[GRASS-SVN] r49736 - grass/branches/develbranch_6/gui/wxpython/xml
svn_grass at osgeo.org
Wed Dec 14 06:30:25 EST 2011
Author: martinl
Date: 2011-12-14 03:30:25 -0800 (Wed, 14 Dec 2011)
New Revision: 49736
grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
wxGUI: i.topo.corr added to the menu + menu cosmetics
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2011-12-14 10:58:05 UTC (rev 49735)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2011-12-14 11:30:25 UTC (rev 49736)
@@ -750,7 +750,7 @@
<menuitem>
<label>User access</label>
<help>Controls access to the current mapset for other users on the system.</help>
- <keywords>general,map management,permission</keywords>
+ <keywords>general,map management</keywords>
<handler>OnMenuCmd</handler>
<command>g.access</command>
</menuitem>
@@ -864,7 +864,7 @@
<menuitem>
<label>Remove extension</label>
<help>Removes installed GRASS AddOns extension.</help>
- <keywords>general,installation,extensions</keywords>
+ <keywords>general,extensions</keywords>
<handler>OnUninstallExtension</handler>
<command>g.extension</command>
</menuitem>
@@ -1227,7 +1227,7 @@
</menuitem>
<menuitem>
<label>Distance to features</label>
- <help>Generates a raster map layer of distance to features in input layer.</help>
+ <help>Generates a raster map of distance to features in input raster map.</help>
<keywords>raster,geometry</keywords>
<command>r.grow.distance</command>
@@ -1736,7 +1736,7 @@
<separator />
<menuitem>
<label>Fill NULL cells</label>
- <help>Fills no-data areas in raster maps using v.surf.rst splines interpolation</help>
+ <help>Fills no-data areas in raster maps using v.surf.rst splines interpolation.</help>
<keywords>raster,elevation,interpolation</keywords>
<command>r.fillnulls</command>
@@ -1806,8 +1806,8 @@
</menuitem>
<menuitem>
<label>Total corrected area</label>
- <help>Prints estimation of surface area for raster map.</help>
- <keywords>raster,surface,statistics,area estimation</keywords>
+ <help>Surface area estimation for rasters.</help>
+ <keywords>raster,statistics</keywords>
<command>r.surf.area</command>
</menuitem>
@@ -2502,7 +2502,7 @@
<separator />
<menuitem>
<label>Mosaic images</label>
- <help>Mosaics up to 4 images and extends colormap; creates map *.mosaic</help>
+ <help>Mosaics up to four images, extending the color table.</help>
<keywords>raster,imagery,mosaicking</keywords>
<command>i.image.mosaic</command>
@@ -2677,7 +2677,7 @@
</menuitem>
<menuitem>
<label>Landsat cloud cover assessment</label>
- <help>Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA).</help>
+ <help>Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA).</help>
<keywords>imagery,landsat,acca</keywords>
<command>i.landsat.acca</command>
@@ -2698,6 +2698,13 @@
<command>i.atcorr</command>
</menuitem>
+ <menuitem>
+ <label>Topographic correction</label>
+ <help>Computes topographic correction of reflectance.</help>
+ <keywords>imagery,terrain,topographic correction</keywords>
+ <handler>OnMenuCmd</handler>
+ <command>i.topo.corr</command>
+ </menuitem>
</items>
</menu>
<menu>
