[GRASS-SVN] r49827 - in grass/trunk/gui/wxpython: . iclass
Mon Dec 19 05:32:12 EST 2011
Author: annakrat
Date: 2011-12-19 02:32:12 -0800 (Mon, 19 Dec 2011)
New Revision: 49827
   grass/trunk/gui/wxpython/iclass/dialogs.py
   grass/trunk/gui/wxpython/iclass/digit.py
   grass/trunk/gui/wxpython/iclass/frame.py
   grass/trunk/gui/wxpython/wxpythonlib.dox
wxIClass: saving signature file improved
Modified: grass/trunk/gui/wxpython/iclass/dialogs.py
--- grass/trunk/gui/wxpython/iclass/dialogs.py	2011-12-19 10:31:30 UTC (rev 49826)
+++ grass/trunk/gui/wxpython/iclass/dialogs.py	2011-12-19 10:32:12 UTC (rev 49827)
@@ -8,6 +8,7 @@
  - dialogs::IClassMapDialog
  - dialogs::IClassCategoryManagerDialog
  - dialogs::CategoryListCtrl
+ - dialogs::IClassSignatureFileDialog
 (C) 2006-2011 by the GRASS Development Team
 This program is free software under the GNU General Public
@@ -17,10 +18,11 @@
 @author Vaclav Petras <wenzeslaus gmail.com>
 @author Anna Kratochvilova <kratochanna gmail.com>
+import os
 import wx
-import  wx.lib.mixins.listctrl as listmix
+import wx.lib.mixins.listctrl as listmix
+import wx.lib.scrolledpanel as scrolled
 from core               import globalvar
 from gui_core.dialogs   import ElementDialog, GroupDialog
@@ -242,6 +244,8 @@
         if attr == 'name':
             self.mapWindow.UpdateRasterName(text, toolbar.GetSelectedCategoryIdx())
+        self.mapWindow.UpdateChangeState(changes = True)
     def Populate(self, columns):
         for i, col in enumerate(columns):
             self.InsertColumn(i, col[0])#wx.LIST_FORMAT_RIGHT
@@ -263,6 +267,7 @@
         self.SetItemCount(len(self.statisticsList))
         self.UpdateChoice()
     def DeleteCategory(self):
         indexList = sorted(self.GetSelectedIndices(), reverse = True)
@@ -276,6 +281,7 @@
         self.UpdateChoice()
         # delete vector items!
@@ -334,3 +340,111 @@
     def OnGetItemAttr(self, item):
         return None
+class IClassSignatureFileDialog(wx.Dialog):
+    def __init__(self, parent, group, file = None, title = _("Save signature file"), id = wx.ID_ANY,
+                 style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
+                 **kwargs):
+        """!Dialog for saving signature file
+        @param parent window
+        @param group group name
+        @param file signature file name
+        @param title window title
+        wx.Dialog.__init__(self, parent, id, title, style = style, **kwargs)
+        self.fileName = file
+        env = grass.gisenv()
+        # inconsistent group and subgroup name
+        # path: grassdata/nc_spm_08/landsat/group/test_group/subgroup/test_group at landsat/sig/sigFile
+        self.baseFilePath = os.path.join(env['GISDBASE'],
+                                         env['LOCATION_NAME'],
+                                         env['MAPSET'],
+                                         'group', group.split('@')[0], # !
+                                         'subgroup', group,
+                                         'sig')
+        self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
+        self.btnCancel = wx.Button(parent = self.panel, id = wx.ID_CANCEL)
+        self.btnOK     = wx.Button(parent = self.panel, id = wx.ID_OK)
+        self.btnOK.SetDefault()
+        self.btnOK.Enable(False)
+        self.__layout()
+        self.fileNameCtrl.Bind(wx.EVT_TEXT, self.OnTextChanged)
+        self.OnTextChanged(None)
+    def OnTextChanged(self, event):
+        """!Name for signature file given"""
+        file = self.fileNameCtrl.GetValue()
+        if len(file) > 0:
+            self.btnOK.Enable(True)
+        else:
+        path = os.path.join(self.baseFilePath, file)
+        self.filePathText.SetLabel(path)
+        bestSize = self.pathPanel.GetBestVirtualSize()
+        self.pathPanel.SetVirtualSize(bestSize)
+        self.pathPanel.Scroll(*bestSize)
+    def __layout(self):
+        """!Do layout"""
+        sizer = wx.BoxSizer(wx.VERTICAL)
+        dataSizer = wx.BoxSizer(wx.VERTICAL)
+        dataSizer.Add(item = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
+                                           label = _("Enter name of signature file:")),
+                      proportion = 0, flag = wx.ALL, border = 3)
+        self.fileNameCtrl = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY, size = (400, -1))
+        if self.fileName:
+            self.fileNameCtrl.SetValue(self.fileName)
+        dataSizer.Add(item = self.fileNameCtrl,
+                      proportion = 0, flag = wx.ALL | wx.EXPAND, border = 3)
+                                                label = _("Signature file path:")),
+        self.pathPanel = scrolled.ScrolledPanel(self.panel, size = (-1, 40))
+        pathSizer = wx.BoxSizer()
+        self.filePathText = wx.StaticText(parent = self.pathPanel, id = wx.ID_ANY,
+                                                label = self.baseFilePath)
+        pathSizer.Add(self.filePathText, proportion = 1, flag = wx.ALL | wx.EXPAND, border = 1)
+        self.pathPanel.SetupScrolling(scroll_x = True, scroll_y = False)
+        self.pathPanel.SetSizer(pathSizer)
+        dataSizer.Add(item = self.pathPanel,
+        # buttons
+        btnSizer = wx.StdDialogButtonSizer()
+        btnSizer.AddButton(self.btnCancel)
+        btnSizer.AddButton(self.btnOK)
+        btnSizer.Realize()
+        sizer.Add(item = dataSizer, proportion = 1,
+                       flag = wx.EXPAND | wx.ALL | wx.ALIGN_CENTER, border = 5)
+        sizer.Add(item = btnSizer, proportion = 0,
+        self.panel.SetSizer(sizer)
+        sizer.Fit(self)
+        self.SetMinSize(self.GetSize())
+    def GetFileName(self, fullPath = False):
+        """!Returns signature file name
+        @param fullPath return full path of sig. file
+        if fullPath:
+            return os.path.join(self.baseFilePath, self.fileNameCtrl.GetValue())
+        return self.fileNameCtrl.GetValue()
Modified: grass/trunk/gui/wxpython/iclass/digit.py
--- grass/trunk/gui/wxpython/iclass/digit.py	2011-12-19 10:31:30 UTC (rev 49826)
+++ grass/trunk/gui/wxpython/iclass/digit.py	2011-12-19 10:32:12 UTC (rev 49827)
@@ -63,6 +63,10 @@
     def _updateATM(self):
         pass
+    def _onRightUp(self, event):
+        super(IClassVDigitWindow, self)._onRightUp(event)
+        self.parent.UpdateChangeState(changes = True)
     def GetCurrentCategory(self):
         """!Returns current category (class).
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py	2011-12-19 10:31:30 UTC (rev 49826)
+++ grass/trunk/gui/wxpython/iclass/frame.py	2011-12-19 10:32:12 UTC (rev 49827)
@@ -53,7 +53,7 @@
                                IClassToolbar, IClassMapManagerToolbar
 from iclass.statistics  import Statistics, BandStatistics
 from iclass.dialogs     import CategoryListCtrl, IClassCategoryManagerDialog,\
-                               IClassGroupDialog, IClassMapDialog
+                               IClassGroupDialog, IClassMapDialog, IClassSignatureFileDialog
 from iclass.plots       import PlotPanel
@@ -143,8 +143,9 @@
                                             Map = self.GetSecondMap())
         self.InitStatistics()
-        #self.InitTestStatistics()
+        self.changes = False
         # PyPlot init
         self.plotPanel = PlotPanel(self, statDict = self.statisticsDict,
                                    statList = self.statisticsList)
@@ -445,6 +446,12 @@
         stat.SetBandStatistics(cstat)
         self.plotPanel.StddevChanged()
+    def UpdateChangeState(self, changes):
+        """!Informs if any important changes happened
+        since last analysis computaiton.
+        self.changes = changes
     def AddRasterMap(self, name, firstMap = True, secondMap = True):
         """!Add raster map to Map"""
         cmdlist = ['d.rast', 'map=%s' % name]
@@ -527,7 +534,7 @@
                 stats.SetReady()
                 self.statisticsDict[stats.category] = stats
-                #self.ConvertToNull(name = stats.rasterName)
+                self.ConvertToNull(name = stats.rasterName)
                 self.previewMapManager.AddLayer(name = stats.rasterName,
                                                 alias = stats.name, resultsLayer = True)
                 # write statistics
@@ -535,6 +542,7 @@
             else:
                 I_iclass_free_statistics(statistics)
+        self.UpdateChangeState(changes = False)
         return True
     def OnSaveSigFile(self, event):
@@ -543,16 +551,36 @@
             GMessage(parent = self, message = _("No imagery group selected."))
             return
-        dlg = wx.TextEntryDialog(self, message = _("Enter name of signature file:"),
-                                 caption = _("Save signature file"))
-        if self.sigFile:
-            dlg.SetValue(self.sigFile)
+        if self.changes:
+            qdlg = wx.MessageDialog(parent = self,
+                                    message = _("Due to recent changes in classes, "
+                                                "signatures can be outdated and should be recalculated. "
+                                                "Do you still want to continue?") ,
+                                   caption = _("Outdated signatures"),
+                                   style = wx.YES_NO | wx.NO_DEFAULT | wx.ICON_QUESTION | wx.CENTRE)
+            if qdlg.ShowModal() == wx.ID_YES:
+                qdlg.Destroy()
+            else:
+                qdlg.Destroy()
+                return
+        dlg = IClassSignatureFileDialog(self, group = self.group, file = self.sigFile)
         if dlg.ShowModal() == wx.ID_OK:
-            file = dlg.GetValue()
+            if os.path.exists(dlg.GetFileName(fullPath = True)):
+                                        message = _("A signature file named %s already exists.\n"
+                                                    "Do you want to replace it?") % dlg.GetFileName(),
+                                        caption = _("File already exists"),
+                                        style = wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION | wx.CENTRE)
+                    qdlg.Destroy()
+                else:
+                    qdlg.Destroy()
+                    return
+            self.sigFile = dlg.GetFileName()
+            self.WriteSignatures(self.signatures, self.group, self.sigFile)
-            self.WriteSignatures(self.signatures, self.group, file)
         dlg.Destroy()
     def InitStatistics(self):
Modified: grass/trunk/gui/wxpython/wxpythonlib.dox
--- grass/trunk/gui/wxpython/wxpythonlib.dox	2011-12-19 10:31:30 UTC (rev 49826)
+++ grass/trunk/gui/wxpython/wxpythonlib.dox	2011-12-19 10:32:12 UTC (rev 49827)
@@ -445,6 +445,7 @@
 - iclass::digit
  - digit::IClassVDigit
  - digit::IClassVDigitWindow
