[GRASS-SVN] r49789 - in grass/trunk/lib/raster3d: . test
svn_grass at osgeo.org
Fri Dec 16 14:32:29 EST 2011
Author: huhabla
Date: 2011-12-16 11:32:29 -0800 (Fri, 16 Dec 2011)
New Revision: 49789
grass/trunk/lib/raster3d/error.c
grass/trunk/lib/raster3d/getvalue.c
grass/trunk/lib/raster3d/test/Makefile
grass/trunk/lib/raster3d/test/test_put_get_value.c
Added boundary check to get_value_region and a unit test.
Modified: grass/trunk/lib/raster3d/error.c
--- grass/trunk/lib/raster3d/error.c 2011-12-16 15:05:32 UTC (rev 49788)
+++ grass/trunk/lib/raster3d/error.c 2011-12-16 19:32:29 UTC (rev 49789)
@@ -40,7 +40,7 @@
void Rast3d_print_error(const char *msg)
fprintf(stderr, "ERROR: ");
- fprintf(stderr, msg);
+ fprintf(stderr, "%s", msg);
fprintf(stderr, "\n");
Modified: grass/trunk/lib/raster3d/getvalue.c
--- grass/trunk/lib/raster3d/getvalue.c 2011-12-16 15:05:32 UTC (rev 49788)
+++ grass/trunk/lib/raster3d/getvalue.c 2011-12-16 19:32:29 UTC (rev 49789)
@@ -166,22 +166,31 @@
int tileIndex, offs;
float *tile;
+ float value;
if (map->typeIntern == DCELL_TYPE)
return (float)Rast3d_get_double_region(map, x, y, z);
+ /* In case of region coordinates out of bounds, return the Null value */
+ if(x < 0 || y < 0 || z < 0 || x >= map->region.cols ||
+ y >= map->region.rows || z >= map->region.depths) {
+ Rast3d_set_null_value(&value, 1, FCELL_TYPE);
+ return value;
Rast3d_coord2tile_index(map, x, y, z, &tileIndex, &offs);
tile = (float *)Rast3d_get_tile_ptr(map, tileIndex);
if (tile == NULL)
- Rast3d_fatal_error("Rast3d_get_float_region: error in Rast3d_get_tile_ptr");
+ Rast3d_fatal_error("Rast3d_get_float_region: error in Rast3d_get_tile_ptr."
+ "Region coordinates x %i y %i z %i tile index %i offset %i",
+ x, y, z, tileIndex, offs);
return tile[offs];
* \brief
@@ -199,22 +208,31 @@
double *tile;
+ double value;
if (map->typeIntern == FCELL_TYPE)
return (double)Rast3d_get_float_region(map, x, y, z);
+ Rast3d_set_null_value(&value, 1, DCELL_TYPE);
+ return value;
tile = (double *)Rast3d_get_tile_ptr(map, tileIndex);
if (tile == NULL)
- Rast3d_fatal_error("Rast3d_get_double_region: error in Rast3d_get_tile_ptr");
+ Rast3d_fatal_error("Rast3d_get_double_region: error in Rast3d_get_tile_ptr."
return tile[offs];
* \brief
@@ -222,6 +240,7 @@
* region-coordinate <em>(x, y, z)</em>. The value returned is of <em>type</em>.
* Here <em>region</em> means the coordinate in the cube of data in the file, i.e.
* ignoring geographic coordinates.
+ * In case the region coordinates are out of bounds, the Null value will be returned.
* This function invokes a fatal error if an error occurs.
* \param map
Modified: grass/trunk/lib/raster3d/test/Makefile
--- grass/trunk/lib/raster3d/test/Makefile 2011-12-16 15:05:32 UTC (rev 49788)
+++ grass/trunk/lib/raster3d/test/Makefile 2011-12-16 19:32:29 UTC (rev 49789)
@@ -2,8 +2,8 @@
PGM=test.g3d.lib
-LIBES = $(GISLIB) $(RASTER3DLIB)
-DEPENDENCIES = $(GISDEP) $(RASTER3DDEP)
+LIBES = $(GISLIB) $(RASTER3DLIB) $(RASTERLIB)
+DEPENDENCIES = $(GISDEP) $(RASTER3DDEP) $(RASTERDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
default: cmd
Modified: grass/trunk/lib/raster3d/test/test_put_get_value.c
--- grass/trunk/lib/raster3d/test/test_put_get_value.c 2011-12-16 15:05:32 UTC (rev 49788)
+++ grass/trunk/lib/raster3d/test/test_put_get_value.c 2011-12-16 19:32:29 UTC (rev 49789)
@@ -435,6 +435,8 @@
sum += test_resampling_dcell(map, north, east, top, col, row, depth, 2);
+ sum += test_get_value_region(map, region.cols, region.rows, region.depths);
Rast3d_close(map);
G_remove("grid3", "test_put_get_value_dcell");
@@ -498,18 +500,55 @@
G_message("Error in Rast3d_get_region_value");
sum++;
- if(value != col + row + depth) {
+ if(value_win != col + row + depth) {
G_message("Error in Rast3d_get_window_value");
sum++;
+ if(value_ref != col + row + depth) {
G_message("Error in Rast3d_get_value");
sum++;
+ if(value_reg != col + row + depth) {
G_message("Error in Rast3d_get_value_region");
sum++;
return sum;
+int test_get_value_region(RASTER3D_Map *map, int cols, int rows, int depths)
+ int sum = 0;
+ FCELL fvalue1 = 0.0;
+ FCELL fvalue2 = 0.0;
+ DCELL dvalue1 = 0.0;
+ DCELL dvalue2 = 0.0;
+ /* Test for correct Null value */
+ Rast3d_get_value_region(map, -1, -1, -1, &fvalue1, FCELL_TYPE);
+ Rast3d_get_value_region(map, cols, rows, depths, &fvalue2, FCELL_TYPE);
+ Rast3d_get_value_region(map, -1, -1, -1, &dvalue1, DCELL_TYPE);
+ Rast3d_get_value_region(map, cols, rows, depths, &dvalue2, DCELL_TYPE);
+ printf("Value %g == %g == %g == %g\n", fvalue1, fvalue2, dvalue1, dvalue2);
+ if(!Rast_is_f_null_value(&fvalue1)) {
+ G_message("Error in Rast3d_get_value_region");
+ sum++;
+ if(!Rast_is_f_null_value(&fvalue2)) {
+ sum++;
+ if(!Rast_is_d_null_value(&dvalue1)) {
+ sum++;
+ if(!Rast_is_d_null_value(&dvalue2)) {
+ sum++;
+ return sum;
\ No newline at end of file
