[GRASS-SVN] r49863 - grass/trunk/lib/vector
svn_grass at osgeo.org
Thu Dec 22 11:11:31 EST 2011
Author: neteler
Date: 2011-12-22 08:11:31 -0800 (Thu, 22 Dec 2011)
New Revision: 49863
grass/trunk/lib/vector/vectorlib.dox
slightly demystified
Modified: grass/trunk/lib/vector/vectorlib.dox
--- grass/trunk/lib/vector/vectorlib.dox 2011-12-22 11:56:59 UTC (rev 49862)
+++ grass/trunk/lib/vector/vectorlib.dox 2011-12-22 16:11:31 UTC (rev 49863)
@@ -622,17 +622,17 @@
- the format is topological (areas build from boundaries)
- currently only 2D topology is supported
-Topology is written for native format while pseudo-topology (boundaries
-constructed from polygons) is written for OGR sources, see
-<tt>v.external</tt> module.
+Topology is written for native GRASS vector format; in case of
+linked OGR sources (see <tt>v.external</tt> module), only
+pseudo-topology (boundaries constructed from polygons) is written.
The following rules apply to the vector data:
- Boundaries should not cross each other (i.e., boundaries which would
cross must be split at their intersection to form distict boundaries).
- Lines can cross each other, e.g. bridges over rivers.
+ On the contrary, lines can cross each other, e.g. bridges over rivers.
- Lines and boundaries share nodes only if their endpoints are identical.
- Lines or boundaries canbe forced to share a common node by snapping
+ Lines or boundaries can be forced to share a common node by snapping
them together. This is particulary important since nodes
are not represented in the coor file, but only implicitly as
endpoints of lines and boundaries.
