_ANY, value = "")
+ east, north = PaperMapCoordinates(map = self.instruction[self.mapId], x = dialogDict['where'][0], y = dialogDict['where'][1], paperToMap = True)
+ panel.position['eCtrl'].SetValue(str(east))
+ panel.position['nCtrl'].SetValue(str(north))
+ self.gridBagSizerM.Add(eastingLabel, pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ self.gridBagSizerM.Add(northingLabel, pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ self.gridBagSizerM.Add(panel.position['eCtrl'], pos = (0,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ self.gridBagSizerM.Add(panel.position['nCtrl'], pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ sizerM.Add(self.gridBagSizerM, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
+ gridBagSizer.Add(sizerM, pos = (2,1), flag = wx.ALIGN_LEFT|wx.EXPAND, border = 0)
def AddFont(self, parent, dialogDict, color = True):
parent.font = dict()
## parent.font['fontLabel'] = wx.StaticText(parent, id = wx.ID_ANY, label = _("Choose font:"))
@@ -2607,24 +2846,31 @@
def update(self):
#draw raster
- map = self.instruction.FindInstructionByType('map')
+ mapInstr = self.instruction.FindInstructionByType('map')
+ if not mapInstr: # no map frame
+ GMessage(message = _("Please, create map frame first."))
+ return
if self.rasterNoRadio.GetValue() or not self.rasterSelect.GetValue():
self.rasterDict['isRaster'] = False
self.rasterDict['raster'] = None
- map['drawMap'] = False
+ mapInstr['drawMap'] = False
if self.id in self.instruction:
del self.instruction[self.id]
else:
self.rasterDict['isRaster'] = True
self.rasterDict['raster'] = self.rasterSelect.GetValue()
- if self.rasterDict['raster'] != map['drawMap']:
- if self.id not in self.instruction:
+ if self.rasterDict['raster'] != mapInstr['drawMap']:
+ raster = self.instruction.FindInstructionByType('raster')
+ if not raster:
raster = Raster(self.id)
self.instruction.AddInstruction(raster)
- self.instruction[self.id].SetInstruction(self.rasterDict)
+ self.instruction[self.id].SetInstruction(self.rasterDict)
+ else:
+ self.instruction[raster.id].SetInstruction(self.rasterDict)
if 'map' in self.mainDialog.parent.openDialogs:
self.mainDialog.parent.openDialogs['map'].updateDialog()
@@ -2983,7 +3229,7 @@
#vector map info
self.connection = True
try:
- self.mapDBInfo = dbm_base.VectorDBInfo(self.vectorName)
+ self.mapDBInfo = VectorDBInfo(self.vectorName)
except grass.ScriptError:
self.connection = False
@@ -5176,74 +5422,22 @@
panel.Fit()
return panel
def _positionPanel(self, notebook):
panel = wx.Panel(parent = notebook, id = wx.ID_ANY, style = wx.TAB_TRAVERSAL)
notebook.AddPage(page = panel, text = _("Position"))
border = wx.BoxSizer(wx.VERTICAL)
- #Position
box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Position"))
sizer = wx.StaticBoxSizer(box, wx.HORIZONTAL)
gridBagSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
gridBagSizer.AddGrowableCol(0)
gridBagSizer.AddGrowableCol(1)
- self.positionLabel = wx.StaticText(panel, id = wx.ID_ANY, label = _("Position is given:"))
- self.paperPositionCtrl = wx.RadioButton(panel, id = wx.ID_ANY, label = _("relatively to paper"), style = wx.RB_GROUP)
- self.mapPositionCtrl = wx.RadioButton(panel, id = wx.ID_ANY, label = _("by map coordinates"))
- self.paperPositionCtrl.SetValue(self.textDict['XY'])
- self.mapPositionCtrl.SetValue(not self.textDict['XY'])
+ #Position
+ self.AddExtendedPosition(panel, gridBagSizer, self.textDict)
- gridBagSizer.Add(self.positionLabel, pos = (0,0), span = (1,3), flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_LEFT, border = 0)
- gridBagSizer.Add(self.paperPositionCtrl, pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_LEFT, border = 0)
- gridBagSizer.Add(self.mapPositionCtrl, pos = (1,1),flag = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_LEFT, border = 0)
- # first box - paper coordinates
- box1 = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = "")
- sizerP = wx.StaticBoxSizer(box1, wx.VERTICAL)
- self.gridBagSizerP = wx.GridBagSizer (hgap = 5, vgap = 5)
- self.gridBagSizerP.AddGrowableCol(1)
- self.gridBagSizerP.AddGrowableRow(3)
- self.AddPosition(parent = panel, dialogDict = self.textDict)
- panel.position['comment'].SetLabel(_("Position from the top left\nedge of the paper"))
- self.AddUnits(parent = panel, dialogDict = self.textDict)
- self.gridBagSizerP.Add(panel.units['unitsLabel'], pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
- self.gridBagSizerP.Add(panel.units['unitsCtrl'], pos = (0,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
- self.gridBagSizerP.Add(panel.position['xLabel'], pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
- self.gridBagSizerP.Add(panel.position['xCtrl'], pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
- self.gridBagSizerP.Add(panel.position['yLabel'], pos = (2,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
- self.gridBagSizerP.Add(panel.position['yCtrl'], pos = (2,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
- self.gridBagSizerP.Add(panel.position['comment'], pos = (3,0), span = (1,2), flag = wx.ALIGN_BOTTOM, border = 0)
- sizerP.Add(self.gridBagSizerP, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
- gridBagSizer.Add(sizerP, pos = (2,0),span = (1,1), flag = wx.ALIGN_CENTER_HORIZONTAL|wx.EXPAND, border = 0)
- # second box - map coordinates
- box2 = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = "")
- sizerM = wx.StaticBoxSizer(box2, wx.VERTICAL)
- self.gridBagSizerM = wx.GridBagSizer (hgap = 5, vgap = 5)
- self.gridBagSizerM.AddGrowableCol(0)
- self.gridBagSizerM.AddGrowableCol(1)
- self.eastingLabel = wx.StaticText(panel, id = wx.ID_ANY, label = "E:")
- self.northingLabel = wx.StaticText(panel, id = wx.ID_ANY, label = "N:")
- self.eastingCtrl = wx.TextCtrl(panel, id = wx.ID_ANY, value = "")
- self.northingCtrl = wx.TextCtrl(panel, id = wx.ID_ANY, value = "")
- east, north = PaperMapCoordinates(map = self.instruction[self.mapId], x = self.textDict['where'][0], y = self.textDict['where'][1], paperToMap = True)
- self.eastingCtrl.SetValue(str(east))
- self.northingCtrl.SetValue(str(north))
- self.gridBagSizerM.Add(self.eastingLabel, pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
- self.gridBagSizerM.Add(self.northingLabel, pos = (1,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
- self.gridBagSizerM.Add(self.eastingCtrl, pos = (0,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
- self.gridBagSizerM.Add(self.northingCtrl, pos = (1,1), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
- sizerM.Add(self.gridBagSizerM, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
- gridBagSizer.Add(sizerM, pos = (2,1), flag = wx.ALIGN_LEFT|wx.EXPAND, border = 0)
#offset
box3 = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " %_("Offset"))
sizerO = wx.StaticBoxSizer(box3, wx.VERTICAL)
@@ -5307,8 +5501,8 @@
panel.SetSizer(border)
panel.Fit()
- self.Bind(wx.EVT_RADIOBUTTON, self.OnPositionType, self.paperPositionCtrl)
- self.Bind(wx.EVT_RADIOBUTTON, self.OnPositionType, self.mapPositionCtrl)
+ self.Bind(wx.EVT_RADIOBUTTON, self.OnPositionType, panel.position['toPaper'])
+ self.Bind(wx.EVT_RADIOBUTTON, self.OnPositionType, panel.position['toMap'])
self.Bind(wx.EVT_CHECKBOX, self.OnRotation, self.rotCtrl)
return panel
@@ -5323,7 +5517,7 @@
self.rotValue.Disable()
def OnPositionType(self, event):
- if self.paperPositionCtrl.GetValue():
+ if self.positionPanel.position['toPaper'].GetValue():
for widget in self.gridBagSizerP.GetChildren():
widget.GetWindow().Enable()
for widget in self.gridBagSizerM.GetChildren():
@@ -5404,7 +5598,7 @@
self.textDict['yoffset'] = self.yoffCtrl.GetValue()
#position
self.textDict['XY'] = True
currUnit = self.unitConv.findUnit(self.positionPanel.units['unitsCtrl'].GetStringSelection())
self.textDict['unit'] = currUnit
@@ -5424,13 +5618,13 @@
self.textDict['east'], self.textDict['north'] = PaperMapCoordinates(self.instruction[self.mapId], x, y, paperToMap = True)
else:
self.textDict['XY'] = False
- if self.eastingCtrl.GetValue():
- self.textDict['east'] = self.eastingCtrl.GetValue()
+ if self.positionPanel.position['eCtrl'].GetValue():
+ self.textDict['east'] = self.positionPanel.position['eCtrl'].GetValue()
else:
self.textDict['east'] = self.textDict['east']
- if self.northingCtrl.GetValue():
- self.textDict['north'] = self.northingCtrl.GetValue()
+ if self.positionPanel.position['nCtrl'].GetValue():
+ self.textDict['north'] = self.positionPanel.position['nCtrl'].GetValue()
else:
self.textDict['north'] = self.textDict['north']
@@ -5469,9 +5663,471 @@
self.positionPanel.position['yCtrl'].SetValue("%5.3f" % y)
# EN coordinates
e, n = self.textDict['east'], self.textDict['north']
- self.eastingCtrl.SetValue(str(self.textDict['east']))
- self.northingCtrl.SetValue(str(self.textDict['north']))
+ self.positionPanel.position['eCtrl'].SetValue(str(self.textDict['east']))
+ self.positionPanel.position['nCtrl'].SetValue(str(self.textDict['north']))
+class ImageDialog(PsmapDialog):
+ """!Dialog for setting image properties.
+ It's base dialog for North Arrow dialog.
+ def __init__(self, parent, id, settings, imagePanelName = _("Image")):
+ PsmapDialog.__init__(self, parent = parent, id = id, title = "Image settings",
+ settings = settings)
+ self.objectType = ('image',)
+ if self.id is not None:
+ self.imageObj = self.instruction[self.id]
+ self.imageDict = self.instruction[id].GetInstruction()
+ else:
+ self.id = wx.NewId()
+ self.imageObj = self._newObject()
+ self.imageDict = self.imageObj.GetInstruction()
+ page = self.instruction.FindInstructionByType('page').GetInstruction()
+ self.imageDict['where'] = page['Left'], page['Top']
+ map = self.instruction.FindInstructionByType('map')
+ if not map:
+ map = self.instruction.FindInstructionByType('initMap')
+ self.mapId = map.id
+ self.imageDict['east'], self.imageDict['north'] = PaperMapCoordinates(map = map, x = self.imageDict['where'][0], y = self.imageDict['where'][1], paperToMap = True)
+ notebook = wx.Notebook(parent = self, id = wx.ID_ANY, style = wx.BK_DEFAULT)
+ self.imagePanelName = imagePanelName
+ self.imagePanel = self._imagePanel(notebook)
+ self.positionPanel = self._positionPanel(notebook)
+ self.OnPositionType(None)
+ if self.imageDict['epsfile']:
+ self.imagePanel.image['dir'].SetValue(os.path.dirname(self.imageDict['epsfile']))
+ else:
+ self.imagePanel.image['dir'].SetValue(self._getImageDirectory())
+ self.OnDirChanged(None)
+ self._layout(notebook)
+ def _newObject(self):
+ """!Create corresponding instruction object"""
+ return Image(self.id, self.instruction)
+ def _imagePanel(self, notebook):
+ panel = wx.Panel(parent = notebook, id = wx.ID_ANY, size = (-1, -1), style = wx.TAB_TRAVERSAL)
+ notebook.AddPage(page = panel, text = self.imagePanelName)
+ border = wx.BoxSizer(wx.VERTICAL)
+ # choose image
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Image"))
+ sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ # choose directory
+ panel.image = {}
+ startDir = os.path.dirname(self.imageDict['epsfile'])
+ else:
+ startDir = self._getImageDirectory()
+ dir = filebrowse.DirBrowseButton(parent = panel, id = wx.ID_ANY,
+ labelText = _("Choose a directory:"),
+ dialogTitle = _("Choose a directory with images"),
+ buttonText = _('Browse'),
+ startDirectory = startDir,
+ changeCallback = self.OnDirChanged)
+ panel.image['dir'] = dir
+ sizer.Add(item = dir, proportion = 0, flag = wx.EXPAND, border = 0)
+ # image list
+ hSizer = wx.BoxSizer(wx.HORIZONTAL)
+ imageList = wx.ListBox(parent = panel, id = wx.ID_ANY)
+ panel.image['list'] = imageList
+ imageList.Bind(wx.EVT_LISTBOX, self.OnImageSelectionChanged)
+ hSizer.Add(item = imageList, proportion = 1, flag = wx.EXPAND | wx.RIGHT, border = 10)
+ # image preview
+ vSizer = wx.BoxSizer(wx.VERTICAL)
+ self.previewSize = (150, 150)
+ img = wx.EmptyImage(*self.previewSize)
+ panel.image['preview'] = wx.StaticBitmap(parent = panel, id = wx.ID_ANY,
+ bitmap = wx.BitmapFromImage(img))
+ vSizer.Add(item = panel.image['preview'], proportion = 0, flag = wx.EXPAND | wx.BOTTOM, border = 5)
+ panel.image['sizeInfo'] = wx.StaticText(parent = panel, id = wx.ID_ANY)
+ vSizer.Add(item = panel.image['sizeInfo'], proportion = 0, flag = wx.ALIGN_CENTER, border = 0)
+ hSizer.Add(item = vSizer, proportion = 0, flag = wx.EXPAND, border = 0)
+ sizer.Add(item = hSizer, proportion = 1, flag = wx.EXPAND | wx.ALL, border = 3)
+ epsInfo = wx.StaticText(parent = panel, id = wx.ID_ANY,
+ label = _("Note: only EPS format supported"))
+ sizer.Add(item = epsInfo, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL, border = 3)
+ border.Add(item = sizer, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 5)
+ # rotation
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Scale And Rotation"))
+ gridSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
+ scaleLabel = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Scale:"))
+ if fs:
+ panel.image['scale'] = fs.FloatSpin(panel, id = wx.ID_ANY, min_val = 0, max_val = 50,
+ increment = 0.5, value = 1, style = fs.FS_RIGHT, size = self.spinCtrlSize)
+ panel.image['scale'].SetFormat("%f")
+ panel.image['scale'].SetDigits(1)
+ else:
+ panel.image['scale'] = wx.TextCtrl(panel, id = wx.ID_ANY, size = self.spinCtrlSize,
+ validator = TCValidator(flag = 'DIGIT_ONLY'))
+ if self.imageDict['scale']:
+ if fs:
+ value = float(self.imageDict['scale'])
+ else:
+ value = str(self.imageDict['scale'])
+ else:
+ if fs:
+ value = 0
+ else:
+ value = '0'
+ panel.image['scale'].SetValue(value)
+ gridSizer.Add(item = scaleLabel, pos = (0, 0), flag = wx.ALIGN_CENTER_VERTICAL)
+ gridSizer.Add(item = panel.image['scale'], pos = (0, 1), flag = wx.ALIGN_CENTER_VERTICAL)
+ rotLabel = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Rotation angle (deg):"))
+ if fs:
+ panel.image['rotate'] = fs.FloatSpin(panel, id = wx.ID_ANY, min_val = 0, max_val = 360,
+ increment = 0.5, value = 0, style = fs.FS_RIGHT, size = self.spinCtrlSize)
+ panel.image['rotate'].SetFormat("%f")
+ panel.image['rotate'].SetDigits(1)
+ else:
+ panel.image['rotate'] = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = self.spinCtrlSize,
+ min = 0, max = 359, initial = 0)
+ panel.image['rotate'].SetToolTipString(_("Counterclockwise rotation in degrees"))
+ if self.imageDict['rotate']:
+ panel.image['rotate'].SetValue(int(self.imageDict['rotate']))
+ else:
+ panel.image['rotate'].SetValue(0)
+ gridSizer.Add(item = rotLabel, pos = (1, 0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
+ gridSizer.Add(item = panel.image['rotate'], pos = (1, 1), flag = wx.ALIGN_CENTER_VERTICAL)
+ self._addConvergence(panel = panel, gridBagSizer = gridSizer)
+ sizer.Add(item = gridSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = 5)
+ panel.SetSizer(border)
+ panel.Fit()
+ return panel
+ def _positionPanel(self, notebook):
+ notebook.AddPage(page = panel, text = _("Position"))
+ # set position
+ box = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Position"))
+ gridBagSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
+ gridBagSizer.AddGrowableCol(0)
+ gridBagSizer.AddGrowableCol(1)
+ self.AddExtendedPosition(panel, gridBagSizer, self.imageDict)
+ sizer.Add(gridBagSizer, proportion = 1, flag = wx.ALIGN_CENTER_VERTICAL| wx.ALL, border = 5)
+ panel.Fit()
+ return panel
+ def OnDirChanged(self, event):
+ """!Image directory changed"""
+ path = self.imagePanel.image['dir'].GetValue()
+ try:
+ files = os.listdir(path)
+ except OSError: # no such directory
+ files = []
+ imageList = []
+ # no setter for startDirectory?
+ try:
+ self.imagePanel.image['dir'].startDirectory = path
+ except AttributeError: # for sure
+ pass
+ for file in files:
+ if os.path.splitext(file)[1].lower() == '.eps':
+ imageList.append(file)
+ imageList.sort()
+ self.imagePanel.image['list'].SetItems(imageList)
+ file = os.path.basename(self.imageDict['epsfile'])
+ self.imagePanel.image['list'].SetStringSelection(file)
+ elif imageList:
+ self.imagePanel.image['list'].SetSelection(0)
+ self.OnImageSelectionChanged(None)
+ def OnPositionType(self, event):
+ for widget in self.gridBagSizerP.GetChildren():
+ widget.GetWindow().Enable()
+ for widget in self.gridBagSizerM.GetChildren():
+ widget.GetWindow().Disable()
+ else:
+ def _getImageDirectory(self):
+ """!Default image directory"""
+ return os.getcwd()
+ def _addConvergence(self, panel, gridBagSizer):
+ pass
+ def OnImageSelectionChanged(self, event):
+ """!Image selected, show preview and size"""
+ if not self.imagePanel.image['dir']: # event is emitted when closing dialog an it causes error
+ return
+ if not havePILImage:
+ self.DrawWarningText(_("PIL\nmissing"))
+ return
+ imageName = self.imagePanel.image['list'].GetStringSelection()
+ if not imageName:
+ self.ClearPreview()
+ return
+ basePath = self.imagePanel.image['dir'].GetValue()
+ file = os.path.join(basePath, imageName)
+ if not os.path.exists(file):
+ return
+ try:
+ pImg = PILImage.open(file)
+ img = PilImageToWxImage(pImg)
+ except IOError, e:
+ GError(message = _("Unable to read file %s") % file)
+ return
+ self.SetSizeInfoLabel(img)
+ img = self.ScaleToPreview(img)
+ bitmap = img.ConvertToBitmap()
+ self.DrawBitmap(bitmap)
+ else:
+ # TODO: read other formats and convert by PIL to eps
+ pass
+ def ScaleToPreview(self, img):
+ """!Scale image to preview size"""
+ w = img.GetWidth()
+ h = img.GetHeight()
+ if w <= self.previewSize[0] and h <= self.previewSize[1]:
+ return img
+ if w > h:
+ newW = self.previewSize[0]
+ newH = self.previewSize[0] * h / w
+ else:
+ newW = self.previewSize[0] * w / h
+ return img.Scale(newW, newH, wx.IMAGE_QUALITY_HIGH)
+ def DrawWarningText(self, warning):
+ """!Draw text on preview window"""
+ buffer = wx.EmptyBitmap(*self.previewSize)
+ dc = wx.MemoryDC()
+ dc.SelectObject(buffer)
+ dc.SetBrush(wx.Brush(wx.Color(250, 250, 250)))
+ dc.Clear()
+ extent = dc.GetTextExtent(warning)
+ posX = self.previewSize[0] / 2 - extent[0] / 2
+ posY = self.previewSize[1] / 2 - extent[1] / 2
+ dc.DrawText(warning, posX, posY)
+ self.imagePanel.image['preview'].SetBitmap(buffer)
+ dc.SelectObject(wx.NullBitmap)
+ def DrawBitmap(self, bitmap):
+ """!Draw bitmap, center it if smaller than preview size"""
+ if bitmap.GetWidth() <= self.previewSize[0] and bitmap.GetHeight() <= self.previewSize[1]:
+ dc.SetBrush(dc.GetBrush())
+ dc.Clear()
+ posX = self.previewSize[0] / 2 - bitmap.GetWidth() / 2
+ posY = self.previewSize[1] / 2 - bitmap.GetHeight() / 2
+ dc.DrawBitmap(bitmap, posX, posY)
+ else:
+ self.imagePanel.image['preview'].SetBitmap(bitmap)
+ def SetSizeInfoLabel(self, image):
+ """!Update image size label"""
+ self.imagePanel.image['sizeInfo'].SetLabel(_("size: %s x %s pts") % (image.GetWidth(), image.GetHeight()))
+ self.imagePanel.image['sizeInfo'].GetContainingSizer().Layout()
+ def ClearPreview(self):
+ """!Clear preview window"""
+ dc.SetBrush(wx.WHITE_BRUSH)
+ dc.Clear()
+ mask = wx.Mask(buffer, wx.WHITE)
+ buffer.SetMask(mask)
+ def update(self):
+ # epsfile
+ selected = self.imagePanel.image['list'].GetStringSelection()
+ if not selected:
+ gcmd.GMessage(parent = self, message = _("No image selected."))
+ return False
+ self.imageDict['epsfile'] = os.path.join(basePath, selected)
+ #position
+ self.imageDict['XY'] = True
+ currUnit = self.unitConv.findUnit(self.positionPanel.units['unitsCtrl'].GetStringSelection())
+ self.imageDict['unit'] = currUnit
+ if self.positionPanel.position['xCtrl'].GetValue():
+ x = self.positionPanel.position['xCtrl'].GetValue()
+ else:
+ x = self.imageDict['where'][0]
+ if self.positionPanel.position['yCtrl'].GetValue():
+ y = self.positionPanel.position['yCtrl'].GetValue()
+ else:
+ y = self.imageDict['where'][1]
+ x = self.unitConv.convert(value = float(x), fromUnit = currUnit, toUnit = 'inch')
+ y = self.unitConv.convert(value = float(y), fromUnit = currUnit, toUnit = 'inch')
+ self.imageDict['where'] = x, y
+ else:
+ self.imageDict['XY'] = False
+ e = self.positionPanel.position['eCtrl'].GetValue()
+ else:
+ self.imageDict['east'] = self.imageDict['east']
+ n = self.positionPanel.position['nCtrl'].GetValue()
+ else:
+ self.imageDict['north'] = self.imageDict['north']
+ x, y = PaperMapCoordinates(map = self.instruction[self.mapId], x = float(self.imageDict['east']),
+ y = float(self.imageDict['north']), paperToMap = False)
+ #rotation
+ rot = self.imagePanel.image['rotate'].GetValue()
+ if rot == 0:
+ self.imageDict['rotate'] = None
+ else:
+ self.imageDict['rotate'] = rot
+ #scale
+ self.imageDict['scale'] = self.imagePanel.image['scale'].GetValue()
+ # scale
+ w, h = self.imageObj.GetImageOrigSize(self.imageDict['epsfile'])
+ self.imageDict['size'] = BBoxAfterRotation(w, h, self.imageDict['rotate'])
+ else:
+ self.imageDict['size'] = w, h
+ w = self.unitConv.convert(value = self.imageDict['size'][0],
+ fromUnit = 'point', toUnit = 'inch')
+ h = self.unitConv.convert(value = self.imageDict['size'][1],
+ self.imageDict['rect'] = wx.Rect2D(x = x, y = y,
+ w = w * self.imageDict['scale'],
+ h = h * self.imageDict['scale'])
+ if self.id not in self.instruction:
+ image = self._newObject()
+ self.instruction.AddInstruction(image)
+ self.instruction[self.id].SetInstruction(self.imageDict)
+ if self.id not in self.parent.objectId:
+ self.parent.objectId.append(self.id)
+ return True
+ def updateDialog(self):
+ """!Update text coordinates, after moving"""
+ # XY coordinates
+ x, y = self.imageDict['where'][:2]
+ x = self.unitConv.convert(value = x, fromUnit = 'inch', toUnit = currUnit)
+ y = self.unitConv.convert(value = y, fromUnit = 'inch', toUnit = currUnit)
+ self.positionPanel.position['xCtrl'].SetValue("%5.3f" % x)
+ self.positionPanel.position['yCtrl'].SetValue("%5.3f" % y)
+ # EN coordinates
+ e, n = self.imageDict['east'], self.imageDict['north']
+ self.positionPanel.position['eCtrl'].SetValue(str(self.imageDict['east']))
+ self.positionPanel.position['nCtrl'].SetValue(str(self.imageDict['north']))
+class NorthArrowDialog(ImageDialog):
+ def __init__(self, parent, id, settings):
+ ImageDialog.__init__(self, parent = parent, id = id, settings = settings,
+ imagePanelName = _("North Arrow"))
+ self.objectType = ('northArrow',)
+ self.SetTitle(_("North Arrow settings"))
+ return NorthArrow(self.id, self.instruction)
+ gisbase = os.getenv("GISBASE")
+ return os.path.join(gisbase, 'etc', 'paint', 'decorations')
+ convergence = wx.Button(parent = panel, id = wx.ID_ANY,
+ label = _("Compute convergence"))
+ gridBagSizer.Add(item = convergence, pos = (1, 2),
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
+ convergence.Bind(wx.EVT_BUTTON, self.OnConvergence)
+ panel.image['convergence'] = convergence
+ def OnConvergence(self, event):
+ ret = RunCommand('g.region', read = True, flags = 'ng')
+ if ret:
+ convergence = float(ret.strip().split('=')[1])
+ if convergence < 0:
+ self.imagePanel.image['rotate'].SetValue(abs(convergence))
+ else:
+ self.imagePanel.image['rotate'].SetValue(360 - convergence)
def convertRGB(rgb):
"""!Converts wx.Colour(r,g,b,a) to string 'r:g:b' or named color,
or named color/r:g:b string to wx.Colour, depending on input"""
@@ -5701,3 +6357,68 @@
return rasterType
else:
return None
+def PilImageToWxImage(pilImage, copyAlpha = True):
+ """!Convert PIL image to wx.Image
+ Based on http://wiki.wxpython.org/WorkingWithImages
+ hasAlpha = pilImage.mode[-1] == 'A'
+ if copyAlpha and hasAlpha : # Make sure there is an alpha layer copy.
+ wxImage = wx.EmptyImage( *pilImage.size )
+ pilImageCopyRGBA = pilImage.copy()
+ pilImageCopyRGB = pilImageCopyRGBA.convert('RGB') # RGBA --> RGB
+ pilImageRgbData = pilImageCopyRGB.tostring()
+ wxImage.SetData(pilImageRgbData)
+ wxImage.SetAlphaData(pilImageCopyRGBA.tostring()[3::4]) # Create layer and insert alpha values.
+ else : # The resulting image will not have alpha.
+ wxImage = wx.EmptyImage(*pilImage.size)
+ pilImageCopy = pilImage.copy()
+ pilImageCopyRGB = pilImageCopy.convert('RGB') # Discard any alpha from the PIL image.
+ return wxImage
+def BBoxAfterRotation(w, h, angle):
+ """!Compute bounding box or rotated rectangle
+ @param w rectangle width
+ @param h rectangle height
+ @param angle angle (0, 360) in degrees
+ angleRad = angle / 180. * pi
+ ct = cos(angleRad)
+ st = sin(angleRad)
+ hct = h * ct
+ wct = w * ct
+ hst = h * st
+ wst = w * st
+ y = x = 0
+ if 0 < angle <= 90:
+ y_min = y
+ y_max = y + hct + wst
+ x_min = x - hst
+ x_max = x + wct
+ elif 90 < angle <= 180:
+ y_min = y + hct
+ y_max = y + wst
+ x_min = x - hst + wct
+ x_max = x
+ elif 180 < angle <= 270:
+ y_min = y + wst + hct
+ y_max = y
+ x_min = x + wct
+ x_max = x - hst
+ elif 270 < angle <= 360:
+ y_min = y + wst
+ y_max = y + hct
+ x_min = x
+ x_max = x + wct - hst
+ width = int(ceil(abs(x_max) + abs(x_min)))
+ height = int(ceil(abs(y_max) + abs(y_min)))
+ return width, height
Modified: grass/branches/develbranch_6/gui/wxpython/psmap/frame.py
--- grass/branches/develbranch_6/gui/wxpython/psmap/frame.py 2011-12-12 09:12:29 UTC (rev 49670)
+++ grass/branches/develbranch_6/gui/wxpython/psmap/frame.py 2011-12-12 09:40:28 UTC (rev 49671)
@@ -99,18 +99,22 @@
'vectorLegend': wx.Pen(colour = wx.Color(219, 216, 4), width = 2),
'mapinfo': wx.Pen(colour = wx.Color(5, 184, 249), width = 2),
'scalebar': wx.Pen(colour = wx.Color(150, 150, 150), width = 2),
+ 'image': wx.Pen(colour = wx.Color(255, 150, 50), width = 2),
+ 'northArrow': wx.Pen(colour = wx.Color(200, 200, 200), width = 2),
'box': wx.Pen(colour = 'RED', width = 2, style = wx.SHORT_DASH),
'select': wx.Pen(colour = 'BLACK', width = 1, style = wx.SHORT_DASH),
'resize': wx.Pen(colour = 'BLACK', width = 1)
self.brush = {
'paper': wx.WHITE_BRUSH,
- 'margins': wx.TRANSPARENT_BRUSH,
+ 'margins': wx.TRANSPARENT_BRUSH,
'map': wx.Brush(wx.Color(151, 214, 90)),
'rasterLegend': wx.Brush(wx.Color(250, 247, 112)),
'vectorLegend': wx.Brush(wx.Color(250, 247, 112)),
'mapinfo': wx.Brush(wx.Color(127, 222, 252)),
'scalebar': wx.Brush(wx.Color(200, 200, 200)),
+ 'image': wx.Brush(wx.Color(255, 200, 50)),
+ 'northArrow': wx.Brush(wx.Color(255, 255, 255)),
'box': wx.TRANSPARENT_BRUSH,
'select':wx.TRANSPARENT_BRUSH,
'resize': wx.BLACK_BRUSH
@@ -213,7 +217,7 @@
"""!Launch ps.map dialog
GUI(parent = self).ParseCommand(cmd = ['ps.map'])
def OnPDFFile(self, event):
"""!Generate PDF from PS with ps2pdf if available"""
try:
@@ -302,13 +306,13 @@
message = _("Program ps2pdf is not available. Please install it to create PDF.\n\n %s") % e)
# show preview only when user doesn't want to create ps or pdf
- if haveImage and event.userData['temp'] and not event.userData['pdfname']:
+ if havePILImage and event.userData['temp'] and not event.userData['pdfname']:
RunCommand('g.region', cols = event.userData['regionOld']['cols'], rows = event.userData['regionOld']['rows'])
## wx.BusyInfo does not display the message
## busy = wx.BusyInfo(message = "Generating preview, wait please", parent = self)
try:
- im = Image.open(event.userData['filename'])
+ im = PILImage.open(event.userData['filename'])
if self.instruction[self.pageId]['Orientation'] == 'Landscape':
im = im.rotate(270)
@@ -600,6 +604,16 @@
AddText.SetBitmap(Icons['psMap']["addText"].GetBitmap(self.iconsize))
decmenu.AppendItem(AddText)
self.Bind(wx.EVT_MENU, self.OnAddText, AddText)
+ # eps image
+ AddImage = wx.MenuItem(decmenu, wx.ID_ANY, Icons['psMap']["addImage"].GetLabel())
+ AddImage.SetBitmap(Icons['psMap']["addImage"].GetBitmap(self.iconsize))
+ decmenu.AppendItem(AddImage)
+ self.Bind(wx.EVT_MENU, self.OnAddImage, AddImage)
+ # north arrow image
+ AddNorthArrow = wx.MenuItem(decmenu, wx.ID_ANY, Icons['psMap']["addNorthArrow"].GetLabel())
+ AddNorthArrow.SetBitmap(Icons['psMap']["addNorthArrow"].GetBitmap(self.iconsize))
+ decmenu.AppendItem(AddNorthArrow)
+ self.Bind(wx.EVT_MENU, self.OnAddNorthArrow, AddNorthArrow)
# Popup the menu. If an item is selected then its handler
# will be called before PopupMenu returns.
self.PopupMenu(decmenu)
@@ -645,6 +659,30 @@
self.openDialogs['mapinfo'] = dlg
self.openDialogs['mapinfo'].Show()
+ def OnAddImage(self, event, id = None):
+ """!Show dialog for image adding and editing"""
+ position = None
+ if 'image' in self.openDialogs:
+ position = self.openDialogs['image'].GetPosition()
+ self.openDialogs['image'].OnApply(event = None)
+ self.openDialogs['image'].Destroy()
+ dlg = ImageDialog(self, id = id, settings = self.instruction)
+ self.openDialogs['image'] = dlg
+ if position:
+ dlg.SetPosition(position)
+ dlg.Show()
+ def OnAddNorthArrow(self, event, id = None):
+ """!Show dialog for north arrow adding and editing"""
+ if self.instruction.FindInstructionByType('northArrow'):
+ id = self.instruction.FindInstructionByType('northArrow').id
+ else: id = None
+ if 'northArrow' not in self.openDialogs:
+ dlg = NorthArrowDialog(self, id = id, settings = self.instruction)
+ self.openDialogs['northArrow'] = dlg
+ self.openDialogs['northArrow'].Show()
def OnAddText(self, event, id = None):
"""!Show dialog for text adding and editing"""
position = None
@@ -658,6 +696,7 @@
dlg.Show()
def getModifiedTextBounds(self, x, y, textExtent, rotation):
"""!computes bounding box of rotated text, not very precisely"""
w, h = textExtent
@@ -792,12 +831,18 @@
for id in ids:
itype = self.instruction[id].type
- if itype in ('scalebar', 'mapinfo'):
+ if itype in ('scalebar', 'mapinfo', 'image'):
drawRectangle = self.canvas.CanvasPaperCoordinates(rect = self.instruction[id]['rect'], canvasToPaper = False)
+ self.canvas.UpdateLabel(itype = itype, id = id)
self.canvas.Draw(pen = self.pen[itype], brush = self.brush[itype],
pdc = self.canvas.pdcObj, drawid = id, pdctype = 'rectText', bb = drawRectangle)
self.canvas.RedrawSelectBox(id)
+ if itype == 'northArrow':
+ drawRectangle = self.canvas.CanvasPaperCoordinates(rect = self.instruction[id]['rect'], canvasToPaper = False)
+ self.canvas.Draw(pen = self.pen[itype], brush = self.brush[itype],
+ pdc = self.canvas.pdcObj, drawid = id, pdctype = 'bitmap', bb = drawRectangle)
+ self.canvas.RedrawSelectBox(id)
if itype == 'text':
if self.instruction[id]['rotate']:
@@ -833,9 +878,8 @@
if itype in ('map', 'vector', 'raster'):
if itype == 'raster':#set resolution
- resol = RunCommand('r.info', read = True, flags = 's', map = self.instruction[id]['raster'])
- resol = grass.parse_key_val(resol, val_type = float)
- RunCommand('g.region', nsres = resol['nsres'], ewres = resol['ewres'])
+ info = grass.raster_info(self.instruction[id]['raster'])
+ RunCommand('g.region', nsres = info['nsres'], ewres = info['ewres'])
# change current raster in raster legend
if 'rasterLegend' in self.openDialogs:
@@ -862,6 +906,7 @@
if itype == 'rasterLegend':
if self.instruction[id]['rLegend']:
@@ -873,6 +918,7 @@
if not self.instruction.FindInstructionByType('vector'):
self.deleteObject(id)
elif self.instruction[id]['vLegend']:
@@ -924,6 +970,8 @@
grass.set_raise_on_error(False)
self.Destroy()
class PsMapBufferedWindow(wx.Window):
"""!A buffered window class.
@@ -960,11 +1008,14 @@
#labels
- self.itemLabels = { 'map': ['MAP FRAME'],
- 'rasterLegend': ['RASTER LEGEND'],
- 'vectorLegend': ['VECTOR LEGEND'],
- 'mapinfo': ['MAP INFO'],
- 'scalebar': ['SCALE BAR']}
+ self.itemLabelsDict = { 'map': 'MAP FRAME',
+ 'rasterLegend': 'RASTER LEGEND',
+ 'vectorLegend': 'VECTOR LEGEND',
+ 'mapinfo': 'MAP INFO',
+ 'scalebar': 'SCALE BAR',
+ 'image': 'IMAGE',
+ 'northArrow': 'NORTH ARROW'}
+ self.itemLabels = {}
# define PseudoDC
self.pdc = wx.PseudoDC()
@@ -1086,13 +1137,14 @@
mapId = self.instruction.FindInstructionByType('map').id
mapId = self.instruction.FindInstructionByType('initMap').id
- texts = self.instruction.FindInstructionByType('text', list = True)
- for text in texts:
- e, n = PaperMapCoordinates(map = self.instruction[mapId], x = self.instruction[text.id]['where'][0],
- y = self.instruction[text.id]['where'][1], paperToMap = True)
- self.instruction[text.id]['east'], self.instruction[text.id]['north'] = e, n
+ for itemType in ('text', 'image', 'northArrow'):
+ items = self.instruction.FindInstructionByType(itemType, list = True)
+ for item in items:
+ e, n = PaperMapCoordinates(map = self.instruction[mapId], x = self.instruction[item.id]['where'][0],
+ y = self.instruction[item.id]['where'][1], paperToMap = True)
+ self.instruction[item.id]['east'], self.instruction[item.id]['north'] = e, n
def OnPaint(self, event):
"""!Draw pseudo DC to buffer
@@ -1330,11 +1382,13 @@
elif event.LeftDClick():
if self.mouse['use'] == 'pointer' and self.dragId != -1:
itemCall = { 'text':self.parent.OnAddText, 'mapinfo': self.parent.OnAddMapinfo,
- 'scalebar': self.parent.OnAddScalebar,
+ 'scalebar': self.parent.OnAddScalebar, 'image': self.parent.OnAddImage,
+ 'northArrow' : self.parent.OnAddNorthArrow,
'rasterLegend': self.parent.OnAddLegend, 'vectorLegend': self.parent.OnAddLegend,
'map': self.parent.OnAddMap}
itemArg = { 'text': dict(event = None, id = self.dragId), 'mapinfo': dict(event = None),
- 'scalebar': dict(event = None),
+ 'scalebar': dict(event = None), 'image': dict(event = None, id = self.dragId),
+ 'northArrow': dict(event = None, id = self.dragId),
'rasterLegend': dict(event = None), 'vectorLegend': dict(event = None, page = 1),
'map': dict(event = None, notebook = True)}
type = self.instruction[self.dragId].type
@@ -1351,11 +1405,13 @@
canvasToPaper = True)
self.RecalculateEN()
- elif itype in ('mapinfo' ,'rasterLegend', 'vectorLegend'):
+ elif itype in ('mapinfo' ,'rasterLegend', 'vectorLegend', 'image', 'northArrow'):
self.instruction[id]['rect'] = self.CanvasPaperCoordinates(rect = self.pdcObj.GetIdBounds(id),
self.instruction[id]['where'] = self.CanvasPaperCoordinates(rect = self.pdcObj.GetIdBounds(id),
- canvasToPaper = True)[:2]
+ canvasToPaper = True)[:2]
+ if itype in ('image', 'northArrow'):
+ self.RecalculateEN()
elif itype == 'scalebar':
@@ -1464,6 +1520,9 @@
self.instruction[id]['rect'] = bounds = self.parent.getModifiedTextBounds(coords[0], coords[1], extent, rot)
self.pdcObj.SetIdBounds(id, bounds)
+ elif type == 'northArrow':
+ self.Draw(pen = self.pen[type], brush = self.brush[type], pdc = self.pdcObj,
+ drawid = id, pdctype = 'bitmap', bb = oRect)
else:
drawid = id, pdctype = 'rectText', bb = oRect)
@@ -1498,8 +1557,18 @@
pdc.SetId(drawid)
pdc.SetPen(pen)
pdc.SetBrush(brush)
+ if pdctype == 'bitmap':
+ if havePILImage:
+ file = self.instruction[drawid]['epsfile']
+ rotation = self.instruction[drawid]['rotate']
+ self.DrawBitmap(pdc = pdc, filePath = file, rotation = rotation, bbox = bb)
+ else: # draw only rectangle with label
+ pdctype = 'rectText'
if pdctype in ('rect', 'rectText'):
pdc.DrawRectangle(*bb)
if pdctype == 'rectText':
dc = wx.PaintDC(self) # dc created because of method GetTextExtent, which pseudoDC lacks
font = self.font
@@ -1508,7 +1577,7 @@
font.SetStyle(wx.ITALIC)
dc.SetFont(font)
pdc.SetFont(font)
- text = '\n'.join(self.itemLabels[self.instruction[drawid].type])
+ text = '\n'.join(self.itemLabels[drawid])
w,h,lh = dc.GetMultiLineTextExtent(text)
textExtent = (w,h)
textRect = wx.Rect(0, 0, *textExtent).CenterIn(bb)
@@ -1523,19 +1592,35 @@
pdc.SetTextForeground(wx.Color(100,100,100,200))
pdc.SetBackgroundMode(wx.TRANSPARENT)
pdc.DrawText(text = text, x = textRect.x, y = textRect.y)
pdc.SetIdBounds(drawid, bb)
pdc.EndDrawing()
self.Refresh()
return drawid
+ def DrawBitmap(self, pdc, filePath, rotation, bbox):
+ """!Draw bitmap using PIL"""
+ pImg = PILImage.open(filePath)
+ if rotation:
+ # get rid of black background
+ pImg = pImg.convert("RGBA")
+ rot = pImg.rotate(rotation, expand = 1)
+ new = PILImage.new('RGBA', rot.size, (255,) * 4)
+ pImg = PILImage.composite(rot, new, rot)
+ pImg = pImg.resize((int(bbox[2]), int(bbox[3])), resample = PILImage.BICUBIC)
+ mask = wx.Mask(bitmap, wx.WHITE)
+ bitmap.SetMask(mask)
+ pdc.DrawBitmap(bitmap, bbox[0], bbox[1], useMask = True)
def DrawRotText(self, pdc, drawId, textDict, coords, bounds):
if textDict['rotate']:
rot = float(textDict['rotate'])
else:
rot = 0
fontsize = textDict['fontsize'] * self.currScale
if textDict['background'] != 'none':
background = textDict['background']
@@ -1561,7 +1646,7 @@
fn = self.parent.makePSFont(textDict)
pdc.SetFont(fn)
pdc.SetTextForeground(convertRGB(textDict['color']))
pdc.DrawRotatedText(textDict['text'], coords[0], coords[1], rot)
@@ -1661,12 +1746,21 @@
if rasterId:
rasterName = self.instruction[rasterId]['raster'].split('@')[0]
- self.itemLabels['map'] = self.itemLabels['map'][0:1]
- self.itemLabels['map'].append("raster: " + rasterName)
+ mapId = self.instruction.FindInstructionByType('map').id
+ self.itemLabels[mapId] = []
+ self.itemLabels[mapId].append(self.itemLabelsDict['map'])
+ self.itemLabels[mapId].append("raster: " + rasterName)
if vectorId:
for map in self.instruction[vectorId]['list']:
- self.itemLabels['map'].append('vector: ' + map[0].split('@')[0])
+ self.itemLabels[mapId].append('vector: ' + map[0].split('@')[0])
+ def UpdateLabel(self, itype, id):
+ self.itemLabels[id] = []
+ self.itemLabels[id].append(self.itemLabelsDict[itype])
+ if itype == 'image':
+ file = os.path.basename(self.instruction[id]['epsfile'])
+ self.itemLabels[id].append(file)
def OnSize(self, event):
"""!Init image size to match window size
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata_psmap.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata_psmap.xml 2011-12-12 09:12:29 UTC (rev 49670)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata_psmap.xml 2011-12-12 09:40:28 UTC (rev 49671)
@@ -94,6 +94,18 @@
<handler>OnAddText</handler>
<shortcut>Ctrl+T</shortcut>
</menuitem>
+ <menuitem>
+ <label>Image</label>
+ <help>Add image</help>
+ <handler>OnAddImage</handler>
+ <shortcut></shortcut>
+ </menuitem>
+ <menuitem>
+ <label>North Arrow</label>
+ <help>Add north arrow</help>
+ <handler>OnAddNorthArrow</handler>
+ </menuitem>
<separator/>
<menuitem>
<label>Delete</label>
