[GRASS-SVN] r49866 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Thu Dec 22 15:09:13 EST 2011
Author: huhabla
Date: 2011-12-22 12:09:13 -0800 (Thu, 22 Dec 2011)
New Revision: 49866
grass/trunk/lib/python/temporal/abstract_dataset.py
grass/trunk/lib/python/temporal/abstract_map_dataset.py
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/aggregation.py
grass/trunk/lib/python/temporal/metadata.py
grass/trunk/lib/python/temporal/space_time_datasets_tools.py
Added listing of stds register.
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py 2011-12-22 20:08:41 UTC (rev 49865)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py 2011-12-22 20:09:13 UTC (rev 49866)
@@ -47,6 +47,24 @@
raise IOError("This method must be implemented in the subclasses")
+ def print_info(self):
+ """Print information about this class in human readable style"""
+ raise IOError("This method must be implemented in the subclasses")
+ def print_shell_info(self):
+ """Print information about this class in shell style"""
+ def print_self(self):
+ """Print the content of the internal structure to stdout"""
+ self.base.print_self()
+ if self.is_time_absolute():
+ self.absolute_time.print_self()
+ if self.is_time_relative():
+ self.relative_time.print_self()
+ self.spatial_extent.print_self()
+ self.metadata.print_self()
def get_id(self):
return self.base.get_id()
@@ -223,70 +241,7 @@
if connect:
dbif.close()
- def print_self(self):
- """Print the content of the internal structure to stdout"""
- self.base.print_self()
- if self.is_time_absolute():
- self.absolute_time.print_self()
- if self.is_time_relative():
- self.relative_time.print_self()
- self.spatial_extent.print_self()
- self.metadata.print_self()
- def print_info(self):
- """Print information about this class in human readable style"""
- if self.get_type() == "raster":
- # 1 2 3 4 5 6 7
- # 0123456789012345678901234567890123456789012345678901234567890123456789012345678
- print ""
- print " +-------------------- Raster Dataset ----------------------------------------+"
- if self.get_type() == "raster3d":
- # 1 2 3 4 5 6 7
- print ""
- print " +-------------------- Raster3d Dataset --------------------------------------+"
- if self.get_type() == "vector":
- # 1 2 3 4 5 6 7
- print ""
- print " +-------------------- Vector Dataset ----------------------------------------+"
- if self.get_type() == "strds":
- # 1 2 3 4 5 6 7
- print ""
- print " +-------------------- Space Time Raster Dataset -----------------------------+"
- if self.get_type() == "str3ds":
- # 1 2 3 4 5 6 7
- print ""
- print " +-------------------- Space Time Raster3d Dataset ---------------------------+"
- if self.get_type() == "stvds":
- # 1 2 3 4 5 6 7
- print ""
- print " +-------------------- Space Time Vector Dataset -----------------------------+"
- print " | |"
- self.base.print_info()
- self.absolute_time.print_info()
- self.relative_time.print_info()
- self.spatial_extent.print_info()
- self.metadata.print_info()
- print " +----------------------------------------------------------------------------+"
- def print_shell_info(self):
- """Print information about this class in shell style"""
- self.base.print_shell_info()
- self.absolute_time.print_shell_info()
- self.relative_time.print_shell_info()
- self.spatial_extent.print_shell_info()
- self.metadata.print_shell_info()
def set_time_to_absolute(self):
self.base.set_ttype("absolute")
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py 2011-12-22 20:08:41 UTC (rev 49865)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py 2011-12-22 20:09:13 UTC (rev 49866)
@@ -52,7 +52,67 @@
def load(self):
"""Load the content of this object from map files"""
+ if self.get_type() == "raster":
+ # 1 2 3 4 5 6 7
+ # 0123456789012345678901234567890123456789012345678901234567890123456789012345678
+ print ""
+ print " +-------------------- Raster Dataset ----------------------------------------+"
+ if self.get_type() == "raster3d":
+ # 1 2 3 4 5 6 7
+ print ""
+ print " +-------------------- Raster3d Dataset --------------------------------------+"
+ if self.get_type() == "vector":
+ # 1 2 3 4 5 6 7
+ print ""
+ print " +-------------------- Vector Dataset ----------------------------------------+"
+ print " | |"
+ self.base.print_info()
+ self.absolute_time.print_info()
+ self.relative_time.print_info()
+ self.spatial_extent.print_info()
+ self.metadata.print_info()
+ datasets = self.get_registered_datasets()
+ count = 0
+ string = ""
+ for ds in datasets:
+ if count == 0:
+ string += ds["id"]
+ else:
+ string += ",%s" % ds["id"]
+ count += 1
+ if count > 2:
+ string += " | ............................ "
+ print " | Registered datasets ........ " + string
+ print " +----------------------------------------------------------------------------+"
+ self.base.print_shell_info()
+ self.absolute_time.print_shell_info()
+ self.relative_time.print_shell_info()
+ self.spatial_extent.print_shell_info()
+ self.metadata.print_shell_info()
+ count = 0
+ string = ""
+ if count == 0:
+ else:
+ count += 1
+ print "registered_datasets=" + string
def set_absolute_time(self, start_time, end_time=None, timezone=None):
"""Set the absolute time interval with start time and end time
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2011-12-22 20:08:41 UTC (rev 49865)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2011-12-22 20:09:13 UTC (rev 49866)
@@ -59,7 +59,55 @@
@param name: The name of the register table
+ if self.get_type() == "strds":
+ # 1 2 3 4 5 6 7
+ print ""
+ print " +-------------------- Space Time Raster Dataset -----------------------------+"
+ if self.get_type() == "str3ds":
+ # 1 2 3 4 5 6 7
+ print ""
+ print " +-------------------- Space Time Raster3d Dataset ---------------------------+"
+ if self.get_type() == "stvds":
+ # 1 2 3 4 5 6 7
+ print ""
+ print " +-------------------- Space Time Vector Dataset -----------------------------+"
+ print " | |"
def set_initial_values(self, temporal_type, semantic_type, \
title=None, description=None):
"""Set the initial values of the space time dataset
@@ -348,7 +396,7 @@
"gap" map objects (id==None). Each list entry is a list of map objects
which are potentially located in temporal relation to the actual granule of the second space time dataset.
- Each entry in the object list is a dict. The actual sampler map and its temporal enxtent (the actual granule) and
+ Each entry in the object list is a dict. The actual sampler map and its temporal extent (the actual granule) and
the list of samples are stored:
list = self.sample_by_dataset_topology(stds=sampler, method=["during","overlap","contain","equal"])
@@ -359,7 +407,8 @@
map.select()
map.print_info()
- A valid temporal topology (no overlapping or inclusion allowed) is needed to get correct results.
+ A valid temporal topology (no overlapping or inclusion allowed) is needed to get correct results in case of gaps
+ in the sample dataset.
Gaps between maps are identified as unregistered maps with id==None.
@@ -458,41 +507,9 @@
for granule in sample_maps:
start, end = granule.get_valid_time()
- where = "("
+ where = create_temporal_relation_sql_where_statement(start, end, use_start, \
+ use_during, use_overlap, use_contain, use_equal)
- if use_start:
- where += "(start_time >= '%s' and start_time < '%s') " % (start, end)
- if use_during:
- if use_start:
- where += " OR "
- where += "((start_time > '%s' and end_time < '%s') OR " % (start, end)
- where += "(start_time >= '%s' and end_time < '%s') OR " % (start, end)
- where += "(start_time > '%s' and end_time <= '%s'))" % (start, end)
- if use_overlap:
- if use_start or use_during:
- where += " OR "
- where += "((start_time < '%s' and end_time > '%s' and end_time < '%s') OR " % (start, start, end)
- where += "(start_time < '%s' and start_time > '%s' and end_time > '%s'))" % (end, start, end)
- if use_contain:
- if use_start or use_during or use_overlap:
- where += " OR "
- where += "((start_time < '%s' and end_time > '%s') OR " % (start, end)
- where += "(start_time <= '%s' and end_time > '%s') OR " % (start, end)
- where += "(start_time < '%s' and end_time >= '%s'))" % (start, end)
- if use_equal:
- if use_start or use_during or use_overlap or use_contain:
- where += " OR "
- where += "(start_time = '%s' and end_time = '%s')" % (start, end)
- where += ")"
rows = self.get_registered_maps("id", where, "start_time", dbif)
result = {}
@@ -1225,3 +1242,80 @@
if connect == True:
dbif.close()
+def create_temporal_relation_sql_where_statement(start, end, use_start=True, use_during=False,
+ use_overlap=False, use_contain=False, use_equal=False):
+ """ Create a SQL WHERE statement for temporal relation selection of maps in space time datastes
+ @param start: The start time
+ @param end: The end time
+ @param use_start: Select maps of which the start time is located in the selection granule
+ map : s
+ granule: s-----------------e
+ map : s--------------------e
+ map : s--------e
+ @param use_during: during: Select maps which are temporal during the selection granule
+ map : s-----------e
+ @param use_overlap: Select maps which temporal overlap the selection granule
+ granule: s----------e
+ @param use_contain: Select maps which temporally contain the selection granule
+ map : s-----------------e
+ granule: s-----------e
+ @param use_equal: Select maps which temporally equal to the selection granule
+ where = "("
+ if use_start:
+ where += "(start_time >= '%s' and start_time < '%s') " % (start, end)
+ if use_during:
+ if use_start:
+ where += " OR "
+ where += "((start_time > '%s' and end_time < '%s') OR " % (start, end)
+ where += "(start_time >= '%s' and end_time < '%s') OR " % (start, end)
+ where += "(start_time > '%s' and end_time <= '%s'))" % (start, end)
+ if use_overlap:
+ if use_start or use_during:
+ where += " OR "
+ where += "((start_time < '%s' and end_time > '%s' and end_time < '%s') OR " % (start, start, end)
+ where += "(start_time < '%s' and start_time > '%s' and end_time > '%s'))" % (end, start, end)
+ if use_contain:
+ if use_start or use_during or use_overlap:
+ where += " OR "
+ where += "((start_time < '%s' and end_time > '%s') OR " % (start, end)
+ where += "(start_time <= '%s' and end_time > '%s') OR " % (start, end)
+ where += "(start_time < '%s' and end_time >= '%s'))" % (start, end)
+ if use_equal:
+ if use_start or use_during or use_overlap or use_contain:
+ where += " OR "
+ where += "(start_time = '%s' and end_time = '%s')" % (start, end)
+ where += ")"
+ return where
Modified: grass/trunk/lib/python/temporal/aggregation.py
--- grass/trunk/lib/python/temporal/aggregation.py 2011-12-22 20:08:41 UTC (rev 49865)
+++ grass/trunk/lib/python/temporal/aggregation.py 2011-12-22 20:09:13 UTC (rev 49866)
@@ -24,12 +24,39 @@
from space_time_datasets import *
-def collect_map_names(sp, dbif, start, end):
+def collect_map_names(sp, dbif, start, end, sampling):
- where = " start_time >= \'%s\' and start_time < \'%s\'" % (start, end)
+ use_start = False
+ use_during = False
+ use_overlap = False
+ use_contain = False
+ use_equal = False
- print where
+ # Inititalize the methods
+ if sampling:
+ for name in sampling.split(","):
+ if name == "start":
+ use_start = True
+ if name == "during":
+ use_during = True
+ if name == "overlap":
+ use_overlap = True
+ if name == "contain":
+ use_contain = True
+ if name == "equal":
+ use_equal = True
+ else:
+ use_start = True
+ if sp.get_map_time() != "interval":
+ use_start = True
+ use_equal = False
+ where = create_temporal_relation_sql_where_statement(start, end, use_start, use_during, use_overlap, use_contain, use_equal)
rows = sp.get_registered_maps("id", where, "start_time", dbif)
if not rows:
@@ -41,7 +68,6 @@
return names
def aggregate_raster_maps(dataset, mapset, inputs, base, start, end, count, method, register_null, dbif):
core.verbose(_("Aggregate %s raster maps") %(len(inputs)))
Modified: grass/trunk/lib/python/temporal/metadata.py
--- grass/trunk/lib/python/temporal/metadata.py 2011-12-22 20:08:41 UTC (rev 49865)
+++ grass/trunk/lib/python/temporal/metadata.py 2011-12-22 20:09:13 UTC (rev 49866)
@@ -199,12 +199,13 @@
print " +-------------------- Metadata information ----------------------------------+"
+ raster_metadata_base.print_info(self)
print " | STRDS register table ....... " + str(self.get_strds_register())
- raster_metadata_base.print_info(self)
raster_metadata_base.print_shell_info(self)
+ print "strds_register=" + str(self.get_strds_register())
@@ -258,17 +259,18 @@
- print " | STR3DS register table ...... " + str(self.get_str3ds_register())
print " | Number of depths:........... " + str(self.get_depths())
print " | Top-Bottom resolution:...... " + str(self.get_tbres())
+ print " | STR3DS register table ...... " + str(self.get_str3ds_register())
- raster_metadata_base.print_shell_info(self)
+ print "str3ds_register=" + str(self.get_str3ds_register())
print "depths=" + str(self.get_depths())
print "tbres=" + str(self.get_tbres())
+ raster_metadata_base.print_shell_info(self)
@@ -541,12 +543,13 @@
+ stds_raster_metadata_base.print_info(self)
print " | Raster register table:...... " + str(self.get_raster_register())
- stds_raster_metadata_base.print_info(self)
stds_raster_metadata_base.print_shell_info(self)
+ print "raster_register=" + str(self.get_raster_register())
@@ -594,17 +597,18 @@
- print " | Raster3d register table:.... " + str(self.get_raster3d_register())
print " | Top-bottom resolution min:.. " + str(self.get_ewres_min())
print " | Top-bottom resolution max:.. " + str(self.get_ewres_max())
+ print " | Raster3d register table:.... " + str(self.get_raster3d_register())
print "tbres_min=" + str(self.get_tbres_min())
print "tbres_max=" + str(self.get_tbres_max())
+ print "raster3d_register=" + str(self.get_raster3d_register())
@@ -632,9 +636,12 @@
+ stds_metadata_base.print_info(self)
print " | Vector register table:...... " + str(self.get_vector_register())
- stds_metadata_base.print_info(self)
stds_metadata_base.print_shell_info(self)
+ print "vector_register=" + str(self.get_vector_register())
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2011-12-22 20:08:41 UTC (rev 49865)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2011-12-22 20:09:13 UTC (rev 49866)
@@ -676,6 +676,7 @@
print output
def sample_stds_by_stds_topology(intype, sampletype, input, sampler, header, separator, method):
""" Sample the input space time dataset with a sample space time dataset and print the result to stdout
@@ -773,3 +774,4 @@
print string
dbif.close()
