[GRASS-SVN] r49770 - grass/trunk/include/iostream
svn_grass at osgeo.org
Thu Dec 15 09:13:31 EST 2011
Author: mmetz
Date: 2011-12-15 06:13:31 -0800 (Thu, 15 Dec 2011)
New Revision: 49770
grass/trunk/include/iostream/ami_stream.h
clean up error messages
Modified: grass/trunk/include/iostream/ami_stream.h
--- grass/trunk/include/iostream/ami_stream.h 2011-12-15 13:43:22 UTC (rev 49769)
+++ grass/trunk/include/iostream/ami_stream.h 2011-12-15 14:13:31 UTC (rev 49770)
@@ -63,6 +63,7 @@
#define DEBUG_DELETE if(0)
#define DEBUG_STREAM_LEN if(0)
+#define DEBUG_ASSERT if(0)
// The name of the environment variable which keeps the name of the
// directory where streams are stored
@@ -103,7 +104,7 @@
AMI_WRITE_STREAM, // Open for writing. Create if non-existent
AMI_APPEND_STREAM, // Open for writing at end. Create if needed.
AMI_READ_WRITE_STREAM, // Open to read and write.
- AMI_APPEND_WRITE_STREAM // Open for writing at end (write only mode).
+ AMI_APPEND_WRITE_STREAM // Open for writing at end (write only mode).
@@ -241,7 +242,8 @@
/* a stream is by default buffered with a buffer of size BUFSIZ=1K */
buf = new char[STREAM_BUFFER_SIZE];
if (setvbuf(fp, buf, _IOFBF, STREAM_BUFFER_SIZE) != 0) {
- cerr << "setvbuf failed (stream " << path << ")" << endl;
+ cerr << "ERROR: setvbuf failed (stream " << path << ") with: "
+ << strerror(errno) << endl;
exit(1);
@@ -286,7 +288,8 @@
exit(1);
@@ -414,8 +417,7 @@
STRUCT_STAT buf;
if (stat(path, &buf) == -1) {
perror("AMI_STREAM::stream_len(): fstat failed ");
- perror(path);
- assert(0);
+ DEBUG_ASSERT assert(0);
exit(1);
@@ -459,9 +461,9 @@
if (substream_level) { //substream
if (offset > (unsigned) (logical_eos - logical_bos)) {
//offset out of range
- cerr << "AMI_STREAM::seek bos=" << logical_bos << ", eos=" << logical_eos
- << ", offset " << offset << " out of range.\n";
- assert(0);
+ cerr << "ERROR: AMI_STREAM::seek bos=" << logical_bos << ", eos="
+ << logical_eos << ", offset " << offset << " out of range.\n";
exit(1);
} else {
//offset in range
@@ -520,9 +522,9 @@
// Get rid of the file if not persistent and if not substream.
if ((per != PERSIST_PERSISTENT) && (substream_level == 0)) {
if (unlink(path) == -1) {
- cerr << "AMI_STREAM: failed to unlink " << path << endl;
- perror("cannot unlink ");
- assert(0);
+ cerr << "ERROR: AMI_STREAM: failed to unlink " << path << endl;
+ perror("cannot unlink: ");
exit(1);
@@ -550,7 +552,7 @@
eof_reached = 1;
return AMI_ERROR_END_OF_STREAM;
} else {
- cerr << "file=" << path << ":";
+ cerr << "ERROR: file=" << path << ":";
perror("cannot read!");
return AMI_ERROR_IO_ERROR;
@@ -584,7 +586,7 @@
eof_reached = 1;
} else {
@@ -608,9 +610,12 @@
} else {
if (fwrite((char*)(&elt), sizeof(T), 1,fp) < 1) {
- cerr << "AMI_STREAM::write_item failed.\n";
- perror(path);
- assert(0);
+ cerr << "ERROR: AMI_STREAM::write_item failed.\n";
+ if (path && *path)
+ perror(path);
+ else
+ perror("AMI_STREAM::write_item: ");
exit(1);
@@ -632,8 +637,12 @@
} else {
nobj = fwrite(data, sizeof(T), len, fp);
if (nobj < len) {
- assert(0);
+ cerr << "ERROR: AMI_STREAM::write_array failed.\n";
+ perror(path);
+ else
+ perror("AMI_STREAM::write_array: ");
exit(1);
return AMI_ERROR_NO_ERROR;
