[GRASS-SVN] r49845 - in grass/trunk: include/defs lib/imagery
svn_grass at osgeo.org
Tue Dec 20 10:04:03 EST 2011
Author: mmetz
Date: 2011-12-20 07:04:03 -0800 (Tue, 20 Dec 2011)
New Revision: 49845
grass/trunk/include/defs/imagery.h
grass/trunk/lib/imagery/georef.c
move polynomial transformation to imagery lib
Modified: grass/trunk/include/defs/imagery.h
--- grass/trunk/include/defs/imagery.h 2011-12-20 11:24:33 UTC (rev 49844)
+++ grass/trunk/include/defs/imagery.h 2011-12-20 15:04:03 UTC (rev 49845)
@@ -31,9 +31,9 @@
FILE *I_fopen_subgroup_file_old(const char *, const char *, const char *);
/* georef.c */
-int I_compute_georef_equations(struct Control_Points *, double[3], double[3],
- double[3], double[3]);
-int I_georef(double, double, double *, double *, double[3], double[3]);
+int I_compute_georef_equations(struct Control_Points *, double *, double *,
+ double *, double *, int);
+int I_georef(double, double, double *, double *, double *, double *, int);
/* group.c */
int I_get_group(char *);
Modified: grass/trunk/lib/imagery/georef.c
--- grass/trunk/lib/imagery/georef.c 2011-12-20 11:24:33 UTC (rev 49844)
+++ grass/trunk/lib/imagery/georef.c 2011-12-20 15:04:03 UTC (rev 49845)
@@ -3,6 +3,11 @@
* MODULE: imagery library
* AUTHOR(S): Original author(s) name(s) unknown - written by CERL
+ * Written By: Brian J. Buckley
+ * At: The Center for Remote Sensing
+ * Michigan State University
* PURPOSE: Image processing library
* COPYRIGHT: (C) 1999, 2005 by the GRASS Development Team
@@ -12,187 +17,435 @@
-#include <grass/config.h>
+ * Written: 12/19/91
+ * Last Update: 12/26/91 Brian J. Buckley
+ * Last Update: 1/24/92 Brian J. Buckley
+ * Added printout of trnfile. Triggered by BDEBUG.
+ * Last Update: 1/27/92 Brian J. Buckley
+ * Fixed bug so that only the active control points were used.
+#include <stdlib.h>
+#include <math.h>
+#include <grass/gis.h>
#include <grass/imagery.h>
#include <signal.h>
-static int floating_exception;
-static void catch(int);
-static double determinant(double, double,
- double, double, double, double, double, double,
- double);
+/* STRUCTURE FOR USE INTERNALLY WITH THESE FUNCTIONS. THESE FUNCTIONS EXPECT
+ SQUARE MATRICES SO ONLY ONE VARIABLE IS GIVEN (N) FOR THE MATRIX SIZE */
-/* find coefficients A,B,C for e2 = A + B*e1 + C*n1
- * also compute the reverse equations
- * return 0 if no points
- * -1 if not solvable
- * 1 if ok
- * method is least squares.
- * the least squares problem reduces to solving the following
- * system of equations for A,B,C
- * s0*A + s1*B + s2*C = x0
- * s1*A + s3*B + s4*C = x1
- * s2*A + s4*B + s5*C = x2
- * use Cramer's rule
- * | x0 s1 s2 | | s0 x0 s2 | | s0 s1 x0 |
- * | x1 s3 s4 | | s1 x1 s4 | | s1 s3 x1 |
- * | x2 s4 s5 | | s2 x2 s5 | | s2 s4 x2 |
- * A = ------------ B = ------------ C = ------------
- * | s0 s1 s2 | | s0 s1 s2 | | s0 s1 s2 |
- * | s1 s3 s4 | | s1 s3 s4 | | s1 s3 s4 |
- * | s2 s4 s5 | | s2 s4 s5 | | s2 s4 s5 |
+struct MATRIX
+ int n; /* SIZE OF THIS MATRIX (N x N) */
+ double *v;
-int I_compute_georef_equations(struct Control_Points *cp,
- double E12[3], double N12[3], double E21[3],
- double N21[3])
+/* CALCULATE OFFSET INTO ARRAY BASED ON R/C */
+#define M(row,col) m->v[(((row)-1)*(m->n))+(col)-1]
+#define MSUCCESS 1 /* SUCCESS */
+#define MNPTERR 0 /* NOT ENOUGH POINTS */
+#define MUNSOLVABLE -1 /* NOT SOLVABLE */
+#define MMEMERR -2 /* NOT ENOUGH MEMORY */
+#define MPARMERR -3 /* PARAMETER ERROR */
+#define MINTERR -4 /* INTERNAL ERROR */
+#define MAXORDER 3 /* HIGHEST SUPPORTED ORDER OF TRANSFORMATION */
+ FUNCTION PROTOTYPES FOR STATIC (INTERNAL) FUNCTIONS
+static int calccoef(struct Control_Points *, double *, double *, int);
+static int calcls(struct Control_Points *, struct MATRIX *, double *,
+ double *, double *, double *);
+static int exactdet(struct Control_Points *, struct MATRIX *, double *,
+static int solvemat(struct MATRIX *, double *, double *, double *, double *);
+static double term(int, double, double);
+ TRANSFORM A SINGLE COORDINATE PAIR.
+int I_georef(double e1, /* EASTING TO BE TRANSFORMED */
+ double n1, /* NORTHING TO BE TRANSFORMED */
+ double *e, /* EASTING, TRANSFORMED */
+ double *n, /* NORTHING, TRANSFORMED */
+ double E[], /* EASTING COEFFICIENTS */
+ double N[], /* NORTHING COEFFICIENTS */
+ int order /* ORDER OF TRANSFORMATION TO BE PERFORMED, MUST MATCH THE
+ ORDER USED TO CALCULATE THE COEFFICIENTS */
- RETSIGTYPE(*sigfpe) (int);
- double s0, s1, s2, s3, s4, s5;
- double x0, x1, x2;
- double det;
- int i;
+ double e3, e2n, en2, n3, e2, en, n2;
+ switch (order) {
+ case 1:
+ *e = E[0] + E[1] * e1 + E[2] * n1;
+ *n = N[0] + N[1] * e1 + N[2] * n1;
+ break;
- s0 = s1 = s2 = s3 = s4 = s5 = 0.0;
- for (i = 0; i < cp->count; i++) {
- if (cp->status[i] <= 0)
- continue;
- s0 += 1.0;
- s1 += cp->e1[i];
- s2 += cp->n1[i];
- s3 += cp->e1[i] * cp->e1[i];
- s4 += cp->e1[i] * cp->n1[i];
- s5 += cp->n1[i] * cp->n1[i];
- if (s0 < 0.5)
- return 0;
+ case 2:
+ e2 = e1 * e1;
+ n2 = n1 * n1;
+ en = e1 * n1;
- floating_exception = 0;
- sigfpe = signal(SIGFPE, catch);
+ *e = E[0] + E[1] * e1 + E[2] * n1 + E[3] * e2 + E[4] * en + E[5] * n2;
+ *n = N[0] + N[1] * e1 + N[2] * n1 + N[3] * e2 + N[4] * en + N[5] * n2;
+ break;
- /* eastings */
- x0 = x1 = x2 = 0.0;
- continue;
- x0 += cp->e2[i];
- x1 += cp->e1[i] * cp->e2[i];
- x2 += cp->n1[i] * cp->e2[i];
+ case 3:
+ e2 = e1 * e1;
+ en = e1 * n1;
+ n2 = n1 * n1;
+ e3 = e1 * e2;
+ e2n = e2 * n1;
+ en2 = e1 * n2;
+ n3 = n1 * n2;
- det = determinant(s0, s1, s2, s1, s3, s4, s2, s4, s5);
- if (det == 0.0) {
- signal(SIGFPE, sigfpe);
- return -1;
- E12[0] = determinant(x0, s1, s2, x1, s3, s4, x2, s4, s5) / det;
- E12[1] = determinant(s0, x0, s2, s1, x1, s4, s2, x2, s5) / det;
- E12[2] = determinant(s0, s1, x0, s1, s3, x1, s2, s4, x2) / det;
+ *e = E[0] +
+ E[3] * e2 + E[4] * en + E[5] * n2 +
+ E[6] * e3 + E[7] * e2n + E[8] * en2 + E[9] * n3;
+ *n = N[0] +
+ N[3] * e2 + N[4] * en + N[5] * n2 +
+ N[6] * e3 + N[7] * e2n + N[8] * en2 + N[9] * n3;
+ break;
- /* northings */
- continue;
- x0 += cp->n2[i];
- x1 += cp->e1[i] * cp->n2[i];
- x2 += cp->n1[i] * cp->n2[i];
+ default:
+ return MPARMERR;
- if (det == 0.0) {
- return -1;
- N12[0] = determinant(x0, s1, s2, x1, s3, s4, x2, s4, s5) / det;
- N12[1] = determinant(s0, x0, s2, s1, x1, s4, s2, x2, s5) / det;
- N12[2] = determinant(s0, s1, x0, s1, s3, x1, s2, s4, x2) / det;
+ return MSUCCESS;
- /* the inverse equations */
- continue;
- s0 += 1.0;
- s1 += cp->e2[i];
- s2 += cp->n2[i];
- s3 += cp->e2[i] * cp->e2[i];
- s4 += cp->e2[i] * cp->n2[i];
- s5 += cp->n2[i] * cp->n2[i];
+ COMPUTE THE FORWARD AND BACKWARD GEOREFFERENCING COEFFICIENTS
+ BASED ON A SET OF CONTROL POINTS
- /* eastings */
- continue;
- x0 += cp->e1[i];
- x1 += cp->e2[i] * cp->e1[i];
- x2 += cp->n2[i] * cp->e1[i];
+int I_compute_georef_equations(struct Control_Points *cp, double E12[],
+ double N12[], double E21[], double N21[],
+ int order)
+ double *tempptr;
+ int status;
+ if (order < 1 || order > MAXORDER)
+ return MPARMERR;
+ /* CALCULATE THE FORWARD TRANSFORMATION COEFFICIENTS */
+ status = calccoef(cp, E12, N12, order);
+ if (status != MSUCCESS)
+ return status;
+ /* SWITCH THE 1 AND 2 EASTING AND NORTHING ARRAYS */
+ tempptr = cp->e1;
+ cp->e1 = cp->e2;
+ cp->e2 = tempptr;
+ tempptr = cp->n1;
+ cp->n1 = cp->n2;
+ cp->n2 = tempptr;
+ /* CALCULATE THE BACKWARD TRANSFORMATION COEFFICIENTS */
+ status = calccoef(cp, E21, N21, order);
+ /* SWITCH THE 1 AND 2 EASTING AND NORTHING ARRAYS BACK */
+ tempptr = cp->e1;
+ cp->e1 = cp->e2;
+ cp->e2 = tempptr;
+ tempptr = cp->n1;
+ cp->n1 = cp->n2;
+ cp->n2 = tempptr;
+ return status;
+ COMPUTE THE GEOREFFERENCING COEFFICIENTS
+static int calccoef(struct Control_Points *cp, double E[], double N[],
+ int order)
+ struct MATRIX m;
+ double *a;
+ double *b;
+ int numactive; /* NUMBER OF ACTIVE CONTROL POINTS */
+ int status, i;
+ /* CALCULATE THE NUMBER OF VALID CONTROL POINTS */
+ for (i = numactive = 0; i < cp->count; i++) {
+ if (cp->status[i] > 0)
+ numactive++;
- if (det == 0.0) {
- return -1;
+ /* CALCULATE THE MINIMUM NUMBER OF CONTROL POINTS NEEDED TO DETERMINE
+ A TRANSFORMATION OF THIS ORDER */
+ m.n = ((order + 1) * (order + 2)) / 2;
+ if (numactive < m.n)
+ return MNPTERR;
+ /* INITIALIZE MATRIX */
+ m.v = G_calloc(m.n * m.n, sizeof(double));
+ a = G_calloc(m.n, sizeof(double));
+ b = G_calloc(m.n, sizeof(double));
+ if (numactive == m.n)
+ status = exactdet(cp, &m, a, b, E, N);
+ else
+ status = calcls(cp, &m, a, b, E, N);
+ G_free(m.v);
+ G_free(a);
+ G_free(b);
+ return status;
+ CALCULATE THE TRANSFORMATION COEFFICIENTS WITH EXACTLY THE MINIMUM
+ NUMBER OF CONTROL POINTS REQUIRED FOR THIS TRANSFORMATION.
+static int exactdet(struct Control_Points *cp, struct MATRIX *m,
+ double a[], double b[],
+ double N[] /* NORTHING COEFFICIENTS */
+ int pntnow, currow, j;
+ currow = 1;
+ for (pntnow = 0; pntnow < cp->count; pntnow++) {
+ if (cp->status[pntnow] > 0) {
+ /* POPULATE MATRIX M */
+ for (j = 1; j <= m->n; j++)
+ M(currow, j) = term(j, cp->e1[pntnow], cp->n1[pntnow]);
+ /* POPULATE MATRIX A AND B */
+ a[currow - 1] = cp->e2[pntnow];
+ b[currow - 1] = cp->n2[pntnow];
+ currow++;
- E21[0] = determinant(x0, s1, s2, x1, s3, s4, x2, s4, s5) / det;
- E21[1] = determinant(s0, x0, s2, s1, x1, s4, s2, x2, s5) / det;
- E21[2] = determinant(s0, s1, x0, s1, s3, x1, s2, s4, x2) / det;
- /* northings */
- continue;
- x0 += cp->n1[i];
- x1 += cp->e2[i] * cp->n1[i];
- x2 += cp->n2[i] * cp->n1[i];
+ if (currow - 1 != m->n)
+ return MINTERR;
+ return solvemat(m, a, b, E, N);
+ CALCULATE THE TRANSFORMATION COEFFICIENTS WITH MORE THAN THE MINIMUM
+ NUMBER OF CONTROL POINTS REQUIRED FOR THIS TRANSFORMATION. THIS
+ ROUTINE USES THE LEAST SQUARES METHOD TO COMPUTE THE COEFFICIENTS.
+static int calcls(struct Control_Points *cp, struct MATRIX *m,
+ int i, j, n, numactive = 0;
+ /* INITIALIZE THE UPPER HALF OF THE MATRIX AND THE TWO COLUMN VECTORS */
+ for (i = 1; i <= m->n; i++) {
+ for (j = i; j <= m->n; j++)
+ M(i, j) = 0.0;
+ a[i - 1] = b[i - 1] = 0.0;
- if (det == 0.0) {
- return -1;
+ /* SUM THE UPPER HALF OF THE MATRIX AND THE COLUMN VECTORS ACCORDING TO
+ THE LEAST SQUARES METHOD OF SOLVING OVER DETERMINED SYSTEMS */
+ for (n = 0; n < cp->count; n++) {
+ if (cp->status[n] > 0) {
+ numactive++;
+ M(i, j) +=
+ term(i, cp->e1[n], cp->n1[n]) * term(j, cp->e1[n],
+ cp->n1[n]);
+ a[i - 1] += cp->e2[n] * term(i, cp->e1[n], cp->n1[n]);
+ b[i - 1] += cp->n2[n] * term(i, cp->e1[n], cp->n1[n]);
- N21[0] = determinant(x0, s1, s2, x1, s3, s4, x2, s4, s5) / det;
- N21[1] = determinant(s0, x0, s2, s1, x1, s4, s2, x2, s5) / det;
- N21[2] = determinant(s0, s1, x0, s1, s3, x1, s2, s4, x2) / det;
- return floating_exception ? -1 : 1;
+ if (numactive <= m->n)
+ return MINTERR;
+ /* TRANSPOSE VALUES IN UPPER HALF OF M TO OTHER HALF */
+ for (i = 2; i <= m->n; i++)
+ for (j = 1; j < i; j++)
+ M(i, j) = M(j, i);
-static double determinant(double a, double b, double c, double d, double e,
- double f, double g, double h, double i)
+ CALCULATE THE X/Y TERM BASED ON THE TERM NUMBER
+ ORDER\TERM 1 2 3 4 5 6 7 8 9 10
+ 1 e0n0 e1n0 e0n1
+ 2 e0n0 e1n0 e0n1 e2n0 e1n1 e0n2
+ 3 e0n0 e1n0 e0n1 e2n0 e1n1 e0n2 e3n0 e2n1 e1n2 e0n3
+static double term(int term, double e, double n)
- /* compute determinant of 3x3 matrix
- * | a b c |
- * | d e f |
- * | g h i |
- return a * (e * i - f * h) - b * (d * i - f * g) + c * (d * h - e * g);
+ switch (term) {
+ case 1:
+ return 1.0;
+ case 2:
+ return e;
+ case 3:
+ return n;
+ case 4:
+ return e * e;
+ case 5:
+ return e * n;
+ case 6:
+ return n * n;
+ case 7:
+ return e * e * e;
+ case 8:
+ return e * e * n;
+ case 9:
+ return e * n * n;
+ case 10:
+ return n * n * n;
-static void catch(int n)
- floating_exception = 1;
- signal(n, catch);
+ return 0.0;
-int I_georef(double e1, double n1,
- double *e2, double *n2, double E[3], double N[3])
+ SOLVE FOR THE 'E' AND 'N' COEFFICIENTS BY USING A SOMEWHAT MODIFIED
+ GAUSSIAN ELIMINATION METHOD.
+ | M11 M12 ... M1n | | E0 | | a0 |
+ | M21 M22 ... M2n | | E1 | = | a1 |
+ | Mn1 Mn2 ... Mnn | | En-1 | | an-1 |
+ and
+ | M11 M12 ... M1n | | N0 | | b0 |
+ | M21 M22 ... M2n | | N1 | = | b1 |
+ | Mn1 Mn2 ... Mnn | | Nn-1 | | bn-1 |
+static int solvemat(struct MATRIX *m, double a[], double b[], double E[],
+ double N[])
- *e2 = E[0] + E[1] * e1 + E[2] * n1;
- *n2 = N[0] + N[1] * e1 + N[2] * n1;
+ int i, j, i2, j2, imark;
+ double factor, temp;
+ double pivot; /* ACTUAL VALUE OF THE LARGEST PIVOT CANDIDATE */
- return 0;
+ j = i;
+ /* find row with largest magnitude value for pivot value */
+ pivot = M(i, j);
+ imark = i;
+ for (i2 = i + 1; i2 <= m->n; i2++) {
+ temp = fabs(M(i2, j));
+ if (temp > fabs(pivot)) {
+ pivot = M(i2, j);
+ imark = i2;
+ /* if the pivot is very small then the points are nearly co-linear */
+ /* co-linear points result in an undefined matrix, and nearly */
+ /* co-linear points results in a solution with rounding error */
+ if (pivot == 0.0)
+ return MUNSOLVABLE;
+ /* if row with highest pivot is not the current row, switch them */
+ if (imark != i) {
+ for (j2 = 1; j2 <= m->n; j2++) {
+ temp = M(imark, j2);
+ M(imark, j2) = M(i, j2);
+ M(i, j2) = temp;
+ temp = a[imark - 1];
+ a[imark - 1] = a[i - 1];
+ a[i - 1] = temp;
+ temp = b[imark - 1];
+ b[imark - 1] = b[i - 1];
+ b[i - 1] = temp;
+ /* compute zeros above and below the pivot, and compute
+ values for the rest of the row as well */
+ for (i2 = 1; i2 <= m->n; i2++) {
+ if (i2 != i) {
+ factor = M(i2, j) / pivot;
+ for (j2 = j; j2 <= m->n; j2++)
+ M(i2, j2) -= factor * M(i, j2);
+ a[i2 - 1] -= factor * a[i - 1];
+ b[i2 - 1] -= factor * b[i - 1];
+ /* SINCE ALL OTHER VALUES IN THE MATRIX ARE ZERO NOW, CALCULATE THE
+ COEFFICIENTS BY DIVIDING THE COLUMN VECTORS BY THE DIAGONAL VALUES. */
+ E[i - 1] = a[i - 1] / M(i, i);
+ N[i - 1] = b[i - 1] / M(i, i);
+ return MSUCCESS;
