[GRASS-SVN] r49992 - grass/trunk/gui/wxpython/dbmgr
svn_grass at osgeo.org
Fri Dec 30 12:49:00 EST 2011
Author: martinl
Date: 2011-12-30 09:49:00 -0800 (Fri, 30 Dec 2011)
New Revision: 49992
grass/trunk/gui/wxpython/dbmgr/manager.py
wxGUI/dbmbr: don't use reserved words as variables (list -> tlist)
(merge r49991 from devbr6)
Modified: grass/trunk/gui/wxpython/dbmgr/manager.py
--- grass/trunk/gui/wxpython/dbmgr/manager.py 2011-12-30 17:46:56 UTC (rev 49991)
+++ grass/trunk/gui/wxpython/dbmgr/manager.py 2011-12-30 17:49:00 UTC (rev 49992)
@@ -863,10 +863,10 @@
tableSizer = wx.StaticBoxSizer(tableBox, wx.VERTICAL)
- list = self._createTableDesc(panel, table)
- list.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnTableRightUp) #wxMSW
- list.Bind(wx.EVT_RIGHT_UP, self.OnTableRightUp) #wxGTK
- self.layerPage[layer]['tableData'] = list.GetId()
+ tlist = self._createTableDesc(panel, table)
+ tlist.Bind(wx.EVT_COMMAND_RIGHT_CLICK, self.OnTableRightUp) #wxMSW
+ tlist.Bind(wx.EVT_RIGHT_UP, self.OnTableRightUp) #wxGTK
+ self.layerPage[layer]['tableData'] = tlist.GetId()
# manage columns (add)
addBox = wx.StaticBox(parent = panel, id = wx.ID_ANY,
@@ -955,7 +955,7 @@
renameSizer.Add(item = btnRenameCol, flag = wx.ALL | wx.ALIGN_RIGHT | wx.EXPAND,
border = 3)
- tableSizer.Add(item = list,
+ tableSizer.Add(item = tlist,
flag = wx.ALL | wx.EXPAND,
proportion = 1,
border = 3)
@@ -989,15 +989,15 @@
def _createTableDesc(self, parent, table):
"""!Create list with table description"""
- list = TableListCtrl(parent = parent, id = wx.ID_ANY,
+ tlist = TableListCtrl(parent = parent, id = wx.ID_ANY,
table = self.mapDBInfo.tables[table],
columns = self.mapDBInfo.GetColumns(table))
- list.Populate()
+ tlist.Populate()
# sorter
# itemDataMap = list.Populate()
# listmix.ColumnSorterMixin.__init__(self, 2)
- return list
+ return tlist
def _createManageLayerPage(self):
"""!Create manage page"""
@@ -1057,15 +1057,15 @@
def _createLayerDesc(self, parent):
"""!Create list of linked layers"""
- list = LayerListCtrl(parent = parent, id = wx.ID_ANY,
+ tlist = LayerListCtrl(parent = parent, id = wx.ID_ANY,
layers = self.mapDBInfo.layers)
- list.Populate()
+ tlist.Populate()
# sorter
- return list
+ return tlist
def _layout(self):
"""!Do layout"""
@@ -1114,12 +1114,12 @@
self.Bind(wx.EVT_MENU, self.OnDeleteSelected, id = self.popupDataID11)
self.Bind(wx.EVT_MENU, self.OnDataReload, id = self.popupDataID10)
- list = self.FindWindowById(self.layerPage[self.layer]['data'])
+ tlist = self.FindWindowById(self.layerPage[self.layer]['data'])
# generate popup-menu
menu = wx.Menu()
menu.Append(self.popupDataID1, _("Edit selected record"))
- selected = list.GetFirstSelected()
- if not self.editable or selected == -1 or list.GetNextSelected(selected) != -1:
+ selected = tlist.GetFirstSelected()
+ if not self.editable or selected == -1 or tlist.GetNextSelected(selected) != -1:
menu.Enable(self.popupDataID1, False)
menu.Append(self.popupDataID2, _("Insert new record"))
menu.Append(self.popupDataID3, _("Delete selected record(s)"))
@@ -1134,14 +1134,14 @@
menu.AppendSeparator()
menu.Append(self.popupDataID7, _("Highlight selected features"))
menu.Append(self.popupDataID8, _("Highlight selected features and zoom"))
- if not self.map or len(list.GetSelectedItems()) == 0:
+ if not self.map or len(tlist.GetSelectedItems()) == 0:
menu.Enable(self.popupDataID7, False)
menu.Enable(self.popupDataID8, False)
menu.Append(self.popupDataID9, _("Extract selected features"))
menu.Append(self.popupDataID11, _("Delete selected features"))
if not self.editable:
menu.Enable(self.popupDataID11, False)
- if list.GetFirstSelected() == -1:
+ if tlist.GetFirstSelected() == -1:
menu.Enable(self.popupDataID3, False)
menu.Enable(self.popupDataID9, False)
@@ -1153,10 +1153,10 @@
# update statusbar
self.log.write(_("Number of loaded records: %d") % \
- list.GetItemCount())
+ tlist.GetItemCount())
def OnDataItemDelete(self, event):
- """!Delete selected item(s) from the list (layer/category pair)"""
+ """!Delete selected item(s) from the tlist (layer/category pair)"""
dlist = self.FindWindowById(self.layerPage[self.layer]['data'])
item = dlist.GetFirstSelected()
@@ -1249,8 +1249,8 @@
if not self.map or not self.mapdisplay:
return
- cats = map(int, list.GetSelectedItems())
+ cats = map(int, tlist.GetSelectedItems())
digitToolbar = None
if 'vdigit' in self.mapdisplay.toolbars:
@@ -1322,7 +1322,7 @@
def OnDataItemAdd(self, event):
"""!Add new record to the attribute table"""
table = self.mapDBInfo.layers[self.layer]['table']
keyColumn = self.mapDBInfo.layers[self.layer]['key']
@@ -1331,12 +1331,12 @@
# collect names of all visible columns
columnName = []
- for i in range(list.GetColumnCount()):
- columnName.append(list.GetColumn(i).GetText())
+ for i in range(tlist.GetColumnCount()):
+ columnName.append(tlist.GetColumn(i).GetText())
# maximal category number
- if len(list.itemCatsMap.values()) > 0:
- maxCat = max(list.itemCatsMap.values())
+ if len(tlist.itemCatsMap.values()) > 0:
+ maxCat = max(tlist.itemCatsMap.values())
else:
maxCat = 0 # starting category '1'
@@ -1373,7 +1373,7 @@
cat = -1
try:
- if cat in list.itemCatsMap.values():
+ if cat in tlist.itemCatsMap.values():
raise ValueError(_("Record with category number %d "
"already exists in the table.") % cat)
@@ -1390,19 +1390,19 @@
continue
try:
- if list.columns[columnName[i]]['ctype'] == int:
+ if tlist.columns[columnName[i]]['ctype'] == int:
# values[i] is stored as text.
value = float(values[i])
else:
value = values[i]
- values[i] = list.columns[columnName[i]]['ctype'] (value)
+ values[i] = tlist.columns[columnName[i]]['ctype'] (value)
except:
raise ValueError(_("Value '%(value)s' needs to be entered as %(type)s.") %
{'value' : str(values[i]),
- 'type' : list.columns[columnName[i]]['type']})
+ 'type' : tlist.columns[columnName[i]]['type']})
columnsString += '%s,' % columnName[i]
- if list.columns[columnName[i]]['ctype'] == str:
+ if tlist.columns[columnName[i]]['ctype'] == str:
valuesString += "'%s'," % values[i]
else:
valuesString += "%s," % values[i]
@@ -1417,16 +1417,16 @@
if missingKey is True:
del values[0]
- # add new item to the list
- if len(list.itemIndexMap) > 0:
- index = max(list.itemIndexMap) + 1
+ # add new item to the tlist
+ if len(tlist.itemIndexMap) > 0:
+ index = max(tlist.itemIndexMap) + 1
else:
index = 0
- list.itemIndexMap.append(index)
- list.itemDataMap[index] = values
- list.itemCatsMap[index] = cat
- list.SetItemCount(list.GetItemCount() + 1)
+ tlist.itemIndexMap.append(index)
+ tlist.itemDataMap[index] = values
+ tlist.itemCatsMap[index] = cat
+ tlist.SetItemCount(tlist.GetItemCount() + 1)
self.listOfSQLStatements.append('INSERT INTO %s (%s) VALUES(%s)' % \
(table,
@@ -1436,22 +1436,22 @@
def OnDataItemEdit(self, event):
"""!Edit selected record of the attribute table"""
- item = list.GetFirstSelected()
+ item = tlist.GetFirstSelected()
if item == -1:
return
- cat = list.itemCatsMap[list.itemIndexMap[item]]
+ cat = tlist.itemCatsMap[tlist.itemIndexMap[item]]
# (column name, value)
data = []
columnName = []
# key column must be always presented
@@ -1472,9 +1472,9 @@
keyId = i
else:
- value = list.GetItem(item, i-1).GetText()
+ value = tlist.GetItem(item, i-1).GetText()
else:
- value = list.GetItem(item, i).GetText()
+ value = tlist.GetItem(item, i).GetText()
data.append((columnName[i], ctype, value))
dlg = ModifyTableRecord(parent = self,
@@ -1488,28 +1488,28 @@
for i in range(len(values)):
if i == keyId: # skip key column
continue
- if list.GetItem(item, i).GetText() != values[i]:
+ if tlist.GetItem(item, i).GetText() != values[i]:
if len(values[i]) > 0:
try:
idx = i - 1
else:
idx = i
- if list.columns[columnName[i]]['ctype'] != type(''):
+ if tlist.columns[columnName[i]]['ctype'] != type(''):
else:
value = values[i]
- list.itemDataMap[item][idx] = \
- list.columns[columnName[i]]['ctype'] (value)
+ tlist.itemDataMap[item][idx] = \
+ tlist.columns[columnName[i]]['ctype'] (value)
else:
- list.itemDataMap[item][idx] = values[i]
+ tlist.itemDataMap[item][idx] = values[i]
except:
raise ValueError(_("Value '%(value)s' needs to be entered as %(type)s.") % \
updateString += "%s='%s'," % (columnName[i], values[i])
else:
updateString += "%s=%s," % (columnName[i], values[i])
@@ -1528,36 +1528,36 @@
keyColumn, cat))
self.ApplyCommands()
- list.Update(self.mapDBInfo)
+ tlist.Update(self.mapDBInfo)
def OnDataReload(self, event):
- """!Reload list of records"""
+ """!Reload tlist of records"""
self.OnApplySqlStatement(None)
self.listOfSQLStatements = []
def OnDataSelectAll(self, event):
"""!Select all items"""
item = -1
while True:
- item = list.GetNextItem(item)
+ item = tlist.GetNextItem(item)
if item == -1:
break
- list.SetItemState(item, wx.LIST_STATE_SELECTED, wx.LIST_STATE_SELECTED)
+ tlist.SetItemState(item, wx.LIST_STATE_SELECTED, wx.LIST_STATE_SELECTED)
event.Skip()
def OnDataSelectNone(self, event):
"""!Deselect items"""
item = -1
while True:
- item = list.GetNextItem(item, wx.LIST_STATE_SELECTED)
+ item = tlist.GetNextItem(item, wx.LIST_STATE_SELECTED)
if item == -1:
break
- list.SetItemState(item, 0, wx.LIST_STATE_SELECTED | wx.LIST_STATE_FOCUSED)
+ tlist.SetItemState(item, 0, wx.LIST_STATE_SELECTED | wx.LIST_STATE_FOCUSED)
event.Skip()
@@ -1595,7 +1595,7 @@
def OnTableItemChange(self, event):
"""!Rename column in the table"""
- list = self.FindWindowById(self.layerPage[self.layer]['tableData'])
+ tlist = self.FindWindowById(self.layerPage[self.layer]['tableData'])
name = self.FindWindowById(self.layerPage[self.layer]['renameCol']).GetValue()
nameTo = self.FindWindowById(self.layerPage[self.layer]['renameColTo']).GetValue()
@@ -1607,9 +1607,9 @@
"No column name defined."))
return
else:
- item = list.FindItem(start = -1, str = name)
+ item = tlist.FindItem(start = -1, str = name)
if item > -1:
- if list.FindItem(start = -1, str = nameTo) > -1:
+ if tlist.FindItem(start = -1, str = nameTo) > -1:
GError(parent = self,
message = _("Unable to rename column <%(column)s> to "
"<%(columnTo)s>. Column already exists "
@@ -1618,7 +1618,7 @@
'table' : table})
return
else:
- list.SetItemText(item, nameTo)
+ tlist.SetItemText(item, nameTo)
self.listOfCommands.append(('v.db.renamecolumn',
{ 'map' : self.vectorName,
@@ -1666,15 +1666,15 @@
def OnTableItemDelete(self, event):
"""!Delete selected item(s) from the list"""
if UserSettings.Get(group = 'atm', key = 'askOnDeleteRec', subkey = 'enabled'):
deleteDialog = wx.MessageBox(parent = self,
message = _("Selected column '%s' will PERMANENTLY removed "
"from table. Do you want to drop the column?") % \
- (list.GetItemText(item)),
+ (tlist.GetItemText(item)),
caption = _("Drop column(s)"),
style = wx.YES_NO | wx.CENTRE)
if deleteDialog != wx.YES:
@@ -1684,10 +1684,10 @@
self.listOfCommands.append(('v.db.dropcolumn',
'layer' : self.layer,
- 'column' : list.GetItemText(item) }
+ 'column' : tlist.GetItemText(item) }
- list.DeleteItem(item)
+ tlist.DeleteItem(item)
# apply changes
@@ -1871,14 +1871,14 @@
# update table description
- list.Update(table = self.mapDBInfo.tables[table],
+ tlist.Update(table = self.mapDBInfo.tables[table],
self.OnTableReload(None)
- # update data list
+ # update data tlist
# reset list of commands
self.listOfCommands = []
@@ -2060,9 +2060,9 @@
"""!Extract vector objects selected in attribute browse window
to new vector map
- # cats = list.selectedCats[:]
- cats = list.GetSelectedItems()
+ # cats = tlist.selectedCats[:]
+ cats = tlist.GetSelectedItems()
if len(cats) == 0:
GMessage(parent = self,
message = _('Nothing to extract.'))
@@ -2091,8 +2091,8 @@
"""!Delete vector objects selected in attribute browse window
(attribures and geometry)
if len(cats) == 0:
message = _('Nothing to delete.'))
@@ -2124,9 +2124,9 @@
Return True if map has been redrawn, False if no map is given
cats = {
- self.layer : list.GetSelectedItems()
+ self.layer : tlist.GetSelectedItems()
if self.mapdisplay.Map.GetLayerIndex(self.qlayer) < 0:
