[GRASS-SVN] r49978 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Fri Dec 30 10:45:03 EST 2011
Author: martinl
Date: 2011-12-30 07:45:03 -0800 (Fri, 30 Dec 2011)
New Revision: 49978
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py
wxGUI/dbm: reorganize 'manage columns' sizer (avoid hidden buttons)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py 2011-12-30 15:16:50 UTC (rev 49977)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py 2011-12-30 15:45:03 UTC (rev 49978)
@@ -860,125 +860,118 @@
list.Bind(wx.EVT_RIGHT_UP, self.OnTableRightUp) #wxGTK
self.layerPage[layer]['tableData'] = list.GetId()
- # add column
- columnBox = wx.StaticBox(parent=panel, id=wx.ID_ANY,
- label=" %s " % _("Manage columns"))
+ # manage columns (add)
+ addBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
+ label = " %s " % _("Add column"))
+ addSizer = wx.StaticBoxSizer(addBox, wx.HORIZONTAL)
- columnSizer = wx.StaticBoxSizer(columnBox, wx.VERTICAL)
- addSizer = wx.FlexGridSizer (cols=5, hgap=3, vgap=3)
- addSizer.AddGrowableCol(3)
- label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Column name"))
- column = wx.TextCtrl(parent=panel, id=wx.ID_ANY, value='',
- size=(150, -1), style=wx.TE_PROCESS_ENTER)
+ column = wx.TextCtrl(parent = panel, id = wx.ID_ANY, value = '',
+ size=(150, -1), style = wx.TE_PROCESS_ENTER)
column.Bind(wx.EVT_TEXT, self.OnTableAddColumnName)
column.Bind(wx.EVT_TEXT_ENTER, self.OnTableItemAdd)
self.layerPage[layer]['addColName'] = column.GetId()
- addSizer.Add(item=label,
- flag=wx.ALIGN_CENTER_VERTICAL)
- addSizer.Add(item=column,
- # data type
- label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Data type"))
+ addSizer.Add(item= wx.StaticText(parent = panel, id = wx.ID_ANY, label=_("Column")),
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT,
+ border = 5)
+ addSizer.Add(item = column, proportion = 1,
+ border = 5)
- subSizer = wx.BoxSizer(wx.HORIZONTAL)
- type = wx.Choice (parent=panel, id=wx.ID_ANY,
- choices = ["integer",
- "double",
- "varchar",
- "date"]) # FIXME
- type.SetSelection(0)
- type.Bind(wx.EVT_CHOICE, self.OnTableChangeType)
- self.layerPage[layer]['addColType'] = type.GetId()
- subSizer.Add(item=type,
+ ctype = wx.Choice (parent=panel, id=wx.ID_ANY,
+ choices = ["integer",
+ "double",
+ "varchar",
+ "date"]) # FIXME
+ ctype.SetSelection(0)
+ ctype.Bind(wx.EVT_CHOICE, self.OnTableChangeType)
+ self.layerPage[layer]['addColType'] = ctype.GetId()
+ addSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY, label=_("Type")),
+ border = 5)
+ addSizer.Add(item = ctype,
flag=wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT,
- border=3)
- # length
- label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Data length"))
- length = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
- initial=250,
- min=1, max=1e6)
+ border = 5)
+ length = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (65, -1),
+ initial = 250,
+ min = 1, max = 1e6)
length.Enable(False)
self.layerPage[layer]['addColLength'] = length.GetId()
- subSizer.Add(item=label,
- flag=wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT,
- border=3)
- subSizer.Add(item=length,
- border=3)
+ addSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Length")),
+ border = 5)
+ addSizer.Add(item = length,
+ border = 5)
- addSizer.Add(item=subSizer,
- border=3)
- btnAddCol = wx.Button(parent=panel, id=wx.ID_ANY, label=_("Add"))
+ btnAddCol = wx.Button(parent = panel, id = wx.ID_ADD)
btnAddCol.Bind(wx.EVT_BUTTON, self.OnTableItemAdd)
btnAddCol.Enable(False)
self.layerPage[layer]['addColButton'] = btnAddCol.GetId()
- addSizer.Add(item=btnAddCol,
- proportion=0,
- flag=wx.EXPAND | wx.ALIGN_RIGHT | wx.FIXED_MINSIZE |
- wx.ALIGN_CENTER_VERTICAL )
+ addSizer.Add(item = btnAddCol, flag = wx.ALL | wx.ALIGN_RIGHT | wx.EXPAND,
+ border = 3)
- # rename col
- label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Rename column"))
- column = wx.ComboBox(parent=panel, id=wx.ID_ANY, size=(150, -1),
- style=wx.CB_SIMPLE | wx.CB_READONLY,
- choices=self.mapDBInfo.GetColumns(table))
+ # manage columns (rename)
+ renameBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
+ label = " %s " % _("Rename column"))
+ renameSizer = wx.StaticBoxSizer(renameBox, wx.HORIZONTAL)
+ # label =
+ column = wx.ComboBox(parent = panel, id = wx.ID_ANY, size = (150, -1),
+ style = wx.CB_SIMPLE | wx.CB_READONLY,
+ choices = self.mapDBInfo.GetColumns(table))
column.SetSelection(0)
self.layerPage[layer]['renameCol'] = column.GetId()
- label = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("To"))
- columnTo = wx.TextCtrl(parent=panel, id=wx.ID_ANY, value='',
+ renameSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Column")),
+ border = 5)
+ renameSizer.Add(item = column, proportion = 1,
+ border = 5)
+ columnTo = wx.TextCtrl(parent = panel, id = wx.ID_ANY, value = '',
+ size = (150, -1), style = wx.TE_PROCESS_ENTER)
columnTo.Bind(wx.EVT_TEXT, self.OnTableRenameColumnName)
columnTo.Bind(wx.EVT_TEXT_ENTER, self.OnTableItemChange)
self.layerPage[layer]['renameColTo'] = columnTo.GetId()
- flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_CENTER)
- addSizer.Add(item=columnTo,
- btnRenameCol = wx.Button(parent=panel, id=wx.ID_ANY, label=_("&Rename"))
+ renameSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("To")),
+ border = 5)
+ renameSizer.Add(item = columnTo, proportion = 1,
+ border = 5)
+ btnRenameCol = wx.Button(parent = panel, id = wx.ID_ANY, label = _("&Rename"))
btnRenameCol.Bind(wx.EVT_BUTTON, self.OnTableItemChange)
btnRenameCol.Enable(False)
self.layerPage[layer]['renameColButton'] = btnRenameCol.GetId()
+ renameSizer.Add(item = btnRenameCol, flag = wx.ALL | wx.ALIGN_RIGHT | wx.EXPAND,
+ border = 3)
- addSizer.Add(item=btnRenameCol,
- proportion=0,
- wx.ALIGN_CENTER_VERTICAL)
- columnSizer.Add(item=addSizer, proportion=1,
- flag=wx.ALL | wx.EXPAND, border=3)
+ tableSizer.Add(item = list,
+ flag = wx.ALL | wx.EXPAND,
+ proportion = 1,
+ border = 3)
- tableSizer.Add(item=list,
- proportion=1,
- border=3)
pageSizer.Add(item=dbSizer,
- proportion=0,
- border=3)
+ proportion = 0,
+ border = 3)
- pageSizer.Add(item=tableSizer,
- flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND,
- proportion=1,
- border=3)
- pageSizer.Add(item=columnSizer,
- proportion=0,
- border=3)
+ pageSizer.Add(item = tableSizer,
+ flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND,
+ proportion = 1,
+ border = 3)
+ pageSizer.Add(item = addSizer,
+ proportion = 0,
+ border = 3)
+ pageSizer.Add(item = renameSizer,
+ proportion = 0,
+ border = 3)
panel.SetSizer(pageSizer)
self.manageTablePage.SetSelection(0) # select first layer
