[GRASS-SVN] r49693 -
grass/branches/releasebranch_6_4/scripts/g.extension
svn_grass at osgeo.org
Mon Dec 12 23:15:45 EST 2011
Author: hamish
Date: 2011-12-12 20:15:45 -0800 (Mon, 12 Dec 2011)
New Revision: 49693
grass/branches/releasebranch_6_4/scripts/g.extension/g.extension
simplified addon dir layout (merge from devbr6)
Modified: grass/branches/releasebranch_6_4/scripts/g.extension/g.extension
--- grass/branches/releasebranch_6_4/scripts/g.extension/g.extension 2011-12-12 21:06:55 UTC (rev 49692)
+++ grass/branches/releasebranch_6_4/scripts/g.extension/g.extension 2011-12-13 04:15:45 UTC (rev 49693)
@@ -270,7 +270,7 @@
if test -f "$MYINST_DIR/scripts/$MODULE" ; then
rm -f "$MYINST_DIR/scripts/$MODULE"
fi
- if test -h "$MYINST_DIR/$MODULE" ; then
+ if test -e "$MYINST_DIR/$MODULE" ; then
rm -f "$MYINST_DIR/$MODULE"
fi
if test -f "${MYINST_DIR}/docs/html/${MODULE}.html" ; then
@@ -280,6 +280,9 @@
if test -f "${MYINST_DIR}/man/man1/${MODULE}.1" ; then
rm -f "${MYINST_DIR}/man/man1/${MODULE}.1"
fi
+ if test -f "$MYINST_DIR/docs/man/man1/$MODULE.1" ; then
+ rm -f "$MYINST_DIR/docs/man/man1/$MODULE.1"
+ fi
exit 0
fi
@@ -383,6 +386,7 @@
fi
else
if test -f "$MYINST_DIR/$PROGTYPE/$MODULE" ; then
+ g.message -w "Replacing previously built <$MODULE>"
rm -f "$MYINST_DIR/$PROGTYPE/$MODULE"
fi
@@ -404,9 +408,23 @@
fi
if [ "$MYINST_DIR" = "$GRASS_ADDON_PATH1" ] || [ "$MYINST_DIR" = ~/.grass6/addons ] ; then
- # symlink into path which is actually in the $PATH
- ln -sf "$MYINST_DIR/$PROGTYPE/$MODULE" "$MYINST_DIR/"
- fi
+ # move bin/ and script/ into ../, then rmdir if they are empty
+ mv "$MYINST_DIR/$PROGTYPE/$MODULE" "$MYINST_DIR/"
+ if [ `ls -a "$MYINST_DIR/$PROGTYPE" | wc -l` -le 2 ] ; then
+ rmdir "$MYINST_DIR/$PROGTYPE"
+ fi
+ # and move the man page into docs/
+ if [ -e "$MYINST_DIR/man/man1/$MODULE.1" ] ; then
+ mkdir -p "$MYINST_DIR/docs/man/man1"
+ mv "$MYINST_DIR/man/man1/$MODULE.1" "$MYINST_DIR/docs/man/man1/"
+ if [ `ls -a "$MYINST_DIR/man/man1" | wc -l` -le 2 ] ; then
+ rmdir "$MYINST_DIR/man/man1"
+ if [ `ls -a "$MYINST_DIR/man" | wc -l` -le 2 ] ; then
+ rmdir "$MYINST_DIR/man"
+ fi
+ fi
+ fi
+ fi
fi
cleanup
