[GRASS-SVN] r49889 - in grass/branches/develbranch_6/gui/wxpython:
lmgr modules
svn_grass at osgeo.org
Sat Dec 24 11:37:51 EST 2011
Author: martinl
Date: 2011-12-24 08:37:51 -0800 (Sat, 24 Dec 2011)
New Revision: 49889
grass/branches/develbranch_6/gui/wxpython/lmgr/frame.py
grass/branches/develbranch_6/gui/wxpython/modules/vclean.py
wxGUI/vclean: wx.Panel needed for wx.Frame (on Windows)
syntax clean up
(merge r49888 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/lmgr/frame.py
--- grass/branches/develbranch_6/gui/wxpython/lmgr/frame.py 2011-12-24 16:31:54 UTC (rev 49888)
+++ grass/branches/develbranch_6/gui/wxpython/lmgr/frame.py 2011-12-24 16:37:51 UTC (rev 49889)
@@ -1190,11 +1190,7 @@
def OnVectorCleaning(self, event, cmd = ''):
"""!Init interactive vector cleaning
- if event:
- cmd = self.GetMenuCmd(event)
- win = VectorCleaningFrame(parent = self, cmd = cmd[0])
+ win = VectorCleaningFrame(parent = self)
win.CentreOnScreen()
win.Show()
Modified: grass/branches/develbranch_6/gui/wxpython/modules/vclean.py
--- grass/branches/develbranch_6/gui/wxpython/modules/vclean.py 2011-12-24 16:31:54 UTC (rev 49888)
+++ grass/branches/develbranch_6/gui/wxpython/modules/vclean.py 2011-12-24 16:37:51 UTC (rev 49889)
@@ -35,36 +35,35 @@
Dialog for interactively defining vector cleaning tools
wx.Frame.__init__(self, parent, id, title, style = style, **kwargs)
self.parent = parent # GMFrame
if self.parent:
self.log = self.parent.GetLogWindow()
else:
self.log = None
# grass command
self.cmd = 'v.clean'
# statusbar
self.CreateStatusBar()
# icon
self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
- # self.panel not set as in colorrules
- # self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
+ self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
# input map to clean
self.inmap = ''
# cleaned output map
self.outmap = ''
self.ftype = ''
# cleaning tools
self.toolslines = {}
self.tool_desc_list = [
_('break lines/boundaries'),
_('remove duplicates'),
@@ -80,7 +79,7 @@
_('remove lines/boundaries of zero length'),
_('remove small angles at nodes')
self.tool_list = [
'break',
'rmdupl',
@@ -96,7 +95,7 @@
'rmline',
'rmsa'
self.ftype = [
'point',
'line',
@@ -104,62 +103,61 @@
'centroid',
'area',
'face']
- self.n_ftypes = 6
+ self.n_ftypes = len(self.ftype)
self.tools_string = ''
self.thresh_string = ''
self.ftype_string = ''
- self.SetTitle(_('Set up vector cleaning tools'))
self.SetStatusText(_("Set up vector cleaning tools"))
self.elem = 'vector'
self.ctlabel = _('Choose cleaning tools and set thresholds')
# top controls
- self.inmaplabel = wx.StaticText(parent = self, id = wx.ID_ANY,
+ self.inmaplabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
label= _('Select input vector map:'))
- self.selectionInput = Select(parent=self, id=wx.ID_ANY,
- size=globalvar.DIALOG_GSELECT_SIZE,
- type='vector')
+ self.selectionInput = Select(parent = self.panel, id = wx.ID_ANY,
+ size = globalvar.DIALOG_GSELECT_SIZE,
+ type = 'vector')
self.ftype_check = {}
- ftypeBox = wx.StaticBox(parent=self, id=wx.ID_ANY,
- label=_(' Feature type: '))
+ ftypeBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+ label = _(' Feature type: '))
self.ftypeSizer = wx.StaticBoxSizer(ftypeBox, wx.HORIZONTAL)
- self.outmaplabel = wx.StaticText(parent = self, id = wx.ID_ANY,
- label= _('Select output vector map:'))
- self.selectionOutput = Select(parent=self, id=wx.ID_ANY,
- type='vector')
+ self.outmaplabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
+ label = _('Select output vector map:'))
+ self.selectionOutput = Select(parent = self.panel, id = wx.ID_ANY,
+ type = 'vector')
- self.overwrite = wx.CheckBox(parent=self, id=wx.ID_ANY,
- label=_('Allow output files to overwrite existing files'))
- self.overwrite.SetValue(UserSettings.Get(group='cmd', key='overwrite', subkey='enabled'))
+ self.overwrite = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
+ label = _('Allow output files to overwrite existing files'))
+ self.overwrite.SetValue(UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled'))
# cleaning tools
- self.ct_label = wx.StaticText(parent=self, id=wx.ID_ANY,
- label=self.ctlabel)
+ self.ct_label = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
+ label = self.ctlabel)
- self.ct_panel = self.__toolsPanel()
+ self.ct_panel = self._toolsPanel()
# buttons to manage cleaning tools
- self.btn_add = wx.Button(parent=self, id=wx.ID_ADD)
- self.btn_remove = wx.Button(parent=self, id=wx.ID_REMOVE)
- self.btn_moveup = wx.Button(parent=self, id=wx.ID_UP)
- self.btn_movedown = wx.Button(parent=self, id=wx.ID_DOWN)
+ self.btn_add = wx.Button(parent = self.panel, id = wx.ID_ADD)
+ self.btn_remove = wx.Button(parent = self.panel, id = wx.ID_REMOVE)
+ self.btn_moveup = wx.Button(parent = self.panel, id = wx.ID_UP)
+ self.btn_movedown = wx.Button(parent = self.panel, id = wx.ID_DOWN)
# add one tool as default
self.AddTool()
self.selected = -1
# Buttons
- self.btn_close = wx.Button(parent = self, id = wx.ID_CLOSE)
- self.btn_run = wx.Button(parent = self, id = wx.ID_ANY, label = _("&Run"))
+ self.btn_close = wx.Button(parent = self.panel, id = wx.ID_CLOSE)
+ self.btn_run = wx.Button(parent = self.panel, id = wx.ID_ANY, label = _("&Run"))
self.btn_run.SetDefault()
- self.btn_clipboard = wx.Button(parent=self, id=wx.ID_COPY)
+ self.btn_clipboard = wx.Button(parent = self.panel, id = wx.ID_COPY)
self.btn_clipboard.SetToolTipString(_("Copy the current command string to the clipboard (Ctrl+C)"))
- self.btn_help = wx.Button(parent = self, id = wx.ID_HELP)
+ self.btn_help = wx.Button(parent = self.panel, id = wx.ID_HELP)
# bindings
self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
@@ -172,11 +170,11 @@
self.btn_moveup.Bind(wx.EVT_BUTTON, self.OnMoveToolUp)
self.btn_movedown.Bind(wx.EVT_BUTTON, self.OnMoveToolDown)
- self.SetMinSize(self.GetBestSize())
# layout
self._layout()
+ self.SetMinSize(self.GetBestSize())
self.CentreOnScreen()
self.Show()
@@ -186,62 +184,62 @@
# input output
- inSizer = wx.GridBagSizer(hgap=5, vgap=5)
+ inSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
- inSizer.Add(item=self.inmaplabel, pos=(0, 0),
- flag=wx.ALIGN_CENTER_VERTICAL | wx.ALL | wx.EXPAND, border=1)
- inSizer.Add(item=self.selectionInput, pos=(1, 0),
+ inSizer.Add(item = self.inmaplabel, pos = (0, 0),
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL | wx.EXPAND, border = 1)
+ inSizer.Add(item = self.selectionInput, pos = (1, 0),
self.ftype_check = [
- wx.CheckBox(parent=self, id=wx.ID_ANY, label=_('point')),
- wx.CheckBox(parent=self, id=wx.ID_ANY, label=_('line')),
- wx.CheckBox(parent=self, id=wx.ID_ANY, label=_('boundary')),
- wx.CheckBox(parent=self, id=wx.ID_ANY, label=_('centroid')),
- wx.CheckBox(parent=self, id=wx.ID_ANY, label=_('area')),
- wx.CheckBox(parent=self, id=wx.ID_ANY, label=_('face'))
+ wx.CheckBox(parent = self.panel, id = wx.ID_ANY, label = _('point')),
+ wx.CheckBox(parent = self.panel, id = wx.ID_ANY, label = _('line')),
+ wx.CheckBox(parent = self.panel, id = wx.ID_ANY, label = _('boundary')),
+ wx.CheckBox(parent = self.panel, id = wx.ID_ANY, label = _('centroid')),
+ wx.CheckBox(parent = self.panel, id = wx.ID_ANY, label = _('area')),
+ wx.CheckBox(parent = self.panel, id = wx.ID_ANY, label = _('face'))
typeoptSizer = wx.BoxSizer(wx.HORIZONTAL)
for num in range(0, self.n_ftypes):
type_box = self.ftype_check[num]
- typeoptSizer.Add(item=type_box, flag=wx.ALIGN_LEFT, border=1)
+ typeoptSizer.Add(item = type_box, flag = wx.ALIGN_LEFT, border = 1)
self.ftypeSizer.Add(item = typeoptSizer,
- flag=wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=2)
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL, border = 2)
- outSizer = wx.GridBagSizer(hgap=5, vgap=5)
+ outSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
- outSizer.Add(item=self.outmaplabel, pos=(0, 0),
- outSizer.Add(item=self.selectionOutput, pos=(1, 0),
+ outSizer.Add(item = self.outmaplabel, pos = (0, 0),
+ outSizer.Add(item = self.selectionOutput, pos = (1, 0),
replaceSizer = wx.BoxSizer(wx.HORIZONTAL)
- replaceSizer.Add(item=self.overwrite, proportion=1,
- flag=wx.ALL | wx.EXPAND, border=1)
+ replaceSizer.Add(item = self.overwrite, proportion = 1,
+ flag = wx.ALL | wx.EXPAND, border = 1)
- outSizer.Add(item=replaceSizer, pos=(2, 0),
+ outSizer.Add(item = replaceSizer, pos = (2, 0),
# tools selection
- bodySizer = wx.GridBagSizer(hgap=5, vgap=5)
+ bodySizer = wx.GridBagSizer(hgap = 5, vgap = 5)
- bodySizer.Add(item=self.ct_label, pos=(0, 0), span=(1, 2),
- flag=wx.ALL, border=5)
+ bodySizer.Add(item = self.ct_label, pos = (0, 0), span = (1, 2),
+ flag = wx.ALL, border = 5)
- bodySizer.Add(item=self.ct_panel, pos=(1, 0), span=(1, 2))
+ bodySizer.Add(item = self.ct_panel, pos = (1, 0), span = (1, 2))
- manageBoxSizer = wx.GridBagSizer(hgap=10, vgap=1)
+ manageBoxSizer = wx.GridBagSizer(hgap = 10, vgap = 1)
# start with row 1 for nicer layout
- manageBoxSizer.Add(item=self.btn_add, pos=(1, 0), border=2, flag=wx.ALL | wx.EXPAND)
- manageBoxSizer.Add(item=self.btn_remove, pos=(2, 0), border=2, flag=wx.ALL | wx.EXPAND)
- manageBoxSizer.Add(item=self.btn_moveup, pos=(3, 0), border=2, flag=wx.ALL | wx.EXPAND)
- manageBoxSizer.Add(item=self.btn_movedown, pos=(4, 0), border=2, flag=wx.ALL | wx.EXPAND)
+ manageBoxSizer.Add(item = self.btn_add, pos = (1, 0), border = 2, flag = wx.ALL | wx.EXPAND)
+ manageBoxSizer.Add(item = self.btn_remove, pos = (2, 0), border = 2, flag = wx.ALL | wx.EXPAND)
+ manageBoxSizer.Add(item = self.btn_moveup, pos = (3, 0), border = 2, flag = wx.ALL | wx.EXPAND)
+ manageBoxSizer.Add(item = self.btn_movedown, pos = (4, 0), border = 2, flag = wx.ALL | wx.EXPAND)
- bodySizer.Add(item=manageBoxSizer, pos=(1, 2),
- flag=wx.EXPAND | wx.LEFT | wx.RIGHT, border=5)
+ bodySizer.Add(item = manageBoxSizer, pos = (1, 2),
+ flag = wx.EXPAND | wx.LEFT | wx.RIGHT, border = 5)
bodySizer.AddGrowableCol(2)
@@ -250,50 +248,52 @@
btnSizer = wx.BoxSizer(wx.HORIZONTAL)
btnSizer.Add(self.btn_close,
- flag=wx.LEFT | wx.RIGHT, border=5)
+ flag = wx.LEFT | wx.RIGHT, border = 5)
btnSizer.Add(self.btn_run,
btnSizer.Add(self.btn_clipboard,
btnSizer.Add(self.btn_help,
# put it all together
- sizer.Add(item=inSizer, proportion=0,
- flag=wx.ALL | wx.EXPAND, border=5)
+ sizer.Add(item = inSizer, proportion = 0,
+ flag = wx.ALL | wx.EXPAND, border = 5)
- sizer.Add(item=self.ftypeSizer, proportion=0,
+ sizer.Add(item = self.ftypeSizer, proportion = 0,
- sizer.Add(item=outSizer, proportion=0,
+ sizer.Add(item = outSizer, proportion = 0,
- sizer.Add(item=wx.StaticLine(parent=self, id=wx.ID_ANY,
- style=wx.LI_HORIZONTAL), proportion=0,
- flag=wx.EXPAND | wx.ALL, border=5)
+ sizer.Add(item = wx.StaticLine(parent = self, id = wx.ID_ANY,
+ style = wx.LI_HORIZONTAL), proportion = 0,
+ flag = wx.EXPAND | wx.ALL, border = 5)
- sizer.Add(item=bodySizer, proportion=1,
+ sizer.Add(item = bodySizer, proportion = 1,
- sizer.Add(item=btnSizer, proportion=0,
- flag=wx.ALL | wx.ALIGN_RIGHT, border=5)
+ sizer.Add(item = btnSizer, proportion = 0,
+ flag = wx.ALL | wx.ALIGN_RIGHT, border = 5)
- self.SetSizer(sizer)
- sizer.Fit(self)
+ self.panel.SetAutoLayout(True)
+ self.panel.SetSizer(sizer)
+ sizer.Fit(self.panel)
self.Layout()
- def __toolsPanel(self):
- ct_panel = scrolled.ScrolledPanel(parent=self, id=wx.ID_ANY,
- size=(500, 240),
- style=wx.SUNKEN_BORDER)
+ def _toolsPanel(self):
+ ct_panel = scrolled.ScrolledPanel(parent = self.panel, id = wx.ID_ANY,
+ size = (500, 240),
+ style = wx.SUNKEN_BORDER)
- self.ct_sizer = wx.GridBagSizer(vgap=2, hgap=4)
+ self.ct_sizer = wx.GridBagSizer(vgap = 2, hgap = 4)
ct_panel.SetSizer(self.ct_sizer)
ct_panel.SetAutoLayout(True)
@@ -309,33 +309,33 @@
num = snum + 1
# tool number
tool_no = wx.StaticText(parent = self.ct_panel, id = 3000+num,
- label= str(num)+'.')
+ label = str(num)+'.')
# tool
- tool_cbox = wx.ComboBox(parent = self.ct_panel, id=1000+num,
+ tool_cbox = wx.ComboBox(parent = self.ct_panel, id = 1000+num,
size = (300, -1), choices = self.tool_desc_list,
style = wx.CB_DROPDOWN |
wx.CB_READONLY | wx.TE_PROCESS_ENTER)
self.Bind(wx.EVT_COMBOBOX, self.OnSetTool, tool_cbox)
# threshold
- txt_ctrl = wx.TextCtrl(parent=self.ct_panel, id=2000+num, value='0.00',
- size=(100,-1),
- style=wx.TE_NOHIDESEL)
+ txt_ctrl = wx.TextCtrl(parent = self.ct_panel, id = 2000+num, value = '0.00',
+ size = (100,-1),
+ style = wx.TE_NOHIDESEL)
self.Bind(wx.EVT_TEXT, self.OnThreshValue, txt_ctrl)
# select
- select = wx.CheckBox(parent=self.ct_panel, id=num)
+ select = wx.CheckBox(parent = self.ct_panel, id = num)
select.SetValue(False)
self.Bind(wx.EVT_CHECKBOX, self.OnSelect, select)
# start with row 1 and col 1 for nicer layout
- self.ct_sizer.Add(item=tool_no, pos=(num, 1),
- flag=wx.ALIGN_CENTER_VERTICAL, border=5)
- self.ct_sizer.Add(item=tool_cbox, pos=(num, 2),
- flag=wx.ALIGN_CENTER | wx.RIGHT, border=5)
- self.ct_sizer.Add(item=txt_ctrl, pos=(num, 3),
- self.ct_sizer.Add(item=select, pos=(num, 4),
- flag=wx.ALIGN_CENTER | wx.RIGHT)
+ self.ct_sizer.Add(item = tool_no, pos = (num, 1),
+ flag = wx.ALIGN_CENTER_VERTICAL, border = 5)
+ self.ct_sizer.Add(item = tool_cbox, pos = (num, 2),
+ flag = wx.ALIGN_CENTER | wx.RIGHT, border = 5)
+ self.ct_sizer.Add(item = txt_ctrl, pos = (num, 3),
+ self.ct_sizer.Add(item = select, pos = (num, 4),
+ flag = wx.ALIGN_CENTER | wx.RIGHT)
self.toolslines[num] = {
'tool_desc' : '' ,
