[GRASS-SVN] r49923 - in grass/trunk/gui/wxpython: dbmgr mapdisp
	vdigit
    svn_grass at osgeo.org
    Mon Dec 26 15:02:39 EST 2011
Author: martinl
Date: 2011-12-26 12:02:39 -0800 (Mon, 26 Dec 2011)
New Revision: 49923
   grass/trunk/gui/wxpython/dbmgr/manager.py
   grass/trunk/gui/wxpython/mapdisp/frame.py
   grass/trunk/gui/wxpython/vdigit/mapwindow.py
   grass/trunk/gui/wxpython/vdigit/wxdigit.py
   grass/trunk/gui/wxpython/vdigit/wxdisplay.py
wxGUI/vdigit: fix highlighting/deleting features from dbmgr
Modified: grass/trunk/gui/wxpython/dbmgr/manager.py
--- grass/trunk/gui/wxpython/dbmgr/manager.py	2011-12-26 17:28:02 UTC (rev 49922)
+++ grass/trunk/gui/wxpython/dbmgr/manager.py	2011-12-26 20:02:39 UTC (rev 49923)
@@ -1260,12 +1260,12 @@
             digitToolbar = self.mapdisplay.toolbars['vdigit']
         if digitToolbar and digitToolbar.GetLayer() and \
                 digitToolbar.GetLayer().GetName() == self.vectorName:
-            self.mapdisplay.digit.driver.SetSelected(cats, field=self.layer)
+            display = self.mapdisplay.GetMapWindow().GetDisplay()
+            display.SetSelected(cats, layer = self.layer)
             if zoom:
-                n, s, w, e = self.mapdisplay.digit.driver.GetRegionSelected()
-                self.mapdisplay.Map.GetRegion(n=n, s=s, w=w, e=e,
-                                              update=True)
+                n, s, w, e = display.GetRegionSelected()
+                self.mapdisplay.Map.GetRegion(n = n, s = s, w = w, e = e,
+                                              update = True)
         else:
             # add map layer with higlighted vector features
             self.AddQueryMapLayer() # -> self.qlayer
@@ -2101,13 +2101,19 @@
             wx.MessageBox(parent=self,
                           message=_('Nothing to delete.'),
                           caption=_('Message'), style=wx.CENTRE)
-        if self.OnDataItemDelete(None):
+        display = None
+        if 'vdigit' in self.mapdisplay.toolbars:
-                self.mapdisplay.digit.driver.SetSelected(map(int, cats), field=self.layer)
-                self.mapdisplay.digit.DeleteSelectedLines()
+                display.SetSelected(map(int, cats), layer = self.layer)
+                self.mapdisplay.MapWindow.UpdateMap(render=True, renderVector=True)
+        if self.OnDataItemDelete(None):
+            if display:
+                self.mapdisplay.GetMapWindow().digit.DeleteSelectedLines()
             else:
                 RunCommand('v.edit',
                            parent = self,
@@ -2115,7 +2121,7 @@
                            map = self.vectorName,
                            tool = 'delete',
                            cats = ListOfCatsToRange(cats))
     def AddQueryMapLayer(self):
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py	2011-12-26 17:28:02 UTC (rev 49922)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py	2011-12-26 20:02:39 UTC (rev 49923)
@@ -182,7 +182,9 @@
         self.decorationDialog = None # decoration/overlays
+    def GetMapWindow(self):
+        return self.MapWindow
     def _addToolbarVDigit(self):
         """!Add vector digitizer toolbar
Modified: grass/trunk/gui/wxpython/vdigit/mapwindow.py
--- grass/trunk/gui/wxpython/vdigit/mapwindow.py	2011-12-26 17:28:02 UTC (rev 49922)
+++ grass/trunk/gui/wxpython/vdigit/mapwindow.py	2011-12-26 20:02:39 UTC (rev 49923)
@@ -40,6 +40,11 @@
         self.Bind(wx.EVT_KEY_DOWN, self.OnKeyDown)
+    def GetDisplay(self):
+        if self.digit:
+            return self.digit.GetDisplay()
+        return None
     def SetToolbar(self, toolbar):
         """!Set up related toolbar
Modified: grass/trunk/gui/wxpython/vdigit/wxdigit.py
--- grass/trunk/gui/wxpython/vdigit/wxdigit.py	2011-12-26 17:28:02 UTC (rev 49922)
+++ grass/trunk/gui/wxpython/vdigit/wxdigit.py	2011-12-26 20:02:39 UTC (rev 49923)
@@ -507,25 +507,21 @@
         # collect categories for delete if requested
         if deleteRec:
-            poCats    = Vect_new_cats_struct()
             poCatsDel = Vect_new_cats_struct()
             for i in self._display.selected['ids']:
-                if Vect_read_line(self.poMapInfo, None, poCats, i) < 0:
+                if Vect_read_line(self.poMapInfo, None, self.poCats, i) < 0:
                     Vect_destroy_cats_struct(poCatsDel)
                     self._error.ReadLine(i)
-                cats = poCats.contents
+                cats = self.poCats.contents
                 for j in range(cats.n_cats):
                     Vect_cat_set(poCatsDel, cats.field[j], cats.cat[j])
-            Vect_destroy_cats_struct(poCats)
         # register changeset
         changeset = self._addActionsBefore()
         poList = self._display.GetSelectedIList()
         nlines = Vedit_delete_lines(self.poMapInfo, poList)
         Vect_destroy_list(poList)
         self._display.selected['ids'] = list()
Modified: grass/trunk/gui/wxpython/vdigit/wxdisplay.py
--- grass/trunk/gui/wxpython/vdigit/wxdisplay.py	2011-12-26 17:28:02 UTC (rev 49922)
+++ grass/trunk/gui/wxpython/vdigit/wxdisplay.py	2011-12-26 20:02:39 UTC (rev 49923)
@@ -410,8 +410,9 @@
             # select by id
             if line in self.selected['ids']:
                 return True
-        else:
+        else:
             # select by cat
+            Vect_read_line(self.poMapInfo, None, self.poCats, line)
             for i in range(cats.n_cats):
                 if cats.field[i] == self.selected['field'] and \
@@ -716,13 +717,34 @@
             self._drawSelected = True
         else:
             self._drawSelected = False
+        self.selected['field'] = layer
         if layer > 0:
-            self.selected['field'] = layer
-            self.selected['cats'] = ids
+            self.selected['cats']  = ids
+            self.selected['ids']   = list()
+            ### cidx is not up-to-date
+            # Vect_cidx_find_all(self.poMapInfo, layer, GV_POINTS | GV_LINES, lid, ilist)
+            nlines = Vect_get_num_lines(self.poMapInfo)
+            for line in range(1, nlines + 1):
+                if not Vect_line_alive(self.poMapInfo, line):
+                    continue
+                ltype = Vect_read_line (self.poMapInfo, None, self.poCats, line)
+                if not (ltype & (GV_POINTS | GV_LINES)):
+                    continue
+                found = False
+                for i in range(0, cats.n_cats):
+                    for cat in self.selected['cats']:
+                        if cats.cat[i] == cat:
+                            found = True
+                            break
+                if found:
+                    self.selected['ids'].append(line)
         else:
-            field = -1
-            self.selected['ids'] = ids
+            self.selected['ids']   = ids
+            self.selected['cats']  = []
     def GetSelectedVertex(self, pos):
         """!Get PseudoDC vertex id of selected line
@@ -790,6 +812,34 @@
         return returnId
+    def GetRegionSelected(self):
+        """!Get minimal region extent of selected features
+        @return n,s,w,e
+        regionBox = bound_box()
+        lineBox = bound_box()
+        setRegion = True
+        nareas = Vect_get_num_areas(self.poMapInfo)
+        for line in self.selected['ids']:
+            area = Vect_get_centroid_area(self.poMapInfo, line)
+            if area > 0 and area <= nareas:
+                if not Vect_get_area_box(self.poMapInfo, area, byref(lineBox)):
+                    continue
+            else:
+                if not Vect_get_line_box(self.poMapInfo, line, byref(lineBox)):
+                    continue
+            if setRegion:
+                Vect_box_copy(byref(regionBox), byref(lineBox))
+                setRegion = False
+            else:
+                Vect_box_extend(byref(regionBox), byref(lineBox))
+        return regionBox.N, regionBox.S, regionBox.W, regionBox.E
     def DrawSelected(self, flag):
         """!Draw selected features
