[GRASS-SVN] r49756 -
grass/branches/develbranch_6/gui/wxpython/modules
svn_grass at osgeo.org
Wed Dec 14 18:27:51 EST 2011
Author: martinl
Date: 2011-12-14 15:27:50 -0800 (Wed, 14 Dec 2011)
New Revision: 49756
grass/branches/develbranch_6/gui/wxpython/modules/colorrules.py
wxGUI/colorrules: - redraw preview on apply
- error message when color column is not defined
- various minor fixes
Modified: grass/branches/develbranch_6/gui/wxpython/modules/colorrules.py
--- grass/branches/develbranch_6/gui/wxpython/modules/colorrules.py 2011-12-14 20:50:39 UTC (rev 49755)
+++ grass/branches/develbranch_6/gui/wxpython/modules/colorrules.py 2011-12-14 23:27:50 UTC (rev 49756)
@@ -35,7 +35,7 @@
from core import globalvar
from core import utils
-from core.gcmd import GMessage, RunCommand
+from core.gcmd import GMessage, RunCommand, GError
from gui_core.gselect import Select, LayerSelect, ColumnSelect, VectorDBInfo
from core.render import Map
from gui_core.forms import GUI
@@ -525,8 +525,9 @@
ret = self.CreateColorTable()
if not ret:
GMessage(parent = self, message = _("No valid color rules given."))
- if ret:
+ else:
+ # re-render preview and current map window
+ self.OnPreview(None)
display = self.parent.GetLayerTree().GetMapDisplay()
if display and display.IsAutoRendered():
display.GetWindow().UpdateMap(render = True)
@@ -681,12 +682,12 @@
output.write(rulestxt)
finally:
output.close()
- cmd = ['%s.colors' % self.mapType[0],#r.colors/v.colors
+ cmd = ['%s.colors' % self.mapType[0], #r.colors/v.colors
'map=%s' % self.inmap,
'rules=%s' % gtemp]
- if self.mapType == 'vector' and self.properties['sourceColumn']\
- and self.properties['sourceColumn'] != 'cat':
+ if self.mapType == 'vector' and self.properties['sourceColumn'] \
+ and self.properties['sourceColumn'] != 'cat':
cmd.append('column=%s' % self.properties['sourceColumn'])
cmd = utils.CmdToTuple(cmd)
ret = RunCommand(cmd[0], **cmd[1])
@@ -1213,9 +1214,9 @@
def AddTemporaryColumn(self, type):
"""!Add temporary column to not overwrite the original values,
- need to be deleted when closing dialog and unloading map
- @param type type of column (e.g. vachar(11))"""
+ need to be deleted when closing dialog and unloading map
+ @param type type of column (e.g. vachar(11))"""
# because more than one dialog with the same map can be opened we must test column name and
# create another one
while self.properties['tmpColumn'] in self.dbInfo.GetTableDesc(self.properties['table']).keys():
@@ -1558,6 +1559,7 @@
ret = self.UpdateColorColumn(tmp)
else:
ret = True
return ret
def UpdateColorColumn(self, tmp):
@@ -1577,8 +1579,9 @@
else:
rgb_col = self.properties['storeColumn']
if not self.properties['storeColumn']:
- GMessage(self.parent, message = _("Please select column to save values to."))
+ GMessage(parent = self.parent,
+ message = _("Please select column to save values to."))
rulestxt += "UPDATE %s SET %s='%s' WHERE %s ;\n" % (self.properties['table'],
rgb_col,
rule[self.attributeType],
@@ -1613,6 +1616,11 @@
if self.colorTable:
self.UseAttrColumn(False)
else:
+ if not self.properties['storeColumn']:
+ GError(_("No color column defined. Operation canceled."),
+ parent = self)
+ return
self.UseAttrColumn(True)
return ColorTable.OnApply(self, event)
