[GRASS-SVN] r49944 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Wed Dec 28 09:03:40 EST 2011
Author: martinl
Date: 2011-12-28 06:03:40 -0800 (Wed, 28 Dec 2011)
New Revision: 49944
grass/trunk/scripts/g.extension/g.extension.py
g.extension.py: minor fix for -a
(merge r49939 from relbr64)
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2011-12-28 14:00:29 UTC (rev 49943)
+++ grass/trunk/scripts/g.extension/g.extension.py 2011-12-28 14:03:40 UTC (rev 49944)
@@ -171,7 +171,7 @@
ret = list()
for tnode in tree.findall('task'):
- ret.append(tnode.get('name'))
+ ret.append(tnode.get('name').strip())
return ret
@@ -416,12 +416,16 @@
# install extension on MS Windows
def install_extension_win():
- ### TODO: do not use hardcoded url
+ ### TODO: do not use hardcoded url - http://wingrass.fsv.cvut.cz/grassXX/addonsX.X.X
version = grass.version()['version'].split('.')
- url = "http://wingrass.fsv.cvut.cz/grass%s%s/addons/" % (version[0], version[1])
grass.message(_("Downloading precompiled GRASS Addons <%s>...") % options['extension'])
+ url = "http://wingrass.fsv.cvut.cz/grass%s%s/addons" % (version[0], version[1])
+ if version[2][1:] != 'svn':
+ url += '%s.%s.%s' % (version[0], version[1], version[2])
+ grass.debug("url=%s" % url, 1)
try:
- f = urlopen(url + options['extension'] + '.zip')
+ f = urlopen(url + '/' + options['extension'] + '.zip')
# create addons dir if not exists
if not os.path.exists(options['prefix']):
@@ -702,7 +706,8 @@
elist = get_installed_extensions()
if elist:
grass.message(_("List of installed extensions:"))
- print os.linesep.join(elist)
+ sys.stdout.write('\n'.join(elist))
+ sys.stdout.write('\n')
else:
grass.info(_("No extension installed"))
return 0
