[GRASS-SVN] r45277 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Feb 1 11:33:32 EST 2011
Author: martinl
Date: 2011-02-01 08:33:32 -0800 (Tue, 01 Feb 2011)
New Revision: 45277
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py
wxGUI: import dialog more flags
(merge r45046 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py 2011-02-01 16:09:49 UTC (rev 45276)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gdialogs.py 2011-02-01 16:33:32 UTC (rev 45277)
@@ -20,7 +20,7 @@
- StaticWrapText
- ImageSizeDialog
-(C) 2008-2010 by the GRASS Development Team
+(C) 2008-2011 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
@@ -930,11 +930,12 @@
class ImportDialog(wx.Dialog):
"""!Dialog for bulk import of various data (base class)"""
- def __init__(self, parent, type,
+ def __init__(self, parent, itype,
id = wx.ID_ANY, title = _("Multiple import"),
style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
- self.parent = parent # GMFrame
- self.importType = type
+ self.parent = parent # GMFrame
+ self.importType = itype
+ self.options = dict() # list of options
self.commandId = -1 # id of running command
@@ -951,7 +952,33 @@
self.list = LayersList(self.panel)
self.list.LoadData()
+ self.optionBox = wx.StaticBox(parent=self.panel, id=wx.ID_ANY,
+ label=_(" Options "))
+ cmd = self._getCommand()
+ task = menuform.GUI().ParseInterface(cmd = [cmd])
+ for f in task.get_options()['flags']:
+ name = f.get('name', '')
+ desc = f.get('label', '')
+ if not desc:
+ desc = f.get('description', '')
+ if not name and not desc:
+ continue
+ if cmd == 'r.in.gdal' and name not in ('o', 'e', 'l', 'k'):
+ continue
+ elif cmd == 'r.external' and name not in ('o', 'e', 'r', 'h', 'v'):
+ continue
+ elif cmd == 'v.in.ogr' and name not in ('c', 'z', 't', 'o', 'r', 'e', 'w'):
+ continue
+ elif cmd == 'v.external' and name not in ('b'):
+ continue
+ elif cmd == 'v.in.dxf' and name not in ('e', 't', 'b', 'f', 'i'):
+ continue
+ self.options[name] = wx.CheckBox(parent = self.panel, id = wx.ID_ANY,
+ label = desc)
self.overwrite = wx.CheckBox(parent=self.panel, id=wx.ID_ANY,
label=_("Allow output files to overwrite existing files"))
self.overwrite.SetValue(UserSettings.Get(group='cmd', key='overwrite', subkey='enabled'))
@@ -994,16 +1021,20 @@
dialogSizer.Add(item=layerSizer, proportion=1,
flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
+ # options
+ optionSizer = wx.StaticBoxSizer(self.optionBox, wx.VERTICAL)
+ for key in self.options.keys():
+ optionSizer.Add(item=self.options[key], proportion=0)
+ dialogSizer.Add(item=optionSizer, proportion=0,
+ flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
- if hasattr(self, "overrideCheck"):
- dialogSizer.Add(item=self.overrideCheck, proportion=0,
- flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=5)
dialogSizer.Add(item=self.overwrite, proportion=0,
+ flag=wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
dialogSizer.Add(item=self.add, proportion=0,
# buttons
@@ -1031,13 +1062,17 @@
dialogSizer.Fit(self.panel)
# auto-layout seems not work here - FIXME
- size = wx.Size(globalvar.DIALOG_GSELECT_SIZE[0] + 175, 400)
+ size = wx.Size(globalvar.DIALOG_GSELECT_SIZE[0] + 225, 550)
self.SetMinSize(size)
self.SetSize((size.width, size.height + 100))
width = self.GetSize()[0]
self.list.SetColumnWidth(col=1, width=width/2 - 50)
self.Layout()
+ def _getCommand(self):
+ """!Get command"""
+ return ''
def OnCancel(self, event=None):
"""!Close dialog"""
self.Close()
@@ -1096,13 +1131,13 @@
self.ogr = ogr
if ogr:
- ImportDialog.__init__(self, parent, type = 'ogr')
+ ImportDialog.__init__(self, parent, itype = 'ogr')
if link:
self.SetTitle(_("Link external vector data"))
else:
self.SetTitle(_("Import vector data"))
else:
- ImportDialog.__init__(self, parent, type = 'gdal')
+ ImportDialog.__init__(self, parent, itype = 'gdal')
if link:
self.SetTitle(_("Link external raster data"))
else:
@@ -1110,10 +1145,6 @@
self.dsnInput = gselect.GdalSelect(parent = self, panel = self.panel, ogr = ogr)
- if not link:
- self.overrideCheck = wx.CheckBox(parent=self.panel, id=wx.ID_ANY,
- label=_("Override projection (use location's projection)"))
if link:
self.add.SetLabel(_("Add linked layers into layer tree"))
else:
@@ -1180,8 +1211,9 @@
if self.overwrite.IsChecked():
cmd.append('--overwrite')
- if not self.link and self.overrideCheck.IsChecked():
- cmd.append('-o')
+ if self.options[key].IsChecked():
+ cmd.append('-%s' % key)
if UserSettings.Get(group='cmd', key='overwrite', subkey='enabled'):
@@ -1192,26 +1224,31 @@
self.OnCancel()
- def OnCmdDialog(self, event):
- """!Show command dialog"""
if self.link:
if self.ogr:
- name = 'v.external'
+ return 'v.external'
else:
- name = 'r.external'
+ return 'r.external'
else:
if self.ogr:
- name = 'v.in.ogr'
+ return 'v.in.ogr'
else:
- name = 'r.in.gdal'
+ return 'r.in.gdal'
+ return ''
+ def OnCmdDialog(self, event):
+ """!Show command dialog"""
+ name = self._getCommand()
menuform.GUI().ParseCommand(cmd = [name],
parentframe = self, modal = True)
class DxfImportDialog(ImportDialog):
"""!Dialog for bulk import of DXF layers"""
def __init__(self, parent):
- ImportDialog.__init__(self, parent, type = 'dxf',
+ ImportDialog.__init__(self, parent, itype = 'dxf',
title = _("Import DXF layers"))
self.dsnInput = filebrowse.FileBrowseButton(parent=self.panel, id=wx.ID_ANY,
@@ -1227,7 +1264,11 @@
self.add.SetValue(UserSettings.Get(group='cmd', key='addNewLayer', subkey='enabled'))
self.doLayout()
+ return 'v.in.dxf'
def OnRun(self, event):
"""!Import/Link data (each layes as separate vector map)"""
data = self.list.GetLayers()
@@ -1242,6 +1283,10 @@
'input=%s' % inputDxf,
'layers=%s' % layer,
'output=%s' % output]
if self.overwrite.IsChecked() or \
