[GRASS-SVN] r49999 - grass/trunk/vector/v.proj
svn_grass at osgeo.org
Sat Dec 31 08:05:38 EST 2011
Author: mmetz
Date: 2011-12-31 05:05:38 -0800 (Sat, 31 Dec 2011)
New Revision: 49999
grass/trunk/vector/v.proj/main.c
grass/trunk/vector/v.proj/v.proj.html
v.proj: add option to wrap eastings to 0,360 for latlon
Modified: grass/trunk/vector/v.proj/main.c
--- grass/trunk/vector/v.proj/main.c 2011-12-31 12:58:14 UTC (rev 49998)
+++ grass/trunk/vector/v.proj/main.c 2011-12-31 13:05:38 UTC (rev 49999)
@@ -51,10 +51,13 @@
struct line_cats *Cats;
struct Map_info Map;
struct Map_info Out_Map;
+ struct bound_box src_box, tgt_box;
+ int wrap360 = 0, recommend_wrap = 0;
struct
struct Flag *list; /* list files in source location */
struct Flag *transformz; /* treat z as ellipsoidal height */
+ struct Flag *wrap; /* latlon output: wrap to 0,360 */
} flag;
G_gisinit(argv[0]);
@@ -114,6 +117,13 @@
"transform if possible");
flag.transformz->guisection = _("Target");
+ flag.wrap = G_define_flag();
+ flag.wrap->key = 'w';
+ flag.wrap->description = _("Latlon output only, default is -180,180");
+ flag.wrap->label =
+ _("Wrap to 0,360 for latlon output");
+ flag.transformz->guisection = _("Target");
/* The parser checks if the map already exists in current mapset,
we switch out the check and do it
in the module after the parser */
@@ -150,6 +160,10 @@
if (!ibaseopt->answer && strcmp(iloc_name, G_location()) == 0)
G_fatal_error(_("Input and output locations can not be the same"));
+ Out_proj = G_projection();
+ if (Out_proj == PROJECTION_LL && flag.wrap->answer)
+ wrap360 = 1;
/* Change the location here and then come back */
select_target_env();
@@ -221,7 +235,6 @@
select_current_env();
/****** get the output projection parameters ******/
- Out_proj = G_projection();
out_proj_keys = G_get_projinfo();
if (out_proj_keys == NULL)
exit(EXIT_FAILURE);
@@ -242,6 +255,108 @@
pj_print_proj_params(&info_in, &info_out);
+ /* Initialize the Point / Cat structure */
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
+ /* test if latlon wrapping to 0,360 would be needed */
+ if (Out_proj == PROJECTION_LL && wrap360 == 0) {
+ int first = 1, counter = 0;
+ double x, y;
+ /* Cycle through all lines */
+ Vect_rewind(&Map);
+ while (1) {
+ type = Vect_read_next_line(&Map, Points, Cats); /* read line */
+ if (type == 0)
+ continue; /* Dead */
+ if (type == -1)
+ G_fatal_error(_("Reading input vector map"));
+ if (type == -2)
+ break;
+ if (first && Points->n_points > 0) {
+ first = 0;
+ src_box.E = src_box.W = Points->x[0];
+ src_box.N = src_box.S = Points->y[0];
+ src_box.T = src_box.B = Points->z[0];
+ for (i = 0; i < Points->n_points; i++) {
+ if (src_box.E < Points->x[i])
+ src_box.E = Points->x[i];
+ if (src_box.W > Points->x[i])
+ src_box.W = Points->x[i];
+ if (src_box.N < Points->y[i])
+ src_box.N = Points->y[i];
+ if (src_box.S > Points->y[i])
+ src_box.S = Points->y[i];
+ counter++;
+ if (counter == 0) {
+ G_warning(_("Input vector map <%s> is empty"), omap_name);
+ exit(EXIT_SUCCESS);
+ /* NW corner */
+ x = src_box.W;
+ y = src_box.N;
+ if (pj_do_transform(1, &x, &y, NULL,
+ &info_in, &info_out) < 0) {
+ G_fatal_error(_("Error in pj_do_transform"));
+ tgt_box.E = x;
+ tgt_box.W = x;
+ tgt_box.N = y;
+ tgt_box.S = y;
+ /* SW corner */
+ x = src_box.W;
+ y = src_box.S;
+ if (tgt_box.W > x)
+ tgt_box.W = x;
+ if (tgt_box.E < x)
+ tgt_box.E = x;
+ if (tgt_box.N < y)
+ tgt_box.N = y;
+ if (tgt_box.S > y)
+ tgt_box.S = y;
+ /* NE corner */
+ x = src_box.E;
+ y = src_box.N;
+ if (tgt_box.W > x) {
+ tgt_box.E = x + 360;
+ recommend_wrap = 1;
+ tgt_box.N = y;
+ tgt_box.S = y;
+ /* SE corner */
+ x = src_box.E;
+ y = src_box.S;
+ if (tgt_box.E < x + 360)
+ tgt_box.N = y;
+ tgt_box.S = y;
G_debug(1, "Open new: location: %s mapset : %s", G__location_path(),
G_mapset());
Vect_open_new(&Out_Map, omap_name, Vect_is_3d(&Map));
@@ -263,10 +378,6 @@
sprintf(date, "%s %d %d", mon, day, yr);
Vect_set_date(&Out_Map, date);
- /* Initialize the Point / Cat structure */
- Points = Vect_new_line_struct();
- Cats = Vect_new_cats_struct();
Vect_rewind(&Map);
i = 0;
@@ -289,7 +400,17 @@
+ if (wrap360) {
+ int j;
+ for (j = 0; j < Points->n_points; j++) {
+ /* use tgt_box.W instead of 0 ? */
+ if (Points->x[j] < 0)
+ Points->x[j] += 360.;
Vect_write_line(&Out_Map, type, Points, Cats); /* write line */
} /* end lines section */
fprintf(stderr, "\r");
@@ -303,5 +424,8 @@
Vect_build(&Out_Map);
Vect_close(&Out_Map);
+ if (recommend_wrap)
+ G_important_message(_("Wrapping to 0,360 recommended."));
exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.proj/v.proj.html
--- grass/trunk/vector/v.proj/v.proj.html 2011-12-31 12:58:14 UTC (rev 49998)
+++ grass/trunk/vector/v.proj/v.proj.html 2011-12-31 13:05:38 UTC (rev 49999)
@@ -23,6 +23,12 @@
<p><em>v.proj</em> supports general datum transformations, making use of the
<em>PROJ.4</em> co-ordinate system translation library.
+<p>When projecting into a latlon location, east coordinates are wrapped
+by the proj4 library to fit into the range -180,180. This is in most cases
+appropriate, but can cause errors the input vector crosses the datum line
+at 180E/W. In this case the east coordinates need to be wrapped to the
+range 0,360 after transformation. Wrapping of eastings to the range 0,360
+is activated with the <b>-w</b> flag.
<h2>EXAMPLES</h2>
