[GRASS-SVN] r49893 - in grass/trunk/scripts: . g.extension g.extension.rebuild.all
Sat Dec 24 18:04:30 EST 2011
Author: martinl
Date: 2011-12-24 15:04:30 -0800 (Sat, 24 Dec 2011)
New Revision: 49893
Added:
   grass/trunk/scripts/g.extension.rebuild.all/
   grass/trunk/scripts/g.extension.rebuild.all/Makefile
   grass/trunk/scripts/g.extension.rebuild.all/g.extension.rebuild.all.html
   grass/trunk/scripts/g.extension.rebuild.all/g.extension.rebuild.all.py
   grass/trunk/scripts/Makefile
   grass/trunk/scripts/g.extension/g.extension.html
new module: g.extension.rebuild.all
Modified: grass/trunk/scripts/Makefile
--- grass/trunk/scripts/Makefile	2011-12-24 17:11:31 UTC (rev 49892)
+++ grass/trunk/scripts/Makefile	2011-12-24 23:04:30 UTC (rev 49893)
@@ -14,6 +14,7 @@
 	db.out.ogr \
 	db.test \
 	g.extension \
+	g.extension.rebuild.all \
 	g.manual \
 	i.fusion.brovey \
 	i.image.mosaic \
Modified: grass/trunk/scripts/g.extension/g.extension.html
--- grass/trunk/scripts/g.extension/g.extension.html	2011-12-24 17:11:31 UTC (rev 49892)
+++ grass/trunk/scripts/g.extension/g.extension.html	2011-12-24 23:04:30 UTC (rev 49893)
@@ -12,9 +12,15 @@
 Download and install <em>i.landsat.toar</em> into current GRASS installation:
 <div class="code"><pre>
-g.extension extension=i.points.auto operation=add
+g.extension extension=i.points.auto
 </pre></div>
+Remove locally installed extension
+<div class="code"><pre>
+g.extension extension=i.points.auto operation=remove
+</pre></div>
 <h2>AUTHOR</h2>
 Markus Neteler<br>
Added: grass/trunk/scripts/g.extension.rebuild.all/Makefile
--- grass/trunk/scripts/g.extension.rebuild.all/Makefile	                        (rev 0)
+++ grass/trunk/scripts/g.extension.rebuild.all/Makefile	2011-12-24 23:04:30 UTC (rev 49893)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = g.extension.rebuild.all
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass/trunk/scripts/g.extension.rebuild.all/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass/trunk/scripts/g.extension.rebuild.all/g.extension.rebuild.all.html
--- grass/trunk/scripts/g.extension.rebuild.all/g.extension.rebuild.all.html	                        (rev 0)
+++ grass/trunk/scripts/g.extension.rebuild.all/g.extension.rebuild.all.html	2011-12-24 23:04:30 UTC (rev 49893)
@@ -0,0 +1,31 @@
+<h2>DESCRIPTION</h2>
+<em>g.extension.rebuild.all</em> reinstalls and updates all locally
+installed GRASS Addons extensions in local GRASS installation. The
+extensions can be installed
+by <em><a href="g.extension.html">g.extension</a></em>. List of
+locally installed extensions can be printed by <tt>g.extension
+-a</tt>.
+<h2>EXAMPLES</h2>
+Re-install all locally installed extensions
+g.extension.rebuild.all
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+  <a href="g.extension.html">g.extension</a>
+</em>
+<h2>AUTHOR</h2>
+<a href="http://geo.fsv.cvut.cz/gwiki/Landa">Martin
+Landa</a>, <a href="http://www.cvut.cz">Czech Technical University in
+Prague</a>, Czech Republic
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass/trunk/scripts/g.extension.rebuild.all/g.extension.rebuild.all.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass/trunk/scripts/g.extension.rebuild.all/g.extension.rebuild.all.py
--- grass/trunk/scripts/g.extension.rebuild.all/g.extension.rebuild.all.py	                        (rev 0)
+++ grass/trunk/scripts/g.extension.rebuild.all/g.extension.rebuild.all.py	2011-12-24 23:04:30 UTC (rev 49893)
@@ -0,0 +1,48 @@
+#!/usr/bin/env python
+# MODULE:       g.extension.rebuild.all
+# AUTHOR(S):   	Martin Landa <landa.martin gmail.com>
+# PURPOSE:      Rebuild locally installed GRASS Addons extensions
+# COPYRIGHT:    (C) 2011 by Martin Landa, and the GRASS Development Team
+#               This program is free software under the GNU General
+#               Public License (>=v2). Read the file COPYING that
+#               comes with GRASS for details.
+#%module
+#% description: Rebuilds all locally installed GRASS Addons extensions.
+#% keywords: general
+#% keywords: installation
+#% keywords: extensions
+#%end
+import sys
+import grass.script as grass
+def main():
+    extensions = grass.read_command('g.extension',
+                                    quiet = True, flags = 'a').splitlines()
+    if not extensions:
+        grass.info(_("No extension installed. Nothing to rebuild."))
+        return 0
+    for ext in extensions:
+        grass.message('-' * 60)
+        grass.message(_("Reinstalling extension <%s>...") % ext)
+        grass.run_command('g.extension',
+                          extension = ext)
+    return 0
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
Property changes on: grass/trunk/scripts/g.extension.rebuild.all/g.extension.rebuild.all.py
   + text/x-python
   + native
