[GRASS-SVN] r49782 -
grass/branches/releasebranch_6_4/include/iostream
svn_grass at osgeo.org
Fri Dec 16 03:23:09 EST 2011
Author: mmetz
Date: 2011-12-16 00:23:08 -0800 (Fri, 16 Dec 2011)
New Revision: 49782
grass/branches/releasebranch_6_4/include/iostream/ami_stream.h
clean up error messages
Modified: grass/branches/releasebranch_6_4/include/iostream/ami_stream.h
--- grass/branches/releasebranch_6_4/include/iostream/ami_stream.h 2011-12-16 01:31:38 UTC (rev 49781)
+++ grass/branches/releasebranch_6_4/include/iostream/ami_stream.h 2011-12-16 08:23:08 UTC (rev 49782)
@@ -41,6 +41,7 @@
#include "mm.h" // Get the memory manager.
#define DEBUG_DELETE if(0)
+#define DEBUG_ASSERT if(0)
// The name of the environment variable which keeps the name of the
// directory where streams are stored
@@ -81,7 +82,7 @@
AMI_WRITE_STREAM, // Open for writing. Create if non-existent
AMI_APPEND_STREAM, // Open for writing at end. Create if needed.
AMI_READ_WRITE_STREAM, // Open to read and write.
- AMI_APPEND_WRITE_STREAM // Open for writing at end (write only mode).
+ AMI_APPEND_WRITE_STREAM // Open for writing at end (write only mode).
@@ -219,7 +220,8 @@
/* a stream is by default buffered with a buffer of size BUFSIZ=1K */
buf = new char[STREAM_BUFFER_SIZE];
if (setvbuf(fp, buf, _IOFBF, STREAM_BUFFER_SIZE) != 0) {
- cerr << "setvbuf failed (stream " << path << ")" << endl;
+ cerr << "ERROR: setvbuf failed (stream " << path << ") with: "
+ << strerror(errno) << endl;
exit(1);
@@ -264,7 +266,8 @@
exit(1);
@@ -388,9 +391,8 @@
#else
struct stat buf;
if (stat(path, &buf) == -1) {
- perror("AMI_STREAM::stream_len(): fstat failed ");
- perror(path);
- assert(0);
+ perror("ERROR: AMI_STREAM::stream_len(): fstat failed ");
+ DEBUG_ASSERT assert(0);
exit(1);
return (buf.st_size / sizeof(T));
@@ -429,9 +431,9 @@
if (substream_level) { //substream
if (offset > (unsigned) (logical_eos - logical_bos)) {
//offset out of range
- cerr << "AMI_STREAM::seek bos=" << logical_bos << ", eos=" << logical_eos
- << ", offset " << offset << " out of range.\n";
- assert(0);
+ cerr << "ERROR: AMI_STREAM::seek bos=" << logical_bos << ", eos="
+ << logical_eos << ", offset " << offset << " out of range.\n";
exit(1);
} else {
//offset in range
@@ -449,8 +451,8 @@
#else
if (fseek(fp, seek_offset, SEEK_SET) == -1) {
#endif
- cerr << "AMI_STREAM::seek offset=" << seek_offset << " failed.\n";
- assert(0);
+ cerr << "ERROR: AMI_STREAM::seek offset=" << seek_offset << " failed.\n";
exit(1);
@@ -498,9 +500,9 @@
// Get rid of the file if not persistent and if not substream.
if ((per != PERSIST_PERSISTENT) && (substream_level == 0)) {
if (unlink(path) == -1) {
- cerr << "AMI_STREAM: failed to unlink " << path << endl;
- perror("cannot unlink ");
- assert(0);
+ cerr << "ERROR: AMI_STREAM: failed to unlink " << path << endl;
+ perror("cannot unlink: ");
exit(1);
@@ -528,7 +530,7 @@
eof_reached = 1;
return AMI_ERROR_END_OF_STREAM;
} else {
- cerr << "file=" << path << ":";
+ cerr << "ERROR: file=" << path << ":";
perror("cannot read!");
return AMI_ERROR_IO_ERROR;
@@ -562,7 +564,7 @@
eof_reached = 1;
} else {
@@ -586,9 +588,12 @@
} else {
if (fwrite((char*)(&elt), sizeof(T), 1,fp) < 1) {
- cerr << "AMI_STREAM::write_item failed.\n";
- perror(path);
- assert(0);
+ cerr << "ERROR: AMI_STREAM::write_item failed.\n";
+ if (path && *path)
+ perror(path);
+ else
+ perror("AMI_STREAM::write_item: ");
exit(1);
@@ -610,8 +615,12 @@
} else {
nobj = fwrite(data, sizeof(T), len, fp);
if (nobj < len) {
- assert(0);
+ cerr << "ERROR: AMI_STREAM::write_array failed.\n";
+ perror(path);
+ else
+ perror("AMI_STREAM::write_array: ");
exit(1);
return AMI_ERROR_NO_ERROR;
