[GRASS-SVN] r49786 - grass/trunk/raster/r.viewshed
svn_grass at osgeo.org
Fri Dec 16 06:30:32 EST 2011
Author: mmetz
Date: 2011-12-16 03:30:32 -0800 (Fri, 16 Dec 2011)
New Revision: 49786
grass/trunk/raster/r.viewshed/main.cpp
r.viewshed: use GRASS .tmp dir for temp data
Modified: grass/trunk/raster/r.viewshed/main.cpp
--- grass/trunk/raster/r.viewshed/main.cpp 2011-12-16 11:30:10 UTC (rev 49785)
+++ grass/trunk/raster/r.viewshed/main.cpp 2011-12-16 11:30:32 UTC (rev 49786)
@@ -574,11 +574,7 @@
streamdirOpt->key = "stream_dir";
streamdirOpt->type = TYPE_STRING;
streamdirOpt->required = NO;
-#ifdef __MINGW32__
- streamdirOpt->answer = G_convert_dirseps_from_host(G_store(getenv("TEMP")));
-#else
- streamdirOpt->answer = "/var/tmp/";
-#endif
+ //streamdirOpt->answer = "";
streamdirOpt->description=
_("Directory to hold temporary files (they can be large)");
@@ -590,8 +586,17 @@
/* store the parameters into a structure to be used along the way */
strcpy(viewOptions->inputfname, inputOpt->answer);
strcpy(viewOptions->outputfname, outputOpt->answer);
- strcpy(viewOptions->streamdir,streamdirOpt->answer);
+ if (!streamdirOpt->answer) {
+ const char *tmpdir = G_tempfile();
+ if (G_mkdir(tmpdir) == -1)
+ G_fatal_error(_("Unable to create temp dir"));
+ strcpy(viewOptions->streamdir, tmpdir);
+ else
+ strcpy(viewOptions->streamdir,streamdirOpt->answer);
viewOptions->obsElev = atof(obsElevOpt->answer);
if(tgtElevOpt->answer)
viewOptions->tgtElev = atof(tgtElevOpt->answer);
