[GRASS-SVN] r49982 - grass/trunk/gui/wxpython/dbmgr
svn_grass at osgeo.org
Fri Dec 30 11:20:12 EST 2011
Author: martinl
Date: 2011-12-30 08:20:11 -0800 (Fri, 30 Dec 2011)
New Revision: 49982
grass/trunk/gui/wxpython/dbmgr/manager.py
wxGUI/dbmgr: clean up manage.py
wx.Message -> GMessage/Warning/Error
Modified: grass/trunk/gui/wxpython/dbmgr/manager.py
--- grass/trunk/gui/wxpython/dbmgr/manager.py 2011-12-30 15:54:13 UTC (rev 49981)
+++ grass/trunk/gui/wxpython/dbmgr/manager.py 2011-12-30 16:20:11 UTC (rev 49982)
@@ -47,7 +47,7 @@
import grass.script as grass
from dbmgr.sqlbuilder import SQLFrame
-from core.gcmd import RunCommand, GException, GError
+from core.gcmd import RunCommand, GException, GError, GMessage, GWarning
from core.utils import ListOfCatsToRange
from gui_core.dialogs import CreateNewVector
from dbmgr.vinfo import VectorDBInfo, unicodeValue, createDbInfoDesc
@@ -85,8 +85,8 @@
self.columns = {} # <- LoadData()
- wx.ListCtrl.__init__(self, parent=parent, id=wx.ID_ANY,
- style=wx.LC_REPORT | wx.LC_HRULES |
+ wx.ListCtrl.__init__(self, parent = parent, id = wx.ID_ANY,
+ style = wx.LC_REPORT | wx.LC_HRULES |
wx.LC_VRULES | wx.LC_VIRTUAL | wx.LC_SORT_ASCENDING)
try:
@@ -116,9 +116,9 @@
# sort item by category (id)
if keyColumn > -1:
- self.SortListItems(col=keyColumn, ascending=True)
+ self.SortListItems(col = keyColumn, ascending = True)
else:
- self.SortListItems(col=0, ascending=True)
+ self.SortListItems(col = 0, ascending = True)
# events
self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnItemSelected)
@@ -131,7 +131,7 @@
self.mapDBInfo = mapDBInfo
self.LoadData(self.layer)
- def LoadData(self, layer, columns=None, where=None, sql=None):
+ def LoadData(self, layer, columns = None, where = None, sql = None):
"""!Load data into list
@param layer layer number
@@ -159,11 +159,10 @@
all = self.mapDBInfo.GetColumns(tableName)
for col in columns:
if col not in all:
- wx.MessageBox(parent=self,
- message=_("Column <%(column)s> not found in "
- "in the table <%(table)s>.") % \
- { 'column' : col, 'table' : tableName },
- caption=_("Error"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ GError(parent = self,
+ message = _("Column <%(column)s> not found in "
+ "in the table <%(table)s>.") % \
+ { 'column' : col, 'table' : tableName })
return
try:
@@ -179,7 +178,7 @@
# stdout can be very large, do not use PIPE, redirect to temp file
# TODO: more effective way should be implemented...
- outFile = tempfile.NamedTemporaryFile(mode='w+b')
+ outFile = tempfile.NamedTemporaryFile(mode = 'w+b')
if sql:
ret = RunCommand('db.select',
@@ -260,7 +259,7 @@
width = 60
if width > 300:
width = 300
- self.SetColumnWidth(col=i, width=width)
+ self.SetColumnWidth(col = i, width = width)
i += 1
self.SendSizeEvent()
@@ -304,7 +303,7 @@
except ValueError, e:
cat = -1
gGError(parent = self,
- message=_("Error loading attribute data. "
+ message = _("Error loading attribute data. "
"Record number: %(rec)d. Unable to convert value '%(val)s' in "
"key column (%(key)s) to integer.\n\n"
"Details: %(detail)s") % \
@@ -386,8 +385,8 @@
self.popupID11 = wx.NewId()
self.popupID12 = wx.NewId()
- popupMenu.Append(self.popupID1, text=_("Sort ascending"))
- popupMenu.Append(self.popupID2, text=_("Sort descending"))
+ popupMenu.Append(self.popupID1, text = _("Sort ascending"))
+ popupMenu.Append(self.popupID2, text = _("Sort descending"))
popupMenu.AppendSeparator()
subMenu = wx.Menu()
popupMenu.AppendMenu(self.popupID3, _("Calculate (only numeric columns)"),
@@ -396,18 +395,18 @@
self.columns[self.GetColumn(self._col).GetText()]['ctype'] not in (types.IntType, types.FloatType):
popupMenu.Enable(self.popupID3, False)
- subMenu.Append(self.popupID4, text=_("Area size"))
- subMenu.Append(self.popupID5, text=_("Line length"))
- subMenu.Append(self.popupID6, text=_("Compactness of an area"))
- subMenu.Append(self.popupID7, text=_("Fractal dimension of boundary defining a polygon"))
- subMenu.Append(self.popupID8, text=_("Perimeter length of an area"))
- subMenu.Append(self.popupID9, text=_("Number of features for each category"))
- subMenu.Append(self.popupID10, text=_("Slope steepness of 3D line"))
- subMenu.Append(self.popupID11, text=_("Line sinuousity"))
- subMenu.Append(self.popupID12, text=_("Line azimuth"))
+ subMenu.Append(self.popupID4, text = _("Area size"))
+ subMenu.Append(self.popupID5, text = _("Line length"))
+ subMenu.Append(self.popupID6, text = _("Compactness of an area"))
+ subMenu.Append(self.popupID7, text = _("Fractal dimension of boundary defining a polygon"))
+ subMenu.Append(self.popupID8, text = _("Perimeter length of an area"))
+ subMenu.Append(self.popupID9, text = _("Number of features for each category"))
+ subMenu.Append(self.popupID10, text = _("Slope steepness of 3D line"))
+ subMenu.Append(self.popupID11, text = _("Line sinuousity"))
+ subMenu.Append(self.popupID12, text = _("Line azimuth"))
- self.Bind (wx.EVT_MENU, self.OnColumnSortAsc, id=self.popupID1)
- self.Bind (wx.EVT_MENU, self.OnColumnSortDesc, id=self.popupID2)
+ self.Bind (wx.EVT_MENU, self.OnColumnSortAsc, id = self.popupID1)
+ self.Bind (wx.EVT_MENU, self.OnColumnSortDesc, id = self.popupID2)
for id in (self.popupID4, self.popupID5, self.popupID6,
self.popupID7, self.popupID8, self.popupID9,
self.popupID10, self.popupID11, self.popupID12):
@@ -481,7 +480,7 @@
info.m_text = self.GetColumn(column).GetText()
self.SetColumn(column, info)
- def SortItems(self, sorter=cmp):
+ def SortItems(self, sorter = cmp):
"""!Sort items"""
items = list(self.itemDataMap.keys())
items.sort(self.Sorter)
@@ -571,7 +570,7 @@
# icon
self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_sql.ico'), wx.BITMAP_TYPE_ICO))
- self.panel = wx.Panel(parent=self, id=wx.ID_ANY)
+ self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
try:
self.map = self.parent.curr_page.maptree.Map
@@ -592,21 +591,19 @@
self.builder = None
if len(self.mapDBInfo.layers.keys()) == 0:
- wx.MessageBox(parent=self.parent,
- message=_("Database connection for vector map <%s> "
- "is not defined in DB file. "
- "You can define new connection in "
- "'Manage layers' tab.") % self.vectorName,
- caption=_("Attribute Table Manager"),
- style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
+ GMessage(parent = self.parent,
+ message = _("Database connection for vector map <%s> "
+ "is not defined in DB file. "
+ "You can define new connection in "
+ "'Manage layers' tab.") % self.vectorName)
# list of command/SQL statements to be performed
self.listOfCommands = []
self.listOfSQLStatements = []
- self.CreateStatusBar(number=1)
+ self.CreateStatusBar(number = 1)
# set up virtual lists (each layer)
### {layer: list, widgets...}
@@ -651,9 +648,9 @@
wx.CallAfter(self.notebook.SetSelection, 0) # select browse tab
# buttons
- self.btnQuit = wx.Button(parent=self.panel, id=wx.ID_EXIT)
+ self.btnQuit = wx.Button(parent = self.panel, id = wx.ID_EXIT)
self.btnQuit.SetToolTipString(_("Close Attribute Table Manager"))
- self.btnReload = wx.Button(parent=self.panel, id=wx.ID_REFRESH)
+ self.btnReload = wx.Button(parent = self.panel, id = wx.ID_REFRESH)
self.btnReload.SetToolTipString(_("Reload attribute data (selected layer only)"))
# events
@@ -671,20 +668,20 @@
self.SetSize((680, 550)) # FIXME hard-coded size
self.SetMinSize(self.GetSize())
- def _createBrowsePage(self, onlyLayer=-1):
+ def _createBrowsePage(self, onlyLayer = -1):
"""!Create browse tab page"""
for layer in self.mapDBInfo.layers.keys():
if onlyLayer > 0 and layer != onlyLayer:
continue
- panel = wx.Panel(parent=self.browsePage, id=wx.ID_ANY)
+ panel = wx.Panel(parent = self.browsePage, id = wx.ID_ANY)
#IMPORTANT NOTE: wx.StaticBox MUST be defined BEFORE any of the
# controls that are placed IN the wx.StaticBox, or it will freeze
# on the Mac
- listBox = wx.StaticBox(parent=panel, id=wx.ID_ANY,
- label=" %s " % _("Attribute data - right-click to edit/manage records"))
+ listBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
+ label = " %s " % _("Attribute data - right-click to edit/manage records"))
listSizer = wx.StaticBoxSizer(listBox, wx.VERTICAL)
win = VirtualAttributeList(panel, self.log,
@@ -700,103 +697,102 @@
label = _("Table")
if not self.editable:
label += _(" (readonly)")
- self.browsePage.AddPage(page=panel, text=" %d / %s %s" % \
+ self.browsePage.AddPage(page = panel, text = " %d / %s %s" % \
(layer, label, self.mapDBInfo.layers[layer]['table']))
pageSizer = wx.BoxSizer(wx.VERTICAL)
# attribute data
- sqlBox = wx.StaticBox(parent=panel, id=wx.ID_ANY,
- label=" %s " % _("SQL Query"))
+ sqlBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
+ label = " %s " % _("SQL Query"))
sqlSizer = wx.StaticBoxSizer(sqlBox, wx.VERTICAL)
win.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnDataRightUp) #wxMSW
win.Bind(wx.EVT_RIGHT_UP, self.OnDataRightUp) #wxGTK
- if UserSettings.Get(group='atm', key='leftDbClick', subkey='selection') == 0:
+ if UserSettings.Get(group = 'atm', key = 'leftDbClick', subkey = 'selection') == 0:
win.Bind(wx.EVT_LEFT_DCLICK, self.OnDataItemEdit)
win.Bind(wx.EVT_COMMAND_LEFT_DCLICK, self.OnDataItemEdit)
else:
win.Bind(wx.EVT_LEFT_DCLICK, self.OnDataDrawSelected)
win.Bind(wx.EVT_COMMAND_LEFT_DCLICK, self.OnDataDrawSelected)
- listSizer.Add(item=win, proportion=1,
- flag=wx.EXPAND | wx.ALL,
- border=3)
+ listSizer.Add(item = win, proportion = 1,
+ flag = wx.EXPAND | wx.ALL,
+ border = 3)
# sql statement box
- btnApply = wx.Button(parent=panel, id=wx.ID_APPLY)
+ btnApply = wx.Button(parent = panel, id = wx.ID_APPLY)
btnApply.SetToolTipString(_("Apply SELECT statement and reload data records"))
btnApply.Bind(wx.EVT_BUTTON, self.OnApplySqlStatement)
- btnSqlBuilder = wx.Button(parent=panel, id=wx.ID_ANY, label=_("SQL Builder"))
+ btnSqlBuilder = wx.Button(parent = panel, id = wx.ID_ANY, label = _("SQL Builder"))
btnSqlBuilder.Bind(wx.EVT_BUTTON, self.OnBuilder)
- sqlSimple = wx.RadioButton(parent=panel, id=wx.ID_ANY,
- label=_("Simple"))
+ sqlSimple = wx.RadioButton(parent = panel, id = wx.ID_ANY,
+ label = _("Simple"))
sqlSimple.SetValue(True)
- sqlAdvanced = wx.RadioButton(parent=panel, id=wx.ID_ANY,
- label=_("Advanced"))
+ sqlAdvanced = wx.RadioButton(parent = panel, id = wx.ID_ANY,
+ label = _("Advanced"))
sqlSimple.Bind(wx.EVT_RADIOBUTTON, self.OnChangeSql)
sqlAdvanced.Bind(wx.EVT_RADIOBUTTON, self.OnChangeSql)
- sqlWhereColumn = wx.Choice(parent=panel, id=wx.ID_ANY,
- size=(100,-1),
- choices=self.mapDBInfo.GetColumns(self.mapDBInfo.layers[layer]['table']))
- sqlWhereValue = wx.TextCtrl(parent=panel, id=wx.ID_ANY, value="",
- style=wx.TE_PROCESS_ENTER)
+ sqlWhereColumn = wx.Choice(parent = panel, id = wx.ID_ANY,
+ size = (100,-1),
+ choices = self.mapDBInfo.GetColumns(self.mapDBInfo.layers[layer]['table']))
+ sqlWhereValue = wx.TextCtrl(parent = panel, id = wx.ID_ANY, value = "",
+ style = wx.TE_PROCESS_ENTER)
sqlWhereValue.SetToolTipString(_("Example: %s") % "MULTILANE = 'no' AND OBJECTID < 10")
- sqlStatement = wx.TextCtrl(parent=panel, id=wx.ID_ANY,
- value="SELECT * FROM %s" % \
+ sqlStatement = wx.TextCtrl(parent = panel, id = wx.ID_ANY,
+ value = "SELECT * FROM %s" % \
self.mapDBInfo.layers[layer]['table'],
sqlStatement.SetToolTipString(_("Example: %s") % "SELECT * FROM roadsmajor WHERE MULTILANE = 'no' AND OBJECTID < 10")
sqlWhereValue.Bind(wx.EVT_TEXT_ENTER, self.OnApplySqlStatement)
sqlStatement.Bind(wx.EVT_TEXT_ENTER, self.OnApplySqlStatement)
- sqlLabel = wx.StaticText(parent=panel, id=wx.ID_ANY,
- label="SELECT * FROM %s WHERE " % \
+ sqlLabel = wx.StaticText(parent = panel, id = wx.ID_ANY,
+ label = "SELECT * FROM %s WHERE " % \
- label_query = wx.StaticText(parent=panel, id=wx.ID_ANY,
- label="")
+ label_query = wx.StaticText(parent = panel, id = wx.ID_ANY,
+ label = "")
- sqlFlexSizer = wx.FlexGridSizer (cols=3, hgap=5, vgap=5)
+ sqlFlexSizer = wx.FlexGridSizer (cols = 3, hgap = 5, vgap = 5)
sqlFlexSizer.AddGrowableCol(1)
- sqlFlexSizer.Add(item=sqlSimple,
- flag=wx.ALIGN_CENTER_VERTICAL)
+ sqlFlexSizer.Add(item = sqlSimple,
+ flag = wx.ALIGN_CENTER_VERTICAL)
sqlSimpleSizer = wx.BoxSizer(wx.HORIZONTAL)
- sqlSimpleSizer.Add(item=sqlLabel,
- sqlSimpleSizer.Add(item=sqlWhereColumn,
- flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
- sqlSimpleSizer.Add(item=sqlWhereValue, proportion=1,
- sqlFlexSizer.Add(item=sqlSimpleSizer,
- flag=wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
- sqlFlexSizer.Add(item=btnApply,
- flag=wx.ALIGN_RIGHT)
- sqlFlexSizer.Add(item=sqlAdvanced,
- sqlFlexSizer.Add(item=sqlStatement,
- flag=wx.EXPAND)
- sqlFlexSizer.Add(item=btnSqlBuilder,
+ sqlSimpleSizer.Add(item = sqlLabel,
+ sqlSimpleSizer.Add(item = sqlWhereColumn,
+ flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
+ sqlSimpleSizer.Add(item = sqlWhereValue, proportion = 1,
+ sqlFlexSizer.Add(item = sqlSimpleSizer,
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
+ sqlFlexSizer.Add(item = btnApply,
+ flag = wx.ALIGN_RIGHT)
+ sqlFlexSizer.Add(item = sqlAdvanced,
+ sqlFlexSizer.Add(item = sqlStatement,
+ flag = wx.EXPAND)
+ sqlFlexSizer.Add(item = btnSqlBuilder,
- sqlSizer.Add(item=sqlFlexSizer,
- flag=wx.ALL | wx.EXPAND,
- border=3)
+ sqlSizer.Add(item = sqlFlexSizer,
+ flag = wx.ALL | wx.EXPAND,
+ border = 3)
- pageSizer.Add(item=listSizer,
- proportion=1,
- border=5)
+ pageSizer.Add(item = listSizer,
+ proportion = 1,
+ border = 5)
- pageSizer.Add(item=sqlSizer,
- proportion=0,
- flag=wx.BOTTOM | wx.LEFT | wx.RIGHT | wx.EXPAND,
- border=5)
+ pageSizer.Add(item = sqlSizer,
+ proportion = 0,
+ flag = wx.BOTTOM | wx.LEFT | wx.RIGHT | wx.EXPAND,
+ border = 5)
panel.SetSizer(pageSizer)
@@ -818,7 +814,7 @@
except (IndexError, KeyError):
self.layer = None
- def _createManageTablePage(self, onlyLayer=-1):
+ def _createManageTablePage(self, onlyLayer = -1):
"""!Create manage page (create/link and alter tables)"""
@@ -827,13 +823,13 @@
if not layer in self.layerPage:
continue
- panel = wx.Panel(parent=self.manageTablePage, id=wx.ID_ANY)
+ panel = wx.Panel(parent = self.manageTablePage, id = wx.ID_ANY)
self.layerPage[layer]['tablePage'] = panel.GetId()
label = _("Table")
- self.manageTablePage.AddPage(page=panel,
- text=" %d / %s %s" % (layer, label,
+ self.manageTablePage.AddPage(page = panel,
+ text = " %d / %s %s" % (layer, label,
@@ -841,20 +837,20 @@
# dbInfo
- dbBox = wx.StaticBox(parent=panel, id=wx.ID_ANY,
- label=" %s " % _("Database connection"))
+ dbBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
+ label = " %s " % _("Database connection"))
dbSizer = wx.StaticBoxSizer(dbBox, wx.VERTICAL)
- dbSizer.Add(item=createDbInfoDesc(panel, self.mapDBInfo, layer),
- proportion=1,
- border=3)
+ dbSizer.Add(item = createDbInfoDesc(panel, self.mapDBInfo, layer),
+ proportion = 1,
+ border = 3)
# table description
table = self.mapDBInfo.layers[layer]['table']
- tableBox = wx.StaticBox(parent=panel, id=wx.ID_ANY,
- label=" %s " % _("Table <%s> - right-click to delete column(s)") % table)
+ tableBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
+ label = " %s " % _("Table <%s> - right-click to delete column(s)") % table)
tableSizer = wx.StaticBoxSizer(tableBox, wx.VERTICAL)
@@ -869,18 +865,18 @@
addSizer = wx.StaticBoxSizer(addBox, wx.HORIZONTAL)
column = wx.TextCtrl(parent = panel, id = wx.ID_ANY, value = '',
- size=(150, -1), style = wx.TE_PROCESS_ENTER)
+ size = (150, -1), style = wx.TE_PROCESS_ENTER)
column.Bind(wx.EVT_TEXT, self.OnTableAddColumnName)
column.Bind(wx.EVT_TEXT_ENTER, self.OnTableItemAdd)
self.layerPage[layer]['addColName'] = column.GetId()
- addSizer.Add(item= wx.StaticText(parent = panel, id = wx.ID_ANY, label=_("Column")),
+ addSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Column")),
flag = wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT,
border = 5)
addSizer.Add(item = column, proportion = 1,
border = 5)
- ctype = wx.Choice (parent=panel, id=wx.ID_ANY,
+ ctype = wx.Choice (parent = panel, id = wx.ID_ANY,
choices = ["integer",
"double",
"varchar",
@@ -888,11 +884,11 @@
ctype.SetSelection(0)
ctype.Bind(wx.EVT_CHOICE, self.OnTableChangeType)
self.layerPage[layer]['addColType'] = ctype.GetId()
- addSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY, label=_("Type")),
+ addSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Type")),
border = 5)
addSizer.Add(item = ctype,
- flag=wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT,
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT,
border = 5)
length = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (65, -1),
@@ -984,9 +980,9 @@
def _createTableDesc(self, parent, table):
"""!Create list with table description"""
- list = TableListCtrl(parent=parent, id=wx.ID_ANY,
- table=self.mapDBInfo.tables[table],
- columns=self.mapDBInfo.GetColumns(table))
+ list = TableListCtrl(parent = parent, id = wx.ID_ANY,
+ table = self.mapDBInfo.tables[table],
+ columns = self.mapDBInfo.GetColumns(table))
list.Populate()
# sorter
# itemDataMap = list.Populate()
@@ -996,55 +992,55 @@
def _createManageLayerPage(self):
"""!Create manage page"""
- splitterWin = wx.SplitterWindow(parent=self.manageLayerPage, id=wx.ID_ANY)
+ splitterWin = wx.SplitterWindow(parent = self.manageLayerPage, id = wx.ID_ANY)
splitterWin.SetMinimumPaneSize(100)
label = _("Layers of vector map")
- self.manageLayerPage.AddPage(page=splitterWin,
- text=label) # dummy page
+ self.manageLayerPage.AddPage(page = splitterWin,
+ text = label) # dummy page
# list of layers
- panelList = wx.Panel(parent=splitterWin, id=wx.ID_ANY)
+ panelList = wx.Panel(parent = splitterWin, id = wx.ID_ANY)
panelListSizer = wx.BoxSizer(wx.VERTICAL)
- layerBox = wx.StaticBox(parent=panelList, id=wx.ID_ANY,
- label=" %s " % _("List of layers"))
+ layerBox = wx.StaticBox(parent = panelList, id = wx.ID_ANY,
+ label = " %s " % _("List of layers"))
layerSizer = wx.StaticBoxSizer(layerBox, wx.VERTICAL)
self.layerList = self._createLayerDesc(panelList)
self.layerList.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnLayerRightUp) #wxMSW
self.layerList.Bind(wx.EVT_RIGHT_UP, self.OnLayerRightUp) #wxGTK
- layerSizer.Add(item=self.layerList,
- proportion=1,
- border=3)
+ layerSizer.Add(item = self.layerList,
+ proportion = 1,
+ border = 3)
- panelListSizer.Add(item=layerSizer,
- proportion=1,
- border=3)
+ panelListSizer.Add(item = layerSizer,
+ proportion = 1,
+ border = 3)
panelList.SetSizer(panelListSizer)
# manage part
- panelManage = wx.Panel(parent=splitterWin, id=wx.ID_ANY)
+ panelManage = wx.Panel(parent = splitterWin, id = wx.ID_ANY)
manageSizer = wx.BoxSizer(wx.VERTICAL)
- self.manageLayerBook = LayerBook(parent=panelManage, id=wx.ID_ANY,
- parentDialog=self)
+ self.manageLayerBook = LayerBook(parent = panelManage, id = wx.ID_ANY,
+ parentDialog = self)
- manageSizer.Add(item=self.manageLayerBook,
- proportion=1,
- flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND,
- border=5)
+ manageSizer.Add(item = self.manageLayerBook,
+ proportion = 1,
+ flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND,
+ border = 5)
panelManage.SetSizer(manageSizer)
splitterWin.SplitHorizontally(panelList, panelManage, 100)
@@ -1052,8 +1048,8 @@
def _createLayerDesc(self, parent):
"""!Create list of linked layers"""
- list = LayerListCtrl(parent=parent, id=wx.ID_ANY,
- layers=self.mapDBInfo.layers)
+ list = LayerListCtrl(parent = parent, id = wx.ID_ANY,
+ layers = self.mapDBInfo.layers)
list.Populate()
# sorter
@@ -1069,13 +1065,13 @@
# buttons
btnSizer = wx.BoxSizer(wx.HORIZONTAL)
- btnSizer.Add(item=self.btnReload, proportion=1,
- flag=wx.ALL | wx.ALIGN_RIGHT, border=5)
- btnSizer.Add(item=self.btnQuit, proportion=1,
+ btnSizer.Add(item = self.btnReload, proportion = 1,
+ flag = wx.ALL | wx.ALIGN_RIGHT, border = 5)
+ btnSizer.Add(item = self.btnQuit, proportion = 1,
- mainSizer.Add(item=self.notebook, proportion=1, flag=wx.EXPAND)
- mainSizer.Add(item=btnSizer, flag=wx.ALIGN_RIGHT | wx.ALL, border=5)
+ mainSizer.Add(item = self.notebook, proportion = 1, flag = wx.EXPAND)
+ mainSizer.Add(item = btnSizer, flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
self.panel.SetAutoLayout(True)
self.panel.SetSizer(mainSizer)
@@ -1097,17 +1093,17 @@
self.popupDataID10 = wx.NewId()
self.popupDataID11 = wx.NewId()
- self.Bind(wx.EVT_MENU, self.OnDataItemEdit, id=self.popupDataID1)
- self.Bind(wx.EVT_MENU, self.OnDataItemAdd, id=self.popupDataID2)
- self.Bind(wx.EVT_MENU, self.OnDataItemDelete, id=self.popupDataID3)
- self.Bind(wx.EVT_MENU, self.OnDataItemDeleteAll, id=self.popupDataID4)
- self.Bind(wx.EVT_MENU, self.OnDataSelectAll, id=self.popupDataID5)
- self.Bind(wx.EVT_MENU, self.OnDataSelectNone, id=self.popupDataID6)
- self.Bind(wx.EVT_MENU, self.OnDataDrawSelected, id=self.popupDataID7)
- self.Bind(wx.EVT_MENU, self.OnDataDrawSelectedZoom, id=self.popupDataID8)
- self.Bind(wx.EVT_MENU, self.OnExtractSelected, id=self.popupDataID9)
- self.Bind(wx.EVT_MENU, self.OnDeleteSelected, id=self.popupDataID11)
- self.Bind(wx.EVT_MENU, self.OnDataReload, id=self.popupDataID10)
+ self.Bind(wx.EVT_MENU, self.OnDataItemEdit, id = self.popupDataID1)
+ self.Bind(wx.EVT_MENU, self.OnDataItemAdd, id = self.popupDataID2)
+ self.Bind(wx.EVT_MENU, self.OnDataItemDelete, id = self.popupDataID3)
+ self.Bind(wx.EVT_MENU, self.OnDataItemDeleteAll, id = self.popupDataID4)
+ self.Bind(wx.EVT_MENU, self.OnDataSelectAll, id = self.popupDataID5)
+ self.Bind(wx.EVT_MENU, self.OnDataSelectNone, id = self.popupDataID6)
+ self.Bind(wx.EVT_MENU, self.OnDataDrawSelected, id = self.popupDataID7)
+ self.Bind(wx.EVT_MENU, self.OnDataDrawSelectedZoom, id = self.popupDataID8)
+ self.Bind(wx.EVT_MENU, self.OnExtractSelected, id = self.popupDataID9)
+ self.Bind(wx.EVT_MENU, self.OnDeleteSelected, id = self.popupDataID11)
+ self.Bind(wx.EVT_MENU, self.OnDataReload, id = self.popupDataID10)
list = self.FindWindowById(self.layerPage[self.layer]['data'])
# generate popup-menu
@@ -1171,13 +1167,13 @@
item = dlist.GetNextSelected(item)
- if UserSettings.Get(group='atm', key='askOnDeleteRec', subkey='enabled'):
- deleteDialog = wx.MessageBox(parent=self,
- message=_("Selected data records (%d) will permanently deleted "
+ if UserSettings.Get(group = 'atm', key = 'askOnDeleteRec', subkey = 'enabled'):
+ deleteDialog = wx.MessageBox(parent = self,
+ message = _("Selected data records (%d) will permanently deleted "
"from table. Do you want to delete them?") % \
(len(self.listOfSQLStatements)),
- caption=_("Delete records"),
- style=wx.YES_NO | wx.CENTRE)
+ caption = _("Delete records"),
+ style = wx.YES_NO | wx.CENTRE)
if deleteDialog != wx.YES:
return False
@@ -1217,13 +1213,13 @@
def OnDataItemDeleteAll(self, event):
"""!Delete all items from the list"""
dlist = self.FindWindowById(self.layerPage[self.layer]['data'])
- message=_("All data records (%d) will permanently deleted "
+ message = _("All data records (%d) will permanently deleted "
(len(dlist.itemIndexMap)),
return
@@ -1266,7 +1262,7 @@
if self.parent and self.parent.GetName() == "LayerManager" and \
self.treeItem:
maptree = self.parent.curr_page.maptree
- opacity = maptree.GetPyData(self.treeItem)[0]['maplayer'].GetOpacity(float=True)
+ opacity = maptree.GetPyData(self.treeItem)[0]['maplayer'].GetOpacity(float = True)
self.qlayer.SetOpacity(opacity)
if zoom:
keyColumn = self.mapDBInfo.layers[self.layer]['key']
@@ -1295,24 +1291,24 @@
key, value = line.split('=')
region[key.strip()] = float(value.strip())
- self.mapdisplay.Map.GetRegion(n=region['n'], s=region['s'],
- w=region['w'], e=region['e'],
- update=True)
+ self.mapdisplay.Map.GetRegion(n = region['n'], s = region['s'],
+ w = region['w'], e = region['e'],
+ update = True)
if zoom:
self.mapdisplay.Map.AdjustRegion() # adjust resolution
self.mapdisplay.Map.AlignExtentFromDisplay() # adjust extent
- self.mapdisplay.MapWindow.UpdateMap(render=True, renderVector=True)
+ self.mapdisplay.MapWindow.UpdateMap(render = True, renderVector = True)
else:
- self.mapdisplay.MapWindow.UpdateMap(render=False, renderVector=True)
+ self.mapdisplay.MapWindow.UpdateMap(render = False, renderVector = True)
def OnDataDrawSelected(self, event):
"""!Reload table description"""
- self._drawSelected(zoom=False)
+ self._drawSelected(zoom = False)
event.Skip()
def OnDataDrawSelectedZoom(self, event):
- self._drawSelected(zoom=True)
+ self._drawSelected(zoom = True)
event.Skip()
def OnDataItemAdd(self, event):
@@ -1361,7 +1357,7 @@
if dlg.ShowModal() == wx.ID_OK:
try: # get category number
- cat = int(dlg.GetValues(columns=[keyColumn])[0])
+ cat = int(dlg.GetValues(columns = [keyColumn])[0])
except:
cat = -1
@@ -1401,10 +1397,9 @@
valuesString += "%s," % values[i]
except ValueError, err:
- message="%s%s%s" % (_("Unable to insert new record."),
- os.linesep, err),
+ message = "%s%s%s" % (_("Unable to insert new record."),
+ os.linesep, err))
return
# remove category if need
@@ -1510,10 +1505,9 @@
updateString += "%s=NULL," % (columnName[i])
- message="%s%s%s" % (_("Unable to update existing record."),
- os.linesep, err),
+ message = "%s%s%s" % (_("Unable to update existing record."),
+ os.linesep, err))
return
if len(updateString) > 0:
@@ -1596,22 +1590,20 @@
table = self.mapDBInfo.layers[self.layer]["table"]
if not name or not nameTo:
- wx.MessageBox(self=self,
- message=_("Unable to rename column. "
- "No column name defined."),
+ message = _("Unable to rename column. "
+ "No column name defined."))
return
else:
- item = list.FindItem(start=-1, str=name)
+ item = list.FindItem(start = -1, str = name)
if item > -1:
- if list.FindItem(start=-1, str=nameTo) > -1:
- message=_("Unable to rename column <%(column)s> to "
- "<%(columnTo)s>. Column already exists "
- {'column' : name, 'columnTo' : nameTo,
- 'table' : table},
+ if list.FindItem(start = -1, str = nameTo) > -1:
+ message = _("Unable to rename column <%(column)s> to "
+ "<%(columnTo)s>. Column already exists "
+ {'column' : name, 'columnTo' : nameTo,
+ 'table' : table})
return
else:
list.SetItemText(item, nameTo)
@@ -1622,11 +1614,10 @@
'column' : '%s,%s' % (name, nameTo) }
else:
- "Column <%(column)s> doesn't exist in the table <%(table)s>.") %
- {'column' : name, 'table' : table},
+ "Column <%(column)s> doesn't exist in the table <%(table)s>.") %
+ {'column' : name, 'table' : table})
return
# apply changes
@@ -1645,9 +1636,9 @@
self.popupTableID1 = wx.NewId()
self.popupTableID2 = wx.NewId()
self.popupTableID3 = wx.NewId()
- self.Bind(wx.EVT_MENU, self.OnTableItemDelete, id=self.popupTableID1)
- self.Bind(wx.EVT_MENU, self.OnTableItemDeleteAll, id=self.popupTableID2)
- self.Bind(wx.EVT_MENU, self.OnTableReload, id=self.popupTableID3)
+ self.Bind(wx.EVT_MENU, self.OnTableItemDelete, id = self.popupTableID1)
+ self.Bind(wx.EVT_MENU, self.OnTableItemDeleteAll, id = self.popupTableID2)
+ self.Bind(wx.EVT_MENU, self.OnTableReload, id = self.popupTableID3)
menu = wx.Menu()
@@ -1667,13 +1658,13 @@
item = list.GetFirstSelected()
- message=_("Selected column '%s' will PERMANENTLY removed "
+ message = _("Selected column '%s' will PERMANENTLY removed "
"from table. Do you want to drop the column?") % \
(list.GetItemText(item)),
- caption=_("Drop column(s)"),
+ caption = _("Drop column(s)"),
return False
@@ -1704,13 +1695,13 @@
if keyColumn in cols:
cols.remove(keyColumn)
- message=_("Selected columns\n%s\nwill PERMANENTLY removed "
+ message = _("Selected columns\n%s\nwill PERMANENTLY removed "
"from table. Do you want to drop the columns?") % \
('\n'.join(cols)),
return False
@@ -1732,9 +1723,9 @@
event.Skip()
- def OnTableReload(self, event=None):
+ def OnTableReload(self, event = None):
- self.FindWindowById(self.layerPage[self.layer]['tableData']).Populate(update=True)
+ self.FindWindowById(self.layerPage[self.layer]['tableData']).Populate(update = True)
def OnTableItemAdd(self, event):
@@ -1763,7 +1754,7 @@
# add item to the list of table columns
tlist = self.FindWindowById(self.layerPage[self.layer]['tableData'])
# check for duplicate items
- if tlist.FindItem(start=-1, str=name) > -1:
+ if tlist.FindItem(start = -1, str = name) > -1:
message = _("Column <%(column)s> already exists in table <%(table)s>.") % \
{'column' : name, 'table' : self.mapDBInfo.layers[self.layer]["table"]}
@@ -1869,8 +1860,8 @@
# update table description
- list.Update(table=self.mapDBInfo.tables[table],
+ list.Update(table = self.mapDBInfo.tables[table],
self.OnTableReload(None)
# update data list
@@ -1882,9 +1873,9 @@
# perform SQL non-select statements (e.g. 'delete from table where cat=1')
if len(self.listOfSQLStatements) > 0:
- sqlFile = tempfile.NamedTemporaryFile(mode="wt")
+ sqlFile = tempfile.NamedTemporaryFile(mode = "wt")
for sql in self.listOfSQLStatements:
- enc = UserSettings.Get(group='atm', key='encoding', subkey='value')
+ enc = UserSettings.Get(group = 'atm', key = 'encoding', subkey = 'value')
if not enc and 'GRASS_DB_ENCODING' in os.environ:
enc = os.environ['GRASS_DB_ENCODING']
if enc:
@@ -1925,7 +1916,7 @@
whereVal = self.FindWindowById(self.layerPage[self.layer]['where']).GetValue().strip()
try:
if len(whereVal) > 0:
- keyColumn = listWin.LoadData(self.layer, where=whereCol + whereVal)
+ keyColumn = listWin.LoadData(self.layer, where = whereCol + whereVal)
else:
keyColumn = listWin.LoadData(self.layer)
except GException, e:
@@ -1940,18 +1931,17 @@
if cols is None and where is None:
sql = win.GetValue()
except TypeError:
- message=_("Loading attribute data failed.\n"
- "Invalid SQL select statement.\n\n%s") % win.GetValue(),
+ message = _("Loading attribute data failed.\n"
+ "Invalid SQL select statement.\n\n%s") % win.GetValue())
win.SetValue("SELECT * FROM %s" % self.mapDBInfo.layers[self.layer]['table'])
cols = None
where = None
if cols or where or sql:
try:
- keyColumn = listWin.LoadData(self.layer, columns=cols,
- where=where, sql=sql)
+ keyColumn = listWin.LoadData(self.layer, columns = cols,
+ where = where, sql = sql)
message = _("Loading attribute data failed.\n\n%s") % e.value)
@@ -1962,9 +1952,9 @@
pass # don't order by key column
else:
if keyColumn > -1:
- listWin.SortListItems(col=keyColumn, ascending=True)
+ listWin.SortListItems(col = keyColumn, ascending = True)
else:
- listWin.SortListItems(col=0, ascending=True)
+ listWin.SortListItems(col = 0, ascending = True)
wx.EndBusyCursor()
@@ -2059,9 +2049,8 @@
# cats = list.selectedCats[:]
cats = list.GetSelectedItems()
if len(cats) == 0:
- message=_('Nothing to extract.'),
- caption=_('Message'), style=wx.CENTRE)
+ GMessage(parent = self,
+ message = _('Nothing to extract.'))
return
else:
# dialog to get file name
@@ -2090,10 +2079,9 @@
if len(cats) == 0:
- message=_('Nothing to delete.'),
+ message = _('Nothing to delete.'))
display = None
if 'vdigit' in self.mapdisplay.toolbars:
digitToolbar = self.mapdisplay.toolbars['vdigit']
@@ -2101,7 +2089,7 @@
digitToolbar.GetLayer().GetName() == self.vectorName:
display = self.mapdisplay.GetMapWindow().GetDisplay()
display.SetSelected(map(int, cats), layer = self.layer)
if self.OnDataItemDelete(None):
if display:
@@ -2114,7 +2102,7 @@
tool = 'delete',
cats = ListOfCatsToRange(cats))
def AddQueryMapLayer(self):
"""!Redraw a map
@@ -2130,7 +2118,7 @@
self.qlayer = None
if self.qlayer:
- self.qlayer.SetCmd(self.mapdisplay.AddTmpVectorMapLayer(self.vectorName, cats, addLayer=False))
+ self.qlayer.SetCmd(self.mapdisplay.AddTmpVectorMapLayer(self.vectorName, cats, addLayer = False))
else:
self.qlayer = self.mapdisplay.AddTmpVectorMapLayer(self.vectorName, cats)
@@ -2169,7 +2157,7 @@
# update list of layers
self.layerList.Update(self.mapDBInfo.layers)
- self.layerList.Populate(update=True)
+ self.layerList.Populate(update = True)
# update selected widgets
listOfLayers = map(str, self.mapDBInfo.layers.keys())
### delete layer page
@@ -2189,13 +2177,13 @@
maxLayer+1)
### modify layer
self.manageLayerBook.modifyLayerWidgets['layer'][1].SetItems(listOfLayers)
- self.manageLayerBook.OnChangeLayer(event=None)
+ self.manageLayerBook.OnChangeLayer(event = None)
def GetVectorName(self):
"""!Get vector name"""
return self.vectorName
@@ -2214,14 +2202,14 @@
# listmix.TextEditMixin):
"""!Table description list"""
- def __init__(self, parent, id, table, columns, pos=wx.DefaultPosition,
- size=wx.DefaultSize):
+ def __init__(self, parent, id, table, columns, pos = wx.DefaultPosition,
+ size = wx.DefaultSize):
self.parent = parent
self.table = table
self.columns = columns
wx.ListCtrl.__init__(self, parent, id, pos, size,
- style=wx.LC_REPORT | wx.LC_HRULES | wx.LC_VRULES |
+ style = wx.LC_REPORT | wx.LC_HRULES | wx.LC_VRULES |
wx.BORDER_NONE)
listmix.ListCtrlAutoWidthMixin.__init__(self)
@@ -2232,7 +2220,7 @@
self.table = table
- def Populate(self, update=False):
+ def Populate(self, update = False):
"""!Populate the list"""
itemData = {} # requested by sorter
@@ -2240,8 +2228,8 @@
headings = [_("Column name"), _("Data type"), _("Data length")]
i = 0
for h in headings:
- self.InsertColumn(col=i, heading=h)
- self.SetColumnWidth(col=i, width=150)
+ self.InsertColumn(col = i, heading = h)
+ self.SetColumnWidth(col = i, width = 150)
i += 1
else:
self.DeleteAllItems()
@@ -2269,13 +2257,13 @@
"""!Layer description list"""
def __init__(self, parent, id, layers,
- pos=wx.DefaultPosition,
+ pos = wx.DefaultPosition,
self.layers = layers
wx.BORDER_NONE)
@@ -2285,7 +2273,7 @@
"""!Update description"""
@@ -2293,7 +2281,7 @@
headings = [_("Layer"), _("Driver"), _("Database"), _("Table"), _("Key")]
i = 0
for h in headings:
i += 1
else:
@@ -2319,9 +2307,9 @@
i += 1
for i in range(self.GetColumnCount()):
- self.SetColumnWidth(col=i, width=wx.LIST_AUTOSIZE)
- if self.GetColumnWidth(col=i) < 60:
- self.SetColumnWidth(col=i, width=60)
+ self.SetColumnWidth(col = i, width = wx.LIST_AUTOSIZE)
+ if self.GetColumnWidth(col = i) < 60:
+ self.SetColumnWidth(col = i, width = 60)
@@ -2331,8 +2319,8 @@
"""!Manage layers (add, delete, modify)"""
parentDialog,
- style=wx.BK_DEFAULT):
- wx.Notebook.__init__(self, parent, id, style=style)
+ style = wx.BK_DEFAULT):
+ wx.Notebook.__init__(self, parent, id, style = style)
self.parentDialog = parentDialog
@@ -2365,14 +2353,12 @@
if len(self.defaultConnect['driver']) == 0 or \
len(self.defaultConnect['database']) == 0:
- message=_("Unknown default DB connection. "
- "Please define DB connection using db.connect module."),
- caption=_("Warning"),
- style=wx.OK | wx.ICON_WARNING | wx.CENTRE)
+ GWarning(parent = self.parent,
+ message = _("Unknown default DB connection. "
+ "Please define DB connection using db.connect module."))
self.defaultTables = self._getTables(self.defaultConnect['driver'],
- self.defaultConnect['database'])
+ self.defaultConnect['database'])
try:
self.defaultColumns = self._getColumns(self.defaultConnect['driver'],
self.defaultConnect['database'],
@@ -2386,8 +2372,8 @@
def _createAddPage(self):
"""!Add new layer"""
- self.addPanel = wx.Panel(parent=self, id=wx.ID_ANY)
- self.AddPage(page=self.addPanel, text=_("Add layer"))
+ self.addPanel = wx.Panel(parent = self, id = wx.ID_ANY)
+ self.AddPage(page = self.addPanel, text = _("Add layer"))
try:
maxLayer = max(self.mapDBInfo.layers.keys())
@@ -2396,43 +2382,43 @@
# layer description
- layerBox = wx.StaticBox (parent=self.addPanel, id=wx.ID_ANY,
- label=" %s " % (_("Layer description")))
+ layerBox = wx.StaticBox (parent = self.addPanel, id = wx.ID_ANY,
+ label = " %s " % (_("Layer description")))
# list of layer widgets (label, value)
self.addLayerWidgets = {'layer':
- (wx.StaticText(parent=self.addPanel, id=wx.ID_ANY,
- label='%s:' % _("Layer")),
- wx.SpinCtrl(parent=self.addPanel, id=wx.ID_ANY, size=(65, -1),
- initial=maxLayer+1,
- min=1, max=1e6)),
+ (wx.StaticText(parent = self.addPanel, id = wx.ID_ANY,
+ label = '%s:' % _("Layer")),
+ wx.SpinCtrl(parent = self.addPanel, id = wx.ID_ANY, size = (65, -1),
+ initial = maxLayer+1,
+ min = 1, max = 1e6)),
'driver':
- label='%s:' % _("Driver")),
- wx.Choice(parent=self.addPanel, id=wx.ID_ANY, size=(200, -1),
- choices=self.listOfDrivers)),
+ label = '%s:' % _("Driver")),
+ wx.Choice(parent = self.addPanel, id = wx.ID_ANY, size = (200, -1),
+ choices = self.listOfDrivers)),
'database':
- label='%s:' % _("Database")),
- wx.TextCtrl(parent=self.addPanel, id=wx.ID_ANY,
- value='',
- style=wx.TE_PROCESS_ENTER)),
+ label = '%s:' % _("Database")),
+ wx.TextCtrl(parent = self.addPanel, id = wx.ID_ANY,
+ value = '',
+ style = wx.TE_PROCESS_ENTER)),
'table':
- label='%s:' % _("Table")),
- choices=self.defaultTables)),
+ label = '%s:' % _("Table")),
+ choices = self.defaultTables)),
'key':
- label='%s:' % _("Key column")),
- choices=self.defaultColumns)),
+ label = '%s:' % _("Key column")),
+ choices = self.defaultColumns)),
'addCat':
- (wx.CheckBox(parent=self.addPanel, id=wx.ID_ANY,
- label=_("Insert record for each category into table")),
+ (wx.CheckBox(parent = self.addPanel, id = wx.ID_ANY,
+ label = _("Insert record for each category into table")),
None),
@@ -2452,31 +2438,31 @@
# list of table widgets
- keyCol = UserSettings.Get(group='atm', key='keycolumn', subkey='value')
- self.tableWidgets = {'table': (wx.StaticText(parent=self.addPanel, id=wx.ID_ANY,
- label='%s:' % _("Table name")),
- value='',
- 'key': (wx.StaticText(parent=self.addPanel, id=wx.ID_ANY,
- value=keyCol,
- style=wx.TE_PROCESS_ENTER))}
+ keyCol = UserSettings.Get(group = 'atm', key = 'keycolumn', subkey = 'value')
+ self.tableWidgets = {'table': (wx.StaticText(parent = self.addPanel, id = wx.ID_ANY,
+ label = '%s:' % _("Table name")),
+ value = '',
+ 'key': (wx.StaticText(parent = self.addPanel, id = wx.ID_ANY,
+ value = keyCol,
+ style = wx.TE_PROCESS_ENTER))}
# events
self.tableWidgets['table'][1].Bind(wx.EVT_TEXT_ENTER, self.OnCreateTable)
self.tableWidgets['key'][1].Bind(wx.EVT_TEXT_ENTER, self.OnCreateTable)
btnTable = wx.Button(self.addPanel, wx.ID_ANY, _("&Create table"),
- size=(125,-1))
+ size = (125,-1))
btnTable.Bind(wx.EVT_BUTTON, self.OnCreateTable)
btnLayer = wx.Button(self.addPanel, wx.ID_ANY, _("&Add layer"),
- size=(125,-1))
+ size = (125,-1))
btnLayer.Bind(wx.EVT_BUTTON, self.OnAddLayer)
btnDefault = wx.Button(self.addPanel, wx.ID_ANY, _("&Set default"),
- size=(125,-1))
+ size = (125,-1))
btnDefault.Bind(wx.EVT_BUTTON, self.OnSetDefault)
# do layout
@@ -2484,7 +2470,7 @@
pageSizer = wx.BoxSizer(wx.HORIZONTAL)
# data area
- dataSizer = wx.GridBagSizer(hgap=5, vgap=5)
+ dataSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
dataSizer.AddGrowableCol(1)
row = 0
for key in ('layer', 'driver', 'database', 'table', 'key', 'addCat'):
@@ -2493,9 +2479,9 @@
span = (1, 2)
else:
span = (1, 1)
- dataSizer.Add(item=label,
- flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0),
- span=span)
+ dataSizer.Add(item = label,
+ flag = wx.ALIGN_CENTER_VERTICAL, pos = (row, 0),
+ span = span)
if not value:
row += 1
@@ -2506,71 +2492,71 @@
else:
style = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND
- dataSizer.Add(item=value,
- flag=style, pos=(row, 1))
+ dataSizer.Add(item = value,
+ flag = style, pos = (row, 1))
row += 1
- layerSizer.Add(item=dataSizer,
- proportion=1,
- border=5)
+ layerSizer.Add(item = dataSizer,
+ proportion = 1,
+ border = 5)
- btnSizer.Add(item=btnDefault,
- proportion=0,
- flag=wx.ALL | wx.ALIGN_LEFT,
- border=5)
+ btnSizer.Add(item = btnDefault,
+ proportion = 0,
+ flag = wx.ALL | wx.ALIGN_LEFT,
+ border = 5)
- btnSizer.Add(item=(5, 5),
- proportion=1,
- border=5)
+ btnSizer.Add(item = (5, 5),
+ proportion = 1,
+ border = 5)
- btnSizer.Add(item=btnLayer,
- proportion=0,
- border=5)
+ btnSizer.Add(item = btnLayer,
+ proportion = 0,
+ border = 5)
- layerSizer.Add(item=btnSizer,
- proportion=0,
- border=0)
+ layerSizer.Add(item = btnSizer,
+ proportion = 0,
+ border = 0)
# table description
- tableBox = wx.StaticBox (parent=self.addPanel, id=wx.ID_ANY,
- label=" %s " % (_("Table description")))
+ tableBox = wx.StaticBox (parent = self.addPanel, id = wx.ID_ANY,
+ label = " %s " % (_("Table description")))
# data area
- dataSizer = wx.FlexGridSizer(cols=2, hgap=5, vgap=5)
+ dataSizer = wx.FlexGridSizer(cols = 2, hgap = 5, vgap = 5)
for key in ['table', 'key']:
label, value = self.tableWidgets[key]
- tableSizer.Add(item=dataSizer,
- proportion=1,
- border=5)
+ tableSizer.Add(item = dataSizer,
+ proportion = 1,
+ border = 5)
- tableSizer.Add(item=btnTable,
- proportion=0,
- flag=wx.ALL | wx.ALIGN_BOTTOM | wx.ALIGN_RIGHT,
- border=5)
+ tableSizer.Add(item = btnTable,
+ proportion = 0,
+ flag = wx.ALL | wx.ALIGN_BOTTOM | wx.ALIGN_RIGHT,
+ border = 5)
- pageSizer.Add(item=layerSizer,
- proportion=3,
- border=3)
+ pageSizer.Add(item = layerSizer,
+ proportion = 3,
+ border = 3)
- pageSizer.Add(item=tableSizer,
- proportion=2,
- flag=wx.TOP | wx.BOTTOM | wx.RIGHT | wx.EXPAND,
- border=3)
+ pageSizer.Add(item = tableSizer,
+ proportion = 2,
+ flag = wx.TOP | wx.BOTTOM | wx.RIGHT | wx.EXPAND,
+ border = 3)
self.addPanel.SetAutoLayout(True)
self.addPanel.SetSizer(pageSizer)
@@ -2578,15 +2564,15 @@
def _createDeletePage(self):
"""!Delete layer"""
- self.deletePanel = wx.Panel(parent=self, id=wx.ID_ANY)
- self.AddPage(page=self.deletePanel, text=_("Remove layer"))
+ self.deletePanel = wx.Panel(parent = self, id = wx.ID_ANY)
+ self.AddPage(page = self.deletePanel, text = _("Remove layer"))
- label = wx.StaticText(parent=self.deletePanel, id=wx.ID_ANY,
- label='%s:' % _("Layer to remove"))
+ label = wx.StaticText(parent = self.deletePanel, id = wx.ID_ANY,
+ label = '%s:' % _("Layer to remove"))
- self.deleteLayer = wx.ComboBox(parent=self.deletePanel, id=wx.ID_ANY, size=(100, -1),
- style=wx.CB_SIMPLE | wx.CB_READONLY,
- choices=map(str, self.mapDBInfo.layers.keys()))
+ self.deleteLayer = wx.ComboBox(parent = self.deletePanel, id = wx.ID_ANY, size = (100, -1),
+ style = wx.CB_SIMPLE | wx.CB_READONLY,
+ choices = map(str, self.mapDBInfo.layers.keys()))
self.deleteLayer.SetSelection(0)
self.deleteLayer.Bind(wx.EVT_COMBOBOX, self.OnChangeLayer)
@@ -2595,8 +2581,8 @@
except ValueError:
tableName = ''
- self.deleteTable = wx.CheckBox(parent=self.deletePanel, id=wx.ID_ANY,
- label=_('Drop also linked attribute table (%s)') % \
+ self.deleteTable = wx.CheckBox(parent = self.deletePanel, id = wx.ID_ANY,
+ label = _('Drop also linked attribute table (%s)') % \
tableName)
if tableName == '':
@@ -2604,7 +2590,7 @@
self.deleteTable.Enable(False)
btnDelete = wx.Button(self.deletePanel, wx.ID_DELETE, _("&Remove layer"),
- size=(125,-1))
+ size = (125,-1))
btnDelete.Bind(wx.EVT_BUTTON, self.OnDeleteLayer)
@@ -2614,76 +2600,76 @@
dataSizer = wx.BoxSizer(wx.VERTICAL)
- flexSizer = wx.FlexGridSizer(cols=2, hgap=5, vgap=5)
+ flexSizer = wx.FlexGridSizer(cols = 2, hgap = 5, vgap = 5)
flexSizer.AddGrowableCol(2)
- flexSizer.Add(item=label,
- flexSizer.Add(item=self.deleteLayer,
+ flexSizer.Add(item = label,
+ flexSizer.Add(item = self.deleteLayer,
- dataSizer.Add(item=flexSizer,
- proportion=0,
- border=1)
+ dataSizer.Add(item = flexSizer,
+ proportion = 0,
+ border = 1)
- dataSizer.Add(item=self.deleteTable,
- proportion=0,
- border=1)
+ dataSizer.Add(item = self.deleteTable,
+ proportion = 0,
+ border = 1)
- pageSizer.Add(item=dataSizer,
- proportion=1,
- border=5)
+ pageSizer.Add(item = dataSizer,
+ proportion = 1,
+ border = 5)
- pageSizer.Add(item=btnDelete,
- proportion=0,
- border=5)
+ pageSizer.Add(item = btnDelete,
+ proportion = 0,
+ border = 5)
self.deletePanel.SetSizer(pageSizer)
def _createModifyPage(self):
"""!Modify layer"""
- self.modifyPanel = wx.Panel(parent=self, id=wx.ID_ANY)
- self.AddPage(page=self.modifyPanel, text=_("Modify layer"))
+ self.modifyPanel = wx.Panel(parent = self, id = wx.ID_ANY)
+ self.AddPage(page = self.modifyPanel, text = _("Modify layer"))
self.modifyLayerWidgets = {'layer':
- (wx.StaticText(parent=self.modifyPanel, id=wx.ID_ANY,
- wx.ComboBox(parent=self.modifyPanel, id=wx.ID_ANY,
- size=(100, -1),
- choices=map(str,
+ (wx.StaticText(parent = self.modifyPanel, id = wx.ID_ANY,
+ wx.ComboBox(parent = self.modifyPanel, id = wx.ID_ANY,
+ size = (100, -1),
self.mapDBInfo.layers.keys()))),
'driver':
- wx.Choice(parent=self.modifyPanel, id=wx.ID_ANY,
- size=(200, -1),
+ wx.Choice(parent = self.modifyPanel, id = wx.ID_ANY,
+ size = (200, -1),
'database':
- wx.TextCtrl(parent=self.modifyPanel, id=wx.ID_ANY,
- value='', size=(350, -1),
+ wx.TextCtrl(parent = self.modifyPanel, id = wx.ID_ANY,
+ value = '', size = (350, -1),
'table':
- size=(200, -1),
+ size = (200, -1),
'key':
- size=(200, -1),
- choices=self.defaultColumns))}
+ size = (200, -1),
+ choices = self.defaultColumns))}
# set default values for widgets
self.modifyLayerWidgets['layer'][1].SetSelection(0)
@@ -2720,7 +2706,7 @@
# self.modifyLayerWidgets['table'][1].Bind(wx.EVT_CHOICE, self.OnTableChanged)
btnModify = wx.Button(self.modifyPanel, wx.ID_DELETE, _("&Modify layer"),
- size=(125,-1))
+ size = (125,-1))
btnModify.Bind(wx.EVT_BUTTON, self.OnModifyLayer)
@@ -2729,28 +2715,28 @@
# data area
for key in ('layer', 'driver', 'database', 'table', 'key'):
label, value = self.modifyLayerWidgets[key]
if label.GetLabel() == "Layer:":
- flag=wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT)
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_LEFT)
else:
- proportion=1,
- border=5)
+ proportion = 1,
+ border = 5)
- pageSizer.Add(item=btnModify,
- proportion=0,
- border=5)
+ pageSizer.Add(item = btnModify,
+ proportion = 0,
+ border = 5)
self.modifyPanel.SetSizer(pageSizer)
@@ -2766,10 +2752,9 @@
database = database)
if ret is None:
- message=_("Unable to get list of tables.\n"
- "Please use db.connect to set database parameters."),
+ message = _("Unable to get list of tables.\n"
+ "Please use db.connect to set database parameters."))
return tables
@@ -2864,17 +2849,15 @@
key = self.tableWidgets['key'][1].GetValue()
if not table or not key:
- message=_("Unable to create new table. "
- "Table name or key column name is missing."),
+ message = _("Unable to create new table. "
+ "Table name or key column name is missing."))
return
if table in self.addLayerWidgets['table'][1].GetItems():
- "Table <%s> already exists in the database.") % table,
+ "Table <%s> already exists in the database.") % table)
return
# create table
@@ -2910,11 +2893,10 @@
key = self.addLayerWidgets['key'][1].GetStringSelection()
if layer in self.mapDBInfo.layers.keys():
- message=_("Unable to add new layer to vector map <%(vector)s>. "
- "Layer %(layer)d already exists.") %
- {'vector' : self.mapDBInfo.map, 'layer' : layer},
+ message = _("Unable to add new layer to vector map <%(vector)s>. "
+ "Layer %(layer)d already exists.") % \
+ {'vector' : self.mapDBInfo.map, 'layer' : layer})
return
# add new layer
@@ -2941,7 +2923,7 @@
if ret == 0:
# update dialog (only for new layer)
- self.parentDialog.UpdateDialog(layer=layer)
+ self.parentDialog.UpdateDialog(layer = layer)
# update db info
self.mapDBInfo = self.parentDialog.mapDBInfo
# increase layer number
@@ -2987,7 +2969,7 @@
tableList.SetStringSelection(table)
# update dialog
# update db info
@@ -3062,7 +3044,7 @@
layer = int(layer))
# update db info
@@ -3070,7 +3052,7 @@
def main(argv = None):
import gettext
- gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
+ gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
if argv is None:
argv = sys.argv
@@ -3083,10 +3065,10 @@
wx.InitAllImageHandlers()
app = wx.PySimpleApp()
- f = AttributeManager(parent=None, id=wx.ID_ANY,
- title="%s - <%s>" % (_("GRASS GIS Attribute Table Manager"),
+ f = AttributeManager(parent = None, id = wx.ID_ANY,
+ title = "%s - <%s>" % (_("GRASS GIS Attribute Table Manager"),
argv[1]),
- size=(900,600), vectorName=argv[1])
+ size = (900,600), vectorName = argv[1])
f.Show()
app.MainLoop()
