[GRASS-SVN] r49904 - in grass/trunk: gui/wxpython/core gui/wxpython/gui_core gui/wxpython/modules lib/init macosx/app scripts/g.extension scripts/g.manual
Sun Dec 25 16:30:56 EST 2011
Author: martinl
Date: 2011-12-25 13:30:56 -0800 (Sun, 25 Dec 2011)
New Revision: 49904
   grass/trunk/gui/wxpython/core/globalvar.py
   grass/trunk/gui/wxpython/gui_core/forms.py
   grass/trunk/gui/wxpython/modules/extensions.py
   grass/trunk/lib/init/grass.py
   grass/trunk/lib/init/variables.html
   grass/trunk/macosx/app/grass.sh.in
   grass/trunk/scripts/g.extension/g.extension.py
   grass/trunk/scripts/g.manual/g.manual.py
define GRASS_ADDON_BASE
Modified: grass/trunk/gui/wxpython/core/globalvar.py
--- grass/trunk/gui/wxpython/core/globalvar.py	2011-12-25 21:28:55 UTC (rev 49903)
+++ grass/trunk/gui/wxpython/core/globalvar.py	2011-12-25 21:30:56 UTC (rev 49904)
@@ -143,20 +143,20 @@
         os.environ["PATH"] = os.getenv("PATH") + os.pathsep + os.path.join(gisbase, 'etc', 'gui', 'scripts')
         cmd = cmd + os.listdir(os.path.join(gisbase, 'etc', 'gui', 'scripts'))
-    # scan addons
-    if os.getenv('GRASS_ADDON_PATH'):
-        path = os.getenv('GRASS_ADDON_PATH')
-        bpath = os.path.join(path, 'bin')
-        spath = os.path.join(path, 'scripts')
-        if not scriptsOnly and os.path.exists(bpath) and \
-                os.path.isdir(bpath):
-            for fname in os.listdir(bpath):
-                name, ext = os.path.splitext(fname)
-                if not EXT_BIN:
-                    cmd.append(fname)
-                elif ext == EXT_BIN:
-                    cmd.append(name)
+    # scan addons (base)
+    if os.getenv('GRASS_ADDON_BASE'):
+        for path in os.getenv('GRASS_ADDON_BASE').split(os.pathsep):
+            bpath = os.path.join(path, 'bin')
+            if not scriptsOnly and os.path.exists(bpath) and \
+                    os.path.isdir(bpath):
+                for fname in os.listdir(bpath):
+                    name, ext = os.path.splitext(fname)
+                    if not EXT_BIN:
+                        cmd.append(fname)
+                    elif ext == EXT_BIN:
+                        cmd.append(name)
+            spath = os.path.join(path, 'scripts')
             if os.path.exists(spath) and os.path.isdir(spath):
                 for fname in os.listdir(spath):
@@ -164,6 +164,16 @@
                         cmd.append(fname)
                     elif ext == EXT_SCT:
                         cmd.append(name)
+    # scan addons (path)
+    if os.getenv('GRASS_ADDON_PATH'):
+        for path in os.getenv('GRASS_ADDON_PATH').split(os.pathsep):
+            for fname in os.listdir(path):
+                if ext in [EXT_BIN, EXT_SCT]:
+                    cmd.append(name)
+                else:
+                    cmd.append(fname)
     return cmd
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py	2011-12-25 21:28:55 UTC (rev 49903)
+++ grass/trunk/gui/wxpython/gui_core/forms.py	2011-12-25 21:30:56 UTC (rev 49904)
@@ -2101,7 +2101,8 @@
     def OnInit(self):
         msg = self.grass_task.get_error_msg()
         if msg:
-            gcmd.GError(msg + '\n\nTry to set up GRASS_ADDON_PATH variable.')
+            gcmd.GError(msg + '\n\n' +
+                        _('Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable.'))
             return True
         self.mf = TaskFrame(parent = None, task_description = self.grass_task)
Modified: grass/trunk/gui/wxpython/modules/extensions.py
--- grass/trunk/gui/wxpython/modules/extensions.py	2011-12-25 21:28:55 UTC (rev 49903)
+++ grass/trunk/gui/wxpython/modules/extensions.py	2011-12-25 21:30:56 UTC (rev 49904)
@@ -222,7 +222,7 @@
         item = self.tree.GetSelected()
         if not item or not item.IsOk() or \
                 returncode != 0 or \
-                not os.getenv('GRASS_ADDON_PATH'):
+                not os.getenv('GRASS_ADDON_BASE'):
             return
         name = self.tree.GetItemText(item)
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py	2011-12-25 21:28:55 UTC (rev 49903)
+++ grass/trunk/lib/init/grass.py	2011-12-25 21:30:56 UTC (rev 49904)
@@ -167,6 +167,7 @@
   GRASS_WISH                     %s
   GRASS_HTML_BROWSER             %s
   GRASS_ADDON_PATH               %s
+  GRASS_ADDON_BASE               %s
   GRASS_BATCH_JOB                %s
   GRASS_PYTHON                   %s
 """ % (_("Usage"),
@@ -189,7 +190,8 @@
        _("select GUI (text, gui)"),
        _("set wish shell name to override 'wish'"),
        _("set html web browser for help pages"),
-       _("set additional path(s) to local GRASS modules"),
+       _("set additional path(s) to local GRASS modules or user scripts"),
+       _("set additional GISBASE for locally installed GRASS Addons"),
        _("shell script to be processed as batch job"),
        _("set python shell name to override 'python'"))
@@ -284,7 +286,7 @@
     # FIXME oldtcltk, gis.m, d.m no longer exist
     if grass_gui in ['d.m', 'gis.m', 'oldtcltk', 'tcltk']:
-        warning(_("GUI '%s' not supported in this version") % grass_gui)
+        warning(_("GUI <%s> not supported in this version") % grass_gui)
 	grass_gui = default_gui
 def get_locale():
@@ -329,16 +331,22 @@
     os.environ[var] = path
 def set_paths():
+    # addons (path)
     addon_path = os.getenv('GRASS_ADDON_PATH')
-    if not addon_path:
-        addon_path = os.path.join(grass_config_dir, 'addons')
-        os.environ['GRASS_ADDON_PATH'] = addon_path
-        # message(_("GRASS_ADDON_PATH undefined, using '%s'") % addon_path)
+    if addon_path:
+        for path in addons_path.split(os.pathsep):
+            path_prepend(addon_path, 'PATH')
-    path_prepend(addon_path, 'PATH')
-    path_prepend(os.path.join(addon_path, 'scripts'), 'PATH')
-    path_prepend(os.path.join(addon_path, 'bin'), 'PATH')
+    # addons (base)
+    addon_base = os.getenv('GRASS_ADDON_BASE')
+    if not addon_base:
+        addon_base = os.path.join(grass_config_dir, 'addons')
+        os.environ['GRASS_ADDON_BASE'] = addon_base
+    for path in addon_base.split(os.pathsep):
+        path_prepend(os.path.join(path, 'scripts'), 'PATH')
+        path_prepend(os.path.join(path, 'bin'), 'PATH')
+    # standard installation
     path_prepend(gfile('scripts'), 'PATH')
     path_prepend(gfile('bin'), 'PATH')
@@ -708,7 +716,7 @@
 def start_gui():
     # Start the chosen GUI but ignore text
     if grass_debug:
-	message(_("GRASS GUI should be '%s'") % grass_gui)
+	message(_("GRASS GUI should be <%s>") % grass_gui)
     # Check for gui interface
     if grass_gui == "wxpython":
@@ -1132,7 +1140,7 @@
     say_hello()
     show_info()
-        message(_("Launching '%s' GUI in the background, please wait...") % grass_gui)
+        message(_("Launching <%s> GUI in the background, please wait...") % grass_gui)
 if sh in ['csh', 'tcsh']:
     csh_startup()
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html	2011-12-25 21:28:55 UTC (rev 49903)
+++ grass/trunk/lib/init/variables.html	2011-12-25 21:30:56 UTC (rev 49904)
@@ -100,8 +100,16 @@
   <dt>GRASS_ADDON_PATH</dt>
   <dd>[grass startup script]<br> allows to specify additional paths to
-    local GRASS modules extra to standard distribution. The default on
-    GNU/Linux is <tt>$HOME/.grass7/addons</tt>.</dd>
+    local GRASS modules or user scripts extra to standard GRASS
+    distribution.</dd>
+  <dt>GRASS_ADDON_BASE</dt>
+  <dd>[grass startup script]<br> allows to specify additional GISBASE
+    for local GRASS modules (normally installed as GRASS Addons
+    by <tt>g.extension</tt> module) extra to standard
+    distribution. The default on GNU/Linux
+    is <tt>$HOME/.grass7/addons</tt>, on MS
+    Windows <tt>$APPDATA\GRASS7\addons</tt>.</dd>
   <dt>GRASS_ADDON_ETC</dt>
   <dd>[libgis, g.findetc]<br>
Modified: grass/trunk/macosx/app/grass.sh.in
--- grass/trunk/macosx/app/grass.sh.in	2011-12-25 21:28:55 UTC (rev 49903)
+++ grass/trunk/macosx/app/grass.sh.in	2011-12-25 21:30:56 UTC (rev 49904)
@@ -46,12 +46,12 @@
 # add some OS X style app support paths, and create user one if missing.
 mkdir -p "$GISBASE_USER/Modules/bin"
-if [ "$GRASS_ADDON_PATH" ] ; then
-	GRASS_ADDON_PATH="$GRASS_ADDON_PATH:$GISBASE_USER/Modules:$GISBASE_SYSTEM/Modules"
+if [ "$GRASS_ADDON_BASE" ] ; then
+	GRASS_ADDON_BASE="$GRASS_ADDON_BASE:$GISBASE_USER/Modules:$GISBASE_SYSTEM/Modules"
 else
-	GRASS_ADDON_PATH="$GISBASE_USER/Modules:$GISBASE_SYSTEM/Modules"
+	GRASS_ADDON_BASE="$GISBASE_USER/Modules:$GISBASE_SYSTEM/Modules"
 fi
-export GRASS_ADDON_PATH
+export GRASS_ADDON_BASE
 mkdir -p "$GISBASE_USER/Modules/etc"
 if [ "$GRASS_ADDON_ETC" ] ; then
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py	2011-12-25 21:28:55 UTC (rev 49903)
+++ grass/trunk/scripts/g.extension/g.extension.py	2011-12-25 21:30:56 UTC (rev 49904)
@@ -52,7 +52,7 @@
 #% type: string
 #% key_desc: path
 #% description: Prefix where to install extension (ignored when flag -s is given)
-#% answer: $GRASS_ADDON_PATH
+#% answer: $GRASS_ADDON_BASE
 #% required: no
 #%end
@@ -468,10 +468,9 @@
         install_extension_xml()
         grass.message(_("Installation of <%s> successfully finished") % options['extension'])
-    if not os.environ.has_key('GRASS_ADDON_PATH') or \
-            not os.environ['GRASS_ADDON_PATH']:
+    if not os.getenv('GRASS_ADDON_BASE'):
         grass.warning(_('This add-on module will not function until you set the '
-                        'GRASS_ADDON_PATH environment variable (see "g.manual variables")'))
+                        'GRASS_ADDON_BASE environment variable (see "g.manual variables")'))
 # install extension on other plaforms
 def install_extension_other():
@@ -686,19 +685,18 @@
     # define path
     if flags['s']:
         options['prefix'] = os.environ['GISBASE']
-    if options['prefix'] == '$GRASS_ADDON_PATH':
+    if options['prefix'] == '$GRASS_ADDON_BASE':
             major_version = int(grass.version()['version'].split('.', 1)[0])
-            grass.warning(_("GRASS_ADDON_PATH is not defined, "
-                            "installing to ~/.grass%d/addons/") % major_version)
+            grass.warning(_("GRASS_ADDON_BASE is not defined, "
+                            "installing to ~/.grass%d/addons") % major_version)
             options['prefix'] = os.path.join(os.environ['HOME'], '.grass%d' % major_version, 'addons')
         else:
-            path_list = os.environ['GRASS_ADDON_PATH'].split(os.pathsep)
+            path_list = os.environ['GRASS_ADDON_BASE'].split(os.pathsep)
             if len(path_list) < 1:
-                grass.fatal(_("Invalid GRASS_ADDON_PATH value - '%s'") % os.environ['GRASS_ADDON_PATH'])
+                grass.fatal(_("Invalid GRASS_ADDON_BASE value - '%s'") % os.environ['GRASS_ADDON_BASE'])
             if len(path_list) > 1:
-                grass.warning(_("GRASS_ADDON_PATH has more items, using first defined - '%s'") % path_list[0])
+                grass.warning(_("GRASS_ADDON_BASE has more items, using first defined - '%s'") % path_list[0])
             options['prefix'] = path_list[0]
     # list available extensions
Modified: grass/trunk/scripts/g.manual/g.manual.py
--- grass/trunk/scripts/g.manual/g.manual.py	2011-12-25 21:28:55 UTC (rev 49903)
+++ grass/trunk/scripts/g.manual/g.manual.py	2011-12-25 21:30:56 UTC (rev 49904)
@@ -45,8 +45,11 @@
         grass.fatal(_("Browser <%s> not found") % browser)
     path = os.path.join(gisbase, 'docs', 'html', entry + '.html')
-    if not os.path.exists(path) and os.getenv('GRASS_ADDON_PATH'):
-        path = os.path.join(os.getenv('GRASS_ADDON_PATH'), 'docs', 'html', entry + '.html')
+    if not os.path.exists(path) and os.getenv('GRASS_ADDON_BASE'):
+        for apath in os.getenv('GRASS_ADDON_BASE').split(os.pathsep):
+            path = os.path.join(apath, 'docs', 'html', entry + '.html')
+            if os.path.exists(path):
+                break
     if not os.path.exists(path):
         grass.fatal(_("No HTML manual page entry for <%s>") % entry)
