[GRASS-SVN] r49799 - in grass/branches/develbranch_6: raster/r.external raster/r.in.gdal vector/v.in.ogr
Sun Dec 18 00:20:05 EST 2011
Author: hamish
Date: 2011-12-17 21:20:05 -0800 (Sat, 17 Dec 2011)
New Revision: 49799
   grass/branches/develbranch_6/raster/r.external/main.c
   grass/branches/develbranch_6/raster/r.in.gdal/main.c
   grass/branches/develbranch_6/vector/v.in.ogr/main.c
if in PERMANENT, also update WIND (merge from trunk; #1507)
Modified: grass/branches/develbranch_6/raster/r.external/main.c
--- grass/branches/develbranch_6/raster/r.external/main.c	2011-12-18 00:16:02 UTC (rev 49798)
+++ grass/branches/develbranch_6/raster/r.external/main.c	2011-12-18 05:20:05 UTC (rev 49799)
@@ -239,7 +239,12 @@
     struct Cell_head cur_wind;
-    G_get_set_window(&cur_wind);
+    if (strcmp(G_mapset(), "PERMANENT") == 0)
+	/* fixme: expand WIND and DEFAULT_WIND independently. (currently
+	 WIND gets forgotten and DEFAULT_WIND is expanded for both) */
+	G_get_default_window(&cur_wind);
+    else
+	G_get_window(&cur_wind);
     cur_wind.north = MAX(cur_wind.north, cellhd->north);
     cur_wind.south = MIN(cur_wind.south, cellhd->south);
@@ -254,7 +259,12 @@
 			      / cur_wind.ew_res);
     cur_wind.east = cur_wind.west + cur_wind.cols * cur_wind.ew_res;
+    if (strcmp(G_mapset(), "PERMANENT") == 0) {
+	G__put_window(&cur_wind, "", "DEFAULT_WIND");
+	G_message(_("Default region for this location updated"));
     G_put_window(&cur_wind);
+    G_message(_("Region for the current mapset updated"));
 static void query_band(GDALRasterBandH hBand, const char *output, int exact_range,
@@ -547,7 +557,9 @@
     flag_e = G_define_flag();
     flag_e->key = 'e';
-    flag_e->description = _("Extend region extents based on new dataset");
+    flag_e->label = _("Extend region extents based on new dataset");
+    flag_e->description =
+	_("Also updates the default region if in the PERMANENT mapset");
     flag_r = G_define_flag();
     flag_r->key = 'r';
Modified: grass/branches/develbranch_6/raster/r.in.gdal/main.c
--- grass/branches/develbranch_6/raster/r.in.gdal/main.c	2011-12-18 00:16:02 UTC (rev 49798)
+++ grass/branches/develbranch_6/raster/r.in.gdal/main.c	2011-12-18 05:20:05 UTC (rev 49799)
@@ -135,7 +135,9 @@
     flag_e->key = 'e';
     flag_f = G_define_flag();
     flag_f->key = 'f';
@@ -594,7 +596,12 @@
     /*      Extend current window based on dataset.                         */
     if (flag_e->answer) {
+	else
 	cur_wind.north = MAX(cur_wind.north, cellhd.north);
 	cur_wind.south = MIN(cur_wind.south, cellhd.south);
@@ -609,7 +616,12 @@
 				  / cur_wind.ew_res);
     exit(EXIT_SUCCESS);
Modified: grass/branches/develbranch_6/vector/v.in.ogr/main.c
--- grass/branches/develbranch_6/vector/v.in.ogr/main.c	2011-12-18 00:16:02 UTC (rev 49798)
+++ grass/branches/develbranch_6/vector/v.in.ogr/main.c	2011-12-18 05:20:05 UTC (rev 49799)
@@ -227,8 +227,10 @@
     extend_flag = G_define_flag();
     extend_flag->key = 'e';
+    extend_flag->label =
+	_("Extend region extents based on new dataset");
     extend_flag->description =
-	_("Extend region extents based on new dataset");
     tolower_flag = G_define_flag();
     tolower_flag->key = 'w';
@@ -695,30 +697,18 @@
 		/** Simple 32bit integer                     OFTInteger = 0        **/
 		/** List of 32bit integers                   OFTIntegerList = 1    **/
 		/** Double Precision floating point          OFTReal = 2           **/
 		/** List of doubles                          OFTRealList = 3       **/
 		/** String of ASCII chars                    OFTString = 4         **/
 		/** Array of strings                         OFTStringList = 5     **/
 		/** Double byte string (unsupported)         OFTWideString = 6     **/
 		/** List of wide strings (unsupported)       OFTWideStringList = 7 **/
 		/** Raw Binary data (unsupported)            OFTBinary = 8         **/
 		/**                                          OFTDate = 9           **/
 		/**                                          OFTTime = 10          **/
 		/**                                          OFTDateTime = 11      **/
 		if (Ogr_ftype == OFTInteger) {
 		    sprintf(buf, ", %s integer", Ogr_fieldname);
@@ -1186,7 +1176,12 @@
     if (extend_flag->answer) {
+	else
@@ -1201,7 +1196,12 @@
 				  / cur_wind.ew_res);
     if (with_z && !z_flag->answer)
