[GRASS-SVN] r49910 - in grass/trunk: gui/wxpython/gui_core lib/init
svn_grass at osgeo.org
Sun Dec 25 18:28:31 EST 2011
Author: martinl
Date: 2011-12-25 15:28:31 -0800 (Sun, 25 Dec 2011)
New Revision: 49910
grass/trunk/gui/wxpython/gui_core/preferences.py
grass/trunk/lib/init/grass.py
simplify language settings, use gisenv instead of environmental variable and expand by startup script
Modified: grass/trunk/gui/wxpython/gui_core/preferences.py
--- grass/trunk/gui/wxpython/gui_core/preferences.py 2011-12-25 23:08:45 UTC (rev 49909)
+++ grass/trunk/gui/wxpython/gui_core/preferences.py 2011-12-25 23:28:31 UTC (rev 49910)
@@ -156,36 +156,6 @@
"""!Button 'Cancel' pressed"""
self.Close()
- def _saveEnv(self, lang):
- """!Save environmental variables
- @param lang locale code (eg. 'C')
- envFile = os.path.join(GetSettingsPath(), 'bashrc')
- # read variables
- if os.path.exists(envFile):
- rcfile = open(os.path.join(GetSettingsPath(), 'bashrc'), "r")
- rclines = rcfile.readlines()
- rcfile.close()
- else:
- rclines = []
- rcfile = open(envFile, "w")
- # save language settings
- grasslang = False
- for line in rclines:
- if 'GRASS_LANG' in line:
- rcfile.write('GRASS_LANG: %s\n' % lang)
- grasslang = True
- else:
- rcfile.write(line)
- if not grasslang:
- rcfile.close()
def OnSave(self, event):
"""!Button 'Save' pressed
Posts event EVT_SETTINGS_CHANGED.
@@ -193,11 +163,9 @@
if self._updateSettings():
self.settings.SaveToFile()
self.parent.goutput.WriteLog(_('Settings saved to file \'%s\'.') % self.settings.filePath)
- fileSettings = {}
- self.settings.ReadSettingsFile(settings = fileSettings)
- self._saveEnv(lang = fileSettings['language']['locale']['lc_all'])
+ lang = UserSettings.Get(group = 'language', key = 'locale', subkey = 'lc_all')
+ if lang:
+ RunCommand('g.gisenv', set = 'LANG=%s' % lang)
event = wxSettingsChanged()
wx.PostEvent(self, event)
self.Close()
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2011-12-25 23:08:45 UTC (rev 49909)
+++ grass/trunk/lib/init/grass.py 2011-12-25 23:28:31 UTC (rev 49910)
@@ -236,16 +236,21 @@
def read_gisrc():
kv = {}
- f = open(gisrc, 'r')
+ try:
+ f = open(gisrc, 'r')
+ except IOError:
+ return kv
for line in f:
k, v = line.split(':', 1)
kv[k.strip()] = v.strip()
f.close()
return kv
-def read_bashrc():
+def read_env_file(path):
kv = {}
- f = open(os.path.join(grass_config_dir, "bashrc"), 'r')
+ f = open(path, 'r')
for line in f:
@@ -292,28 +297,12 @@
def get_locale():
global locale
locale = None
- try:
- kv = read_bashrc()
- except:
- kv = {}
- if 'GRASS_LANG' in os.environ:
- locale = os.environ['GRASS_LANG']
- if locale[0:2] == 'en':
- locale = None
- elif 'GRASS_LANG' in kv:
- locale = kv['GRASS_LANG']
- locale = None
- if locale:
- for var in ['LC_ALL', 'LC_MESSAGES', 'LANG', 'LANGUAGE']:
- os.environ[var] = locale
+ for var in ['LC_ALL', 'LC_MESSAGES', 'LANG', 'LANGUAGE']:
+ loc = os.getenv(var)
+ if loc:
+ locale = loc[0:2]
+ return
- loc = os.getenv(var)
- if loc:
- locale = loc[0:2]
- return
def path_prepend(dir, var):
path = os.getenv(var)
if path:
@@ -334,7 +323,7 @@
# addons (path)
addon_path = os.getenv('GRASS_ADDON_PATH')
if addon_path:
- for path in addons_path.split(os.pathsep):
+ for path in addon_path.split(os.pathsep):
path_prepend(addon_path, 'PATH')
# addons (base)
@@ -628,15 +617,21 @@
location = os.path.join(gisdbase, location_name, mapset)
- # convert selected gisenv variables to environmental variables
+def set_env_from_gisrc():
+ kv = read_gisrc()
+ ### addons
if kv.get('ADDON_PATH'):
addon_path = kv.get('ADDON_PATH')
if os.getenv('GRASS_ADDON_PATH'):
os.environ['GRASS_ADDON_PATH'] += os.pathsep + addon_path
else:
os.environ['GRASS_ADDON_PATH'] = addon_path
- path_prepend(addon_path, 'PATH')
+ ### language
+ if kv.get('LANG'):
+ os.environ['LANGUAGE'] = kv.get('LANG')
def check_lock():
global lockfile
if not os.path.exists(location):
@@ -860,11 +855,6 @@
f.write("export PATH=\"%s\"\n" % os.getenv('PATH'))
f.write("export HOME=\"%s\"\n" % userhome) # restore user home path
- g7bashrc = os.path.join(grass_config_dir,'bashrc')
- if not os.path.exists(g7bashrc):
- fg7 = open(g7bashrc, 'w')
- fg7.close()
for env, value in os.environ.iteritems():
if env.find('GRASS_') < 0:
continue
@@ -1059,6 +1049,9 @@
# Ensure GUI is set
read_gui()
+# Get environmental variables from gisenv variables
+set_env_from_gisrc()
# Get Locale name
get_locale()
