[GRASS-SVN] r49959 - grass/trunk/vector/v.category
svn_grass at osgeo.org
Wed Dec 28 17:03:24 EST 2011
Author: mmetz
Date: 2011-12-28 14:03:24 -0800 (Wed, 28 Dec 2011)
New Revision: 49959
grass/trunk/vector/v.category/main.c
v.category: topology is optional
Modified: grass/trunk/vector/v.category/main.c
--- grass/trunk/vector/v.category/main.c 2011-12-28 20:48:49 UTC (rev 49958)
+++ grass/trunk/vector/v.category/main.c 2011-12-28 22:03:24 UTC (rev 49959)
@@ -59,6 +59,7 @@
struct cat_list *Clist;
int i, j, ret, option, otype, type, with_z, step, id;
int n_areas, centr, new_centr, nmodified;
+ int open_level;
double x, y;
int cat, ocat, scat, *fields, nfields, field;
struct GModule *module;
@@ -185,9 +186,30 @@
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
+ /* do we need topology ? */
+ if ((option == O_ADD && (otype & GV_AREA)) ||
+ (option == O_REP && (otype & GV_AREA)) ||
+ (option == O_TRANS)) /* topo for cidx check */
+ open_level = 2;
+ else
+ open_level = 1;
/* open input vector */
- Vect_set_open_level(2);
- Vect_open_old2(&In, in_opt->answer, "", field_opt->answer);
+ if (open_level > 1) {
+ Vect_set_open_level(open_level);
+ if (Vect_open_old2(&In, in_opt->answer, "", field_opt->answer) < open_level) {
+ G_warning(_("Can not open vector <%s> on level %d"),
+ Vect_get_full_name(&In), open_level);
+ open_level = 1;
+ if (open_level == 1) {
+ G_fatal_error(_("Can not open vector <%s> on level %d"),
/* read fields */
i = nfields = 0;
@@ -206,7 +228,11 @@
if (nfields != 2 && option == O_CHFIELD)
G_fatal_error(_("2 layers must be specified"));
- if (option == O_TRANS) {
+ if (option == O_TRANS && open_level == 1 && nfields < 2) {
+ G_fatal_error(_("2 layers must be specified"));
+ if (option == O_TRANS && open_level > 1) {
/* check if field[1] already exists */
if (nfields > 1) {
if (Vect_cidx_get_field_index(&In, fields[1]) != -1)
@@ -275,7 +301,7 @@
Vect_write_line(&Out, type, Points, Cats);
/* Areas */
- if (otype & GV_AREA) {
+ if ((otype & GV_AREA) && open_level > 1) {
n_areas = Vect_get_num_areas(&In);
new_centr = 0;
for (i = 1; i <= n_areas; i++) {
@@ -474,6 +500,62 @@
freps[fld]->max[FR_ALL] = cat;
+ /* Areas */
+ if ((otype & GV_AREA) && open_level > 1 && !Clist) {
+ n_areas = Vect_get_num_areas(&In);
+ for (i = 1; i <= n_areas; i++) {
+ int k;
+ centr = Vect_get_area_centroid(&In, i);
+ if (centr <= 0)
+ continue; /* Area without centroid */
+ Vect_read_line(&In, NULL, Cats, centr);
+ for (j = 0; j < Cats->n_cats; j++) {
+ field = Cats->field[j];
+ cat = Cats->cat[j];
+ ret = FALSE;
+ for (k = 0; k < nfreps; k++) {
+ if (freps[k]->field == field) {
+ fld = k;
+ ret = TRUE;
+ break;
+ if (!ret) { /* field report doesn't exist */
+ nfreps++;
+ freps =
+ (FREPORT **) G_realloc(freps,
+ nfreps * sizeof(FREPORT *));
+ fld = nfreps - 1;
+ freps[fld] = (FREPORT *) G_calloc(1, sizeof(FREPORT));
+ freps[fld]->field = field;
+ for (j = 0; j < FRTYPES; j++) {
+ /* cat '0' is valid category number */
+ freps[fld]->min[k] = -1;
+ if ((Fi = Vect_get_field(&In, field)) != NULL) {
+ freps[fld]->table = G_store(Fi->table);
+ else {
+ freps[fld]->table = '\0';
+ freps[fld]->count[FR_AREA]++;
+ if (freps[fld]->min[FR_AREA] == -1 ||
+ freps[fld]->min[FR_AREA] > cat)
+ freps[fld]->min[FR_AREA] = cat;
+ if ((freps[fld]->max[FR_AREA] == 0) ||
+ freps[fld]->max[FR_AREA] < cat)
+ freps[fld]->max[FR_AREA] = cat;
for (i = 0; i < nfreps; i++) {
if (shell->answer) {
if (freps[i]->count[FR_POINT] > 0)
