[GRASS-SVN] r50018 - in grass/trunk/raster/r.series.interpol: . test
svn_grass at osgeo.org
Sat Dec 31 18:20:29 EST 2011
Author: huhabla
Date: 2011-12-31 15:20:29 -0800 (Sat, 31 Dec 2011)
New Revision: 50018
Added:
grass/trunk/raster/r.series.interpol/test/infile_2.txt
grass/trunk/raster/r.series.interpol/test/outfile_1.txt
grass/trunk/raster/r.series.interpol/test/outfile_2.txt
grass/trunk/raster/r.series.interpol/test/outfile_corrupt.txt
grass/trunk/raster/r.series.interpol/test/test_2_map_12.ref
grass/trunk/raster/r.series.interpol/test/test_2_map_14.ref
grass/trunk/raster/r.series.interpol/test/test_2_map_16.ref
grass/trunk/raster/r.series.interpol/test/test_2_map_18.ref
grass/trunk/raster/r.series.interpol/test/test_2_map_25.ref
grass/trunk/raster/r.series.interpol/test/test_2_map_35.ref
grass/trunk/raster/r.series.interpol/main.c
grass/trunk/raster/r.series.interpol/r.series.interpol.html
grass/trunk/raster/r.series.interpol/test/test.r.series.interpol.sh
Implemented multiple linear interpolation
Modified: grass/trunk/raster/r.series.interpol/main.c
--- grass/trunk/raster/r.series.interpol/main.c 2011-12-31 17:47:30 UTC (rev 50017)
+++ grass/trunk/raster/r.series.interpol/main.c 2011-12-31 23:20:29 UTC (rev 50018)
@@ -9,7 +9,7 @@
* COPYRIGHT: (C) 2011-2012 by the GRASS Development Team
* This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
+ * License (>=v2). Read the infile COPYING that comes with GRASS
* for details.
@@ -24,8 +24,7 @@
#include <grass/stats.h>
#define LINEAR_INTERPOLATION 1
-#define QUADRATIC_INTERPOLATION 2
-#define CUBIC_INTERPOLATION 3
+#define SPLINE_INTERPOLATION 2
struct map_store
@@ -33,26 +32,28 @@
double pos;
DCELL *buf;
int fd;
+ int has_run;
-double linear_position[2] = {0.0, 1.0};
-double quadratic_position[3] = {0.0, 0.5, 1.0};
-double cubic_position[4] = {0.0, 1.0/3.0, 2.0/3.0, 1.0};
+void selection_sort(struct map_store **array, int num);
+static struct map_store *get_parameter_input(const char *type, char **map_names, char **positions, char *file, int *number_of_maps);
+static void linear_interpolation(struct map_store **inp, int num_inputs, struct map_store **outp, int num_outputs);
+static void interpolate_row_linear(struct map_store *left, struct map_store *right, struct map_store *out, int ncols);
+static void start_interpolation(struct map_store *inputs, int num_inputs, struct map_store *outputs, int num_outputs, int interpol_method);
-static void linear_interpolation(struct map_store *inputs, struct map_store *out, int ncols);
-static int start_interpolation(struct map_store *inputs, int num_inputs, int interpolation_method, struct map_store *out);
int main(int argc, char *argv[])
struct GModule *module;
struct
- struct Option *input, *file, *output, *sampoints, *method;
+ struct Option *input, *datapos, *infile, *output, *samplingpos, *outfile, *method;
} parm;
- int i;
int num_outputs;
int num_inputs;
- int num_sampoints;
struct map_store *inputs = NULL;
struct map_store *outputs = NULL;
int interpol_method = LINEAR_INTERPOLATION;
@@ -68,24 +69,36 @@
"in between input raster maps at specific sampling positions.");
parm.input = G_define_standard_option(G_OPT_R_INPUTS);
+ parm.input->required = NO;
+ parm.datapos = G_define_option();
+ parm.datapos->key = "datapos";
+ parm.datapos->type = TYPE_DOUBLE;
+ parm.datapos->required = NO;
+ parm.datapos->description = _("Data point position for each input map");
+ parm.datapos->multiple = YES;
+ parm.infile = G_define_standard_option(G_OPT_F_INPUT);
+ parm.infile->key = "infile";
+ parm.infile->description = _("Input file with an input raster map name and data point position per line,"
+ " field separator between name and sample point is |");
+ parm.infile->required = NO;
parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
parm.output->multiple = YES;
parm.output->required = NO;
- parm.sampoints = G_define_option();
- parm.sampoints->key = "sampoints";
- parm.sampoints->type = TYPE_DOUBLE;
- parm.sampoints->required = NO;
- parm.sampoints->description = _("Sampling point for each input map,"
- " the point must in between the interval (0;1)");
- parm.sampoints->multiple = YES;
+ parm.samplingpos = G_define_option();
+ parm.samplingpos->key = "samplingpos";
+ parm.samplingpos->type = TYPE_DOUBLE;
+ parm.samplingpos->required = NO;
+ parm.samplingpos->description = _("Sampling point position for each output map");
- parm.file = G_define_standard_option(G_OPT_F_INPUT);
- parm.file->key = "file";
- parm.file->description = _("Input file with output a raster map name and sample point per line,"
- " field separator between name and sample point is |");
- parm.file->required = NO;
+ parm.outfile = G_define_standard_option(G_OPT_F_INPUT);
+ parm.outfile->key = "outfile";
+ parm.outfile->description = _("Input infile with an output raster map name and sample point position per line,"
+ parm.outfile->required = NO;
parm.method = G_define_option();
parm.method->key = "method";
@@ -99,80 +112,65 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- if (parm.output->answer && parm.file->answer)
- G_fatal_error(_("output= and file= are mutually exclusive"));
+ if (parm.output->answer && parm.outfile->answer)
+ G_fatal_error(_("output= and outfile= are mutually exclusive"));
- if (parm.sampoints->answer && parm.file->answer)
- G_fatal_error(_("sampoints= and file= are mutually exclusive"));
+ if (parm.samplingpos->answer && parm.outfile->answer)
+ G_fatal_error(_("samplingpos= and outfile= are mutually exclusive"));
+ if (!parm.output->answer && !parm.outfile->answer)
+ G_fatal_error(_("Please specify output= or outfile="));
+ if (parm.output->answer && !parm.samplingpos->answer)
+ G_fatal_error(_("Please specify output= and samplingpos="));
- if (!parm.output->answer && !parm.file->answer)
- G_fatal_error(_("Please specify output= or file="));
+ if (parm.input->answer && parm.infile->answer)
+ G_fatal_error(_("input= and infile= are mutually exclusive"));
- if (parm.output->answer && !parm.sampoints->answer)
- G_fatal_error(_("Please specify output= and sampoints="));
+ if (parm.datapos->answer && parm.infile->answer)
+ G_fatal_error(_("datapos= and infile= are mutually exclusive"));
+ if (!parm.input->answer && !parm.infile->answer)
+ G_fatal_error(_("Please specify input= or infile="));
+ if (parm.input->answer && !parm.datapos->answer)
+ G_fatal_error(_("Please specify input= and datapos="));
- if(G_strncasecmp(parm.method->answer, "linear", 6))
+ if(G_strncasecmp(parm.method->answer, "linear", 6) == 0)
- /* process the input maps */
- for (i = 0; parm.input->answers[i]; i++)
- num_inputs = i;
+ if(G_strncasecmp(parm.method->answer, "spline", 6) == 0)
+ interpol_method = SPLINE_INTERPOLATION;
- if (num_inputs < 1)
- G_fatal_error(_("No input raster map not found"));
+ inputs = get_parameter_input("input", parm.input->answers, parm.datapos->answers, parm.infile->answer, &num_inputs);
+ outputs = get_parameter_input("output", parm.output->answers, parm.samplingpos->answers, parm.outfile->answer, &num_outputs);
- if(interpol_method == LINEAR_INTERPOLATION)
- if (num_inputs != 2)
- G_fatal_error(_("You need to specify two input maps for linear interpolation"));
+ start_interpolation(inputs, num_inputs, outputs, num_outputs, interpol_method);
- if(interpol_method == QUADRATIC_INTERPOLATION)
- if (num_inputs != 3)
- G_fatal_error(_("You need to specify three input maps for quadratic interpolation"));
+ exit(EXIT_SUCCESS);
- if(interpol_method == CUBIC_INTERPOLATION)
- if (num_inputs != 4)
- G_fatal_error(_("You need to specify 4 input maps for linear interpolation"));
+struct map_store *get_parameter_input(const char *type, char **map_names, char **positions, char *file, int *number_of_maps)
+ struct map_store *maps = NULL;
+ int max_maps;
+ int num_maps;
+ int num_points;
- inputs = G_calloc(num_inputs, sizeof(struct map_store));
- for (i = 0; i < num_inputs; i++) {
- struct map_store *in = &inputs[i];
- in->name = parm.input->answers[i];
- in->pos = linear_position[i];
- in->pos = quadratic_position[i];
- in->pos = cubic_position[i];
- in->buf = Rast_allocate_d_buf();
- in->fd = Rast_open_old(in->name, "");
- G_verbose_message(_("Reading input raster map <%s> at sample point %g..."), in->name, in->pos);
- /* process the output maps from the file */
- if (parm.file->answer) {
+ /* process the output maps from the infile */
+ if (file) {
FILE *in;
- int max_outputs;
- double left = 0.0;
- double right = 1.0;
- if(interpol_method == LINEAR_INTERPOLATION) {
- left = linear_position[0];
- right = linear_position[1];
- in = fopen(parm.file->answer, "r");
+ in = fopen(file, "r");
if (!in)
- G_fatal_error(_("Unable to open input file <%s>"), parm.file->answer);
+ G_fatal_error(_("Unable to open %s file <%s>"), type, file);
- num_outputs = 0;
- max_outputs = 0;
+ num_maps = 0;
+ max_maps = 0;
for (;;) {
char buf[GNAME_MAX + 50]; /* Name and position */
@@ -193,10 +191,6 @@
if(ntokens > 1) {
name = G_chop(tokens[0]);
pos = atof(G_chop(tokens[1]));
- if(pos < left || pos > right)
- G_fatal_error(_("Wrong sampling point for output map <%s> in file <%s> "
- "near line %i, sampling point must be in between (%g:%g) not: %g"),
- name, parm.file->answer, num_outputs + 1, left, right, pos);
} else {
name = G_chop(buf);
@@ -206,117 +200,177 @@
continue;
if(pos == -1)
- G_fatal_error(_("Missing sampling point for output map <%s>"
+ G_fatal_error(_("Missing point position for %s map <%s>"
" in file <%s> near line %i"),
- name, parm.file->answer, num_outputs);
+ type, name, file, num_maps);
- if (num_outputs >= max_outputs) {
- max_outputs += 100;
- outputs = G_realloc(outputs, max_outputs * sizeof(struct map_store));
+ if (num_maps >= max_maps) {
+ max_maps += 100;
+ maps = G_realloc(maps, max_maps * sizeof(struct map_store));
- p = &outputs[num_outputs++];
+ p = &maps[num_maps++];
p->name = G_store(name);
p->pos = pos;
p->fd = -1;
p->buf = NULL;
+ p->has_run = 0;
+ G_verbose_message(_("Preparing %s map <%s> at position %g"), type, p->name, p->pos);
- if (num_outputs < 1)
- G_fatal_error(_("No raster map name found in file <%s>"), parm.file->answer);
+ if (num_maps < 1)
+ G_fatal_error(_("No raster map name found in %s file <%s>"), type, file);
fclose(in);
else {
- for (i = 0; parm.output->answers[i]; i++)
+ int i;
+ for (i = 0; map_names[i]; i++)
- num_outputs = i;
+ num_maps = i;
- G_fatal_error(_("No output raster map not found"));
+ if (num_maps < 1)
+ G_fatal_error(_("No %s raster map not found"), type);
- for (i = 0; parm.sampoints->answers[i]; i++)
+ for (i = 0; positions[i]; i++)
- num_sampoints = i;
+ num_points = i;
- if (num_sampoints != num_outputs)
- G_fatal_error(_("input= and sampoints= must have the same number of values"));
+ if (num_points != num_maps)
+ G_fatal_error(_("The number of %s maps and %s point positions must be equal"), type, type);
- outputs = G_malloc(num_outputs * sizeof(struct map_store));
+ maps = G_malloc(num_maps * sizeof(struct map_store));
- for (i = 0; i < num_outputs; i++) {
- struct map_store *p = &outputs[i];
+ for (i = 0; i < num_maps; i++) {
+ struct map_store *p = &maps[i];
- p->name = parm.output->answers[i];
- p->pos = (DCELL)atof(parm.sampoints->answers[i]);
+ p->name = map_names[i];
+ p->pos = (DCELL)atof(positions[i]);
p->fd = -1;
p->buf = NULL;
+ p->has_run = 0;
- /* Start the interpolation for each output map */
- G_verbose_message(_("Processing output raster map <%s> at sample point %g..."), outputs[i].name, outputs[i].pos);
- start_interpolation(inputs, num_inputs, interpol_method, &outputs[i]);
+ *number_of_maps = num_maps;
+ return maps;
- /* Close input maps */
- Rast_close(inputs[i].fd);
- exit(EXIT_SUCCESS);
+void start_interpolation(struct map_store *inputs, int num_inputs, struct map_store *outputs, int num_outputs, int interpol_method)
+ int i;
+ struct map_store **inp = (struct map_store**) G_malloc(num_inputs * sizeof(struct map_store*));
+ struct map_store **outp = (struct map_store**) G_malloc(num_outputs * sizeof(struct map_store*));
+ G_verbose_message(_("Start interpolation run with %i input maps and %i output maps"),
+ num_inputs, num_outputs);
+ for(i = 0; i < num_inputs; i++)
+ inp[i] = &inputs[i];
+ for(i = 0; i < num_outputs; i++)
+ outp[i] = &outputs[i];
+ /* Sort input and output pointer by their point position
+ * using brute force. :)
+ selection_sort(inp, num_inputs);
+ selection_sort(outp, num_outputs);
+ if(interpol_method == LINEAR_INTERPOLATION)
+ linear_interpolation(inp, num_inputs, outp, num_outputs);
+ for(i = 0; i < num_outputs; i++) {
+ if(outp[i]->has_run == 0)
+ G_warning(_("map <%s> at position %g was not interpolated. Check the interpolation interval."), outp[i]->name, outp[i]->pos);
-int start_interpolation(struct map_store *inputs, int num_inputs, int interpol_method, struct map_store *out) {
- struct History history;
- int row, i;
- int nrows = Rast_window_rows();
- int ncols = Rast_window_cols();
+void linear_interpolation(struct map_store **inp, int num_inputs,
+ struct map_store **outp, int num_outputs)
+ struct map_store *left;
+ struct map_store *right;
+ struct History history;
+ int interval, l, row;
+ int nrows = Rast_window_rows();
+ int ncols = Rast_window_cols();
+ int start = 0;
- out->fd = Rast_open_new(out->name, DCELL_TYPE);
- out->buf = Rast_allocate_d_buf();
+ if(num_inputs < 2)
+ G_fatal_error(_("At least 2 input maps are required for linear interpolation"));
- /* process the data */
- G_verbose_message(_("Percent complete..."));
+ /* Interpolate for each interval */
+ for(interval = 0; interval < num_inputs - 1; interval++) {
- for (row = 0; row < nrows; row++) {
- G_percent(row, nrows, 2);
+ left = inp[interval];
+ right = inp[interval + 1];
+ left->fd = Rast_open_old(left->name, "");
+ right->fd = Rast_open_old(right->name, "");
+ left->buf = Rast_allocate_d_buf();
+ right->buf = Rast_allocate_d_buf();
- Rast_get_d_row(inputs[i].fd, inputs[i].buf, row);
+ for(l = start; l < num_outputs; l++) {
+ /* Check if the map is in the interval and process it */
+ if(outp[l]->pos >= left->pos && outp[l]->pos <= right->pos) {
+ outp[l]->fd = Rast_open_new(outp[l]->name, DCELL_TYPE);
+ outp[l]->buf = Rast_allocate_d_buf();
- linear_interpolation(inputs, out, ncols);
- /* Add new interpolation methods here */
+ G_verbose_message(_("Interpolate map <%s> at position %g in interval (%g;%g)"),
+ outp[l]->name, outp[l]->pos, left->pos, right->pos);
+ G_verbose_message(_("Percent complete..."));
- Rast_put_d_row(out->fd, out->buf);
+ for (row = 0; row < nrows; row++) {
+ G_percent(row, nrows, 2);
+ Rast_get_d_row(left->fd, left->buf, row);
+ Rast_get_d_row(right->fd, right->buf, row);
- Rast_close(out->fd);
+ interpolate_row_linear(left, right, outp[l], ncols);
+ Rast_put_d_row(outp[l]->fd, outp[l]->buf);
- Rast_short_history(out->name, "raster", &history);
- Rast_command_history(&history);
- Rast_write_history(out->name, &history);
- G_free(out->buf);
+ Rast_close(outp[l]->fd);
+ Rast_short_history(outp[l]->name, "raster", &history);
+ Rast_command_history(&history);
+ Rast_write_history(outp[l]->name, &history);
- return 1;
+ G_free(outp[l]->buf);
+ outp[l]->has_run = 1;
+ start = l;
+ Rast_close(left->fd);
+ G_free(left->buf);
+ Rast_close(right->fd);
+ G_free(right->buf);
/* linear function v = (1 - pos/dist) * u1 + pos/dist * u2
* v -> The value of the output map
- * pos -> The normalized position of the output map (0;1)
+ * pos -> The normalized position of the output map
* u1 -> The value of the left input map
* u2 -> The value of the right input map
* dist -> The distance between the position of u1 and u2
-void linear_interpolation(struct map_store *inputs, struct map_store *out, int ncols)
+void interpolate_row_linear(struct map_store *left, struct map_store *right, struct map_store *out, int ncols)
DCELL v;
DCELL u1;
@@ -325,17 +379,41 @@
int col;
for (col = 0; col < ncols; col++) {
- u1 = inputs[0].buf[col];
- u2 = inputs[1].buf[col];
- dist = fabs(inputs[1].pos - inputs[0].pos);
+ u1 = left->buf[col];
+ u2 = right->buf[col];
+ dist = fabs(right->pos - left->pos);
if(Rast_is_d_null_value(&u1) || Rast_is_d_null_value(&u2)) {
Rast_set_d_null_value(&v, 1);
} else {
- v = (1 - (out->pos/dist)) * u1 + (out->pos/dist) * u2;
+ v = (1 - ((out->pos - left->pos)/dist)) * u1 + ((out->pos - left->pos)/dist) * u2;
out->buf[col] = v;
return;
+ int i, j, b;
+ struct map_store *min;
+ for (i = 0; i < num - 1; i++) {
+ b = i;
+ min = array[b];
+ for (j = i + 1; j < num; j++) {
+ if (array[j]->pos < min->pos) {
+ b = j;
+ min = array[b];
+ array[b] = array[i];
+ array[i] = min;
Modified: grass/trunk/raster/r.series.interpol/r.series.interpol.html
--- grass/trunk/raster/r.series.interpol/r.series.interpol.html 2011-12-31 17:47:30 UTC (rev 50017)
+++ grass/trunk/raster/r.series.interpol/r.series.interpol.html 2011-12-31 23:20:29 UTC (rev 50018)
@@ -2,15 +2,16 @@
<em>r.series.interpol</em>
interpolates new raster maps located temporal or spatial in between existing raster maps.
-The interpolation is performed at specific sampling positions. The sampling position for each output map must be specified.
-Sampling positions are always located in the normalized intervall (0;1).
+The interpolation is performed at specific sampling positions. The sampling position for each output map must be specified,
+as well as the data position of the input maps.
The following interpolation methods are supported.
<ul>
- <li>linear: Linear interpolation. Two input maps are required. The first input map is located at position 0.0, the second input map at position 1.0.
+ <li>linear: Linear interpolation. At least two input maps and data positions are required.
</ul>
<h2>EXAMPLES</h2>
-<p>Interpolate linear three new maps at 3 sampling positions
+<p>Interpolate linear three new maps at 3 sampling positions in the interval (0.0;1.0)
First prepare the input maps:
<br>
@@ -24,16 +25,16 @@
<p>Interpolate
<div class="code"><pre>
-r.series.interpol --o --v input=prec_1,prec_5 output=prec_2,prec_3,prec_4 sampoint=0.25,0.5,0.75 method=linear
+r.series.interpol --o --v input=prec_1,prec_5 datapos=0.0,1.0\
+ output=prec_2,prec_3,prec_4 sampoint=0.25,0.5,0.75\
+ method=linear
</pre></div>
<p>Interpolate using the file option.
First prepare the input file:
<br>
-TMP_FILE=`g.tempfile pid=1`
-cat > "${TMP_FILE}" << EOF
+cat > outfile.txt << EOF
prec_2|0.25
prec_3|0.5
prec_4|0.75
@@ -43,7 +44,7 @@
<p>Interpolate:
-r.series.interpol --o --v input=prec_1,prec_5 file="${TMP_FILE}" method=linear
+r.series.interpol --o --v input=prec_1,prec_5 datapos=0.0,1.0 file=outfile.txt method=linear
</pre></div>
The resulting maps will have the values 200, 300 and 400.
Added: grass/trunk/raster/r.series.interpol/test/infile_2.txt
--- grass/trunk/raster/r.series.interpol/test/infile_2.txt (rev 0)
+++ grass/trunk/raster/r.series.interpol/test/infile_2.txt 2011-12-31 23:20:29 UTC (rev 50018)
@@ -0,0 +1,4 @@
+map_10|10
+map_20|20
+map_30|30
+map_40|40
Added: grass/trunk/raster/r.series.interpol/test/outfile_1.txt
--- grass/trunk/raster/r.series.interpol/test/outfile_1.txt (rev 0)
+++ grass/trunk/raster/r.series.interpol/test/outfile_1.txt 2011-12-31 23:20:29 UTC (rev 50018)
@@ -0,0 +1,9 @@
+prec_2|0.25
+prec_3|0.5
+prec_4|0.75
Added: grass/trunk/raster/r.series.interpol/test/outfile_2.txt
--- grass/trunk/raster/r.series.interpol/test/outfile_2.txt (rev 0)
+++ grass/trunk/raster/r.series.interpol/test/outfile_2.txt 2011-12-31 23:20:29 UTC (rev 50018)
@@ -0,0 +1,6 @@
+map_12|12
+map_14|14
+map_16|16
+map_18|18
+map_25|25
+map_35|35
Added: grass/trunk/raster/r.series.interpol/test/outfile_corrupt.txt
--- grass/trunk/raster/r.series.interpol/test/outfile_corrupt.txt (rev 0)
+++ grass/trunk/raster/r.series.interpol/test/outfile_corrupt.txt 2011-12-31 23:20:29 UTC (rev 50018)
@@ -0,0 +1,3 @@
+prec_2|0.25
+prec_3|0.5
+prec_4
Modified: grass/trunk/raster/r.series.interpol/test/test.r.series.interpol.sh
--- grass/trunk/raster/r.series.interpol/test/test.r.series.interpol.sh 2011-12-31 17:47:30 UTC (rev 50017)
+++ grass/trunk/raster/r.series.interpol/test/test.r.series.interpol.sh 2011-12-31 23:20:29 UTC (rev 50018)
@@ -8,56 +8,49 @@
r.mapcalc --o expr="prec_1 = 100"
r.mapcalc --o expr="prec_5 = 500"
-TMP_FILE_CORRUPT=`g.tempfile pid=2`
+r.mapcalc --o expr="map_10 = 10"
+r.mapcalc --o expr="map_20 = 20"
+r.mapcalc --o expr="map_30 = 30"
+r.mapcalc --o expr="map_40 = 40"
# We create an input files containing empty lines.
# However, r.series.interpol should process the
# valid raster maps and positions listed in the files.
-prec_2|0.25
-prec_3|0.5
-prec_4|0.75
-EOF
-cat > "${TMP_FILE_CORRUPT}" << EOF
-prec_2|0.25
-prec_3|0.5
-prec_4
-EOF
# The first @test with map input and @precision=3
-r.series.interpol --o --v input=prec_1,prec_5 output=prec_2,prec_3,prec_4 sampoints=0.25,0.5,0.75 method=linear
+r.series.interpol --o --v input=prec_1,prec_5 datapos=0.0,1.0 output=prec_2,prec_3,prec_4 samplingpos=0.25,0.5,0.75 method=linear
#r.out.ascii --o input=prec_2 output=test_1_prec_2.ref dp=3
#r.out.ascii --o input=prec_3 output=test_1_prec_3.ref dp=3
#r.out.ascii --o input=prec_4 output=test_1_prec_4.ref dp=3
# The second @test with file input and @precision=3
+r.series.interpol --o --v input=prec_1,prec_5 datapos=0.0,1.0 outfile=outfile_1.txt method=linear
+r.series.interpol --o --v infile=infile_2.txt outfile=outfile_2.txt method=linear
#r.out.ascii --o input=prec_2 output=test_2_prec_2.ref dp=3
#r.out.ascii --o input=prec_3 output=test_2_prec_3.ref dp=3
#r.out.ascii --o input=prec_4 output=test_2_prec_4.ref dp=3
+#r.out.ascii --o input=map_12 output=test_2_map_12.ref dp=3
+#r.out.ascii --o input=map_14 output=test_2_map_14.ref dp=3
+#r.out.ascii --o input=map_16 output=test_2_map_16.ref dp=3
+#r.out.ascii --o input=map_18 output=test_2_map_18.ref dp=3
+#r.out.ascii --o input=map_25 output=test_2_map_25.ref dp=3
+#r.out.ascii --o input=map_35 output=test_2_map_35.ref dp=3
# We need @tests to check the @failure handling, as outputs, file and sampling points
# are not handled by the grass parser
# No outputs
-r.series.interpol --o --v input=prec_1,prec_5 sampoints=0.25,0.5,0.75
+r.series.interpol --o --v input=prec_1,prec_5 datapos=0.0,1.0 samplingpos=0.25,0.5,0.75
# No sampling points
# Output and file at once
-r.series.interpol --o --v input=prec_1,prec_5 file="${TMP_FILE}" output=prec_2,prec_3,prec_4 sampoints=0.25,0.5,0.75 method=linear
+r.series.interpol --o --v input=prec_1,prec_5 datapos=0.0,1.0 outfile=outfile_1.txt \
+ output=prec_2,prec_3,prec_4 samplingpos=0.25,0.5,0.75 method=linear
# Sampling points and file at once
-r.series.interpol --o --v input=prec_1,prec_5 file="${TMP_FILE}" sampoints=0.25,0.5,0.75 method=linear
+r.series.interpol --o --v input=prec_1,prec_5 datapos=0.0,1.0 outfile=outfile_1.txt samplingpos=0.25,0.5,0.75 method=linear
# Wrong input file
-r.series.interpol --o --v input=prec_1,prec_5 file=no_file_there method=linear
+r.series.interpol --o --v input=prec_1,prec_5 datapos=0.0,1.0 outfile=no_file_there method=linear
# Corrupt input file
-r.series.interpol --o --v input=prec_1,prec_5 file="${TMP_FILE_CORRUPT}" method=linear
+r.series.interpol --o --v input=prec_1,prec_5 datapos=0.0,1.0 outfile=outfile_corrupt.txt method=linear
Added: grass/trunk/raster/r.series.interpol/test/test_2_map_12.ref
--- grass/trunk/raster/r.series.interpol/test/test_2_map_12.ref (rev 0)
+++ grass/trunk/raster/r.series.interpol/test/test_2_map_12.ref 2011-12-31 23:20:29 UTC (rev 50018)
@@ -0,0 +1,14 @@
+north: 80
+south: 0
+east: 120
+west: 0
+rows: 8
+cols: 12
+12 12 12 12 12 12 12 12 12 12 12 12
Added: grass/trunk/raster/r.series.interpol/test/test_2_map_14.ref
--- grass/trunk/raster/r.series.interpol/test/test_2_map_14.ref (rev 0)
+++ grass/trunk/raster/r.series.interpol/test/test_2_map_14.ref 2011-12-31 23:20:29 UTC (rev 50018)
@@ -0,0 +1,14 @@
+north: 80
+south: 0
+east: 120
+west: 0
+rows: 8
+cols: 12
+14 14 14 14 14 14 14 14 14 14 14 14
Added: grass/trunk/raster/r.series.interpol/test/test_2_map_16.ref
--- grass/trunk/raster/r.series.interpol/test/test_2_map_16.ref (rev 0)
+++ grass/trunk/raster/r.series.interpol/test/test_2_map_16.ref 2011-12-31 23:20:29 UTC (rev 50018)
@@ -0,0 +1,14 @@
+north: 80
+south: 0
+east: 120
+west: 0
+rows: 8
+cols: 12
+16 16 16 16 16 16 16 16 16 16 16 16
Added: grass/trunk/raster/r.series.interpol/test/test_2_map_18.ref
--- grass/trunk/raster/r.series.interpol/test/test_2_map_18.ref (rev 0)
+++ grass/trunk/raster/r.series.interpol/test/test_2_map_18.ref 2011-12-31 23:20:29 UTC (rev 50018)
@@ -0,0 +1,14 @@
+north: 80
+south: 0
+east: 120
+west: 0
+rows: 8
+cols: 12
+18 18 18 18 18 18 18 18 18 18 18 18
Added: grass/trunk/raster/r.series.interpol/test/test_2_map_25.ref
--- grass/trunk/raster/r.series.interpol/test/test_2_map_25.ref (rev 0)
+++ grass/trunk/raster/r.series.interpol/test/test_2_map_25.ref 2011-12-31 23:20:29 UTC (rev 50018)
@@ -0,0 +1,14 @@
+north: 80
+south: 0
+east: 120
+west: 0
+rows: 8
+cols: 12
+25 25 25 25 25 25 25 25 25 25 25 25
Added: grass/trunk/raster/r.series.interpol/test/test_2_map_35.ref
--- grass/trunk/raster/r.series.interpol/test/test_2_map_35.ref (rev 0)
+++ grass/trunk/raster/r.series.interpol/test/test_2_map_35.ref 2011-12-31 23:20:29 UTC (rev 50018)
@@ -0,0 +1,14 @@
+north: 80
+south: 0
+east: 120
+west: 0
+rows: 8
+cols: 12
+35 35 35 35 35 35 35 35 35 35 35 35
