[GRASS-SVN] r49732 - grass/trunk/vector/v.in.lidar
svn_grass at osgeo.org
Wed Dec 14 04:11:59 EST 2011
Author: hamish
Date: 2011-12-14 01:11:59 -0800 (Wed, 14 Dec 2011)
New Revision: 49732
grass/trunk/vector/v.in.lidar/main.c
minor cleanup of location creation and extending region code
Modified: grass/trunk/vector/v.in.lidar/main.c
--- grass/trunk/vector/v.in.lidar/main.c 2011-12-14 07:56:46 UTC (rev 49731)
+++ grass/trunk/vector/v.in.lidar/main.c 2011-12-14 09:11:59 UTC (rev 49732)
@@ -210,7 +210,7 @@
extend_flag = G_define_flag();
extend_flag->key = 'e';
extend_flag->description =
- _("Extend location extents based on new dataset");
+ _("Extend region extents based on new dataset");
no_import_flag = G_define_flag();
no_import_flag->key = 'i';
@@ -349,9 +349,13 @@
/* If the i flag is set, clean up? and exit here */
if(no_import_flag->answer)
exit(EXIT_SUCCESS);
+ /* TODO: */
+ G_warning("Import into new location not yet implemented");
+ /* at this point the module should be using G__create_alt_env()
+ to change context to the newly created location; once done
+ it should switch back with G__switch_env(). See r.in.gdal */
else {
int err = 0;
@@ -364,10 +368,7 @@
/* Does the projection of the current location match the dataset? */
/* G_get_window seems to be unreliable if the location has been changed */
- if (outloc_opt->answer)
- G__get_window(&loc_wind, "", "DEFAULT_WIND", "PERMANENT");
- else
- G_get_set_window(&loc_wind);
+ G_get_default_window(&loc_wind);
/* fetch LOCATION PROJ info */
if (loc_wind.proj != PROJECTION_XY) {
loc_proj_info = G_get_projinfo();
@@ -460,8 +461,8 @@
G_fatal_error(error_msg);
else {
- G_message(_("Projection of input dataset and current location "
- "appear to match"));
+ G_verbose_message(_("Projection of input dataset and current "
+ "location appear to match"));
@@ -803,10 +804,7 @@
/ loc_wind.ew_res);
loc_wind.east = loc_wind.west + loc_wind.cols * loc_wind.ew_res;
- G__put_window(&loc_wind, "../PERMANENT", "DEFAULT_WIND");
- else
- G_put_window(&loc_wind);
+ G_put_window(&loc_wind);
exit(EXIT_SUCCESS);
