[GRASS-SVN] r49836 - in grass/trunk/gui/wxpython: iclass lmgr
svn_grass at osgeo.org
Mon Dec 19 08:09:30 EST 2011
Author: martinl
Date: 2011-12-19 05:09:30 -0800 (Mon, 19 Dec 2011)
New Revision: 49836
grass/trunk/gui/wxpython/iclass/frame.py
grass/trunk/gui/wxpython/lmgr/frame.py
wxGUI/iclass: show error message when unable to launch wxIClass
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py 2011-12-19 12:39:23 UTC (rev 49835)
+++ grass/trunk/gui/wxpython/iclass/frame.py 2011-12-19 13:09:30 UTC (rev 49836)
@@ -32,11 +32,12 @@
try:
from grass.lib.imagery import *
from grass.lib.vector import *
+ haveIClass = True
+ errMsg = ''
except ImportError, e:
- sys.stderr.write(_("Loading imagery lib failed"))
+ haveIClass = False
+ errMsg = _("Loading imagery lib failed.\n%s") % e
-#sys.path.append(os.path.join(globalvar.ETCWXDIR, "icons"))
import grass.script as grass
from mapdisp import statusbar as sb
@@ -55,7 +56,6 @@
from iclass.dialogs import CategoryListCtrl, IClassCategoryManagerDialog,\
IClassGroupDialog, IClassMapDialog, IClassSignatureFileDialog
from iclass.plots import PlotPanel
class IClassMapFrame(DoubleMapFrame):
"""! wxIClass main frame
@@ -76,7 +76,6 @@
@param toolbars dictionary of active toolbars (defalult value represents all toolbars)
@param size default size
DoubleMapFrame.__init__(self, parent = parent, title = title,
name = name,
firstMap = Map(), secondMap = Map(),
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2011-12-19 12:39:23 UTC (rev 49835)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2011-12-19 13:09:30 UTC (rev 49836)
@@ -65,7 +65,6 @@
from gui_core.forms import GUI
from gcp.manager import GCPWizard
from nviz.main import haveNviz
-from iclass.frame import IClassMapFrame
class GMFrame(wx.Frame):
"""!Layer Manager frame with notebook widget for controlling GRASS
@@ -1100,6 +1099,12 @@
def OnIClass(self, event):
"""!Start wxIClass tool"""
+ from iclass.frame import IClassMapFrame, haveIClass, errMsg
+ if not haveIClass:
+ GError(_('Unable to launch "Supervised Classification Tool".\n\n'
+ 'Reason: %s') % errMsg)
+ return
win = IClassMapFrame(parent = self)
win.CentreOnScreen()
