[GRASS-SVN] r49847 - grass/trunk/imagery/i.rectify
Tue Dec 20 10:25:09 EST 2011
Author: mmetz
Date: 2011-12-20 07:25:09 -0800 (Tue, 20 Dec 2011)
New Revision: 49847
Removed:
   grass/trunk/imagery/i.rectify/crs.c
   grass/trunk/imagery/i.rectify/crs.h
   grass/trunk/imagery/i.rectify/cp.c
   grass/trunk/imagery/i.rectify/get_wind.c
   grass/trunk/imagery/i.rectify/main.c
   grass/trunk/imagery/i.rectify/rectify.c
use imagery lib for transformation
Modified: grass/trunk/imagery/i.rectify/cp.c
--- grass/trunk/imagery/i.rectify/cp.c	2011-12-20 15:10:56 UTC (rev 49846)
+++ grass/trunk/imagery/i.rectify/cp.c	2011-12-20 15:25:09 UTC (rev 49847)
@@ -2,7 +2,7 @@
 #include <string.h>
 #include <grass/glocale.h>
 #include "global.h"
-#include "crs.h"		/* CRS HEADER FILE */
 int get_control_points(char *group, int order	/* THIS HAS BEEN ADDED WITH THE CRS MODIFICATIONS */
@@ -15,7 +15,7 @@
     sprintf(msg, _("Control Point file for group <%s@%s> - "),
 	    group, G_mapset());
-    switch (CRS_compute_georef_equations(&cp, E12, N12, E21, N21, order)) {
+    switch (I_compute_georef_equations(&cp, E12, N12, E21, N21, order)) {
     case 0:
 	sprintf(&msg[strlen(msg)],
 		_("Not enough active control points for current order, %d are required."),
Deleted: grass/trunk/imagery/i.rectify/crs.c
--- grass/trunk/imagery/i.rectify/crs.c	2011-12-20 15:10:56 UTC (rev 49846)
+++ grass/trunk/imagery/i.rectify/crs.c	2011-12-20 15:25:09 UTC (rev 49847)
@@ -1,711 +0,0 @@
-   CRS.C - Center for Remote Sensing rectification routines
-   Written By: Brian J. Buckley
-   At: The Center for Remote Sensing
-   Michigan State University
-   302 Berkey Hall
-   East Lansing, MI  48824
-   (517)353-7195
-   Written: 12/19/91
-   Last Update: 12/26/91 Brian J. Buckley
-   Last Update:  1/24/92 Brian J. Buckley
-   Added printout of trnfile. Triggered by BDEBUG.
-   Last Update:  1/27/92 Brian J. Buckley
-   Fixed bug so that only the active control points were used.
-#include <stdio.h>
-#include <string.h>
-#include <stdlib.h>
-#include <math.h>
-#include <limits.h>
-#include <grass/gis.h>
-   #define MSDOS 1
-   #define BDEBUG
-#ifdef BDEBUG
-FILE *fp;
-#endif
-#ifdef MSDOS
-#include "stdlib.h"
-#include "dummy.h"
-typedef double DOUBLE;
-#else
-#include <grass/imagery.h>
-#endif
-#include "crs.h"
-/* STRUCTURE FOR USE INTERNALLY WITH THESE FUNCTIONS.  THESE FUNCTIONS EXPECT
-   SQUARE MATRICES SO ONLY ONE VARIABLE IS GIVEN (N) FOR THE MATRIX SIZE */
-struct MATRIX
-    int n;			/* SIZE OF THIS MATRIX (N x N) */
-    DOUBLE *v;
-/* CALCULATE OFFSET INTO ARRAY BASED ON R/C */
-#define M(row,col) m->v[(((row)-1)*(m->n))+(col)-1]
-#define MSUCCESS     1		/* SUCCESS */
-#define MNPTERR      0		/* NOT ENOUGH POINTS */
-#define MUNSOLVABLE -1		/* NOT SOLVABLE */
-#define MMEMERR     -2		/* NOT ENOUGH MEMORY */
-#define MPARMERR    -3		/* PARAMETER ERROR */
-#define MINTERR     -4		/* INTERNAL ERROR */
-   FUNCTION PROTOTYPES FOR STATIC (INTERNAL) FUNCTIONS
-#ifdef MSDOS
-static int calccoef(struct Control_Points *, double *, double *, int);
-static int calcls(struct Control_Points *, struct MATRIX *,
-		  DOUBLE *, DOUBLE *, double *, double *);
-static int exactdet(struct Control_Points *, struct MATRIX *,
-static int solvemat(struct MATRIX *, DOUBLE *, DOUBLE *, double *, double *);
-static DOUBLE term(int, double, double);
-#ifdef BDEBUG
-static int checkgeoref(struct Control_Points *, double *, double *, int, int,
-		       FILE * fp);
-#endif
-#else
-static int calccoef();
-static int calcls();
-static int exactdet();
-static int solvemat();
-static DOUBLE term();
-#ifdef BDEBUG
-static int checkgeoref();
-#endif
-#endif
-   USE THIS TRANSFORMATION FUNCTION IF YOU WANT TO DO ARRAYS.
-#ifdef BETTERGEOREF
-extern void CRS_georef(int, DOUBLE *, DOUBLE *, DOUBLE *, DOUBLE *, int);
-void CRS_georef2(int order,	/* ORDER OF TRANSFORMATION TO BE PERFORMED, MUST MATCH THE
-				   ORDER USED TO CALCULATE THE COEFFICIENTS */
-		 double E[],	/* EASTING COEFFICIENTS */
-		 double N[],	/* NORTHING COEFFICIENTS */
-		 double e[],	/* EASTINGS TO BE TRANSFORMED */
-		 double n[],	/* NORTHINGS TO BE TRANSFORMED */
-		 int numpts	/* NUMBER OF POINTS TO BE TRANSFORMED */
-    DOUBLE e3, e2n, e2, en2, en, e1, n3, n2, n1;
-    int i;
-    switch (order) {
-    case 3:
-	for (i = 0; i < numpts; i++) {
-	    e1 = e[i];
-	    n1 = n[i];
-	    e2 = e1 * e1;
-	    en = e1 * n1;
-	    n2 = n1 * n1;
-	    e3 = e1 * e2;
-	    e2n = e2 * n1;
-	    en2 = e1 * n2;
-	    n3 = n1 * n2;
-	    e[i] = E[0] +
-		E[1] * e1 + E[2] * n1 +
-		E[3] * e2 + E[4] * en + E[5] * n2 +
-		E[6] * e3 + E[7] * e2n + E[8] * en2 + E[9] * n3;
-	    n[i] = N[0] +
-		N[1] * e1 + N[2] * n1 +
-		N[3] * e2 + N[4] * en + N[5] * n2 +
-		N[6] * e3 + N[7] * e2n + N[8] * en2 + N[9] * n3;
-	break;
-    case 2:
-	    e1 = e[i];
-	    n1 = n[i];
-	    e2 = e1 * e1;
-	    n2 = n1 * n1;
-	    en = e1 * n1;
-	    e[i] = E[0] + E[1] * e1 + E[2] * n1 +
-		E[3] * e2 + E[4] * en + E[5] * n2;
-	    n[i] = N[0] + N[1] * e1 + N[2] * n1 +
-		N[3] * e2 + N[4] * en + N[5] * n2;
-	break;
-    case 1:
-	    e1 = e[i];
-	    n1 = n[i];
-	    e[i] = E[0] + E[1] * e1 + E[2] * n1;
-	    n[i] = N[0] + N[1] * e1 + N[2] * n1;
-	break;
-#endif
-   TRANSFORM A SINGLE COORDINATE PAIR.
-int CRS_georef(double e1,	/* EASTINGS TO BE TRANSFORMED */
-	       double n1,	/* NORTHINGS TO BE TRANSFORMED */
-	       double *e,	/* EASTINGS TO BE TRANSFORMED */
-	       double *n,	/* NORTHINGS TO BE TRANSFORMED */
-	       int order	/* ORDER OF TRANSFORMATION TO BE PERFORMED, MUST MATCH THE
-    DOUBLE e3, e2n, en2, n3, e2, en, n2;
-    switch (order) {
-    case 1:
-	*e = E[0] + E[1] * e1 + E[2] * n1;
-	*n = N[0] + N[1] * e1 + N[2] * n1;
-	break;
-    case 2:
-	e2 = e1 * e1;
-	n2 = n1 * n1;
-	en = e1 * n1;
-	*e = E[0] + E[1] * e1 + E[2] * n1 + E[3] * e2 + E[4] * en + E[5] * n2;
-	*n = N[0] + N[1] * e1 + N[2] * n1 + N[3] * e2 + N[4] * en + N[5] * n2;
-	break;
-    case 3:
-	e2 = e1 * e1;
-	en = e1 * n1;
-	n2 = n1 * n1;
-	e3 = e1 * e2;
-	e2n = e2 * n1;
-	en2 = e1 * n2;
-	n3 = n1 * n2;
-	*e = E[0] +
-	*n = N[0] +
-	break;
-    default:
-	return (MPARMERR);
-	break;
-    return (MSUCCESS);
-   COMPUTE THE GEOREFFERENCING COEFFICIENTS BASED ON A SET OF CONTROL POINTS
-int
-CRS_compute_georef_equations(struct Control_Points *cp, double E12[],
-			     double N12[], double E21[], double N21[],
-			     int order)
-    double *tempptr;
-    int status;
-    if (order < 1 || order > MAXORDER)
-#ifdef BDEBUG
-    fp = fopen("error.dat", "w");
-    if (fp == NULL)
-	return (-1);
-#endif
-    /* CALCULATE THE FORWARD TRANSFORMATION COEFFICIENTS */
-    status = calccoef(cp, E12, N12, order);
-    if (status != MSUCCESS)
-	return (status);
-#ifdef BDEBUG
-    checkgeoref(cp, E12, N12, order, 1, fp);
-#endif
-    /* SWITCH THE 1 AND 2 EASTING AND NORTHING ARRAYS */
-    tempptr = cp->e1;
-    cp->e1 = cp->e2;
-    cp->e2 = tempptr;
-    tempptr = cp->n1;
-    cp->n1 = cp->n2;
-    cp->n2 = tempptr;
-    /* CALCULATE THE BACKWARD TRANSFORMATION COEFFICIENTS */
-    status = calccoef(cp, E21, N21, order);
-#ifdef BDEBUG
-    checkgeoref(cp, E21, N21, order, 0, fp);
-    fclose(fp);
-#endif
-    /* SWITCH THE 1 AND 2 EASTING AND NORTHING ARRAYS BACK */
-    tempptr = cp->e1;
-    cp->e1 = cp->e2;
-    cp->e2 = tempptr;
-    tempptr = cp->n1;
-    cp->n1 = cp->n2;
-    cp->n2 = tempptr;
-    return (status);
-static int
-calccoef(struct Control_Points *cp, double E[], double N[], int order)
-    struct MATRIX m;
-    DOUBLE *a;
-    DOUBLE *b;
-    int numactive;		/* NUMBER OF ACTIVE CONTROL POINTS */
-    int status, i;
-    /* CALCULATE THE NUMBER OF VALID CONTROL POINTS */
-    for (i = numactive = 0; i < cp->count; i++) {
-	if (cp->status[i] > 0)
-	    numactive++;
-    /* CALCULATE THE MINIMUM NUMBER OF CONTROL POINTS NEEDED TO DETERMINE
-       A TRANSFORMATION OF THIS ORDER */
-    m.n = ((order + 1) * (order + 2)) / 2;
-    if (numactive < m.n)
-	return (MNPTERR);
-    /* INITIALIZE MATRIX */
-    m.v = (DOUBLE *) G_calloc(m.n * m.n, sizeof(DOUBLE));
-    if (m.v == NULL) {
-	return (MMEMERR);
-    a = (DOUBLE *) G_calloc(m.n, sizeof(DOUBLE));
-    if (a == NULL) {
-	G_free((char *)m.v);
-	return (MMEMERR);
-    b = (DOUBLE *) G_calloc(m.n, sizeof(DOUBLE));
-    if (b == NULL) {
-	G_free((char *)a);
-	return (MMEMERR);
-    if (numactive == m.n)
-	status = exactdet(cp, &m, a, b, E, N);
-    else
-	status = calcls(cp, &m, a, b, E, N);
-    G_free((char *)b);
-    return (status);
-   CALCULATE THE TRANSFORMATION COEFFICIENTS WITH EXACTLY THE MINIMUM
-   NUMBER OF CONTROL POINTS REQUIRED FOR THIS TRANSFORMATION.
-static int exactdet(struct Control_Points *cp, struct MATRIX *m, DOUBLE a[], DOUBLE b[], double E[],	/* EASTING COEFFICIENTS */
-		    double N[]	/* NORTHING COEFFICIENTS */
-    int pntnow, currow, j;
-    currow = 1;
-    for (pntnow = 0; pntnow < cp->count; pntnow++) {
-	if (cp->status[pntnow] > 0) {
-	    /* POPULATE MATRIX M */
-#ifdef BDEBUG
-	    fprintf(fp, "%2d ", pntnow + 1);
-#endif
-	    for (j = 1; j <= m->n; j++) {
-		M(currow, j) = term(j, cp->e1[pntnow], cp->n1[pntnow]);
-#ifdef BDEBUG
-		fprintf(fp, "%+14.7le ", M(currow, j));
-		if (j == 5)
-		    fprintf(fp, "\n   ");
-#endif
-#ifdef BDEBUG
-	    fprintf(fp, "\n");
-#endif
-	    /* POPULATE MATRIX A AND B */
-	    a[currow - 1] = cp->e2[pntnow];
-	    b[currow - 1] = cp->n2[pntnow];
-#ifdef BDEBUG
-	    fprintf(fp, "   %+14.7le ", a[currow - 1]);
-	    fprintf(fp, "%+14.7le\n", b[currow - 1]);
-#endif
-	    currow++;
-#ifdef BDEBUG
-	else {
-	    fprintf(fp, "%2d UNUSED\n", pntnow + 1);
-#endif
-    if (currow - 1 != m->n)
-	return (MINTERR);
-    return (solvemat(m, a, b, E, N));
-   CALCULATE THE TRANSFORMATION COEFFICIENTS WITH MORE THAN THE MINIMUM
-   NUMBER OF CONTROL POINTS REQUIRED FOR THIS TRANSFORMATION.  THIS
-   ROUTINE USES THE LEAST SQUARES METHOD TO COMPUTE THE COEFFICIENTS.
-static int calcls(struct Control_Points *cp, struct MATRIX *m, DOUBLE a[], DOUBLE b[], double E[],	/* EASTING COEFFICIENTS */
-    int i, j, n, numactive = 0;
-    /* INITIALIZE THE UPPER HALF OF THE MATRIX AND THE TWO COLUMN VECTORS */
-    for (i = 1; i <= m->n; i++) {
-	for (j = i; j <= m->n; j++)
-	    M(i, j) = 0.0;
-	a[i - 1] = b[i - 1] = 0.0;
-    /* SUM THE UPPER HALF OF THE MATRIX AND THE COLUMN VECTORS ACCORDING TO
-       THE LEAST SQUARES METHOD OF SOLVING OVER DETERMINED SYSTEMS */
-    for (n = 0; n < cp->count; n++) {
-	if (cp->status[n] > 0) {
-	    numactive++;
-		    M(i, j) +=
-			term(i, cp->e1[n], cp->n1[n]) * term(j, cp->e1[n],
-							     cp->n1[n]);
-		a[i - 1] += cp->e2[n] * term(i, cp->e1[n], cp->n1[n]);
-		b[i - 1] += cp->n2[n] * term(i, cp->e1[n], cp->n1[n]);
-    if (numactive <= m->n)
-	return (MINTERR);
-    /* TRANSPOSE VALUES IN UPPER HALF OF M TO OTHER HALF */
-    for (i = 2; i <= m->n; i++) {
-	for (j = 1; j < i; j++)
-	    M(i, j) = M(j, i);
-   CALCULATE THE X/Y TERM BASED ON THE TERM NUMBER
-   ORDER\TERM   1    2    3    4    5    6    7    8    9   10
-   1        e0n0 e1n0 e0n1
-   2        e0n0 e1n0 e0n1 e2n0 e1n1 e0n2
-   3        e0n0 e1n0 e0n1 e2n0 e1n1 e0n2 e3n0 e2n1 e1n2 e0n3
-static DOUBLE term(int term, double e, double n)
-    switch (term) {
-    case 1:
-	return ((DOUBLE) 1.0);
-    case 2:
-	return ((DOUBLE) e);
-    case 3:
-	return ((DOUBLE) n);
-    case 4:
-	return ((DOUBLE) (e * e));
-    case 5:
-	return ((DOUBLE) (e * n));
-    case 6:
-	return ((DOUBLE) (n * n));
-    case 7:
-	return ((DOUBLE) (e * e * e));
-    case 8:
-	return ((DOUBLE) (e * e * n));
-    case 9:
-	return ((DOUBLE) (e * n * n));
-    case 10:
-	return ((DOUBLE) (n * n * n));
-    return ((DOUBLE) 0.0);
-   SOLVE FOR THE 'E' AND 'N' COEFFICIENTS BY USING A SOMEWHAT MODIFIED
-   GAUSSIAN ELIMINATION METHOD.
-   | M11 M12 ... M1n | | E0   |   | a0   |
-   | M21 M22 ... M2n | | E1   | = | a1   |
-   | Mn1 Mn2 ... Mnn | | En-1 |   | an-1 |
-   and
-   | M11 M12 ... M1n | | N0   |   | b0   |
-   | M21 M22 ... M2n | | N1   | = | b1   |
-   | Mn1 Mn2 ... Mnn | | Nn-1 |   | bn-1 |
-static int solvemat(struct MATRIX *m,
-		    DOUBLE a[], DOUBLE b[], double E[], double N[])
-    int i, j, i2, j2, imark;
-    DOUBLE factor, temp;
-    DOUBLE pivot;		/* ACTUAL VALUE OF THE LARGEST PIVOT CANDIDATE */
-	j = i;
-	/* find row with largest magnitude value for pivot value */
-	pivot = M(i, j);
-	imark = i;
-	for (i2 = i + 1; i2 <= m->n; i2++) {
-	    temp = fabs(M(i2, j));
-	    if (temp > fabs(pivot)) {
-		pivot = M(i2, j);
-		imark = i2;
-	/* if the pivot is very small then the points are nearly co-linear */
-	/* co-linear points result in an undefined matrix, and nearly */
-	/* co-linear points results in a solution with rounding error */
-	if (pivot == 0.0)
-	    return (MUNSOLVABLE);
-	/* if row with highest pivot is not the current row, switch them */
-	if (imark != i) {
-	    for (j2 = 1; j2 <= m->n; j2++) {
-		temp = M(imark, j2);
-		M(imark, j2) = M(i, j2);
-		M(i, j2) = temp;
-	    temp = a[imark - 1];
-	    a[imark - 1] = a[i - 1];
-	    a[i - 1] = temp;
-	    temp = b[imark - 1];
-	    b[imark - 1] = b[i - 1];
-	    b[i - 1] = temp;
-	/* compute zeros above and below the pivot, and compute
-	   values for the rest of the row as well */
-	for (i2 = 1; i2 <= m->n; i2++) {
-	    if (i2 != i) {
-		factor = M(i2, j) / pivot;
-		for (j2 = j; j2 <= m->n; j2++)
-		    M(i2, j2) -= factor * M(i, j2);
-		a[i2 - 1] -= factor * a[i - 1];
-		b[i2 - 1] -= factor * b[i - 1];
-    /* SINCE ALL OTHER VALUES IN THE MATRIX ARE ZERO NOW, CALCULATE THE
-       COEFFICIENTS BY DIVIDING THE COLUMN VECTORS BY THE DIAGONAL VALUES. */
-	E[i - 1] = a[i - 1] / M(i, i);
-	N[i - 1] = b[i - 1] / M(i, i);
-#ifdef BDEBUG
-static int checkgeoref(struct Control_Points *cp,
-		       double E[], double N[], int order, int forward,
-		       FILE * fp)
-    DOUBLE xrms, yrms, dx, dy, dx2, dy2, totaldist, dist;
-    double tempx, tempy;
-    int i, n, numactive;
-    n = ((order + 1) * (order + 2)) / 2;
-    if (forward)
-	fprintf(fp, "FORWARD:\n");
-    else
-	fprintf(fp, "BACKWARD:\n");
-    fprintf(fp, "%d order\n", order);
-    for (i = 0; i < n; i++)
-	fprintf(fp, "%+.17E %+.17E\n", E[i], N[i]);
-    xrms = yrms = dx2 = dy2 = totaldist = 0.0;
-    numactive = 0;
-    for (i = 0; i < cp->count; i++) {
-	fprintf(fp, "\nCONTROL POINT: %d\n", i + 1);
-	fprintf(fp, "%20s: %+.20lE %+.20lE\n", "ORIGINAL POINT",
-		cp->e1[i], cp->n1[i]);
-	fprintf(fp, "%20s: %+.20lE %+.20lE\n", "DESIRED POINT",
-		cp->e2[i], cp->n2[i]);
-	if (cp->status[i] > 0) {
-	    numactive++;
-	    CRS_georef(cp->e1[i], cp->n1[i], &tempx, &tempy, E, N, order);
-	    fprintf(fp, "%20s: %+.20lE %+.20lE\n", "CALCULATED POINT", tempx,
-		    tempy);
-	    dx = tempx - cp->e2[i];
-	    dy = tempy - cp->n2[i];
-	    fprintf(fp, "%20s: %+.20lE %+.20lE\n", "RESIDUAL ERROR", dx, dy);
-	    dx2 = dx * dx;
-	    dy2 = dy * dy;
-	    dist = sqrt(dx2 + dy2);
-	    fprintf(fp, "%20s: %+.20lE\n", "DISTANCE (RMS) ERROR", dist);
-	    xrms += dx2;
-	    yrms += dy2;
-	    totaldist += dist;
-	else
-	    fprintf(fp, "NOT USED\n");
-    xrms = sqrt(xrms / (DOUBLE) numactive);
-    yrms = sqrt(yrms / (DOUBLE) numactive);
-    fprintf(fp, "\n%20s: %+.20lE %+.20lE\n", "RMS ERROR", xrms, yrms);
-    fprintf(fp, "\n%20s: %+.20lE\n", "TOTAL RMS ERROR",
-	    sqrt(xrms * xrms + yrms * yrms));
-    fprintf(fp, "\n%20s: %+.20lE\n", "AVG. DISTANCE ERROR",
-	    totaldist / numactive);
-    return (0);
-#endif
Deleted: grass/trunk/imagery/i.rectify/crs.h
--- grass/trunk/imagery/i.rectify/crs.h	2011-12-20 15:10:56 UTC (rev 49846)
+++ grass/trunk/imagery/i.rectify/crs.h	2011-12-20 15:25:09 UTC (rev 49847)
@@ -1,47 +0,0 @@
-   CRS.H - Center for Remote Sensing rectification routines
-   302 Berkey Hall
-   (517)353-7195
-   Written: 12/19/91
-#define MAXORDER 3
-#ifdef MSDOS
-extern int CRS_compute_georef_equations(struct Control_Points *, double *,
-					double *, double *, double *, int);
-extern int CRS_georef(double, double, double *, double *, double *, double *,
-		      int);
-#else
-#ifdef NO_PROTO
-extern int CRS_compute_georef_equations();
-extern int CRS_georef();
-#else
-/* crs.c */
-void CRS_georef2(int, double[], double[], double[], double[], int);
-int CRS_georef(double, double, double *, double *, double[], double[], int);
-int CRS_compute_georef_equations(struct Control_Points *,
-				 double[], double[], double[], double[], int);
-#endif
-#endif
Modified: grass/trunk/imagery/i.rectify/get_wind.c
--- grass/trunk/imagery/i.rectify/get_wind.c	2011-12-20 15:10:56 UTC (rev 49846)
+++ grass/trunk/imagery/i.rectify/get_wind.c	2011-12-20 15:25:09 UTC (rev 49847)
@@ -1,7 +1,6 @@
 #include <math.h>
 #include "global.h"
 int georef_window(struct Cell_head *w1, struct Cell_head *w2, int order, double res)
@@ -11,13 +10,13 @@
     } nw, ne, se, sw;
     /* extends */
-    CRS_georef(w1->west, w1->north, &e, &n, E12, N12, order);
+    I_georef(w1->west, w1->north, &e, &n, E12, N12, order);
     w2->north = w2->south = n;
     w2->west = w2->east = e;
     nw.n = n;
     nw.e = e;
-    CRS_georef(w1->east, w1->north, &e, &n, E12, N12, order);
+    I_georef(w1->east, w1->north, &e, &n, E12, N12, order);
     ne.n = n;
     ne.e = e;
     if (n > w2->north)
@@ -29,7 +28,7 @@
     if (e < w2->west)
 	w2->west = e;
-    CRS_georef(w1->west, w1->south, &e, &n, E12, N12, order);
+    I_georef(w1->west, w1->south, &e, &n, E12, N12, order);
     sw.n = n;
     sw.e = e;
     if (n > w2->north)
@@ -41,7 +40,7 @@
     if (e < w2->west)
 	w2->west = e;
-    CRS_georef(w1->east, w1->south, &e, &n, E12, N12, order);
+    I_georef(w1->east, w1->south, &e, &n, E12, N12, order);
     se.n = n;
     se.e = e;
     if (n > w2->north)
Modified: grass/trunk/imagery/i.rectify/main.c
--- grass/trunk/imagery/i.rectify/main.c	2011-12-20 15:10:56 UTC (rev 49846)
+++ grass/trunk/imagery/i.rectify/main.c	2011-12-20 15:25:09 UTC (rev 49847)
@@ -30,7 +30,6 @@
 #include "global.h"
-#include "crs.h"
 char *seg_mb;
@@ -185,9 +184,9 @@
 	k++;
+    if (order < 1 || order > 3)  /* MAXORDER in lib/imagery/georef.c */
 	G_fatal_error(_("Invalid order (%d); please enter 1 to %d"), order,
-		      MAXORDER);
+		      3);
     /* determine the number of files in this group */
     if (I_get_group_ref(group, &ref) <= 0) {
Modified: grass/trunk/imagery/i.rectify/rectify.c
--- grass/trunk/imagery/i.rectify/rectify.c	2011-12-20 15:10:56 UTC (rev 49846)
+++ grass/trunk/imagery/i.rectify/rectify.c	2011-12-20 15:25:09 UTC (rev 49847)
@@ -5,7 +5,6 @@
 #include "global.h"
 /* Modified to support Grass 5.0 fp format 11 april 2000
@@ -73,7 +72,7 @@
 	    e1 = target_window.west + (col + 0.5) * target_window.ew_res;
 	    /* backwards transformation of target cell center */
-	    CRS_georef(e1, n1, &ex, &nx, E21, N21, order);
+	    I_georef(e1, n1, &ex, &nx, E21, N21, order);
 	    /* convert to row/column indices of source raster */
 	    row_idx = (cellhd.north - nx) / cellhd.ns_res;
