[GRASS-SVN] r49853 - grass-addons/grass6/raster/mcda/r.mcda.ahp
svn_grass at osgeo.org
Wed Dec 21 12:28:25 EST 2011
Author: gianluca
Date: 2011-12-21 09:28:25 -0800 (Wed, 21 Dec 2011)
New Revision: 49853
grass-addons/grass6/raster/mcda/r.mcda.ahp/r.mcda.ahp.py
Modified: grass-addons/grass6/raster/mcda/r.mcda.ahp/r.mcda.ahp.py
--- grass-addons/grass6/raster/mcda/r.mcda.ahp/r.mcda.ahp.py 2011-12-21 12:59:18 UTC (rev 49852)
+++ grass-addons/grass6/raster/mcda/r.mcda.ahp/r.mcda.ahp.py 2011-12-21 17:28:25 UTC (rev 49853)
@@ -1,106 +1,109 @@
-#!/usr/bin/env python
-# MODULE: r.in.drsa
-# AUTHOR: Gianluca Massei - Antonio Boggia
-# PURPOSE: Generate a raster map classified with analytic hierarchy process (AHP) [Saaty, 1977 and Saaty & Vargas, 1991]
-# COPYRIGHT: c) 2010 Gianluca Massei, Antonio Boggia and the GRASS
-# Development Team. This program is free software under the
-# GNU General PublicLicense (>=v2). Read the file COPYING
-# that comes with GRASS for details.
-#%Module
-#% description: Generate a raster map classified with analytic hierarchy process (AHP).
-#% keywords: raster, analytic hierarchy process (AHP), Multi Criteria Decision Analysis (MCDA)
-#%End
-#%option
-#% key: criteria
-#% type: string
-#% multiple: yes
-#% gisprompt: old,cell,raster
-#% key_desc: name
-#% description: Name of criteria raster maps
-#% required: yes
-#%end
-#%option
-#% key: pairwise
-#% type: string
-#% gisprompt: old,file,input
-#% description: Pairwise comparison matrix
-#% required: yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new_file,cell,output
-#% description: output classified raster map
-#% required: yes
-#%end
-#%flag
-#% key:k
-#% description:build a void pairwise comparison matrix and exit (no yet implemented)
-#%end
-import sys
-import grass.script as grass
-import numpy as np
-def calculateWeight(pairwise):
- "Define vector of weight based on eigenvector and eigenvalues"
- pairwise=np.genfromtxt(pairwise, delimiter=",")
- eigenvalues, eigenvector=np.linalg.eig(pairwise)
- maxindex=np.argmax(eigenvalues)
- eigenvalues=np.float32(eigenvalues)
- eigenvector=np.float32(eigenvector)
- weight=eigenvector[:, maxindex] #extract vector from eigenvector with max vaue in eigenvalues
- weight.tolist() #convert array(numpy) to vector
- weight=[ w/sum(weight) for w in weight ]
- return weight, eigenvalues, eigenvector
-def calculateMap(criteria, weight, outputMap):
- "Parser a formula for mapcalc and run grass.mapcalc"
- formula=''
- for i in range(len(criteria)-1):
- formula += "%s*%s + " % (criteria[i], weight[i])
- formula +="%s*%s " % (criteria[len(criteria)-1], weight[len(criteria)-1])
- grass.mapcalc(outputMap +"=" +formula)
- return 0
-def Consistency(weight,eigenvalues):
- "Calculete Consistency index in accord with Saaty (1977)"
- RI=[0.00, 0.00, 0.00,0.52,0.90,1.12,1.24,1.32,1.41] #order of matrix: 0,1,2,3,4,5,6,7,8
- order=len(weight)
- CI= (MaxEigenvalue-order)/(lorder-1)
- return CI/RI[order-1]
-def ReportLog():
- log=open("log.txt", "w")
- log.write("eigenvalues:\n%s" % eigenvalues)
- log.write("\neigenvector:\n%s" % eigenvector)
- log.write("\nweight:\n%s" % weight)
- log.write("\nconsistency:\n%s" % consistency)
- log.close()
- return 0
-def main():
- "main"
- criteria = options['criteria'].split(',')
- pairwise = options['pairwise']
- outputMap = options['output']
- gregion = grass.region()
- nrows = gregion['rows']
- ncols = gregion['cols']
- ewres=int(gregion['ewres'])
- nsres=int(gregion['nsres'])
- weight = calculateWeight(pairwise)
- calculateMap(criteria, weight, outputMap)
-if __name__ == "__main__":
- options, flags = grass.parser()
- sys.exit(main())
+#!/usr/bin/env python
+# MODULE: r.mcda.ahp
+# AUTHOR: Gianluca Massei - Antonio Boggia
+# PURPOSE: Generate a raster map classified with analytic hierarchy process (AHP) [Saaty, 1977 and Saaty & Vargas, 1991]
+# COPYRIGHT: c) 2010 Gianluca Massei, Antonio Boggia and the GRASS
+# Development Team. This program is free software under the
+# GNU General PublicLicense (>=v2). Read the file COPYING
+# that comes with GRASS for details.
+#%Module
+#% description: Generate a raster map classified with analytic hierarchy process (AHP).
+#% keywords: raster, analytic hierarchy process (AHP), Multi Criteria Decision Analysis (MCDA)
+#%End
+#%option
+#% key: criteria
+#% type: string
+#% multiple: yes
+#% gisprompt: old,cell,raster
+#% key_desc: name
+#% description: Name of criteria raster maps
+#% required: yes
+#%end
+#%option
+#% key: pairwise
+#% type: string
+#% gisprompt: old,file,input
+#% description: Pairwise comparison matrix
+#% required: yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new_file,cell,output
+#% description: output classified raster map
+#% required: yes
+#%end
+#%flag
+#% key:k
+#% description:build a void pairwise comparison matrix and exit (no yet implemented)
+#%end
+import sys
+import grass.script as grass
+import numpy as np
+def calculateWeight(pairwise):
+ "Define vector of weight based on eigenvector and eigenvalues"
+ pairwise=np.genfromtxt(pairwise, delimiter=",")
+ eigenvalues, eigenvector=np.linalg.eig(pairwise)
+ maxindex=np.argmax(eigenvalues)
+ eigenvalues=np.float32(eigenvalues)
+ eigenvector=np.float32(eigenvector)
+ weight=eigenvector[:, maxindex] #extract vector from eigenvector with max vaue in eigenvalues
+ weight.tolist() #convert array(numpy) to vector
+ weight=[ w/sum(weight) for w in weight ]
+ return weight, eigenvalues, eigenvector
+def calculateMap(criteria, weight, outputMap):
+ "Parser a formula for mapcalc and run grass.mapcalc"
+ formula=''
+ for i in range(len(criteria)-1):
+ formula += "%s*%s + " % (criteria[i], weight[i])
+ formula +="%s*%s " % (criteria[len(criteria)-1], weight[len(criteria)-1])
+ grass.mapcalc(outputMap +"=" +formula)
+ return 0
+def Consistency(weight,eigenvalues):
+ "Calculete Consistency index in accord with Saaty (1977)"
+ RI=[0.00, 0.00, 0.00,0.52,0.90,1.12,1.24,1.32,1.41] #order of matrix: 0,1,2,3,4,5,6,7,8
+ order=len(weight)
+ CI= (np.max(eigenvalues)-order)/(order-1)
+ return CI/RI[order-1]
+def ReportLog(eigenvalues,eigenvector, weight, consistency):
+ "Make a log file"
+ log=open("log.txt", "w")
+ log.write("eigenvalues:\n%s" % eigenvalues)
+ log.write("\neigenvector:\n%s" % eigenvector)
+ log.write("\nweight:\n%s" % weight)
+ log.write("\nconsistency:\n%s" % consistency)
+ log.close()
+ return 0
+def main():
+ "main"
+ criteria = options['criteria'].split(',')
+ pairwise = options['pairwise']
+ outputMap = options['output']
+ gregion = grass.region()
+ nrows = gregion['rows']
+ ncols = gregion['cols']
+ ewres=int(gregion['ewres'])
+ nsres=int(gregion['nsres'])
+ weight, eigenvalues, eigenvector = calculateWeight(pairwise)
+ calculateMap(criteria, weight, outputMap)
+ consistency=Consistency(weight,eigenvalues)
+ ReportLog(eigenvalues,eigenvector, weight, consistency)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
